Possible to find tweaks on audi A8 2012
vagcom pro
Verified VCDS-User
C?ID=342235
HI
Just for reference i am posting the auto scan for audi a8 2012 possible to know what sort of tweaks are available as i cant see much online
Saturday,19,January,2019,18:17:19:22147
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUZZZ4H6DN007736   License Plate:
Mileage: 180955km-112440mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 11 31 15 16 17 19 22 28 30 34 36 3B
          42 46 47 48 52 53 55 56 57 5B 5F 62 6C 6D 6F 72 81 85 88 89
          8A 8D 8F 90
VIN: WAUZZZ4H6DN007736   Mileage: 180955km-112440miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CDSB)       Labels:. 057-907-409-CKD.clb
   Part No SW: 4H0 907 409 B    HW: 4H0 907 409 B
   Component: 4.2TDI EDC17  X38 0002
   Revision: 55X38---
   Coding: 0A2A4012052601020800
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM42TDI1114H0907409B 001007
   ROD: EV_ECM42TDI1114H0907409B.rod
   VCID: 2B0304AEB380586F1B9-807E
          U1113 00 [032] - -
   Part No SW: 4H1 927 158 AS    HW: 0BL 927 156 H
   Component: 0BL 42 TDIRdW H16 1006
   Revision: --H16---
   Coding: 000001
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011.rod
   VCID: 015F8606618C623F915-8054
8724 - Park-Lock
          P17F9 00 [032] - Mechanical Malfunction
                    Mileage: 178165 km
                    Date: 2019.01.03
                    Time: 15:00:12
                    Unlearning counter according OBD: 20
                    Voltage terminal 30: 13.187 V
                    Engine speed: 0 /min
                    Transmission input speed: 14.00 /min
                    Transmission fluid temperature: 88 °C
                    Transmission output speed: 0.00 /min
                    Transfer speed from ESP: valid
                    Transfer speed from ESP: 0.00 km/h
   Part No SW: 4H0 907 379 D    HW: 4H0 907 379 D
   Component: ESP PREMIUM   H10 0352
   Coding: E4EDE30027B7C700E300
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 33331CCE6BB000AF539-8066
0694 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Fault Frequency: 10
                    Reset counter: 45
                    Mileage: 177729 km
                    Date: 2019.01.02
                    Time: 00:05:44
                    VzRef: 42
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 06
                    Bit Info 4: 12
                    F-Path: 47
                    F-Type: 0D
                    Uz: B5
   Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 CB
   Component: BCM2 2.0      H32 0510
   Coding: 05B72F46000000000000
   Shop #: WSC 08794 001 1048576
   VCID: 6C81C7B2768E9F57523-8038
   Serial number: 2312000137515008
   Revision: AA000000    Serial number: 00000033901588
   Coding: 0038B60000047201000001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 34311FD26E3E07974A3-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 G    HW: 4H0 820 043 G
   Component: Klima 4 Zonen H20 0120
   Coding: 382102BE3C
   VCID: 2411EF92DE5E9717DA3-8070
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001546930
   Coding: 0200201050B49FE1EB810007A0001908009DC30A0F000101800008406100
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110529  H35 0080
   Serial number:         120124222047
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 10266935
   Coding: 025523
   Component: E1 - LDS  H07 0044
   Serial number: 20 06 2012  00001547
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103815000001527535
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 68288636000000000001
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061218601045
   Coding: 280302
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   VCID: 77ABE8DE3F482C8FAF1-8022
1112068 - Front Left Center Parking Aid Sensor
          B10F8 04 [008] - Internal System Fault
                    Reset counter: 152
                    Mileage: 166445 km
                    Date: 2018.10.28
                    Time: 22:06:32
Address 11: Engine II (J624)       Labels: None
   Component: 4.2TDI EDC17  H38 0002
   Revision: 55H38---
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM42TDI2114H0907409B 001007
   ROD: EV_ECM42TDI2114H0907409B.rod
   Revision: --------    Serial number: 003JG00985S2
   Coding: 30314246323430303038554A305234483053
   VCID: 363525DA78C21587747-8062
   Serial number: 3575HRB40691E4S2318Q
   Serial number: 3585HRB405L1F0BC8HIG
   Serial number: 3515JRB400E4UHL6Q1VA
   Serial number: 3525JRB400A4UHL6E9S0
   Serial number: 3554VRB400E4UI5EK9SH
   Serial number: 3564VRB400E4UI5EEPMM
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90815LFR0007O
   Coding: 000034
   VCID: 372B28DE7F48EC8F6F1-8062
   Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
   Component: E221 - MFL  H09 0009
   Serial number: 13 04 2012  B1046954
   Part No SW: 4H0 920 910 K    HW: 4H0 920 910 K
   Component: TDieGB------- H71 0515
   Revision: 35081077    Serial number: 658200612592053
   Coding: 33A608009B402600010000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   VCID: 2C0107B2B68E5F57123-8078
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Component: Analoguhr D4  H05 0224
   Serial number: 1120622000735
   Part No SW: 4H0 907 468 AB    HW: 4H0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000586243
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 71BFD6C6512C72BF615-8024
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970710063
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 12179001258021200410
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 002206120001067
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 270BF89EAF687C0FFF1-8072
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H16 0120
   Coding: 2800000000
   ROD: EV_AirCondiHeck.rod
   VCID: 313F16C691AC32BF215-8064
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000031292
   Coding: 01010101000000000001000202
   VCID: 6491AF929E5ED7171A3-8030
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050DBA80922D473C7-807A
          C10C8 00 [008] -  -
                    Reset counter: 28
                    Mileage: 178165 km
                    Date: 2019.01.03
                    Time: 14:57:45
   Revision: AA000000    Serial number: 00000048945238
   Coding: 0038BF8000857201020001010101112131313333203333
   Shop #: WSC 71976 210 82617
   Part No SW: 4H0 907 637 L    HW: 4H0 907 637 G
   Component: SARA 6D red   H02 0053
   Revision: --------    Serial number: EJ1BPA71000XVN
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   VCID: 38292BE272D6E3F766B-806C
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0263
   Revision: --------    Serial number: 0000128767254
   Coding: 011F1E005E0162C202083006
   Shop #: WSC 02312 785 00200
   VCID: 48C95B2202B6937716B-801C
   Revision: 00002001    Serial number: 0178417853
   Coding: 011B0E2200B93D85B320C7C40A03010F0000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H07 0006
   Serial number:     WOO16815050
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H11 0080
   Serial number: A2012000000000591393
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS010  H05 0005
   Serial number:     WOO1000QDGU
   Subsystem 6 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84271468
03634 - Switch for Window Shade Illumination; Front
                    Fault Status: 00101100
                    Reset counter: 45
                    Mileage: 165763 km
                    Date: 2018.10.25
                    Time: 22:27:45
                    Fault Frequency: 14
                    Reset counter: 16
                    Mileage: 173092 km
                    Date: 2018.12.01
                    Time: 09:32:37
02201 - Trunk / Luggage Compartment Closing Assist; Position - Unlocked (F332)
                    Reset counter: 24
                    Mileage: 177904 km
                    Date: 2019.01.02
                    Time: 01:50:30
02202 - Trunk / Luggage Compartment Closing Assist; Position - Locked (F332)
                    Reset counter: 24
                    Mileage: 177904 km
                    Date: 2019.01.02
                    Time: 01:50:34
   Revision: CJ007001    Serial number: 00000000067219
   Coding: 030000
   VCID: 1D67DA76FDB4A6DF95D-8048
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000014431853
   Coding: 003892800000700D0A00392038193A2039203B3B202020
   VCID: 71BFD6C651AC72BF615-8024
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000128770954
   VCID: 3C2137F2466ECFD7823-8068
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000395839
   ROD: EV_ParkiBrake_VW51.rod
721152 - Brake pad replacement mode active
          C1011 00 [000] -  -
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 120627-0004-028
   Coding: 11116F33F918EB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 323D19CA94AA09A758F-8066
H02 0009
   Coding: 1A0000
H02 0009
   Coding: 1A0000
   Part No SW: 4H0 035 061 E    HW: 4H0 035 061
   Component: Radio U DAB   H60 0099
   Revision: AB001007    Serial number: 440FV0C7516065
   Coding: 010103010000000001
   VCID: 2019E382CAC68B37BEB-8074
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 A    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0510
   Revision: R0043000    Serial number: 06801100667301
   Coding: 03000000
   VCID: 2B0304AEB300586F1B9-807E
02283 - Video Connection to Output [End Unit]
                    Fault Status: 00101010
                    Reset counter: 18
                    Mileage: 173298 km
                    Date: 2018.12.03
                    Time: 09:25:42
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000014816433
   Coding: 003896800000700D0A00392038193A2039203B3B382020
   Part No SW: 4H0 035 670 N    HW: 4H0 035 670 N
   Component: H-BNT-EU      H44 0526
   Revision: --------    Serial number: 179G+0C7502573
   Coding: 020101000001F1EF45908B1E00000003000001000000000000
   VCID: 2F3B10BE8718244F371-807A
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4H0 919 604 F    HW: 4H0 919 604 F
   Component: DU8 D4 SV NB  H47 0021
   Serial number: AUZ8ZDC9300QP1Z
   Subsystem 3 - Part No SW: 4H2 919 600 H    HW: 4H2 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000086667
   Component: CD-Database  3638
03787 - Rotation Mechanism for Display Module Front
                    Fault Status: 00100011
                    Fault Frequency: 21
                    Reset counter: 44
                    Mileage: 176814 km
                    Date: 2018.12.23
                    Time: 17:16:15
                    Voltage: 12.40 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000128548777
   Coding: 010F1E00420062C202083006
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Revision: --H06---    Serial number: 525 PA8J25D2IF
   Coding: 1082003
   VCID: 2615F59AA4E26507C47-8072
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 172200594
   Coding: 0210044000
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D273AF65DF4C6DFB5D-8068
0051 - Hall Sensors in Motor 1 for Rear Lid
          B1211 12 [008] - Short to Plus
                    Fault Frequency: 58
                    Reset counter: 32
                    Mileage: 158226 km
                    Date: 2018.04.26
                    Time: 12:30:56
                    Voltage terminal 30: 11.56 V
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Revision: --------    Serial number: 000000079301
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393AC8E9BD0D02FE39-8036
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000128773510
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H08 0083
   Revision: 0R0D5014    Serial number: SN120516  0079
   ROD: EV_GSM2x3Mono.rod
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: E4040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F59AA8626507C47-8072
   Serial number: 00006523079102
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3B10BE8798244F371-807A
   Serial number: 00006523105502
   Coding: 272FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00006527100801
   Coding: 212F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00006527105102
   Coding: 212F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:12, VBatt start/end: 12.0V/12.0V)-----------
Is there anything in particular you wish to do?
