Results 1 to 10 of 12
Thread: Hello from Central Louisiana (help please)
    Feb 2019
    novice trying to fix dtc's
    Hi. I recently pulled fuses in the passenger and engine compartments on my 2013 VW Jetta SE 2.5l during troubleshooting a headlight. I did not disconnect the battery (didn't know better at the time). Now I have the TPMS amber light and the Traction (slippery when wet) amber lights illuminated. I bought a VCDS and scanned the car. I even managed to turn of my SRS amber light and reset my service interval (oil change). Attached is a copy of my autoscan, and I cut and pasted below as well. Any advice on how to get these two modules corrected and working again would be appreciated. Please remember I'm a novice at this, so I may ask questions a few times unless the steps are spelled out for me.
    Thank you much for your patience, help and understanding!
    LouisianaDave
    Sunday,10,February,2019,09:55:25:33681
    VIN: 3VWDX7AJ1DM372802   License Plate: 625AKD
    Mileage: 120941   Repair Order: 1
                    Address 03: ABS Brakes
    Control Module Part Number: 1K0 907 379 BL
      Component and/or Version: ESP MK60EC1   H31 0152
               Software Coding: B14B400C492908FC8D1302E4921B1061A71000
                Work Shop Code: WSC 00066
                          VCID: 7DA7FB364DF957FFF5B-8028
    Advanced Identification
         Identification: 3QT-03A
         Revision: 00H31001
         Date: 16.07.12
         Manufacturer number: 0102
         Test stand number: 0971
    Flash Status
         Programming Attempts(application): 0
         Successful Attempts(application): 0
         Programming Status: 00000000
         Flash Date: 2000.00.00
         Flash Tool Code: 00000 000 00000
    Misc.
         Hardware number: 1K0 907 379 BL
         Workshop System Name: J104
    VCDS Info:
           Labels: 1K0-907-379-60EC1F.CLB
    Sunday,10,February,2019,09:57:07:33681
                    Address 03: ABS Brakes  (1K0 907 379 BL)
    09:56:41 Group 042: Tire Pressure Monitoring System (TPMS) Reset
      Tire Pressure  Tire Pressure Monitoring System
      EEPROM Reset
      Done  Reset Status
      N/A
    Address 03: DTCs cleared
    Address 19: DTCs cleared
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 56
    VIN: 3VWDX7AJ1DM372802   Mileage: 194640km-120943miles
    04-Steering Angle -- Status: Cannot be reached 1100
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 DK    HW: 07K 907 309 B
       Component: 2,5l R5/4V      G01 4334
       Revision: T4H06---    Serial number:
       Coding: 0000075
       Shop #: WSC 00066 000 00000
       VCID: 7AADF02A50D760C7D09-802E
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 000 -
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:48:32
                        RPM: 732 /min
                        Load: 22.0 %
                        Temperature: 54.0C
                        Temperature: 20.0C
                        Absolute Pres.: 1020.0 mbar
    Readiness: 1110 0101
       Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
       Component: AQ 250 6F           2246
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 005982C2360B3A179ED-8054
       Revision: 00H31001
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:57:50
                        Count: 3
                        Count: 14
                        Count: 28672
                        Count: 166
                        Count: 43008
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:57:50
                        Count: 3
                        Count: 14
                        Count: 28672
                        Count: 16390
                        Count: 43008
    Address 08: Auto HVAC        Labels: 5C0-820-047.clb
       Part No SW: 5C0 820 047 AT    HW: 5C0 820 047 AT
       Component: J301  Klimaanlage   0204
       Revision: 2001012S    Serial number: 00000001155507
       VCID: 72BDD80A08A71887989-8026
       Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0256
       Revision: B2066001    Serial number: 04371230120119
       Coding: 7B994B1808AB0B0000302000240884D400C2502E60000000300000000000
       VCID: 2F3B117ED715756F377-807A
       Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  004 3465
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  004 3465
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
       Component: J388__TSG_HL  004 3464
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
       Component: J389__TSG_HR  004 3464
       Coding: 800000
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   014 0808
       Serial number: 003GTM07TBF3
       Coding: 00003936
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 34311E123EB356B74A5-8060
       Serial number: 6940000Y120000J85M0O
       Coding: 303037
       Serial number: 3572MSME174B436EZZZ0
       Serial number: 3582MSME124B636FZZZ%
       Serial number: 3516KSME1046451DZZZN
       Serial number: 3526KSME5A726E1DZZZ5
       Serial number: 3556LSME2C06521CZZZY
       Serial number: 3566LSME294C651CZZZ3
       Part No SW: 5C6 920 952 B    HW: 5C6 920 952 B
       Component: KOMBI         H06 0705
       Coding: 270201
       Shop #: WSC 00066 000 00122
       VCID: 2B03056EE38D094F1BF-807E
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H66 0256
       Revision: B2066001
       Coding: 102200
       VCID: 70B9D2020AAB2A976ED-8024
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:59:42
    01304 - Radio
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:59:46
       Component: IMMO          H06 0705
       VCID: 6A8DC06A2CF7D047209-803E
    Address 56: Radio
    End----(Elapsed Time: 01:13, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    VCDS Release 18.9.1:  SRI Reset-SRI1.CLB
    Control Module Part Number: 5C6 920 952 B       Labels:  .*5K0-920-xxx-17.clb-SRI1
    Component:KOMBI         H06 0705, Coding:270201
    Channel        Description                                                     Current val.                                                    New val.
    IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                    Reset                                                           ---
    IDE00510-ESI: distance driven from inspection                                                           ESI: Distance since Inspection                                  800 km                                                          ---
    IDE00511-ESI: time from inspection        ESI: Time since Inspection                                      8 d                                                             ---
    IDE00515-ESI: oil quality        ESI: Oil Quality                                                poor oil quality                                                ---
    IDE00517-ESI: soot entry        ESI: Soot Quantity                                              0 km                                                            ---
    IDE00518-ESI: thermal load        ESI: Thermal Load                                               0 km                                                            ---
    IDE01153-SIA: maximum value of distance to service                                                      SIA: Maximum Distance to Service                                16100 km                                                        ---
    IDE01154-SIA: maximum value of time to service                                                          SIA: Maximum Time to Service                                    372 d                                                           ---
        FIX: Maximum Distance to Inspection                             ---                                                             ---
        FIX: Maximum Time to Inspection                                 ---                                                             ---
        FIX: Distance since Inspection                                  ---                                                             ---
        FIX: Time since Inspection                                      ---                                                             ---
       Coding: 0000075
                   U0126 - 000 -
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:48:32
                        RPM: 732 /min
                        Load: 22.0 %
                        Temperature: 54.0C
                        Temperature: 20.0C
       Coding: 0000840
       Revision: 00H31001
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:57:50
                        Count: 3
                        Count: 14
                        Count: 28672
                        Count: 166
                        Count: 43008
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:57:50
                        Count: 3
                        Count: 14
                        Count: 28672
                        Count: 16390
                        Count: 43008
       Coding: 820000
       Coding: 820000
       Coding: 800000
       Coding: 800000
       Coding: 00003936
       Coding: 303037
       Coding: 270201
       Revision: B2066001
       Coding: 102200
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:59:42
    01304 - Radio
                        Reset counter: 193
                        Mileage: 194640 km
                        Date: 2013.07.03
                        Time: 21:59:46
    Address 56: Radio
    End----------(Elapsed Time: 01:13, VBatt start/end: 14.2V/14.2V)-----------
    Hi and welcome. Nice first post.
    I think the root of your problem is the fault: "00778 - Steering Angle Sensor (G85) - No Signal/Communication"
    Is there any chance that a fuse did not get re-installed properly?
    Feb 2019
    Thank you for your reply. Yes, there is a very likely probability that may have happened. To dive further into that train of thought, would anyone be aware of resource to find a reliable fuse diagram for this vehicle? The owners manual does not have it. Evidently it was not available at the time of manufacture and printing. thats the reason I pulled and checked each fuse one at a time to begin with. The car is a 2013 Jetta 2.5SE. I have no clue if it a CBTA or CBUA... as this is an entirely different confusing matter.
    Are you planning to keep this car for any length of time? If so, register with erWin:
    https://erwin.vw.com/erwin/showCustomerRegistration.do
    Then pay the for the minimum length subscription (I think it's $35 for one day) and download everything specific to this car, which I think you can do bin VIN. You most especially want all the wiring diagrams.
  5. Likes Jack@European_Parts liked this post
    Feb 2019
    i'd like it to be around at least until its paid off, haha. It currently serves as my daily commuter (125mi round trip), and has been very reliable for 2 years now. I'm the 2nd owner. If possible, I'd like to see it roll up to 300k miles before setting it out to pasture. Thanks for the info, and your time!
    Hey OP can you show us a scan of OBD2 mode and fault codes there plus Mode 9 data?
    Was there a check engine light?
    In engine 0x01 Advanced ID in VCDS will show you it is a CBTA
    Feb 2019
    If you can give me until this time tomorrow, I will be happy to scan OBD2 and upload. I'm not sure what Mode 9 data is. Explain?
  9. #8
    Feb 2019
    ah, i see it now in the OBD2 menu. I will scan and post in 24hrs
  10. #9
    When in OBD2 ( 0x33 ) it will be clearly marked Mode 9 as will DTC's or Pending DTC's.
  11. #10
    Feb 2019
    as promised:
    Mode : Calibration Identification
    Type 02 - VIN : 3VWDX7AJ1DM372802 (Address E8)
    Type 04 - Calibration ID : 07K906055DK 4334 (Address E8)
    Type 04 - Calibration ID : 09G927750LF 2246 (Address E9)
    Type 06 - Calibration Verification Number : 9F460A82 (Address E8)
    Type 06 - Calibration Verification Number : 363065D8 (Address E9)
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
    OBD2 scan shows no faults, so i didnt copy it
  12. Likes Uwe liked this post
