Results 1 to 7 of 7
Thread: T5 ABS Coding - Help needed
    Verified VCDS-Lite User
    Feb 2019
    Hi, I'm having an issue with the ABS unit on my VW T5 MULTIVAN, i have found a replacement with the same part numbers but cannot access the old unit to find out the original coding.
    Can anyone help by working out what my login & coding details from the following vehicle info ?
    WV2ZZZ7HZ4H05XXXX
    7HM C11
    Multivan Come. KR
    128kw TDISG6
    AXE GWB
    LA5W 0000 0000 EJ
    X10 B0A CS3 G0K H2N J1U MS0
    1AT 1G2 2PW 1NL 5RQ 5SL T86
    3S4 3U4 QG1 8UT 8GV 8L6
    1BA 0GE
    0E1 4UF 4X3 4R1 4K3 N0H 5MA
    9VK 2JG E0A 2V1 0JE 0YB
    1D2 A8E 8EL U5A 1N1 3L3 4A3 8N1
    Any help would be greatly appreciated ?
    Hi and welcome.
    Please post a complete Auto-Scan for context.
    Feb 2019
    Hi I can post a full scan but there’s no abs unit currently connected as it has been removed and sent away for testing.
    Will this help ?
    Quote Originally Posted by Veedubmad View Post
    Will this help ?
    No, not really. Please do it when you get the module back and re-installed.
    Feb 2019
    This was the scan I did before disconnecting it however I believe the connector on the coolant expansion tank was disconnected at the time.
    Chassis Type: 7H - VW Transporter
    Scan: 01,02,03,08,09,0B,0D,15,16,17,18,19,1C,22,2D,37,45,46,47,56,57,6E,76,77,78,7D
    Address 01: Engine       Labels: 070-906-016-AXD.LBL
       Controller: 070 906 016 AN
       Component: R5 2,5L EDC G000SG  5394
       Coding: 0001072
       Shop #: WSC 02756
       VCID: 5CCBD6C7DF33
    8 Faults Found:
    18057 -  Powertrain Data Bus: Missing Message from ABS Controller
                P1649 - 000 -   -
    18044 -  Powertrain Data Bus: Missing Message from Airbag Controller
                P1636 - 000 -   -
    18045 -  Powertrain Data Bus: Missing Message from Electric Load Controller
                P1637 - 000 -   -
    18043 -  Powertrain Data Bus: Missing Message from A/C Controller
                P1635 - 000 -   -
    17075 -  Fan 1 Control Circuit: Short to GND
                P0691 - 000 -   -
    17077 -  Fan 2 Control Circuit: Short to GND
                P0693 - 000 -   -
    18049 -  Please check DTC Memory of A/C Controller
                P1641 - 000 -   -
    17978 -  Engine Start Blocked by Immobilizer
                P1570 - 000 -   -
    Readiness: N/A
    Address 08: Auto HVAC       Labels: Redir Fail!
       Controller: 7H5 907 040 B
       Component: CLIMAtronic T5    X 3316
       Coding: 0000140
       Shop #: WSC 02737
       VCID: 2A27401FC5E7
    00819 -  High Pressure Sensor (G65)
                009 -  Open or Short to Ground
    01592 -  Air Quality Sensor (G238)
                007 -  Short to Ground
    01299 -  Diagnostic Interface for Data Bus (J533)
                008 -  Implausible Signal
    02098 -  Control Circuit for Left Booster Blower
    02099 -  Control Circuit for Right Booster Blower
    Address 09: Cent. Elect.       Labels: 7H0-937-049.LBL
       Controller: 7H0 937 049 K
       Component: BORDNETZ SGVER 1.0  1901
       Coding: 0000615
       Shop #: WSC 02756
       VCID: 3A07705F3547
    01598 -  Drive Battery Voltage
                002 -  Lower Limit Exceeded
                013 -  Check DTC Memory
    01341 -  Control Module in Instrument Panel On Comfort CAN (J285)
    Address 17: Instruments       Labels: 7Hx-920-xxx-17.LBL
       Controller: 7H5 920 860 J
       Component: KOMBI+WEGFAHRSP VDO V01
       Coding: 07112
       VCID: 3701696B0655
       WV2ZZZ7HZ4H056706     VWZ7Z0C8386292
    01314 -  Engine Control Module
                49-00 -  No Communications
    01316 -  ABS Control Module
    01321 -  Control Module for Airbags (J234)
    Address 18: Aux. Heat       Labels: None
       Controller: 7H0 819 008 H
       Component: Standheizung        0206
       Coding: 0000000
       VCID: 31155773E831
    00664 -  Fuel gauge
    02085 -  Incorrect Control Module Installed
                000 -   - - Intermittent
    01336 -  Data Bus for Comfort System
                004 -  No Signal/Communication - Intermittent
    01126 -  Engine Speed Signal
    Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
       Controller: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02756
       VCID: F0931277A3BB
    00778 -  Steering Angle Sensor (G85)
    Address 46: Central Conv.       Labels: 7H0-959-433.LBL
       Controller: 7H0 959 433
       Component:    Komfortgerát     0004
       Coding: 00079
       Shop #: WSC 02756
       VCID: F0931277A3BB
    01312 -  Powertrain Data Bus
                79-00 -  Please Check Fault Codes
    00932 -  Electric Window Motor; Drivers Side (V147)
                62-00 -  No or Incorrect Adjustment
    00941 -  Exterior Mirror Retract Motor; Driver Side (V121)
                35-10 -   - - Intermittent
    00933 -  Electric Window Motor; Passenger Side (V148)
                62-10 -  No or Incorrect Adjustment - Intermittent
    Address 47: Sound System       Labels: None
       Controller: 7L0 035 456
       Component: 08K Audioverst.     0106
       Coding: 0000000
       VCID: EAA7001F8567
    Address 56: Radio       Labels: None
       Controller: 7L6 035 195
       Component: Radio DE2           0012
       Coding: 0003013
       Shop #: WSC 02737
       VCID: F0931277A3BB
    Address 6E: Ctrl Head Roof       Labels: 7L6-919-044.LBL
       Controller: 7L6 919 044 H
       Component: DACHDISPLAY         0530
       Coding: 0000000
       VCID: 3C0B76473F73
    00446 -  Function Limitation due to Under-Voltage
                002 -  Lower Limit Exceeded - Intermittent
    Address 77: Telephone       Labels: None
       Controller: 7L6 035 729 A
       Component: CIB PAH  HW 117 SW  0193
       Coding: 0000000
       Shop #: WSC 00001
       VCID: 341B5E671723
  6. Likes Uwe liked this post
    New User
    May 2019
    Bor, Serbia
    Thread is here.
    Last edited by Boki Ar; 05-16-2019 at 03:57 PM. Reason: "Linking" Stefan's thread.
    Oct 2014
    Arandjelovac, Serbia
    Welcome aboard Stefan!
    Sorry team, I've seen a mess too late.
