Wednesday,13,February,2019,11:10:18:02696
VCDS Version: 18.9.1.0 (x64)
VIN: WVGZZZ5NZGW30xxxx License Plate:
Mileage: 66066km-41051mi Repair Order:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 42 44 52 55 5F
69 A5
VIN: WVGZZZ5NZGW301089 Mileage: 66066km-41051miles
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EH HW: 04L 907 309 M
Component: R4 2.0l TDI H23 2950
Revision: B4H23---
Coding: 0125001A04761D083000
ASAM Dataset: EV_ECM20TDI01104L906026EH 004002
ROD: EV_ECM20TDI01104L906026EF_004.rod
VCID: 74EC37F8DFB1A7EAC9-8020
7158 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [032] - -
4997 - Glow Plug Control Module
P064C 00 [032] - -
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 011 A HW: 0DE 927 711
Component: GSG DQ500 H12 1406
Revision: 00H12V32
ROD: EV_TCMDQ500021.rod
VCID: 26481DB059ED857A87-8072
Part No SW: 5Q0 614 517 BH HW: 5Q0 614 517 AD
Component: ESC H25 0507
Revision: 00000000 Serial number: 60816000000020
Coding: 0AEE6A9A34200B6D4777670862CC4950562CD0E2E646927D38625078C22A02
VCID: 78F403C8C3D9C38AE5-802C
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0398751509
Coding: 030C0C0F03
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 3A70D9C0BD55119AD3-806E
U1400 00 [008] - -
Reset counter: 211
Mileage: 66018 km
Date: 2019.01.24
Time: 14:52:06
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 E HW: 5NA 907 044 E
Component: AC Automat H35 4001
Revision: 20K07000 Serial number: 00000B00080673
Coding: 0002010420411101110510000010100A
ASAM Dataset: EV_ACClimaPrehVW37X 002014
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 4182AE2CD083424292-8014
Subsystem 1 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 00000000000000000000
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Fault Frequency: 29
Reset counter: 207
Mileage: 65552 km
Date: 2018.12.06
Time: 19:49:04
Outside air temperature: 0.0 °C
Voltage terminal 30: 14.7 V
System run time-Engine running time: 253 s
System run time-Terminal 15 on: 253 s
Air quality status: ERROR
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 BQ HW: 5Q0 937 084 BQ
Component: BCM MQBAB H H32 0212
Serial number: 00021607401548
Coding: 00031E46C24112FB4FE44010001C07281C80000000000000000000000000
ASAM Dataset: EV_BCMMQB 016001
ROD: EV_BCMBOSCH_016_VW37.rod
VCID: 08147308B339B30A95-805C
Subsystem 1 - Part No SW: 5NB 955 119 HW: 5NB 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 160218 033 0372
Serial number: 00000001602150300076
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y16M03D31H13M12S49
Coding: 00A8DD
Part No SW: 3Q0 919 294 HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0152
Serial number: 002002167478020
Coding: 0071051911
ASAM Dataset: EV_EPHBO18VW3260000 007013
ROD: EV_EPHBO18VW3260000.rod
VCID: 76E80DF0C9CDB5FAF7-8022
1112049 - Parking Sensor; Front Left
B10F7 F1 [008] - Reverberation Time too Long
Reset counter: 211
Mileage: 66018 km
Date: 2019.01.24
Time: 14:52:13
1079025 - Parking Sensor; Rear Left
B1076 F1 [008] - Reverberation Time too Long
Reset counter: 211
Mileage: 66018 km
Date: 2019.01.24
Time: 14:52:13
10494464 - Function Limitation due to Environmental Factors
B2022 00 [008] - -
Reset counter: 211
Mileage: 66018 km
Date: 2019.01.24
Time: 14:52:13
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 H HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0155
Coding: 320147C950FF8728749C806D304085
ASAM Dataset: EV_ACCMRRCONTIVW376 001010
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 3972C6CCB8531A82DA-806C
196743 - Sensor for Automatic Distance Control
Reset counter: 198
Mileage: 65521 km
Date: 2018.12.06
Time: 18:50:25
Voltage terminal 15: 14.4 V
Control Module temperature: 25 °C
Velocity_vehicle_reference: 13.48 m/s
Longitudinal_acceleration_vehicle_reference: 0.69 m/s²
Part No SW: 5Q0 959 655 AE HW: 5Q0 959 655 AE
Component: AirbagVW21 005 0130
Serial number: 003NSR1LL10$
Coding: 98FCC0C00C0000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 030E64248A1F9052C0-8056
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5NB857705C0079Q01120
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5NB857706C0076Q00613
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 903 16
Serial number: 357000000006AA2C8A1V
Subsystem 4 - Part No SW: ----------- HW: 480 002 903 16
Serial number: 358000000006A72C8A1T
Subsystem 5 - Part No SW: ----------- HW: 480 403 003 16
Serial number: 3510001B920E271426D
Subsystem 6 - Part No SW: ----------- HW: 480 402 202 16
Serial number: 3520001AF1EE218304A7
Subsystem 7 - Part No SW: ----------- HW: 480 402 403 16
Component: FrontSensor_D 000 6149
Serial number: 3550001AB20E2712C1F5
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 400 104 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001BD20A94F43536
Subsystem 9 - Part No SW: ----------- HW: 480 400 104 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001BD20A94F4679I
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 400 104 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001BF20A94F233A4
Subsystem 11 - Part No SW: ----------- HW: 480 002 902 16
Component: PedPSensor_D2 001 0887
Serial number: I0M000000005DB81A91C
Subsystem 12 - Part No SW: ----------- HW: 480 002 902 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000BF09D891L
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160313400541
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F86A8D4A67734B2E4-806A
Part No SW: 5NA 920 751 HW: 5NA 920 751
Component: KOMBI 308 6421
Coding: 07A40018EF84000801886B031401000000000000
VCID: 7CFC1FD8F7E1EFAA81-8028
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
VCID: 3874C3C88359038A25-806C
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001294010
0036 - Fuel Level too Low
P1250 00 [008] - -
Reset counter: 211
Mileage: 66006 km
Date: 2019.01.23
Time: 07:39:16
Operating condition of parking heater: Start
88
Coolant temperature of parking heater: 72 °C
Coolant temperature: 69 °C
Engine running status: detected
Fuel level: 10 l
Heater output: 2440 W
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 19031610801101
Coding: 030500341F087300FB03225E1E0F00010001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 79F206CCF8D3DA829A-802C
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 0681618381502166AS2B
Coding: 2D0000
Subsystem 3 - Part No SW: 5QA 915 181 B HW: 5QA 915 181 B
Component: J367-BDMHella H10 9052
Serial number: 8801249703
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00023.02.16
Coding: 0101
VCID: 4A908900EDB5811A43-801E
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000052758001
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E23EECA0A392C222-8024
Component: TSG FS 020 0041
Serial number: 160216EBG15285
Coding: 00311320D000048000001000
VCID: 438EA424CA9F505280-8016
Serial number: 00000000000009387676
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000700121
Coding: 01000011004001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D7AD2DCAC7B26A2F6-8068
Component: TSG BFS 020 0041
Serial number: 290116EAS02083
Coding: 00311120DC00048000001000
VCID: 4280A120D585595A8B-8016
Serial number: 00000000000009410139
Coding: 090000
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Coding: 08AA00104B200201
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER 820 0624
Coding: 02730601FF00000051111101008808001F0100C4012001008E
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3064FBE86B29DBCA6D-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL00ACQ
Subsystem 2 - Part No SW: 3G0 919 866 M HW: -----------
Component: ECE 2016 --- 0521
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0398536619
Coding: 0100000202000000
VCID: 3B7EDCC4B26F2892C8-806E
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 E HW: 3Q0 980 654
Component: MQB_B_MFK H04 0211
Serial number: 30031611P10364
Coding: 0003070600000401002213458050A10094000E200040
End-------------------------(Elapsed Time: 05:35)--------------------------
Have a V2 cable at home, so the "Only supported by current.gen interfaces" will be resolved shortly.
