T5 ABS Coding - Help needed
Veedubmad
Verified VCDS-Lite User
C?ID=197935
Hi, I'm having an issue with the ABS unit on my VW T5 MULTIVAN, i have found a replacement with the same part numbers but cannot access the old unit to find out the original coding.
Can anyone help by working out what my login & coding details from the following vehicle info ?
WV2ZZZ7HZ4H05XXXX
7HM C11
Multivan Come. KR
128kw TDISG6
AXE GWB
LA5W 0000 0000 EJ
X10 B0A CS3 G0K H2N J1U MS0
1AT 1G2 2PW 1NL 5RQ 5SL T86
3S4 3U4 QG1 8UT 8GV 8L6
1BA 0GE
0E1 4UF 4X3 4R1 4K3 N0H 5MA
9VK 2JG E0A 2V1 0JE 0YB
1D2 A8E 8EL U5A 1N1 3L3 4A3 8N1
Any help would be greatly appreciated ?
Veedubmad
C?ID=197935
Hi I can post a full scan but there’s no abs unit currently connected as it has been removed and sent away for testing.
Will this help ?
Will this help ?
No, not really. Please do it when you get the module back and re-installed.
Veedubmad
C?ID=197935
This was the scan I did before disconnecting it however I believe the connector on the coolant expansion tank was disconnected at the time.
Chassis Type: 7H - VW Transporter
Scan: 01,02,03,08,09,0B,0D,15,16,17,18,19,1C,22,2D,37,45,46,47,56,57,6E,76,77,78,7D
Address 01: Engine       Labels: 070-906-016-AXD.LBL
   Controller: 070 906 016 AN
   Component: R5 2,5L EDC G000SG  5394
   Coding: 0001072
   Shop #: WSC 02756
   VCID: 5CCBD6C7DF33
8 Faults Found:
18057 -  Powertrain Data Bus: Missing Message from ABS Controller
            P1649 - 000 -   -
18044 -  Powertrain Data Bus: Missing Message from Airbag Controller
            P1636 - 000 -   -
18045 -  Powertrain Data Bus: Missing Message from Electric Load Controller
            P1637 - 000 -   -
18043 -  Powertrain Data Bus: Missing Message from A/C Controller
            P1635 - 000 -   -
17075 -  Fan 1 Control Circuit: Short to GND
            P0691 - 000 -   -
17077 -  Fan 2 Control Circuit: Short to GND
            P0693 - 000 -   -
18049 -  Please check DTC Memory of A/C Controller
            P1641 - 000 -   -
17978 -  Engine Start Blocked by Immobilizer
            P1570 - 000 -   -
Readiness: N/A
Address 08: Auto HVAC       Labels: Redir Fail!
   Controller: 7H5 907 040 B
   Component: CLIMAtronic T5    X 3316
   Coding: 0000140
   Shop #: WSC 02737
   VCID: 2A27401FC5E7
00819 -  High Pressure Sensor (G65)
            009 -  Open or Short to Ground
01592 -  Air Quality Sensor (G238)
            007 -  Short to Ground
01299 -  Diagnostic Interface for Data Bus (J533)
            008 -  Implausible Signal
02098 -  Control Circuit for Left Booster Blower
02099 -  Control Circuit for Right Booster Blower
Address 09: Cent. Elect.       Labels: 7H0-937-049.LBL
   Controller: 7H0 937 049 K
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000615
   Shop #: WSC 02756
   VCID: 3A07705F3547
01598 -  Drive Battery Voltage
            002 -  Lower Limit Exceeded
            013 -  Check DTC Memory
01341 -  Control Module in Instrument Panel On Comfort CAN (J285)
Address 17: Instruments       Labels: 7Hx-920-xxx-17.LBL
   Controller: 7H5 920 860 J
   Component: KOMBI+WEGFAHRSP VDO V01
   Coding: 07112
   VCID: 3701696B0655
   WV2ZZZ7HZ4H056706     VWZ7Z0C8386292
01314 -  Engine Control Module
            49-00 -  No Communications
01316 -  ABS Control Module
01321 -  Control Module for Airbags (J234)
Address 18: Aux. Heat       Labels: None
   Controller: 7H0 819 008 H
   Component: Standheizung        0206
   Coding: 0000000
   VCID: 31155773E831
00664 -  Fuel gauge
02085 -  Incorrect Control Module Installed
            000 -   - - Intermittent
01336 -  Data Bus for Comfort System
            004 -  No Signal/Communication - Intermittent
01126 -  Engine Speed Signal
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: F0931277A3BB
00778 -  Steering Angle Sensor (G85)
Address 46: Central Conv.       Labels: 7H0-959-433.LBL
   Controller: 7H0 959 433
   Component:    Komfortgerát     0004
   Coding: 00079
   Shop #: WSC 02756
   VCID: F0931277A3BB
01312 -  Powertrain Data Bus
            79-00 -  Please Check Fault Codes
00932 -  Electric Window Motor; Drivers Side (V147)
            62-00 -  No or Incorrect Adjustment
00941 -  Exterior Mirror Retract Motor; Driver Side (V121)
            35-10 -   - - Intermittent
00933 -  Electric Window Motor; Passenger Side (V148)
            62-10 -  No or Incorrect Adjustment - Intermittent
Address 47: Sound System       Labels: None
   Controller: 7L0 035 456
   Component: 08K Audioverst.     0106
   Coding: 0000000
   VCID: EAA7001F8567
Address 56: Radio       Labels: None
   Controller: 7L6 035 195
   Component: Radio DE2           0012
   Coding: 0003013
   Shop #: WSC 02737
   VCID: F0931277A3BB
Address 6E: Ctrl Head Roof       Labels: 7L6-919-044.LBL
   Controller: 7L6 919 044 H
   Component: DACHDISPLAY         0530
   Coding: 0000000
   VCID: 3C0B76473F73
00446 -  Function Limitation due to Under-Voltage
            002 -  Lower Limit Exceeded - Intermittent
Address 77: Telephone       Labels: None
   Controller: 7L6 035 729 A
   Component: CIB PAH  HW 117 SW  0193
   Coding: 0000000
   Shop #: WSC 00001
   VCID: 341B5E671723
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Welcome aboard Stefan!
Sorry team, I've seen a mess too late. :facepalm:
