Results 1 to 10 of 11
Thread: Re-fit a lockable rear diff to my 2008 T5 4motion
    Jan 2019
    Barcelona, Catalonia
    Hi.
    I bought a second hand T5 multivan 4motion from 2008 a year ago. I wanted it with rear diff lock, but to my surprise the day I was to lock the diff, it did not work, and I found out the rear diff had been replaced by a non-lockable rear diff.
    So I plan to re-fit an original lockable rear diff. This work could be like a retrofit, maybe, but I suspect it should be way easier since I know my van will easily accept the modifications as it accepted them when she went out of the factory.
    So I am posting here a AWD scan and a complete autoscan. In the AWD section, I'd appreciate if someone with a 4motion from 2008 with rear diff lock can compare the codes below against theirs, and give me some clues on what I should be doing / considering / taking care of before starting the job --- even before buying a lockable differential.
    AWD section:
       Part No: 7H0 907 554 F
       Component: HALDEX 4Motion      2110
       Shop #: WSC 49856 001 1048576
       VCID: 33331D04772445EF53F-513C
    Full autoscan for reference:
    Thursday,14,February,2019,02:13:28:04823
    VIN: WV2ZZZ7HZ8H133087   License Plate:
              57 6E 76 77 78 7D
    VIN: WV2ZZZ7HZ8H133087   Mileage: 236970km-147246miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 DR    HW: 070 906 016 DR
       Component: R5 2,5L EDC  000SG  1584
       Revision: --H06---    Serial number: VWZ7Z0H6297210
       Coding: 0001172
       Shop #: WSC 36843 001 1048576
       VCID: 6393AD448744956FE3F-5184
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
       Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
       Component: ESP MK25E1          0104
       Revision: 00H31001
       Coding: 0000607
       Shop #: WSC 02756 790 00000
       VCID: 44D14ED8228AF257FA5-513C
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 40
                        Mileage: 236975 km
                        Count: 128
                        Count: 6913
                        Count: 128
                        Count: 255
       Part No: 7H5 820 045 P
       Component: CLIMA/AC            0303
       VCID: 372B2914635CA9CF6F7-513C
       Part No: 7H0 937 049 AD
       Component: BORDNETZ SGVER 1.0  2101
       Coding: 0000103
       VCID: 74B1DE1832AA02D78A5-513C
       Part No: 1C0 909 605 F
       Component: 11 AIRBAG VW61 0R   0004
       Coding: 12593
       Shop #: WSC 02756
       VCID: 270BF954B6FC394FFF7-513C
       Part No: 7H0 920 861 E
       Coding: 06113
       Shop #: WSC 32919
       VCID: 2E050C70990668073C1-513C
       WV2ZZZ7HZ8H133087     VWZ7Z0H6297210
    Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
       Part No: 7H0 819 008 R
       Component: Standheizung        0209
       VCID: 3B2335245F748DAF8BF-513C
       Part No: 6N0 909 901
       Coding: 00022
       Shop #: WSC 02756
       VCID: 70B9D20843B23EF76ED-513C
       Part No: 7H0 959 433 B
       Component: C11 KomfortgerŠt     0004
       Coding: 00025
       Shop #: WSC 02756
       VCID: 323D18008D3E4CE7589-4B1E
    Address 6E: Ctrl Head Roof        Labels: 7H5-919-044-W1.clb
       Part No SW: 7H5 919 044 J    HW: 7H5 919 044 J
       Component: J702  Dachdisplay   0500
       Revision: 1010007S    Serial number: 00000000060769
       Coding: 0000003
       VCID: 392F2F2C5548BFBF993-513C
    Jan 2019
    While I wait, I'd also appreciate a little help in interpreting the AWD section -- Since I could not find a "Autoscan interpretation guide" section or similar:
    What is "Shop #" ??
    What is "WSC" ??
    What is "VCID" ??
    What are the essential codes I should be looking at? The "Coding" section? Is it really just these few codes, or should I improve this scan with some deeper scan?
    Thanks from a newbie!
    "Shop #" consists of WSC (Work Shop Code), Importer number, and Equipment Number. This stuff is explained on a bit more than half-way down the following page of the VCDS product manual:
    http://www.ross-tech.com/vcds/tour/option_screen.php
    Our FAQ entry 2.9 also has some discussion of it:
    http://www.ross-tech.com/vag-com/faq_2.php#2.9
    VCID is is something proprietary to VCDS; it contains VCDS version info, control module protocol info, and so on.
  4. Likes jsola, Jack@European_Parts liked this post
    Jan 2019
    I am having no feedback on this. Le me try again see if I can wake this thread up...
    I have a T5 4-motion from 2008. It is originally with diff lock (differential lock). However, the previous owner changed the diff to a non lockable one. So now I have no diff lock. However, I have all the valves and the dash button and the vacuum tubes and everything needed to re-fit a diff-lock unit.
    I wish to have the diff lock back in. My mechanic tried 3 units already, and says he's having trouble with the ECU rejecting them. I do not trust my mechanic a lot (he could not replace a shaft boot properly last week) and am trying to take this job in my own hands.
    I am ebaying for a rear differential with diff lock. I can find some things in the 500 euro range, which I think it's pretty fair. I found one diff from 2006 with diff lock. The downside, it comes with no Haldex unit.
    So my intention is to use the mechanical gearings part, which has the diff lock, and fit my working haldex into it. Since my ECU is really communicating with my Haldex, I think I should be able to complete the job this way without communication issues.
    The job would be: 1) Take my working haldex out of my non-lockable diff, 2) put it in the new ebay lockable diff, 3) put the whole thing under my van.
    Any wise opinions for / against this approach??
    Yeah, look up all parts needed in microfiche at dealer and use PR tag + VIN.
    The 1970s called and wants its technology back.
  8. Likes NZDubNurd, Jack@European_Parts liked this post
    Hey I still use it and FYI it doesn't need a net connection or PC.
  10. Likes D-Dub, PetrolDave liked this post
  11. #8
    Jan 2019
    Thanks Jack for this input. I did not know what PR codes were until now!
    I am posting this for reference. Also if anyone is willing to clarify some doubts I will be of course thankful!
    The diff lock option has PR code 1Y4. This involves the differential housing and parts, including all the commands for the lock, and the signals from the log, which come from 3 reed switches located at the lock lever.
    The Haldex unit, however, is common to both lockable and non-lockable versions.
    I do not see any other difference in parts. Even across the years of production, all parts of the differential itself (which differ on the last letter of the OEM code depending on year) seem to be compatible. The Haldex however seems to have changed sometime in 2007, so beware of this part code. I am keeping my Haldex so no problem here.
    Regarding ECUs and codes, the reed switches in the diff lock mechanism communicate with the AWD computer which is located in the Haldex.
    Additionally, and to allow for engaging the diff lock, the system first reads vehicle wheel speeds from the ABS computer. It seems to only read this info, so I assume the ABS computer will need no recoding after re-fitting the diff lock.
    So the situation seems as follows:
    - If I keep the Haldex I currently have, I should have no mechanical problems in assembling it into a lockable differential.
    - If I re-fit the lockable differential, I may have to see whether I have to recode the AWD computer or not to account for the info read from the reed switches. Actually here I do not know: how can I know what is necessary?
    - It does not seem I have to take care of codings in the ABS computer.
    The current code of the AWD computer in the Haldex I have is:
       VCID: 33331D04772445EF53F-5160
    00003 - Control Module
    02248 - Valve for Controlling Clutch Operating Angle (N373)
    Most of the parts in my van have #Shop code WSC 02756. So my Haldex seems to be not the original, or perhaps it has been recoded at #Shop 49856. How to know which shop is this? I might be interested in contacting them.
    Thanks
    Joan
  12. #9
    Vehicle Identification No. WV2ZZZ7HZ8H133087
    Model transp. multivan
    4motion
    TR
    Date of production 10.03.2008
    Model year 2008
    Sales type 7HMC15
    Engine Code BPC
    Transmission Code KLF
    Axle drive 6S
    Equipment EJ
    Roof color G2
    Carpet color code
    Exterior color / Paint Code G2 / Y3D
    Take to retrofits or install parts to comport with a qualified repair..........
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 1CP Vehicle class differentiation -7H0-
    drive-off assistance UG0 Without hill start assist/hill descent control/comfort driving assist
    Emission standard 7GG Emission standard EU4 DPF
    Trailer hitch 1D2 Trailer hitch, removable and lockable
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Storage compartments, cab 5FA Without additional storage in the cab
    Tray areas package QE4 stowage package 2
    Armrests for front seats 4S1 Armrests for both front seats
    Aerials 8ZF Side window antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SL Left exterior mirror, aspherical
    Right exterior mirror 5RB Right exterior mirror, convex, and wide-angle
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Final drive/gear ratio 0ZN Gear ratio, high geared
    Equipment levels A8E Multivan "Comfortline"
    batteries J1D Battery 380 A (72 Ah)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Controls (steering wheel/steering column) 4LA Without control element
    Dashboard illumination 7V0 Standard dashboard illumination
    Floor coverings in cab 5AD Carpet floor covering in cab
    Floor covering in passenger/luggage compartment 5BE Tough plastic lining in passenger compartment
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0B Component parts set, complying with vehicle type for Austria, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AK Electronic stability control (ESC) with brake assist system
    Owner's manuals 0XY Information kit in German (for Austria)
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    C-rails 6L0 Without C-rails
    General operating permit, alterations C16 Operating permit, alteration
    Roof types 3R0 Standard roof
    Shock absorption/suspension, chassis 1BJ Uprated suspension/shock absorption in front and rear
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    roof turn signals 9H0 Without roof turn signal lights
    Roof insert for in passenger/luggage compartment 3JA Without roof insert in the luggage/passenger comp.
    Differential lock 1Y4 Differential lock
    Roof trim 5CJ Roof trim, 2-piece comfort headliner in cab and passenger compartment
    4th row of seats 3WA Without bench seat
    Insert for the filling up of unleaded fuel/fuel type 2G2 Without insert for the filling up (diesel) without fluorination (not RME-resistant)
    Theft protection system 7AA Electronic immobilizer
    Inserts 5MA Decorative inserts
    Identification lights, roof 9KA Without identification lights
    Insert/badges (interior) NR1 Insert/badges (interior)
    Park distance control 7X0 Without park distance control
    2nd row of seats 4C2 2 swivel seats w/ longitudinal adjustm. on rail system
    Electric interface for external use UF0 Without electric interface
    Power-operated door (power latching) GZ0 door, manually operated
    Electrically actuated door (power closing) right-hand side GX3 Power latching for sliding door right
    Antidrum measures 2N4 Special sound deadening measures in cab and passenger compartment
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    Tachograph/logbook 9ND Tachograph preparation
    chassis/running gear 2E3 16-inch chassis
    window regulator 4R1 Power windows
    fire extinguisher 6A0 without fire extinguisher
    Hood and trunk stay 5NJ Hood gas prop with standard tailgate vent lock
    Headlight activation 8K0 Without special driving light switching
    Rear heating system/ventilation system 6CC Vent, B-pillar, with fan
    Fresh air intake for passenger compartment (with particulate filter) 2V1 dust-pollen filter
    Curtains/roller blinds 5G0 Without curtains
    Interior noise suppression measures 3W3 Special interior noise insulation
    Base carrier NG0 Without top carrier
    Alternators 8GR Alternator 150 A
    Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
    Weight category front axle 0JG Weight category front axle weight range 7
    Base engine TN7 5-cylinder diesel engine 2.5 l unit 070.N
    Luggage compartment cover 3U4 Luggage compartment cover
    cruise control system 8T0 Without cruise control system (CCS)
    Exterior noise suppression measures 2B1 additional noise dampener
    Transmission specifications G0L 6-speed manual transmission for four-wheel drive vehicle
    Rear gates/tailgate 3RC Tailgate with window aperture
    Rear window insert 4HS Heated rear window with rear wiper
    Grab handles at roof frame 5N6 Folding grab handles on roof frame soft fold-away
    Entry grab handle (A/B-pillar) 6X2 Entry grab handle (front passenger side)
    Heating and air-conditioning system 9AV Manually controlled air conditioning in cab plus passenger compartment ventilation with second heater
    Rear side window for load or passenger compartment, left 4FN Sliding window passenger compartment, left
    Rear side window for load or passenger compartment, right 4JH Fixed side window in load/passenger compartment, right
    Headlamps 8EL Headlight with double reflector for driving on the right
    Labels 1HZ Labels without country group
    Interior lights in passenger and load compartment 9CH Interior light concept for Multivan in passenger compartment
    Customized installation FC0 Without individual installation
    Instrument clusters U4A Instrument insert, km/h speedometer
    Instrument panel 4N3 Comfort dashboard
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K4H Closed body
    coolbox 1W0 Without refrigerator/glove compartment cooling system
    child safety 4H1 Childproof lock in the rear
    Child seats QA0 without child seat
    Folding table 1U1 Folding table
    Climatic zones 0Y1 Standard climatic zones
    Head restraints 3J3 Tilt- and height-adjustable head restraints
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Body measures 5C0 Without special body measures
    Cooker for Camper AE0 Without camping stove
    Paint preservative/transit coating 5K7 Partial protective cover/film (Europe) with additional transport protection measures
    Steering system arrangement L0L Left-hand drive
    Load edge protection 2P1 Plastic loading edge protection
    steering wheels 2PW Leather-wrapped steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Leather parts 3HB Leather parts
    Air cleaner (engine) 1L0 Standard air cleaner
    Headlight range control 8Q1 Headlight range control
    Multi-function display/trip computer 9Q1 Multi-function display/trip computer
    Awning NF0 Without awning
    Engine cooling 8Z5 not hot country
    Engine specifications MS0 5-cyl. turbo diesel engine 2.5 L/128 kW pump-jet injection system base engine: T9L/T03/T86/TB7/TG7/TN7/TP7
    Left vanity mirror 4SM Left vanity mirror illuminated with cover and pocket
    Right vanity mirror 4TM Vanity mirror, right, illuminated with cover and pocket
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TC Rear fog light for driving on the right
    Front fog lamp/additional headlamp 8WB Front fog lamps
    Upgrading measures GP0 Vehicles w/o special upgrade measures
    Hubcaps 1ND Full wheel covers
    Wheels C1G Steel wheels 6.5J x 16
    Radios 8UB radiopreinstallation
    Smoker's/non-smoker's package 9JC Smoker's package
    Spare wheel mounts 1B1 Standard spare wheel bracket
    tire H1E Winter tires 215/65 R16 C 106/104T
    Spare wheel/breakdown kit 1G2 Spare wheel with full tyre, steel
    Wheelbases 0E1 Short wheelbase
    Surround sound combination/rotating beacon light 9LA Without rotating emergency lights
    PW2 Auxiliary water heater with timer and radio remote control
    RV1 Radio preparation
    WE7 Package for Austria
    ZK3 Air conditioning system for cab and passenger compartment ventilation
    ZR9 Steel spare wheel with original equipment tire (Tire Mobility Set deleted)
    Stowage compartment AF0 without storage room
    Special labels/plates 0ST Labels in German and French
    Hinges for side and tail gates 5V3 Hinges for rear door/flap (normal version)
    Tail lamp assemblies 8SD Taillight assembly w/ red colored lens
    Pane type (except windshield) QL5 Dark tinted glass in rear seat area (Venus 35/Privacy) heat-insulating glass (green) in front
    Locking mechanism for boot lid/cover rear 4E9 Trunk lid power closing with operating lever inside
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Seat belt check 9P0 without press button buckle with warning contact
    seat covers N0H Seat trim covers in woven fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A3 seat heating for front seats separat controlable
    Side interior lighting passenger/luggage compartment 5DD Comfort side trim panel in passenger compartment
    Key for locking system 8QD Key for locking system
    Horns 8Y1 Two-tone horn
    Voice enhancer VX0 Without voice enhancer
    Protective side molding 4B2 Body-colored protective side molding
    Sunroof roller blind for rear/side windows 3Y7 Roll-up sun screen
    power outlet 7B3 12-volt outlet(s)
    Bumper 2JG bumper in color of vehicle
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N1 Windshield wiper intermittent control
    mud flaps 6N0 without mud flaps
    Special approval measures 3M7 Passenger car version with up to 7 seats
    Nameplate set 0NM Without engine designation and nameplate set
    Door storage compartments in front 3YR Door pockets with insert mats
    Mass damper for steering wheels 1Q3 Mass damper for steering wheel, XXHz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Doors, passenger/load compartment, left 5Q0 Without door in load/passenger compartment left (closed sideboard)
    Doors, passenger/load compartment, right 5R2 Sliding door right in load/passenger compartment
    Type approval countries/countries with special requirements B12 Type approval country Austria
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Step illumination 9N3 Step illumination, cab and sliding door(s)
    Door and side trim panels 3LQ Door trim panel
    Identification plates 1EX Special identification plate for EU
    Delivery equipment 2A0 Without delivery equipment
    First aid kit / warning triangle 1T3 First aid kit with warning triangle
    Modular seat attachment 2Q0 Without modular seat mounting
    Storage compartment -- veneered key storage box 4Y0 Without storage compartment/safe box
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Lashing rings/rails for load restraint 6B3 Lashing rings for tough floor covering
    LongLife Service Regime QG1 LongLife Service Regime
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Second battery/battery installation 8FB 2nd battery
    floor mats 0TA without floor mats
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    3rd row of seats 3VX 3-seater bench with storage compartment, movable and reclining seat mechanism
    Additional dust seals 6U1 Additional dust seal outside
    permissible total weight 0WQ Gross vehicle weight rating
    Auxiliary heating system 7VL Water heater with radio remote control
  13. #10
    Jan 2019
    Find the continuation of this topic with a happy end here:
    https://forums.ross-tech.com/showthr...5E1-ABS-module
  14. Likes Uwe liked this post
