Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Problem with CJAA TDI swap into a 1991 GTI
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by m87a View Post
    Did you try to open throttle body and check teeth on gears?
    This s TDI , there is no Throttle body . TDI has ASV which will not cause limp mode.
    Quote Originally Posted by MartinsX View Post
    Address 01: Engine      Labels: 03L-906-022-CBE.clb
            Part No SW: 03L 906 019 DA      HW: 03L906022TS
            Component: R4 2,0L EDC G001SG   7969
            Revision: 12H03---      Serial Number:
            Coding: 0050072
            Shop #: WSC 01955 666 02675
            VCID: 6D9D5AB7242DEE46F654E6-8038
    001158 - Exhaust Gas Recirculation Sensor 2
            P0486 - 001 - Electrical Malfunction
    001152 - Coolant Fan Control Circuit 1
            P0480 - 000 - Electrical Malfunction
    012332 - Relay for Low Heater Output
            P302C - 000 - Short to Ground
    001114 - EGR Valve 2 (N213)
            P045A - 000 - Electrical Malfunction
    000321 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
            P0141 - 002 - Malfunction
    I think EGR DTC's will switch on limp mode anyway. You need to restore EGR system as it was originally. Or ask a tuner to remove everything EGR related from ECU software.
    100% Agree. This is most likely root of the problem.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  2. Likes Uwe, m87a liked this post
  3. #12
    Jan 2015
    Bosnia and Herzegovina
    you are correct it's not throttle body, but as i know it will cause limp mode?
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  4. #13
    Only of is pedal faulty, but he said he checked it already.I never see ASV makes it to go in limp mode. This car has Electronic EGR at front of the intake as well , maybe you confusing this with it.
    Immobilizer/ECU
  5. #14
    Jan 2015
    I know EGR will cause a limp mode but I was under impression that this will also cause limp mode... well you live to learn
    GOOD CHEAP FAST
  6. Likes Jetta ,97 liked this post
