A4 B8 LED Euro Spec Retrofit
Planekiller1
Miami, Fl
C?ID=317931
Waiting for full verification so I'll get the ball rolling here and hopefully a moderator can approve me and move this to Retrofits.
So far I've bought the set from ECS tuning and fit them to make sure they will work.
I've 3d printed new connectors and added terminals to each for the new lights.
Next question I have is wiring in the new seperate turn signal which will now be amber.
Here is a list of my pins vs the old and the current coding following.
My question thus far is what coding needs to be changed and what pin from the 46 control module needs to be added to gian the turn signals.
I checked this side using a 12v battery and working out what each connector linked up to bulb wise.
Left Main
1 Grey / Black - Brake / Turn
2 Black - Reverse
3 Green - Sidelight
4 Brown - Ground
Left Inner
1 Blue / Black - Rear Fog
2 Brown - Ground
3 Gray - Sidelight
4 Yellow / Grey - Sidelight
(Both sidelights are independent bulbs left and right bulbs).
I have not checked exactly what the right side does because I assumed it was the same as the other side but I am unsure now.
Right Inner
1 White / Grey
2 Brown
3 Grey
4 Blue / Grey
Right Main
1 Brown
2 Yellow / Brown
3 White / Black
4 Green / Black
Coding:
195-14848
196-14881
197-13320
198-13352
203-14849
204-14881
205-13
206-45
207-73
208-105
209-51202
210-51234
211-51214
212-51215
213-16689
214-3
Thanks,
Kurt
PetrolDave
Westbury, UK
C?ID=1423
Gonna need you to post a full Auto-Scan to be able to advise on coding changes...
Planekiller1
Miami, Fl
C?ID=317931
Saturday,22,September,2018,23:40:57:23117
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: xxxxx965   License Plate:
Mileage: 115020km-71470mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
          6D 72 77
VIN: WAUWFBFL3CA048965   Mileage: 115020km-71470miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H20 0002
   Revision: E1H20---
   Coding: 010C010A290F0160
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74B2D403AE3E8B7765F-8021
4007 - Idle Control System RPM
          P0507 00 [096] - Higher than Expected.
                    Mileage: 114943 km
                    Date: 2018.09.20
                    Time: 21:23:00
                    Engine speed: 818.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 93 ∞C
                    Intake air temperature: 42 ∞C
                    Voltage terminal 30: 13.711 V
   Part No SW: 8K0 927 158 S    HW: 0BK 927 156 R
   Component: 0BK 20TFSIUSA H08 1003
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 46D65ECB882249E70BB-8013
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 1D0D18
   VCID: 025E82DBE40AB5C7673-8057
   Part No SW: 8K0 907 064 CH    HW: 8K0 907 064 CH
   Component: BCM2 2.0      H05 0435
   Coding: 0D0200
   Shop #: WSC 06335 000 00000
   VCID: 78AAE033B2D6EF17497-802D
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 2311000172027002
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01210820111931
   Coding: 64002000
   VCID: 005A88D3EA06A7D7717-8055
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000001190065
   Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000
   VCID: 3C223C23C66E03376DF-8069
   Component: WWS 170811  H07 0070
   Serial number: SWF11080175160
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11619924
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001408110257
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
                    Fault Status: 00101100
                    Reset counter: 142
                    Mileage: 115029 km
                    Date: 2018.09.22
                    Time: 23:03:00
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0NXC0Z
   Coding: 303937354230303030304A55304C384B3053
   VCID: 45D459C7B52442FF021-8011
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1100005ZT2
   Serial number: 6334MSME63037052%
   Serial number: 6344MSME63037566A
   Serial number: 6352QSME705A0248D
   Serial number: 6362QSME725C1476M
   Serial number: 63732SME535A287EA
   Serial number: 63832SME005B4A760
   Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20110824000578
   Coding: 000037
   Shop #: WSC 06335 123 12345
   VCID: 49CC55F799BCA69FE69-801D
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 950 H    HW: 8K0 920 950 H
   Component: KOMBIINSTR.   H20 0258
   Revision: 00300000    Serial number: EIL24F18C
   Coding: 831F11000300D705020000
   VCID: 34321403EE3ECB77A5F-8061
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G118098761
   Coding: 00C303
   VCID: 015C8DD7E10CAEDF7E9-8055
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H07 0170
   Serial number: 110302CC100811
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392C2537C95C361F769-806D
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00000011870991
   Coding: 00581B00000000000000
   VCID: 3B203F3FC360040F645-806F
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000118938504
   Coding: 011C13204E00410001
   VCID: 4ACE6AFB9CBAAD87EF3-801F
   Revision: 00002001    Serial number: 0154859572
   Coding: 0126063A20BA741580B0023200000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000427646
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS137  H07 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS229  H07 0041
                    Fault Status: 00101001
                    Reset counter: 142
                    Mileage: 113347 km
                    Date: 2018.09.03
                    Time: 11:20:07
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
   Component: DSP STD       H11 0460
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 303A18131A26F757C17-8065
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000118703953
   Revision: 00000003    Serial number: 20000000083445
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 392C2537C55C361F769-806D
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000011    Serial number: AUZ5Z6K1635983
   Coding: 04020002010285004BD9070802
   VCID: 46D65ECB88A249E70BB-8013
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
                    Reset counter: 45
                    Mileage: 113333 km
                    Date: 2018.09.01
                    Time: 22:22:33
            000 -  -  - Intermittent
                    Fault Frequency: 35
                    Reset counter: 142
                    Mileage: 113347 km
                    Date: 2018.09.03
                    Time: 11:50:58
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000012126278
   Coding: 010C13204000210001
   VCID: 45D459C7B5A442FF021-8011
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Revision: --------    Serial number: 8K9827851A
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Serial number: 8K9827852A
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000012126533
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005239488
   Coding: 0010370
   VCID: 3E26362BDC72112743B-806B
End----------(Elapsed Time: 01:47, VBatt start/end: 12.6V/12.2V)-----------
Planekiller1
Miami, Fl
C?ID=317931
Hope that's what your looking for, thanks for the help
Verified. Moving to Retrofits.
myounus
Northwest UK
C?ID=321059
Hi
Have you purchased OEM lights or aftermarket ones? If it's the latter then usually they done need coding.
I'm also a little concerned about your comments of 3D printing new connectors and adding terminals. What specifically are you trying to achieve?
Planekiller1
Miami, Fl
C?ID=317931
Hi
Have you purchased OEM lights or aftermarket ones? If it's the latter then usually they don't need coding.
Not sure why you are concerned with the connectors I live in Florida and don't have the issues associated with corrosion up North in the US. I've printed the connectors already and they fit snug and work really well. As for programming and wiring I will 100% have to reprogram and rewire the tails as the US spec lights don't have amber turns as the Euro Spec do. The lights I ordered are from Germany, not after market they have rebranded OEM Euro Spec tails.
As for what I'm trying to achieve well that's simple a cheap easy way to change the lights from US spec to Euro Spec trying to find the connectors I have was nearly impossible and the site I found them on it would take almost 3 months to get to me. So I took the short cut and designed the connectors in CAD and ordered the terminals, fitted last week and tested with a 12v battery and they work great and don't come out unless you pull really hard will post pictures of that later once I've completed this retrofit.
There is a thread on audizine that walks people through this retrofit however the lights and connectors are slightly different so I just wanted to confirm the exact coding needed. Talked it through with someone over there and cleared it up was hoping to find some answers over here before they responded.
Thanks for the help,
Kurt
That's certainly not true for all of Florida. If you're close enough to the ocean, it can be far worse for corrosion than the northern parts of the US.
PetrolDave
Westbury, UK
C?ID=1423
Anywhere liable to salt water spray (whether from the sea or from salted roads), regardless of the temperature, is seriously bad news for electrical connections.
Planekiller1
Miami, Fl
C?ID=317931
Ok well set the corrosion issue aside the connectors that are 3d printed are sealed so it's unlikely to present an issue however I'll check them in 6 months and get back to you and would we mind focusing on the main issue in this thread the coding changes needed.
Right now all the lights are working as requested but that's only because I turned 181 to 0 which inhibits bulb detection and errors on the dash. This also solved the blinker only doing one cycle then turning off So all the lights are working however the errors are still hidden behind the scene.
