Results 1 to 5 of 5
Thread: New member + problem with VW bluetooth
    Feb 2019
    Belgium
    Hi there!
    I'm a new member here. My name is Jasper, 24 years old and I'm from Belgium.
    Studying industrial engineering electronics-ict at university and this out of curiosity for automotive electronics
    That's one of the reason why I bought myself a VCDS as well.
    My car is a VW Polo 6R 1.4i Highline from 2010. Already did a lot of mods and retrofits like OEM Helix subwoofer, auto light switch, MDI,...
    Last summer I started my latest one: bluetooth. Bought a bluetooth module (part number 5K0035730D) which I believed would have A2DP and 9W7 support. I first used it a couple of months in combination with my RCD 310, which worked perfectly for music except I couldn't see track info on my screen (limitation of the radio unit itself I believe) but telephone function wasn't supported here of course. Back in December, I decided it was time for the next step and bought myself an RCD 510 (part number 3C8035195), which supports the telephone function. Everything works fine now except one thing: my telephone book doesn't show my contacts names? For every contact name it just shows 3 dots and when you check the contact's details it just shows crap. I'm not able to call someone as well. BUT if someone calls me, his/her name shows up on the screen, I'm able to accept or decline, accepting and calling works perfect, so this is all fine. When I go into missed calls, I see names of people who tried to call me, so this is fine as well. Only my telephone book lost its mind... Does anyone knows what's wrong here? My phone is an iPhone 7 with all of the contacts names and numbers in the fields provided for this. Didn't have problems with this in other cars and I already tried with another iPhone with different contacts but gave the same problem. Does anyone knows what's the problem?
    VCDS auto-scan: (4 faults in radio section are because I pulled out the bluetooth module connector while engine was running)
    Chassis Type: 6R-VW25 (6N0)
     Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 77
     VIN: WVWZZZ6RZAY173210 Mileage: 96790km-60142miles
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine Labels: 03C-906-024-BXW.lbl
    Part No SW: 03C 906 024 BH HW: 03C 906 024 BH
    Component: CGGB MM4HV G 8327
    Revision: --H09--- Serial number:
    Coding: 0000071
    Shop #: WSC 03247 202 104841
    VCID: 65C03A52AF78C16246-5140
     Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
     PartNoSW:6R0907379R HW:6R0907379R
     Component: ESP8.2i front H04 0002
     Revision: --------
     Coding: 210228E3217400B5842714E384D100401300
     Shop #: WSC 02069 000 00000
     VCID: 4D90E2F210C819226E-8018
     02214 - Tire Pressure Warning
     Reset counter: 214
     Mileage: 96593 km
     Date: 2013.05.30
     Time: 16:45:55
     Hex Value: 0x0000
     Hex Value: 0x8000
     Hex Value: 0x1203
     Hex Value: 0x2BB3
     Hex Value: 0x497F
     Hex Value: 0x7F7F
     Hex Value: 0x8000
     Hex Value: 0x0000
     Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
     Revision: V0000000
     VCID: 326A910E6D3666DA13-8066
      Reset counter: 225
     Mileage: 92177 km
     Date: 2013.02.02
     Time: 18:24:25
     01273 - Fresh Air Blower (V2)
     Reset counter: 170
     Mileage: 94135 km
     Date: 2013.03.18
     Time: 16:30:23
     Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    PartNoSW:6R0937087D HW:6R0937087D
    Component: BCM PQ25 H+4 H46 0207
    Revision: BF046001 Serial number: 0147 012100753
    Coding: 3CB029BF08A10000012006003C2B16D000C0410F60060000200000000000
    Shop #: WSC 12345 160 20947
    VCID: 3E72B53EA96EB2BAE7-FFFE
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
     Component: RLS 150110 05 54 0402
     Coding: 0005F3
     Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
     Component: J386__TSG_FT 006 0912
     Serial number: KU0-KU007.01.1016901
     Coding: 08BC30
     Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
     Component: J387__TSG_BT 006 0912
     Serial number: KU0-KU010.12.0915961
     Coding: 08BC30
    Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
    Part No SW: 6R0 919 475 HW: 6R0 919 475
    Component: PARKHILFE 4K H07 0008
    Revision: -------- Serial number: 71320935601747
    Coding: 100001
    Shop #: WSC 124697 483 00190
    ASAM Dataset: EV_VW250ParkiAssis2 S01006
    ROD: EV_VW250ParkiAssis2.rod
    VCID: 7BF47C2AF2FC679280-802E
    PartNoSW:6R0959655C HW:6R0959655C
    Component: VW10Airbag00L H09 0018
    Revision: -------- Serial number: 003DW00BCK9E
    Coding: 00304C
    ROD: EV_AirbaVW10BPAVW250.rod
    VCID: 428AC1CED596D65A83-8016
    Serial number: 3572SRB40000A89501A1
    Page 5
      Serial number: 3582SRB40000A8BCC93O
      Serial number: 3516GRB4033CA5L92KVH
     Serial number: 3526GRB4029CA5L8T3EF
    PartNoSW:6R0920860D HW:6R0920860D
    Component: KOMBI H03 0205
    Coding: 140A00
    VCID: 3560AA12945871E236-8060
     Part No SW: 6N0 909 901 HW: 6R0 937 087 D
      Coding: 002000
     VCID: 70EE5B06A3BA14CA25-8024
    Reset counter: 221
    Mileage: 96694 km
    Date: 2013.06.05
    Time: 20:43:56
    Component: IMMO H03 0205
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
    VCID: 6ADA496E8D66EE1A6B-803E
    PartNoSW:5N0035342F HW:5N0035342F
    Component: SG EXT.PLAYER H19 0550
    Revision: A1001003 Serial number: 7663885169
    Coding: 010100
    VCID: 2A5A896E45E62E1AAB-807E
     Part No: 6R0 423 156 A
     Component: LenkhilfeTRW V275
     Coding: 10150
     Shop #: WSC 00788
     VCID: 2E52857EED0E423A77-807A
    Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
     Part No SW: 3C8 035 195 HW: 3C8 035 195
     Component: Radio RCD510 036 0130
     Revision: 00000001 Serial number: VWZ1Z3I4227281
     Coding: 0501000001
     Shop #: WSC 00028 028 00001
     VCID: 65C03A526C78C16246-8030
    Reset counter: 221
    Mileage: 96694 km
    Date: 2013.06.05
    Time: 20:43:56
    00856 - Radio Antenna
     Fault Status: 00101011
     Fault Frequency: 27
     Reset counter: 198
     Mileage: 176392 km
     Date: 2013.11.08
     Time: 09:10:29
     Reset counter: 198
     Mileage: 140558 km
     Date: 2014.02.14
     Time: 21:03:20
     03138 - Input AUX IN
     Reset counter: 187
    PartNoSW:5K0035730D HW:5K0035730D
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007662541084
    Coding: 0810000000010110
    ASAM Dataset: EV_UHVNA A01719
    ROD: UHVNA.rod
    VCID: 26427D5E59FE0A7A8F-8072
    images: (sorry didn't find the option to upload them)
    https://imgur.com/a/jKEHb31
    https://imgur.com/a/sl4LBUk
    Feb 2019
    Belgium
    No-one knows?
    United States
    Hi Jasper,
    Per your email to support (regarding that ROD problem) I'm moving this thread to our Retrofit section. I'll report back if I have any suggestions or contributions regarding the telephone module. In the meanwhile this page isn't entirely up to date but it may help: http://wiki.ross-tech.com/wiki/index...)_Retrofitting
    United States
    Well, that Wiki page isn't gonna help much because we don't have all of the 5K0-035-730-D details at this time.
    Moving forward, I don't believe the 56 coding is causing your issue but the sound system (i.e. with a diag capable 47 module) configuration isn't correct so you might want to try: 0500040004
    If that causes speaker faults you can use the LCH to fine tune the installed speaker configuration.
    77 appears to be coded properly as far as I can tell but sorting the phone book by last name might be worth experimenting with. In that case you would go with: 0800000000010110
    I had a RNS510 -and- (7P6 035 730 C) 9W7 retrofitted to a 2010 GTI at one point years ago and I was using the 77 coding of 0200000000010100 but I had a factory fitted overhead BT button pack so the last Byte was 00'd.
  5. Likes Eric, Uwe liked this post
    Feb 2019
    Belgium
    Thanks for your reply, Dana!
    I tried sorting the phone book by last name, but this didn't help much. Still looks the same actually.
    Coding of the 56-Radio module indeed causes speaker faults. Already experienced those back in September and turned off the speaker monitoring system back then to disable the faults.
    This was my coding back in September compared to now (0501000001):
    VCDS Self-Diagnosis Log Monday,10,September,2018,11:31:09:06407 Page 5
    VIN: WVWZZZ6RZAY173210   License Plate:
    Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
    Component: Radio RCD310  016 0049
    Revision: 01000000    Serial number: VWZ1Z2K7023823
    Coding: 0000040002
    VCID: 6BD44C6A8A9CF71CE1-803E
    2 Faults Found: 00874 - Treble Speaker Front Left (R20)
    Reset counter: 188
    Mileage: 92076 km
    Date: 2013.01.31
    Time: 11:30:05
    Reset counter: 188
    Mileage: 92076 km
    Date: 2013.01.31
    Time: 11:30:05
  7. Likes Dana liked this post
