2006 Audi A6 Avant Startup/Transmission Issues
cdheikkila
C?ID=352193
I recently have been having some issues with a slow/rough cold start on my car. This has been a very consistent issue. I discovered that I have two sensors on the same bank that seem to be faulty, could this be causing the issue? My next question would be asking for suggestions on replacing them for cheap. I am not familiar with locations of these sensors on the car, and so I am wondering whether this is a DIY job, or something I should bring in to the shop. Any input is appreciated!
Thanks!
Tuesday,05,February,2019,16:37:06:55997
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUKG74F76N063701   License Plate: BLF8681
Mileage: 276110km-171566mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUKG74F76N063701   Mileage: 276110km-171566miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0030
   Revision: --H15---    Serial number:
   Coding: 0000000000000000
   Shop #: WSC 22162 444 53437
   VCID: 2B0305BDFF089B8F1BF-807E
000342 - Oxygen (Lambda) Sensor B2 S2
               P0156 - 007 - Malfunction in Circuit - Intermittent
                    Fault Status: 00000010
                    Reset counter: 29
                    Mileage: 275979 km
                    Date: 2019.01.31
                    Time: 13:02:56
                    RPM: 672 /min
                    Mass Air / Rev.: 109.0 mg/str
                    Temperature: 85.5∞C
                        Idle
                    Load: 16.9 %
000310 - Oxygen (Lambda) Sensor B1 S2
               P0136 - 007 - Malfunction in Circuit - Intermittent
                    Reset counter: 29
                    Mileage: 275979 km
                    Date: 2019.01.31
                    Time: 13:03:01
                    RPM: 704 /min
                    Temperature: 85.5∞C
                        Idle
                    Load: 15.7 %
   Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0030
   Revision: --H01---    Serial number:        4068051
   Shop #: WSC 02327 785 00200
   VCID: 313F17D5DD24F15F213-8064
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0020895
   VCID: 2D070BA5C11C95BF05B-8078
   Component: FBSAUDIC6 ELV   H31 0240
   Revision: 07020801    Serial number: 10600600229680
   Coding: 0000143
   Shop #: WSC 22162 444 84622
   VCID: 6393AD9DD75813CFE3F-8036
   Component: FBSAUDIC6 KSG   H26 0080
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H44 0060
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 00101011
                    Reset counter: 215
                    Mileage: 275138 km
                    Date: 2019.01.08
                    Time: 20:34:56
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 303HJ057505560
   Coding: 0001003
   Shop #: WSC 02335 785 00200
   Component: Bedienteil MMIC6H07 0050
   Subsystem 2 - Serial number: 00000000208947
   Subsystem 3 - Serial number: 0129.07.050000000100010125ˇ
   Subsystem 4 - Serial number: 010125ˇ
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 61
                    Mileage: 273062 km
                    Date: 2018.11.22
                    Time: 15:47:06
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 251
                    Mileage: 276086 km
                    Date: 2019.02.04
                    Time: 08:12:49
            000 -  -  - Intermittent
                    Reset counter: 40
                    Mileage: 274237 km
                    Date: 2018.12.07
                    Time: 07:53:38
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      100
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000000171457
   Coding: 0524582
   VCID: 5BE3957DEF282B0FABF-800E
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0014123
   VCID: 2A0D00B9F0F28287E09-807E
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7216688
   VCID: 1C61D661AAA66C37625-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
   Component: SDAR XM         H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E2029525
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 12H29000    Serial number: 00359D0A1KM/
   Coding: 0013878
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0B1468191
   Subsystem 3 - Serial number: 6342CSME0A775A6CJ
   Subsystem 4 - Serial number: 6352QSME036211796
   Subsystem 5 - Serial number: 6362QSME04522F15C
   Subsystem 6 - Serial number: 63734SME03440C4D+
   Subsystem 7 - Serial number: 63834SME044F41771
   Component: Lenks‰ulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026052070161
   Coding: 0002042
   Shop #: WSC 02323 785 00200
   VCID: 6695B489246A66E7041-8032
   Component: Lenkradmodul    H07 0080
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H16 0630
   Revision: 00000000    Serial number: 4PY175X75
   Coding: 2129263
   VCID: 211FE7958DC441DFB13-8074
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 13008058118151
   Coding: ECFE73CD1B7904
   VCID: 270BF98DE3E0BFEFFF7-8072
                    Reset counter: 61
                    Mileage: 273062 km
                    Date: 2018.11.22
                    Time: 15:48:07
   Coding: 0082954
   VCID: 619FA795CD4401DFF13-8034
   Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
   Component: MNS US          H45 0740
   Revision: 00000000    Serial number: 355GS057552228
   VCID: 38292AF13E5E201766D-806C
   Component: TSG FA          H12 0080
   Revision: 00-00000
   Coding: 0052971
   Shop #: WSC 98765 666 36911
   VCID: 2C0106A1FA069CB7125-8078
   Component: Komfortgeraet   H19 0140
   Revision: 01400019    Serial number: 01006252890000
   Coding: 4618813
   VCID: 2E050CA9CC1AEEA73C1-807A
   Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
   Component: DSP-High C6     H09 0140
   Revision: PROD_01     Serial number: 00000000702172
   Coding: 0000126
   Shop #: WSC 22162 444 13633
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000005735
   Coding: 0002114
   VCID: 5EE59C69FC3A3E27CC1-800A
   Component: TSG BF          H12 0080
   Revision: 00-00000
   Coding: 0052971
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DE79B65F13C253FD5B-8008
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000016
   VCID: 2615F489E4EAA6E7C41-8072
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
   Revision: 00000000    Serial number: 394HO057601711
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000088324
   Shop #: WSC 26107 444 01170
   VCID: 2313ED9D97D853CFA3F-8076
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  00915105CE
   Coding: 344630393135313035452056413030303931353130354345
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 72
                    Reset counter: 0
                    Mileage: 273062 km
                    Date: 2018.11.22
                    Time: 21:58:40
                    Mileage: 276086 km
                    Date: 2019.02.04
                    Time: 04:53:18
02276 - Quiescent Current Stage 5
                    Mileage: 276086 km
                    Date: 2019.02.04
                    Time: 04:53:29
02274 - Quiescent Current Stage 3
                    Mileage: 276086 km
                    Date: 2019.02.04
                    Time: 04:53:39
                    Mileage: 276086 km
                    Date: 2019.02.04
                    Time: 04:53:49
   Coding: 0052778
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000900008357
   Coding: 0062221
   VCID: 6099A291C64E08D7FED-8034
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000508050033
   Shop #: WSC 12336 024 394758
   VCID: 34311EC12236C4774A5-8060
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Coding: 0052778
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0020
   Revision: 00H09000    Serial number: 11720521406897
   Coding: 0001216
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 61
                    Mileage: 273062 km
                    Date: 2018.11.23
                    Time: 11:48:34
Address 77: Telephone
End----(Elapsed Time: 01:58, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
The faults are for Sensor B2 S2 and Sensor B1 S2. Those are the behind-the-CAT sensors on both banks. Both faults have a Frequency of 1 and ocurred on the same day. I wouldn't be so quick to replace them. The car might simply have woken up on the wrong side of the bed that day. Is it possible it was unusually cold then?
I also doubt that the post-CAT sensors would have much effect on cold starts. They can't possibly be doing anything at that point. Their primary job is to monitor the health of the CATs.
Since those faults occurred two weeks ago, and apparently not since then, I would clear them. This will also reset your fuel trims, which may have some effect on how the engine starts and runs.
There are update firmware options for this condition according to TSB if observed.
Most likely carbon build up and injection contamination
cdheikkila
C?ID=352193
What would my best option be for a firmware update, is it a visit to the dealership? Also, is there anything that I can do outside of this update for the carbon buildup/injection contamination? I am aware that there are addatives out there for carbon buildup, are there any in particular that you would suggest/suggest against altogether?
Thank you!!
Ask local Audi dealer about update.
Google and YouTube videos.
cdheikkila
C?ID=352193
As with a previous post of mine, going through and closing out old threads. This issue is still persistent, but hasn't been more than a slight concern when starting up cold. As it is an 06' and hasn't ever failed to turn over, I would consider this within normal operating condition.
