Hi guys
Originally this car was installed with a RNS-D, but a previous owner has ripped this out and put in a Android unit which I didn´t like at all. I have now retrofitted a RNS-E, and after some challenges, everything is now working fine. Info from the unit to the DIS, illumination in the buttons, turns on and off with the ignition. All seem to work (almost) fine. However, the VDCS log lists a number of faults for the navigation unit, and the radio reception (FM) is very poor. Any ideas from you will highly appreciated. I tried with a small separate antenna amplifier which made the reception better, but if possible I would like to use the original one.
Does the log indicate that the antenna amplifier doesn´t get any power? If so how / which pin should be used for this?
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
Component: RNS-E HIGH EU H74 0650
Revision: 05S Serial number: AUZBZ7G1164583
Coding: 0509155
Shop #: WSC 45503 002 104857
VCID: 353723FAF95F6E8F7DD-513C
8 Faults Found:
00856 - Radio Antenna
Reset counter: 129
Date: 2013.01.21
Time: 12:05:12
Mileage: 655350 km
Count: 65535
Clock: 255:255
Reset counter: 99
Date: 2013.01.20
Time: 11:30:02
Mileage: 655350 km
Count: 2001
Clock: 11:29
Coding: 0509155
8 Faults Found:
Reset counter: 129
Date: 2013.01.21
Time: 12:05:12
Mileage: 655350 km
Count: 65535
Clock: 255:255
Reset counter: 99
Date: 2013.01.20
Time: 11:30:02
Mileage: 655350 km
Count: 2001
Clock: 11:29
