Blocking of particle filter regen?
suffeks
Poland
C?ID=128398
i found a row IDE01711 - blocking of particle filter regeneration, if i set this to active will the car stop doing dpf regens? i am thinking dpf delete but was told i need new soft for the ecu but here i found this vcds option...
1.6 tdi with 190k km, still on original dpf, i understand its 60g/70g full?
Address 01: Engine  (03L 906 023 PF)
13:12:30
  IDE00427-ENG101722   Particle filter: difference pressure-DIP_PF 3.15 hPa
  IDE00428-ENG100917   Particle filter: offset for differential press.-DIP_PF_AD[0] -2.74 hPa
  IDE00432-ENG103847   Particle filter: time since last regeneration-T_WOUT_RGN 6517.10 s
  IDE00433-ENG103279   Particle filter: oil ash volume-MASS_ASH_PF 60.5141966 g
  IDE00434-ENG102050   Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 8.12 g
  IDE00435-ENG101197   Particle filter: soot mass measured-MASS_SOOT_PHY_PF -2.04 g
  IDE00436-ENG102397   Particle filter: kilometers since last regeneration-DIST_RGN 71.1 km
  IDE01409-ENG102169   Charge limit for service regeneration-Ash Mass Diag 40.00 g
  IDE01410-ENG102169   Charge limit over-charge-Ash Mass Diag 45.00 g
  IDE06059-ENG103279   Particulate filter: oil ash mass-MASS_ASH_PF 60.5141966 g
  IDE06060-ENG111632   Particulate filter ash load limit-C_MASS_ASH_PF_LIM_TEST 70.00 g
  ENG110258-ENG99928   X_Soot_equivalent_of_ash_mass-MASS_SOOT_EQU_ASH_PF 0.56 g
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Thread lock based on e-mail report until further notice. Tnx for understanding.
Cleaned up and unlocked.
suffeks
Poland
C?ID=128398
i guess if nobody wants to answer i will set it and see if it stops doing regen based on the time and distance traveled, and i will report back for the non tree huggers
I am going to speculate that if this works at all, it will reset back to 'not active' every time the engine is turned off and back on again.
suffeks
Poland
C?ID=128398
haha sounds like super accurate "speculation" ok we will see
AIB Wolfgang
Man's will is his heaven!
The saying goes that the freedom to make decisions yourself is a very high good. It is compared to the kingdom of heaven.
Sometimes the saying is used sighing and slightly ironic: one fulfills a wish or leaves it to one's will, even though one knows
that it is not necessarily for his good or that there are equivalent alternatives.
:cool:
suffeks
Poland
C?ID=128398
i was curious and called dealer, new dpf costs $2400USD, thats crazy, considering the price of the car i want to replace it in is worth $5k
this is how we clean dpf filters in poland lol
Did you use oven cleaner first? :cool:
suffeks
Poland
C?ID=128398
ok so like you said, after 5-6 restarts the ecu turned back stop dpf regen from active to not active, either after restarts or when the time/distance counter gets too high, so will need to get a remap
6831970997625578073%253Faccount_id%253D0
Did you really think there would be a setting in the ECU that would permanently disable regeneration, which would certainly clog up the DPF, eventually reaching the point where the engine won't even run? :rolleyes:
suffeks
Poland
C?ID=128398
YES
and i wish it was the dieselgate easter egg haha anything possible
suffeks
Poland
C?ID=128398
no dieselgate wasnt crazy at all....
It wasn't staring anyone right in the face in the scan-tool API though. In fact, there's still no clear way to tell when those engines are in "test" mode vs. "cheat" mode using a scan tool.
PetrolDave
Westbury, UK
C?ID=1423
VAG bosses were crazy to think that they could get away with it.
I'm just surprised that the other car manufacturers have covered up their cheats more effectively so it's taking longer to find them out - but some others have been found out and I'm confident there are more manufacturers who still have a "guilty secret" waiting to be made public :cool:
