Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 68
Thread: 2013 Golf 7 coding problem
  1. #41
    Jun 2015
    Brazil
    I'm having the same problem ere with my Golf VII 2015
    The original code of module 5Q0 955 547 A - RLHS was 00A8DD. Now I coded exaclty as told, to 06A8DD. The code was accepted, I did all the right procedures (lights in auto, wipers either) but it's not closing the windows.
    I've seem in other foruns that this tweak is not working in 2015MY, is that true? Is there a solution for this?
  2. #42
    Administrator Andy's Avatar
    Sector 7G
    I definitely enabled it in my US market 2015 Golf GTI:
    http://forums.vwvortex.com/showthrea...1#post86246484
  3. Likes Dana, Uwe liked this post
  4. #43
    Jun 2015
    Brazil
    Quote Originally Posted by Andy View Post
    But yours is a RLHS or RLFS? It's the same module/part number?
  5. #44
    Jun 2015
    Brazil
    Any ideas?
  6. #45
    United States
    Quote Originally Posted by AMBSC View Post
    Just a RLS per that scan clip.
    Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
    Component: RLS 024 0042
    Serial number: Y14M02D19H17M22S34S9
    Coding: 00A8DD
  7. #46
    Jun 2015
    Brazil
    Maybe the problem is in the RLHS/part number. Anyone with a 2015 RLHS type was actually successful with this tweak?
  8. #47
    United States
    andyvee (not the Andy from Ross-Tech) has a bunch of threads linked here that may be helpful:
    http://forums.ross-tech.com/showthre...latform-tweaks
  9. #48
    Mar 2014
    Slovenia
    Accoding to my knowledge and practical experience, rain closing does not work on Golf 7 with RLHS modules (so from model year 2015 forward). It accepts all the coding, but does not work. This is also stated in one of the andyvee-s links.
  10. Likes Dana liked this post
  11. #49
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    Thanks mtl and Dana - if you have the RLHS it doesn't work. You can of course replace it with the earlier RLFS and then it will work
  12. Likes Dana liked this post
  13. #50
    Feb 2015
    I have tried the setup several times. I have a 2015 Golf Mk7 and it has an RLS rain sensor. I shut off the ignition, open windows, put the wiper stalk up one position (intermittent/sensor) get out and lock the doors with the fob. Rain closing works every time, but only within about 5 minutes of shutting the car down. Wait 15 minutes or more and rain closing doesn't work! I can repeat this every time I test.
    The control module must be going to sleep and there's probably something else needing to be set.
