Chassis Type: 7H - VW Transporter
Scan: 01,02,03,08,09,0B,0D,15,16,17,18,19,1C,22,2D,37,45,46,47,56,57,6E,76,77,78,7D
Address 01: Engine Labels: 070-906-016-AXD.LBL
Controller: 070 906 016 AN
Component: R5 2,5L EDC G000SG 5394
Coding: 0001072
Shop #: WSC 02756
VCID: 5CCBD6C7DF33
8 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 000 - -
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 000 - -
18045 - Powertrain Data Bus: Missing Message from Electric Load Controller
P1637 - 000 - -
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 000 - -
17075 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
17077 - Fan 2 Control Circuit: Short to GND
P0693 - 000 - -
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - -
Readiness: N/A
Address 08: Auto HVAC Labels: Redir Fail!
Controller: 7H5 907 040 B
Component: CLIMAtronic T5 X 3316
Coding: 0000140
Shop #: WSC 02737
VCID: 2A27401FC5E7
009 - Open or Short to Ground
007 - Short to Ground
008 - Implausible Signal
02098 - Control Circuit for Left Booster Blower
02099 - Control Circuit for Right Booster Blower
Address 09: Cent. Elect. Labels: 7H0-937-049.LBL
Controller: 7H0 937 049 K
Component: BORDNETZ SGVER 1.0 1901
Coding: 0000615
Shop #: WSC 02756
VCID: 3A07705F3547
01598 - Drive Battery Voltage
002 - Lower Limit Exceeded
013 - Check DTC Memory
Address 17: Instruments Labels: 7Hx-920-xxx-17.LBL
Controller: 7H5 920 860 J
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 07112
VCID: 3701696B0655
WV2ZZZ7HZ4H056706 VWZ7Z0C8386292
49-00 - No Communications
01316 - ABS Control Module
Address 18: Aux. Heat Labels: None
Controller: 7H0 819 008 H
Component: Standheizung 0206
Coding: 0000000
VCID: 31155773E831
00664 - Fuel gauge
02085 - Incorrect Control Module Installed
01336 - Data Bus for Comfort System
01126 - Engine Speed Signal
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 02756
VCID: F0931277A3BB
Address 46: Central Conv. Labels: 7H0-959-433.LBL
Controller: 7H0 959 433
Component: Komfortgerát 0004
Coding: 00079
Shop #: WSC 02756
VCID: F0931277A3BB
01312 - Powertrain Data Bus
62-00 - No or Incorrect Adjustment
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
35-10 - - - Intermittent
Address 47: Sound System Labels: None
Controller: 7L0 035 456
Component: 08K Audioverst. 0106
Coding: 0000000
VCID: EAA7001F8567
Address 56: Radio Labels: None
Controller: 7L6 035 195
Component: Radio DE2 0012
Coding: 0003013
Shop #: WSC 02737
VCID: F0931277A3BB
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.LBL
Controller: 7L6 919 044 H
Component: DACHDISPLAY 0530
Coding: 0000000
VCID: 3C0B76473F73
Address 77: Telephone Labels: None
Controller: 7L6 035 729 A
Component: CIB PAH HW 117 SW 0193
Coding: 0000000
Shop #: WSC 00001
VCID: 341B5E671723
