Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: A4 B8 Avant - coding issues after Keyless Go / Xenon retrofit
    Aug 2014
    I've retrofitted both Keyless Go and Xenon/LED to my 2013 Audi A4 Avant....
    I have 2 (well 3 actually) problems:
    1) Keyless Go is working almost perfekt. Start button is working. Door handles locks all doors, but when unlocking the car I've got a problem.
    - If I touch the driver door handle, all other 3 doors unlocks. Driver door remains locked
    - If I touch the front passager door handle, all other 3 doors unlocks. Front passenger door remains locked
    - If I touch the one of the the rear doors handle, all other 3 doors unlocks.
    It must be a coding issue, but I've really can't see what's going on.
    Bonus info: [46] is a used box found on Ebay.
    2) My xenon/LED lights are working as they should, however what byte should be enabled for this cornering lights to be enabled ?
    3) Service Due! I've reset the service information and in MMI inspection and next oil change is in 27.000 km/+ 500 days, but the cluster keeps telling me that it's time for service when I put the ignition on/off.
    What adaption channel do I need to reset ?
    Hope it's okay with multiple questions in one thread :-)
    Friday,03,August,2018,09:04:03:21096
    VCDS Version: 18.2.1.5
    VIN: WAUZZZ8K3DA044370   License Plate: A4
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 03 05 08 09 13 15 16 17 19 20 3C 42 44 46 47 52 53 56 5C
              5F 62 69 6C 6D 72
    Address 01: Engine (B8-PA-CDHA)       Labels:. 06H-907-115-CAB.clb
       Part No SW: 8K1 907 115 N    HW: 8K1 907 115 N
       Component: 1.8l R4/4V TF H04 0002
       Revision: PBH04---
       Coding: 12190013045401022000
       Shop #: WSC 06208 123 12345
       ASAM Dataset: EV_ECM18TFS0118K1907115N 001004
       ROD: EV_ECM18TFS0118K1907115N.rod
       VCID: 3972996DB80BFA8C23-806C
    Readiness: 1110 0101
       Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
       Component: ESP8 front    H09 0020
       Coding: 16DDC401
       Shop #: WSC 06325 123 12345
       VCID: 07162F95B67F5C7C65-8052
       Part No SW: 8K0 907 064 HJ    HW: 8K0 907 064 GJ
       Component: BCM2 2.0      H13 0641
       Coding: 07A24000000000000000
       Shop #: WSC 12345 123 12345
       VCID: 7F06B775EEAF14BC5D-802A
       Serial number: 2312000060374001
       Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
       Component: KLIMA 3 ZONEN H04 0036
       Revision: C1000000    Serial number: 01220320120348
       Coding: 643802C000
       Shop #: WSC 06335 123 12345
       VCID: 336EAB45926700DCE9-8066
                        Reset counter: 126
                        Mileage: 77270 km
                        Date: 2018.08.03
                        Time: 08:59:17
       Revision: 08016001    Serial number: 00000789001102
       Coding: 26008011C074AFE00681400300001D0D439C270826080341000008000000020000000034000000
       VCID: 78F45C69CB8123841C-802C
       Component: WWS 250312  H07 0070
       Serial number: SWF12030255319
       Coding: 00FD11
       Serial number: 20209350
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001703121109
       Serial number: 5018CD16000000000001
                        Reset counter: 126
                        Mileage: 77270 km
                        Date: 2018.08.03
                        Time: 08:59:18
       Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
       Component: ACC3          H11 0100
       Coding: 00A4B1
       VCID: 3162A14D687B32CC9B-8064
       Serial number: 003KFD91YZKL
       Coding: 30514435363030303030554A304C384B3053
       Shop #: WSC 05298 002 1048576
       VCID: 4894ECA9F3E19304AC-801C
       Serial number: 6334MSME6C112A41A
       Serial number: 6344MSME6D740409H
       Serial number: 6352QSME530F354AM
       Serial number: 6362QSME570F3F6E0
       Serial number: 63732SME7E0F586CN
       Serial number: 63832SME7A0F22665
       Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
       Component: Lenks.Modul   H03 0004
       Revision: --------    Serial number: 90372LAA00140
       Coding: 0000DF
       VCID: 448CF899C7C9B76440-8010
       Part No SW: 8K0 920 931 D    HW: 8K0 920 931 D
       Component: KOMBIINSTR.   H05 0534
       Revision: 00100000    Serial number: IWU271V4C
       Coding: 0FFF100047010008010001
       Shop #: WSC 00751 204 00897
       VCID: 2F66A7357E4F243C8D-807A
       Revision: 1Z120030    Serial number: 3041Z153080152
       Coding: 80C307FF00
       Shop #: WSC 02391 785 00200
       VCID: 4C9CD0B9EF997F2488-8018
       Serial number: 8519277101
       Serial number: 12056001533021200410
       Revision: AA001002
       Coding: 02019164747464545425363E00
       Shop #: WSC 06385 000 00000
       VCID: 7CFC4079FFB90FA478-8028
       Component: SWA Master    H03 0060
       Serial number: 0187427767
       Coding: 010321
       Shop #: WSC 02152 785 00200
       VCID: 3F86F775A62FD4BC1D-806A
       Component: SWA Slave  H03 0060
       Serial number: 0187448857
       Coding: 000103
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000098250416
       Coding: 011F02205000410001
       Shop #: WSC 00605 128 28888
       VCID: 4FA6C7B51E8F443CED-801A
       Revision: 00001000    Serial number: 0010433530
       Coding: 100001010001
       Shop #: WSC 17369 123 104857
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 346CA8599F6907E4F0-8060
       Revision: 00002001    Serial number: 0319784903
       Coding: 01161F2020FD30C183B0023EA4000000
    01134 - Alarm Horn (H12)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 126
                        Mileage: 77270 km
                        Date: 2018.08.03
                        Time: 08:59:21
       Revision: 00005001    Serial number: 94813006913102
       VCID: 2D5ABD3D7443562CBF-8078
       Component: TSG BF        H02 0510
       Revision:             Serial number: 0000072597277
       Coding: 011F02205C00410001
       VCID: 4E98DAB119854D34E6-801A
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 30000000034229
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 36689251891515F4CE-8062
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H52 0154
       Revision: AB001007    Serial number: 109FV0B7526224
       Coding: 010105010000000001
       Shop #: WSC 31414 790 00001
    Address 5C: Lane Maintain.        Labels: None
       Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
       Component: J759 HC             0040
       Revision: 00H08004    Serial number: 4002121190000E
       Coding: 0122002
       Shop #: WSC 06765 128 28888
       VCID: 37769F55461FECFCD5-8062
       Part No SW: 8R1 035 670 M    HW: 8R1 035 670 C
       Component: H-BNT-EU      H46 1036
       Revision: --------    Serial number: 207GZ0D7554081
       Coding: 0F0100010206EBFF3F80EF7E00000403040000000100000300
       VCID: 3D7A8D7DA423C6AC0F-8068
       Subsystem 1 - Part No: 8R0 060 884 EM
       Component: EUR 2017/2018  2503
       Component: DU7 High  H42 0104
       Serial number: A130CK0F3302257
       Serial number: 00000002049538
       Component: CD-Database  5298
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Revision:             Serial number: 0000027010898
       Coding: 010C02204000210001
       VCID: 438EFB85C2C7B05C79-8016
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00000142341233
       Coding: 010D000000000000
       Shop #: WSC 25381 000 00000
       VCID: 36689251811515F4CE-8062
       Revision: --H11---    Serial number: 525PA8-JB490BS
       Coding: 1030007
       Shop #: WSC 98765 666 38384
       VCID: 38749C694B01E384DC-806C
                000 -  -
                        Reset counter: 126
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H51 0330
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C7C8079BF39CFA438-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H51 0330
       Serial number: 8K9827852A
       Revision:             Serial number: 0000027010090
    End-------------------------(Elapsed Time: 04:00)--------------------------
    Audi A4 Avant - '13
    Next mod: none... Strange...
    Completed: Sport Edition Plus bumpers, Xenon/LED, MMI 3G+ DAB/SIM, PDC, A6 4G exterior door handles with lights, reverse camera, ACC, electric trunk, footwell lights, trailer hitch, Bang & Olufsen DSP, Side Assist, Active Lane Assist and Keyless Go
    Quote Originally Posted by diskoboy View Post
    Probably 53 or 55, but...
    Go to [SRI Reset], let VCDS read all the SRI-related channels, then click [Add to logfile] and post the file here so we can see exactly what's going on.
    Aug 2014
    Here you go
    VCDS Release 18.2.1:  SRI Reset
    Control Module Part Number: 8K0 920 931 D       Labels:  .8T0-920-xxx-17.clb
    Component:KOMBIINSTR.   H05 0534, Coding:0FFF100047010008010001
    Channel  	Description                                       	Unit      	Current val.  	New val.
    02       	Service Reminder Status                           	          	1             	---
    40       	Distance since Service                            	km x100   	0             	---
    41       	Time since Service                                	Days      	1             	---
    42       	Minimum Distance to Service                       	km x100   	150           	---
    43       	Maximum Distance to Service                       	km x100   	300           	---
    44       	Maximum Time to Service                           	Days      	730           	---
    45       	Oil Quality                                       	          	2             	---
    47       	Soot Quantity                                     	DIST x100 	0             	---
    48       	Thermal Load                                      	DIST x100 	0             	---
    49       	Minimum Time to Service                           	Days      	365           	---
    50       	Basic Distance Value for Oil Change               	km x100   	150           	---
    51       	Basic Time Value for Oil Change                   	Days      	365           	---
    52       	Basic Distance Value for Inspection               	km x100   	300           	---
    53       	Distance since Inspection                         	km x100   	16            	---
    54       	Basic Time Value for Inspection                   	Days      	730           	---
    55       	Time since Inspection                             	Days      	20            	---
    56       	Day Counter                                       	Days      	2433          	---
    Audi A4 Avant - '13
    53 and 55 look OK; they are less than 52 and 54 respectively, so they're not the reason why the light remains on.
    But 02 is a 1 in it. That indicates service is due. Not sure how/why what you've done so far, but looking at where it is right now, I'd just go put a zero into channel 2, with considerable confidence that will get the warning gone.
  5. Likes PetrolDave liked this post
    Jun 2017
    Regarding your static cornering lights:
    You can try two things:
    BCM, Set Bit 3 in Byte 4
    Test it.
    If it does not work, reset it again.
    Then set Bit 0 in Byte 31 please and test.
  7. Likes Uwe liked this post
    Aug 2014
    Test it.
    Thanks for your sugestions :-)
    Bit 3 Byte 4 - didn't do anything
    Bit 0 Bite 31 however gave me this:
                    Address 09: Cent. Elect.       Labels: 8K0-907-063.clb
    Control Module Part Number: 8K0 907 063 DH    HW: 8K0 907 063 DH
      Component and/or Version: BCM1 1.0      H16 0103
               Software Coding: 2600C0108074AFC00081400300001D0D0F9C270826090341000008000001020100000034000000
                Work Shop Code: WSC 06335 123 12345
                          VCID: 78F45C69DB8123841C-802C
    00497 - Sensor for Vehicle Leveling; Rear
                        Fault Status: 00100111
                        Reset counter: 177
                        Mileage: 77511 km
                        Date: 2018.08.06
                        Time: 21:07:19
    01312 - Powertrain Data Bus
                        Reset counter: 137
                        Mileage: 77511 km
                        Date: 2018.08.06
                        Time: 21:07:58
    1) Ive noticed that only the left side headlight went up/down when the ignition is on. Is there a easy way to test the modules like if the car has the [55]-module? I’ve been looking through all adaptation channels but can’t find any relevant...
    2) Rear sensor - any adaptation channels?
    3) After adding byte 31 bit 0 it throws the power train can error . Why? And what pins should they be connected to?
    Audi A4 Avant - '13
    Aug 2014
    Channel 2 is now 0... "Service Due!" is still showing. I've also pulled out the battery just to be sure.
    Audi A4 Avant - '13
  10. #8
    Aug 2014
    Audi A4 Avant - '13
  11. #9
    Please post an updated log of the channels, like you did in post #3.
  12. #10
    Aug 2014
    Here is an updated scan:
    41       	Time since Service                                	Days      	2             	---
    53       	Distance since Inspection                         	km x100   	18            	---
    55       	Time since Inspection                             	Days      	25            	---
    56       	Day Counter                                       	Days      	2438          	---
    Audi A4 Avant - '13
