Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Audi A3 8V facelift - AUTO HOLD retrofit
    Mar 2014
    Slovenia
    AUTO HOLD has been retrofitted to A3 MY2017, the problem is the coding.
    Set was bought from k-electronics, but their instructions for coding do not work.
    Has anyone successfully coded AUTO HOLD retrofit?
    Part No SW: 8V0 907 379 B HW: 8V0 907 379 B
    Component: ESC H25 0610
    When trying to code IDE05263-AUTO HOLD functionality to activated, message Enter security code appears even if 20103 was accepted before chaning the add. channel. I have tried also with a few other codes and the same happens.
    And after the coding was done:
    319C6B8D549B1BAB89930B694191698CD62AD891D082967602 4100F4820812 to
    319C6B8D549B1BAB4B930B694191698CD62AD8D2D082967302 4100F4820812
    the following trouble code appears in ABS module:
    4410 - Indicator Lamp in Auto-Hold Switch
    C1156 14 [009] - Open or Short to Ground
    Reset counter: 246
    Mileage: 66349 km
    Date: 2019.04.04
    Time: 14:58:46
    May 2017
    Wiring issue? Coding seems to be working as it throws an error about autohold indicator light.
    Mar 2014
    Slovenia
    It should not be the case, since the installation has been done at Audi dealer.
    And I have found a few others with the same problem...
    Does anyone have a facelifted A3 with AUTO HOLD installed and 8V0 907 379 B ABS control unit, quattro, S-tronic, if possible without ACC. I would appreciate coding, so I can try to get the correct coding.
    Jun 2017
    Use security code 24990
  5. Likes Dana, Uwe liked this post
    May 2017
    Can you post full autoscan from the car?
  7. Likes Dana liked this post
    United States
    Please do let us know if 24990 allows you to modify that channel. There threads include alternative codes:
    https://forums.ross-tech.com/showthr...l=1#post148438
    https://forums.ross-tech.com/showthr...8737#post88737
    Do make sure Adv measuring value IDE00323 -- Security Access: Number of invalid keys isn't over 2 or the module will likely refuse valid SA codes.
  9. Likes Uwe, downtime liked this post
  10. #7
    Jun 2017
    Quote Originally Posted by mtl View Post
    Could you please quote the coding instructions from K-Eletronics?
    They were wrong for a long time.
  11. Likes Uwe, Dana liked this post
  12. #8
    United States
    Thanks hadez16,
    I may not be correct here, and really should wait for the scan with VIN, but I believe this would be the new coding based on the original value:
    319C6B8D549B1BAB8B930B694191698CD62AD8D1D0829677024100F4820812
    Last edited by Uwe; 05-07-2019 at 07:35 PM. Reason: CODE tags to keep the forum software from inserting a superfluous blank in the coding string
  13. Likes Uwe, downtime liked this post
  14. #9
    Mar 2014
    Slovenia
    Quote Originally Posted by Rainesh View Post
    It was not accepted.
    I haven't checked this value, but some other security codes were accepted, so this should not be a problem.
    Byte 08 to 4B
    Byte 19 to D2
    Byte 23 to 73
    Byte 25 to 41 (automatic, this was already from factory coded)
    AUTO HOLD functional status - always active
    AUTO HOLD functionality to active (this one does not work)
    But I think it is not a problem in this add. channel, but the coding is wrong.
    So, the factory coding was:
    Recoded:
    I have access to newer FL Audi A3 with Auto Hold, but they have newer ABS unit (5Q0-614-517-AC) and the coding is completelly different. It would be great if somebody has 8V0 907 379 B with AUTO HOLD activated, so I could try to get the coding out.
    It is not my car, so I cannot post it. What part of it do you need?
  15. #10
    May 2017
    I want to see the complete scan. What are the modules in the car, what is the abs unit and what is the coding in it. Also VIN number is needed for abs coding.
  16. Likes Dana liked this post
