GOLF 7 REAR WINDOW CODING
cqae
Australia
C?ID=102860
Hi guys, I recently fitted a rear window motor to this golf7 & didnt realize I needed to code it. SO before I head back to the dealers, is there any way I can do it with vag com? Or any other tools before I go to the dealers?
Thank you!
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F
VIN: WVWZZZAUZGP569178   Mileage: 35639km-22145miles
Address 01: Engine (J623-CJSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 319D00122426050B3000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM18TFS0208V0906264H 001005
   ROD: EV_ECM18TFS0208V0906264H_VW37.rod
   VCID: 41824B17D0B55C429A-8014
   Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4909
   Revision: 06253104    Serial number: TFK01510131173
   Shop #: WSC 00028 028 00068
   ROD: EV_TCMDQ250021.rod
   VCID: 1932C37718A5248232-804C
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62985000001593
   Coding: 43FA8AA1342651750778070741CB29C2512C8AE0E08294FD00420038E209
   VCID: 79F2E3F7F8E5C48292-802C
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 153
                    Date: 2018.11.29
                    Time: 14:28:23
   Revision: 00021000    Serial number: 0384339086
   Coding: 030C0C
   VCID: 3A703CFBBD630F9ADB-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 02120024200100001005000012101402
   VCID: 6AD0CCBB8D437F1A6B-803E
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580211151844
   Coding: 03511A46C24122FB4BE44000000C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 030E811F8A298E52C8-8056
   Component: WWS    150829  042 0551
   Serial number:         150927122912
   Component: RLHS  037 0059
   Serial number: S5Y15M11D05H19M17S43
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000LKJMA00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000LKKB000000
   Coding: 191800
550677 - Databus
                    Fault Frequency: 7
                    Reset counter: 200
                    Mileage: 33928 km
                    Date: 2018.12.07
                    Time: 11:49:03
551445 - Databus
                    Reset counter: 170
                    Mileage: 33928 km
                    Date: 2018.12.07
                    Time: 12:10:58
   Revision: --------    Serial number: 39391529607975
   Coding: 0031151011
   VCID: 438E411FCAA94E5288-8016
   Serial number: 003F6R167KTS
   Coding: 98CCC000000000005C00000000C800000065
   Shop #: WSC 00028 028 00059
   ROD: EV_AirbaVW20SMEVW37X.rod
   Subsystem 1 - Part No SW: -----------    HW: 480 002 310 15
   Serial number: 35767000000124F8171O
   Subsystem 2 - Part No SW: -----------    HW: 480 002 310 15
   Serial number: 3586700000079C09171W
   Subsystem 3 - Part No SW: -----------    HW: 480 402 810 15
   Serial number: 3516502C51D3F97313FN
   Subsystem 4 - Part No SW: -----------    HW: 480 402 810 15
   Serial number: 3526502C51D3F972A35M
   Subsystem 5 - Part No SW: -----------    HW: 480 403 110 15
   Serial number: 3556502BD1D73C6561DV
   Revision: FF033033    Serial number: 20151024401111
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 040C82038F27896AF1-8050
   Part No SW: 5G1 920 740 A    HW: 5G1 920 740 A
   Component: KOMBI         202 6420
   Coding: 27A4101B2B80000801086A001400000000000000
   VCID: 244CE2832FE7696A91-8070
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 25101510521318
   Coding: 030100343F085900FB00224A1E0F00010001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29150002063400065423
   Coding: 29FFFF
   Serial number: 7132888203
   Serial number: HA1-00001.10.15
   Coding: 0001
   VCID: 4A906C3BED839F1A4B-801E
   Revision: 00000000    Serial number: 15000240788009
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346C12C39F07F9EA01-8060
   Serial number: 0000172461092
   Coding: 003A13208001020000001000
   VCID: 4796550FFE91627254-8012
   Serial number: 00000000000002464356
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   VCID: 448C4203CFA7496AB1-8010
   Serial number: 0000173035789
   Coding: 003A11208E01020000801000
   VCID: 4688580BF99B7B7AAF-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG ---  007 0002
   Serial number: 00000000000004368096
   Coding: 000400
589851 - Window Regulator; Front Passenger side
          B1320 F6 [009] - Invalid Data Record
                    Reset counter: 160
                    Mileage: 35639 km
                    Date: 2018.12.20
                    Time: 14:46:56
589852 - Window Regulator; Front Passenger side
          B1320 F2 [009] - Not Coded
                    Reset counter: 160
                    Mileage: 35639 km
                    Date: 2018.12.20
                    Time: 14:46:56
   Coding: 06AE00000B000200
   VCID: 40844E13DBBF554A95-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     H24 0245
   Serial number: VWZAZ2R0555311
   Coding: 02730208FF00000051510001000828001F0100D601200102C7
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 6ED8C0ABB1AB933A37-803A
   Component: ABT_Std-2_Nav  H43 4060
   Serial number: VWZ6Z9R3050040
   Subsystem 2 - Part No SW: 3G0 919 866 P    HW: -----------
   Component: MRM2 2016  --- 0521
          B1066 13 [008] - Open Circuit
                    Reset counter: 200
                    Mileage: 35639 km
                    Date: 2018.12.20
                    Time: 14:42:49
                    Voltage terminal 30: 12.3 V
DV52
C?ID=194404
cqae: G'day!
Here's a list of the "rear wiper" settings on the BCM from an Aussie MY16 mk7 Stn Wgn with HW/SW 5Q0-937-086-AG (Alas it's from an admap with the old RT reporting protocols- i.e. sans "Tags").
(1)-Rear Window Wiper-Komfortwischen Heck	>	active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW	>	active
(3)-Rear Window Wiper-Automatisches Heckwischen	>	not active
(4)-Rear Window Wiper-Traenenwischen Heck	>	active
(5)-Rear Window Wiper-Heckwischer Weiterlauf	>	not active
(6)-Rear Window Wiper-Kein automatisches Abparken	>	not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	>	7 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	>	7 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	>	5 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	>	3 s
(11)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	>	0 s
(12)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	>	0.0 s
(13)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	>	not active
And you will need to set the following bit in the BCM code-string:
Mika_M
C?ID=183725
I don't think that rear WIPER settings will help to resolve new WINDOW motors? :p
I would go searching in modules 42 & 52, which both have a submodule for rear doors. Maybe VCDS will show some coding help to see what has to be changed...?
NEtech
C?ID=56995
Coding for [52] Sub ecu should be:
050000
But I guess this needs dealer tester.
                    Reset counter: 160
                    Mileage: 35639 km
                    Date: 2018.12.20
                    Time: 14:46:56
cqae
Australia
C?ID=102860
yeah Ive had a good look & cant find anywhere to directly communicate with the rear window motor. Normally there is a coding value in earlier models, but not on this car. Looks like at this stage its a dealer only function.
Thank you all!
cqae
Australia
C?ID=102860
Thanks NEtech, I wasnt able to find anything like that in this car, but will use that info to look a little closer!
cqae
Australia
C?ID=102860
Thanks again NEtech, I got it coded. I didn't see the drop down menu at the top enabling me to code the motor via the front motor screen-all done!
