Hello ,
Just run for the first time and disappointed the measuring block button does not work on my car. Advanced Measuring values button works fine. Probably something basic I am missing.
I have a screenshot.
https://imgur.com/a/OpnwoAs
Here is the autoscan
Monday,11,February,2019,22:11:22:10363
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8K8DA019111 License Plate: KY12TYV
Mileage: 167120km-103843mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K8DA019111 Mileage: 167120km-103843miles
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 KD HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9978
Revision: 45H25---
Coding: 32194012242601080000
Shop #: WSC 45123 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018KD 003005
ROD: EV_ECM20TDI01103L906018JG.rod
VCID: 76B5E47C3845BA07B41-8022
5290 - Throttle Actuator Control Circuit
P2100 00 [032] - Open Circuit
5305 - Throttle Position Sensor (G69)
P0123 00 [032] - Signal too High
4891 - EGR Valve (N18)
P0403 00 [104] - Malfunction
Fault Frequency: 41
Mileage: 163395 km
Date: 2018.09.22
Time: 10:54:51
Engine speed: 2675.00 /min
Normed load value: 7.1 %
Vehicle speed: 41 km/h
Coolant temperature: 45 °C
Intake air temperature: 20 °C
Voltage terminal 30: 14.620 V
Unlearning counter according OBD: 36
Air mass: actual value (mg/stroke): 523.9 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 91.31 %
EGR valve: offset closed: 0.12 %
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 16
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 7
High press EGR actuator: actual unconditioned volt val: 1017.4 mV
4892 - EGR Valve (N18)
Fault Frequency: 44
Mileage: 161217 km
Date: 2018.06.14
Time: 07:43:17
Engine speed: 2887.50 /min
Normed load value: 4.7 %
Vehicle speed: 43 km/h
Air mass: actual value (mg/stroke): 289.6 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 15.00 %
EGR Solen.val.: actual value: 19.48 %
High press EGR actuator: actual unconditioned volt val: 3680.0 mV
Readiness: 0 2 0 0 0
Part No SW: 8K9 907 379 L HW: 8K9 907 379 L
Component: ESP8 quattro H09 0100
Coding: 061544
Shop #: WSC 06334 000 00000
VCID: 4BC3658813C797EF3BF-801E
Part No SW: 8K0 907 064 FC HW: 8K0 907 064 FC
Component: BCM2 2.0 H10 0602
Coding: 03B20000000000000000
Shop #: WSC 06335 000 00000
VCID: 76B5E47C38C5BA07B41-8022
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0812000010987021
Serial number: 2312000008927005
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AD HW: 8K2 820 043 AD
Revision: D1000000 Serial number: 01010220120923
Coding: 342402E000
VCID: 6B83C508738777EF5BF-803E
Part No SW: 8K0 907 063 DD HW: 8K0 907 063 AD
Component: BCM1 1.0 H14 0103
Revision: 04014001 Serial number: 00000026734701
Coding: 290000308034A7C00081000300001F1F001D070827080201000008000000030000000024000000
Shop #: WSC 24550 000 1048576
VCID: 74B1DE742EB9A8178A5-8020
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 030212 H06 0070
Serial number: SWF12020030078
Coding: 00FD11
Component: G397_RLFS H06 0001
Serial number: 20146343
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002601121540
Component: AQ_Hum_Sensor H02 0002
Serial number: 71080F06000000000001
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD90VJ4S
Coding: 30534435363030303030554A3052384B3053
VCID: 48C95A8402317CF716D-801C
Serial number: 6334MSME6A7043238
Serial number: 6344MSME6B1405359
Serial number: 6352QSME446C1848O
Serial number: 6362QSME3C6C307AV
Serial number: 63732SME446D0354
Serial number: 63832SME196C0A667
Revision: 00000000 Serial number: 20120209000335
Coding: 000017
VCID: 4FFB7198E7DFABCF577-801A
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 982 B HW: 8K0 920 982 B
Component: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NTE21312D
Coding: 3304290202012600010000
VCID: 33331D686B37EF2F53F-8066
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y1213102A5
Coding: 00CF07FF00
VCID: 3FDB4158577F3B4FA77-806A
Serial number: 0285756701
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 12021001088011200181
Reset counter: 109
Mileage: 166521 km
Date: 2019.01.31
Time: 20:20:24
Bin. Bits: 10111
Voltage: 11.30 V
Count: 6
Part No SW: 8K0 959 793 Q HW: 8K0 959 793 Q
Component: TSG FA H02 0506
Revision: Serial number: 0000022583491
Coding: 011002204001410001
VCID: 4EC56C9CE0D5A2C75C1-801A
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0028339006
Coding: 100000000001
Shop #: WSC 24552 000 1048576
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311E746EB9E8174A5-8060
Revision: 00002001 Serial number: 0168122851
Coding: 013B062220B900408020023680000000
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 39
Reset counter: 78
Mileage: 163076 km
Date: 2018.09.01
Time: 18:07:53
02615 - Fuel Tank Cap; Lock
Fault Frequency: 13
Reset counter: 78
Mileage: 166153 km
Date: 2019.01.04
Time: 18:25:55
Part No SW: 8K0 959 792 Q HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000023538209
VCID: 4DC76B90EDD399DF25B-8018
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 10000000015760
ROD: EV_ParkiBrake_AU48.rod
VCID: 3635247C78C5FA07741-8062
Part No SW: 4G0 035 056 D HW: 4G0 035 056
Component: Radio U STD H60 0094
Revision: AB001007 Serial number: 229B-0C7553067
Coding: 010003020100000001
VCID: 221DE82CC4CD76A7A89-8076
Part No SW: 8R2 035 652 A HW: 8R2 035 652
Component: B-BN-EU H62 0175
Revision: -------- Serial number: 147BP0C7506005
Coding: 01010101000681ED01800B4E000000030000
VCID: 323D186C942DE627589-8066
Subsystem 1 - Part No: 4G0 919 884 K
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Serial number: 9465AU0C2504754
Subsystem 3 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Serial number: 00000001062793
02244 - Button in Control Head is Stuck
Reset counter: 79
Mileage: 167129 km
Date: 2019.02.11
Time: 22:06:11
Voltage: 12.10 V
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000001
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000023308328
Coding: 010002204001210001
VCID: 43D34DA83B975FAFC3F-8016
Component: TSG HR H01 0506
Revision: Serial number: 0000023308409
End----(Elapsed Time: 02:00, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
