I have a fault with transmission neutral switch fault. found out garage put a replacement gearbox which does not have this switch, is there anyway to code out this or remove it. thanks.
scan attached
scan attached
Saturday,16,February,2019,13:21:56:42542
VCDS Version: 18.9.1.0
VIN: WVWZZZ13ZCV038650 License Plate: SC12XBW
Mileage: 138440km-86022mi Repair Order: SCIRROCO.GOOD
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 14 15 16 17 19 25 2E 37 42 44 46 52 56 61
VIN: WVWZZZ13ZCV038650 Mileage: 138440km-86022miles
Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 GF HW: 03L 907 309 N
Component: R4 2.0l TDI X27 9979
Revision: 41X27--- Serial number:
Coding: 00190012040501080000
Shop #: WSC 77021 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018GF 003010
ROD: EV_ECM20TDI01103L906018GA.rod
VCID: 74E70D75DF1D01EAC9-8020
10092 - Unknown Error Code
P086D 00 [039] - -
Mileage: 138449 km
Date: 2019.02.16
Time: 23:18:40
Coolant temperature: 34 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.000 V
Neutral position sensor: current transmission angle: 20.00 °
Neutral position sensor: adapted transmission angle: 0.00 °
Transmission neutral position sensor voltage: 0 mV
selected gear-Bits 0-7: 0
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 763B40F5492580026E1102E992190192350000
Shop #: WSC 00020 790 00000
VCID: 7BF52649FA434E9288-802E
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004003
Shop #: WSC 00020 999 00000
VCID: 000F51A59BA52D4ADD-8054
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0064
Revision: BC021001
Coding: 48180A388025E100408800C4340001644B513B88436D85605C8087000041
VCID: 3E73EF5DA9D19BBAEF-806A
Subsystem 1 - Part No SW: 1K8 955 119 G HW: 1K8 955 119 G Labels: 1KX-955-119.CLB
Component: Wischer 27011 10 0603
Coding: 009795
Component: RLS 170412 05 54 0403
Coding: 0230ED
Component: LIN BACKUP HO H11 9005
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 22
Mileage: 138449 km
Date: 2013.07.09
Time: 23:18:41
Voltage: 11.85 V
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Revision: 00000000 Serial number: 16041203450001
Coding: 000180
VCID: 275D2A39564B3A72BC-8072
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0H AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D04UEG8
Coding: 0012360
VCID: 6FED02197E3B223234-803A
Subsystem 1 - Serial number: 6332MSME6D6143105
Subsystem 2 - Serial number: 6342MSME6D256F51P
Subsystem 3 - Serial number: 6352QSME6D121E60K
Subsystem 4 - Serial number: 6362QSME07131B72A
Part No SW: 5K0 953 521 BM HW: 5K0 953 569 D
Revision: FF010041 Serial number: 20120425200774
Coding: 1082040000
ROD: EV_SMLSNGVOLWS.rod
VCID: 78FF3945C375658AE5-802C
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Coding: 820000
Part No SW: 1K8 920 973 A HW: 1K8 920 973 A
Component: KOMBI H03 0607
Coding: 470B01
VCID: 3365CE699A9346D210-8066
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 240412F1002532
Coding: 354001
VCID: 3B75E649BAC38E92C8-806E
Component: IMMO H03 0607
VCID: 6ADB130D8DD9C71A63-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662352823
Coding: 020000
VCID: 29592C01405F0C02AA-807C
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 H HW: 3C0 035 279 H
Component: RNS315-EU H36 0263
Serial number: VWZAZ2M3993672
Coding: 040004110400040000009002
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 285F29055355350AB5-807C
Component: EUR_W_0038 0038
1048600 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 22
Mileage: 138449 km
Date: 2019.02.16
Time: 23:18:43
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2130
Coding: 0148021
VCID: 3979FC4170FFBC82DA-806C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 178 3305
Revision: 00H22000
VCID: 377DFA7946EBAAF22C-8062
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0148020
VCID: 3A7BE34D75F9B79AD3-806E
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: 030F1859
VCID: 71E90461A80F34C222-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900163182
End-------------------------(Elapsed Time: 02:56)--------------------------
