Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 68
Thread: 2013 Golf 7 coding problem
  1. #31
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    Yep, this is the same issue some others are seeing as well, as well as the rain closing working for about an hour then stopping working.
    Try deactivating and then reactivating rain closing from the Infotainment unit. Also, you can test by 'tapping' the rain sensor with your finger, you don't need to keep spraying water.
    Make sure that the following procedure is followed to test it:
    Engine is running and wipers and headlights on auto with drivers door closed.
    Turn off engine, exit vehicle and close door
    Use the button on the remote fob to lower the windows an inch
    Lock the vehicle
    Tap on the rainsensor with your fingers
    There appears to be an issue on MQB platform cars where for the settings to take effect properly the control unit has to reset after the coding changes. I don't think VCDS does this, but VCP resets the controllers after every change (hence why you can only do one adaptation channel at a time with VCP), and has a manual reset as well. A suggestion to include in future beta versions Dana?????
  2. #32
    Magdeburg, Germany
    Hello Andy, this function is already on our wish/todo list. We'll see what we can do about this.
  3. Likes andyvee, flygteye liked this post
  4. #33
    Nice one Sebastian
    A few users were having issues after coding rain closing
    http://www.briskoda.net/forums/topic...i-vcds-tweaks/
  5. #34
    Administrator Andy's Avatar
    Sector 7G
    bloggo,
    Were you ever able to make the appropriate changes with a newer version of VCDS? Please post an AutoScan using Release 14.10 and/or Beta 15.3
    http://www.ross-tech.com/vcds/download/current.html
  6. #35
    Mar 2014
    Birmingham UK
    Andy,
    I carried out the procedure that DV52 posted on the "vwwatercooled" site and all codings were accepted.
    Saturday,02,May,2015,15:53:39:11201
    VCDS Version: 15.3.0.0 (x64)
    Data version: 20150314
    VIN: WVWZZZAUZDP******   License Plate:
    Mileage: 10669km-6629mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZDP******   Mileage: 10669km-6629miles
    Address 01: Engine (J623-CPTA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
       Component: 1.4l R4 TSI   H02 5532
       Revision: WKH02---
       Coding: 01250032236405082000
       Shop #: WSC 00028 028 00080
       ASAM Dataset: EV_ECM14TFS01104E906016AD 002006
       ROD: EV_ECM14TFS01104E906016AD.rod
       VCID: 64C759686F707E1843-8031
       Part No SW: 0CW 300 047 T    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5211
       Revision: 00043014    Serial number: CU501303187173
       Shop #: WSC 00028 028 00310
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: 4C9791C8E7E0D6586B-8019
       Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
       Component: ESC           H75 0537
       Coding: 01FA8AA1202712750377060801CC2980510448C0608094F3F82A502AC1
       VCID: 7EF30B00E1DCB4C8B5-802B
       Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00120004200100011005004000101000
       ROD: EV_ACClimaBHBVW37X_VW37.rod
       VCID: 3663D320896CBC882D-8063
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011308601425
       Coding: 03001846C24102FB0FA44080B11C0728100A000000000000000000000000
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 4683A3E0F98C2C08BD-8013
       Slave 1:
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
       Component: WWS    130317  042 0551
       Serial number:         130319080559
       Coding: 0E4DD5
       Slave 2:
       Component: RLFS  024 0042
       Serial number: Y13M04D09H13M01S36S1
       Coding: 06A8DD
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY130520P6C
       Serial number: 00000000000056508464
    539925 - Databus
                        Reset counter: 152
                        Mileage: 10112 km
                        Date: 2015.03.27
                        Time: 11:18:53
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
       Component: PARKHILFE PLA H11 0029
       Revision: --------    Serial number: 61131308700820
       Coding: 0131161051
       Shop #: WSC 00017 666 00908
       ASAM Dataset: EV_EPHVA2CAU3700000 003014
       ROD: EV_EPHVA2CAU3700000_VW37.rod
       VCID: 3D71CC0CAC5A6FD0EC-8068
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
       Component: ACC3          H08 0390
       Serial number: 04041375030254
       Coding: 001E1300FE0309
       ASAM Dataset: EV_ACCBoschMQB 001021
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 3F8DB604A6567DC0FE-806A
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Serial number: 003M1R02DGFD
       Coding: 98FCC0C0000000005C5400CF00C800000065
       Shop #: WSC 00028 028 00057
       VCID: 4A9B97D0ED94C86859-801F
       Seat belt tensioner; left:
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169677A04041350661
       Coding: 333135
       Seat belt tensioner; right:
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169676A04041340700
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 803 13
       Serial number: 35767000000BB8B0AC05
       Subsystem 4 - Part No SW: -----------    HW: 480 002 803 13
       Serial number: 35867000000187BCDC07
       Subsystem 5 - Part No SW: -----------    HW: 480 400 304 13
       Serial number: 35165029B0FAE8A462D
       Subsystem 6 - Part No SW: -----------    HW: 480 400 304 13
       Serial number: 3526502BF0FEA210C0DU
       Subsystem 7 - Part No SW: -----------    HW: 480 402 003 13
       Serial number: 3556502B70FAE8A1223N
       Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 12031308490737
       Coding: 0D00
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 7BF50214F2CEA1E092-802E
       Part No SW: 5G0 920 970     HW: 5G0 920 970
       Component: KOMBI         336 0580
       Coding: 67A401082790260001886A01040000
       VCID: 67DD4E649E46150066-8032
    1048578 - No Basic Setting
              B2010 00 [008] -  -
                        Reset counter: 161
                        Mileage: 9214 km
                        Date: 2015.01.21
                        Time: 09:35:54
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1109
       Revision: --------    Serial number: 0000484847
       Coding: 030100042B086400EF00065C1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_VW37.rod
       VCID: 3467E9289F10AE9813-8061
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
    H13 0035
       Serial number: 23130000275380040291
       Coding: 2DFFFF
       Serial number: 6877660103
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Component: TSG FS        007 0006
       Serial number: 0000056235917
       Coding: 003B0220D001028000001000
       Shop #: WSC 00028 028 00074
       VCID: 020B7FF09524D028D1-8057
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Serial number: 00000000000001117534
       Coding: 0D0000
       Coding: 83
       ROD: EV_SteerAssisMQB.rod
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Component: TSG BFS       007 0006
       Serial number: 0000056849937
       Coding: 003B0020DE01028000801000
       VCID: 010970FC9022CB30C8-8054
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Serial number: 00000000000001128000
       Coding: 050000
       Part No SW: 5G0 035 858     HW: 5G0 035 858
       Component: MU-S-ND-ER    039 0170
       Serial number: V5F00704130548
       Coding: 02730001FF00000021111201002800001F0100160100010045
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 69D9485C8852237070-803C
       Media Player Position 1:
       Component: ABT_Std_Nav  H44 0020
       Serial number: VWZ8Z9N3401HQ1
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 5G0 919 866 N    HW: -----------
       Component:  ECE 2014/15  --- 0040
    Mods carried out with beta 15.3.0
    End-------------------------(Elapsed Time: 03:33)--------------------------
  7. Likes Andy, Uwe liked this post
  8. #36
    Sector 7G
    Excellent! Thanks for the feedback.
  9. #37
    Mar 2014
    Birmingham UK
    Andy,
    Although the coding's were accepted I was still unable to get the rain closing to work.
    Bill.
  10. #38
    Sector 7G
    Quote Originally Posted by bloggo View Post
    Andy,
    Bill.
    Hmmmm .... not sure what else to suggest if you tried all the stuff shown here:
    http://forums.vwvortex.com/showthrea...1#post86246484
  11. Likes DV52 liked this post
  12. #39
    Bill: I've just had look at Andy's instructions compared to mine. The only difference that I can find is in the In-cabin procedures. Andy suggests that you reset all the car's settings to factory, whereas my instruction are to reset opening and closing settings. Worth trying Andy's way if you still have the adaptation/coding changes made.
    Cheers
  13. #40
    Mar 2014
    Birmingham UK
    Andy/DV52
    Ok, I've tried both suggestions with no luck.
    I will try starting from scratch when I have time, to see if it works and keep you advised.
    Thanks to you both for your assistance.
    Bill.
