Results 1 to 6 of 6
Thread: VW passat in limp mode
    Verified VCDS-User
    Sep 2018
    Exclamation VW passat in limp mode
    Hi I need help i came across vw passat B7 with plenty of errors car is in limp mode and according to owner it has egr and dpf delete all the work was done by some one else who claims that they know everything but i am not sure about that any help will be appreciated as where to start with the thing i dont understand is if egr is deleted why its still showing the egr error?
    	Sunday,17,February,2019,22:23:41:22147
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVWZZZ3CZAP064800   License Plate:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77 7D
    37-Navigation -- Status: Not registered 0011
    77-Telephone -- Status: Not registered 0001
    7D-Aux. Heat -- Status: Cannot be reached 1100
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 019 AD    HW: 03L 907 309 F
       Component: R4 2,0L EDC G000SG  5875
       Revision: 22H30---    Serial number: VWZCZ000000000
       Coding: 0001072
       Shop #: WSC 00999 444 64523
       VCID: 6D87CAB64194965F45D-8038
    6 Faults Found:
    009254 - Exhaust Gas Recirculation Cooling Valve Control Circuit
                   P2426 - 000 - Short to Ground - MIL ON
                        Fault Status: 11100000
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:30:29
                        Temperature: 24.3C
                        Absolute Pres.: 989.4 mbar
                        (no units): 856.8
                        (no units): 3.97
                        Temperature: 49.5C
    000071 - Boost Pressure Control Valve/Solenoid (Bank 1)
                   P0047 - 000 - Short to GND - MIL ON
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:00:32
                        Load: 9.8 %
                        Lambda: 13.4 %
                        Temperature: 24.3C
    049478 - No Communication with Diagnostic Gateway
                   U0146 - 000 -
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:00:32
                        Temperature: 9.9C
                        Voltage: 12.08 V
                        Bin. Bits: 00000000
                        Torque: 219.0 Nm
                        Temperature: 23.4C
    009754 - Coolant Pump 2
                   P261A - 000 - Open circuit - MIL ON
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:00:34
                        Voltage: 12.08 V
                        Lambda: 79.7 %
                        Bin. Bits: 10011110
                        Count: 1
                        Temperature: 25.2C
    000260 - Mass Air Flow Sensor (G70)
                   P0104 - 000 - Intermittent - MIL ON
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:04:59
                        RPM: 667 /min
                        Voltage: 11.70 V
                        Load: 100.0 %
                        Load: 100.0 %
                        Mass Air / Rev.: 710.0 mg/str
                        Mass Air / Rev.: 1275.0 mg/str
    009756 - Coolant Pump 2
                   P261C - 000 - Short to GND - Intermittent
                        Mileage: 276592 km
                        Date: 2032.14.21
                        Time: 14:43:02
                        RPM: 943 /min
                        Speed: 5.0 km/h
                        Voltage: 13.91 V
                        Lambda: 79.7 %
                        Bin. Bits: 10011111
                        Temperature: 52.2C
    Readiness: 1 4 0 0 1
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AH    HW: 3C0 614 109 AH
       Component: J104    C4 440 V2   0024
       Revision: --026---    Serial number: 00000705936964
       Coding: 0036347
       Shop #: WSC 00028 790 00002
       VCID: 6491AF92925ED7171A3-8030
    Address 08: Auto HVAC
       Part No SW: 3C8 937 049 AA    HW: 3C8 937 049 AA
       Component: Bordnetz-SG     H57 3204
       Revision: 00H57000    Serial number: 00000004071009
       Coding: 00908F0700041A00470A00000F000000000059435C000100000308000000
       Shop #: WSC 00028 028 00001
       VCID: 70B9D3C256A67BB76EB-8024
       Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 280710 026  0612
       Coding: 00046997
       Shop #: WSC 00028
                        Fault Frequency: 9
                        Reset counter: 52
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:31:01
                        Voltage: 12.50 V
    00483 - Control Module for Auxiliary Air Heater
                        Reset counter: 52
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:31:01
                        Voltage: 12.50 V
    03789 - Terminal 75 Limp Mode Active
                        Fault Frequency: 10
                        Reset counter: 52
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:34:01
                        Voltage: 14.10 V
       Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
       Component: J234__006 VW10 HI   1916
       Revision: 21014000    Serial number: 003GHPEF2X1/
       Coding: 0012342
       VCID: 48C95B220EB6937716B-801C
       Subsystem 1 - Serial number: 6332MTS673951950
       Subsystem 2 - Serial number: 6342MTS618361880
       Subsystem 3 - Serial number: 6351HTS609D4D6KJ
       Subsystem 4 - Serial number: 6361HTS6LMU1D6KR
    Address 16: Steering wheel
    Address 17: Instruments
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C06522156A
       Coding: 3DFD2C04C21003
       VCID: 211FE686CDCC823FB15-8074
                        Reset counter: 51
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:31:34
                        Reset counter: 51
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:31:35
                        Reset counter: 51
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:31:38
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       Shop #: WSC 00137 211 56823
       VCID: 7AADF1EA00DA31E7D0F-802E
    Address 37: Navigation
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 195    3001
       Revision: 00H17000
       VCID: 313F16C69D2C32BF215-8064
       Component:    KSG PQ46 ELV 043 0612
       Coding: 01910A0001860E763004941570085FCE107C01
       Shop #: WSC 12345 123 45725
       Subsystem 1 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HORN H11 9004
    01134 - Alarm Horn (H12)
                        Reset counter: 51
                        Mileage: 276590 km
                        Date: 2032.14.21
                        Time: 14:33:47
                        Reset counter: 91
                        Mileage: 276592 km
                        Date: 2032.14.21
                        Time: 14:43:09
                        Reset counter: 91
                        Mileage: 276598 km
                        Date: 2032.14.21
                        Time: 15:23:03
    Address 52: Door Elect, Pass.
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   011       Serial number: 00000000351227
       Coding: 0000056
       VCID: 2C0107B2BA0E5F57123-8078
    Address 56: Radio
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000A07957351
       Coding: 012120
       VCID: 2A0D01AABCFA4167E0F-807E
    Address 7D: Aux. Heat
    End----------(Elapsed Time: 03:14, VBatt start/end: 13.9V/13.9V)-----------
    Sep 2014
    From your scan, I would say the EGR valve is still present and faulty. It may be that the car has been flashed to not use the EGR value but it is still physically fitted to the car and looks to have developed a short circuit.
    Unless it has been removed and the wiring hacked-up as there seem to be a number of electrical wiring issues here.
    Nov 2017
    Latvia
    Could you explain this?
    Norristown, PA
    Limp mode likely caused by MAF and boost controller errors.
    Check the wiring at the boost controller. The wires like to break under the boot at the connector.
    Verified VCDS-User
    Sep 2018
    Thank you for replies I will keep you all updated thanks again
    Quote Originally Posted by _Val View Post
    4 Fault codes, 2 Intermittent does not count here.
  7. Likes _Val liked this post
