I started getting this message and VCDS does not complete but seems to be stuck continuous loop. A circle symbol stays constant in the dash warning message block. The auto scan below seems lacking in component tests so im guessing its the ABS controller which i replaced once about 5 or more years ago. The brakes feel fine since i had them completely fixed less than 4000 miles ago in 2017. Yes I dont put a lot of miles on my car, but it has just turned 160K miles. If anyone can help I would sincerely appreciate it. Thank you.
Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: Release 18.9.1(x64) Data version: 20190114 DS296.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,19,February,2019,16:17:25:03199
VIN: License Plate:
Mileage: 257880km-160239mi Repair Order:
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Mileage: 257880km-160239miles
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 AN
Component: 2.8L V6/5V G 0050
Coding: 07551
Shop #: WSC 08097
VCID: 6FE32DE12D91733234-513C
16497 - Intake Air Temp. Sensor (G42)
P0113 - 35-10 - Signal too High - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 35-10 - Insufficient Flow - Intermittent
P1602 - 35-10 - Voltage too Low - Intermittent
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-10 - Insufficient Flow - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 AS
Component: AG5 01V 2.8l5V USA 3132
Coding: 00104
Shop #: WSC 05311
VCID: 7EFD00A57AFB0ABAAF-513C
Self-Diagnosis Log
Page 2
VIN: License Plate:
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00021
Shop #: WSC 00028
VCID: 64C952CDF457C06A59-5120
Part No: 6Q0 909 605 B
Component: 03 AIRBAG VW5 0003
Coding: 12339
Shop #: WSC 05311
VCID: 366DD885124B02FA37-4AE6
Address 17: Instruments Labels: 3B0-920-xx2-17.lbl
Part No: 3B0 920 920 B
Component: B5-KOMBIINSTR. VDO V24
Coding: 07265
Shop #: WSC 05311
VCID: 1D3F272997BDB1A2D6-513C
Part No: 6N0 909 901
Coding: 00005
Shop #: WSC 05314
VCID: 70E12E9D30AF6CCA2D-513C
Self-Diagnosis Log
Page 3
VIN: License Plate:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 6W Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 05311
VCID: 060D6845222B527AE7-4B18
Subsystem 1 - Part No: 1J1959801D
Component: 6W Tõrsteuerger. FS0002F
Subsystem 2 - Part No: 1J1959802E
Component: 6W Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811D
Component: 6W Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812D
Component: 6W Tõrsteuerger. HR0002H
35-00 - -
01358 - Internal Central Locking Switch; Driver Side (E150)
00912 - Window Regulator Switch; Front Left (E40)
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 B
Component: Radio DE2 0003
Coding: 04041
Shop #: WSC 05311
VCID: 1E3D20259ABBAABACF-51B2
End-------------------------(Elapsed Time: 04:07)--------------------------
