Results 1 to 6 of 6
Thread: Messed up Audi Q5 while adapting rear lights, need advice.
    Lithuania
    Hello fellow members.
    Unfortunately i have finally done it. Audi Q5 (2010) wont start after i have tried adapting rear taillights, since i have done it successfully few time before without any problems, i thought this will take just 5 minutes and done. Well, no, the car now wont start, i mean it will not turn on the ignition, with no other error messages except the one on the screen it says - "Component protection active, please turn on ignition <...>" and something else, cant remember exactly.
    Anyway, what i have done before this happened, step by step.
    The purpose of the adaptation. Retrofitted EU bumper lights with amber turn signals. Edited some channels between 180 and 201, with values that i had previously written in a spreadsheet. However i messed up an saved wrong values. After some time figuring out whats wrong, got the error on dash that steering lock is defective which disappeared after probably one minute and never came back again. Steering lick acted strange, it was unlocked, and wont lock when key removed, and made no "releasing" sound when key inserted. I panicked, and returned all the values i have changed to default numbers, since i had the adaptation channel scan in CSV.
    The steering lock came back to life after i have disconnected battery for few minutes. I might have entered security access code wrong 106117 instead 16017, and cant tel at which pint i did that.
    Now all the car is doing:
    Accepting the key, releasing the steering lock (steering wheel moves freely).
    Ignition wont turn on at all
    On the screen i get message "component protection active, please turn on ignition <...> " and something about limited functionality.
    Radio works if i make volume up.
    I can remove the key, its is released, and the steering wheel lock is making sounds + lock the steering when key removed.
    The battery is not dead, tested twice, recharged.
    Tested fuses in the back, and fuses on the sides of the dashboard. They are all good.
    Tesed wires that go from steering lock to the BCM2 (46) in the trunk, all good.
    All the values in the adaptation (of module 46) are the way they were before i messed up.
    Maybe tested some more things just cant remember at the moment.
    There are few errors only, light switch is removed by me, and steerig wheel controls are removed by me also, so only these errors, nothigng else what could be related to no start...
    Anyway could all this nonsense be related to entering wrong security access ? could this be just a waiting time before i can restart the car?
    I have made autoscan, but it wont scan modules which turn on with the ignition, since it is not turning on, cant scan the rest at the moment.
    If some one has a hint how i can diagnose or sort out this problem, please share your knowledge, i am really desperate... Anything will help
    Thank you all for your time.
    Friday,15,February,2019,21:07:57:32826
    VCDS Version: 18.9.1.0 (x64)
    VIN:    License Plate: AUDIQ5
    Mileage: 216260km-134377mi   Repair Order:
    Chassis Type: 8T0
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
              62 6C 6D 72
       Mileage: 216260km-134377miles
    01-Engine -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
       Component: ESP8 quattro  H06 0020
       Coding: 041D18
       Shop #: WSC 06335 000 00000
       VCID: 4A9B9065E53F331A43-801E
       Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
       Component: BCM2 1.1      H02 0326
       Coding: 090500
       VCID: 04077E5D879B256AF9-8050
       Subsystem 1 - Part No SW: 8T0 959 754 J    HW: 8T0 959 754 J
       Component: FBSAUDIB8 IDG  H61 0072
       Serial number: 0512000019332008
       Serial number: 0209000073290004
       Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01191020091292
       Coding: 46112000
       VCID: 7AFB00A5F55F639A93-802E
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000367875
       Coding: 26001085063CAF010001000300001D0D0F1C460800010161000000
       Shop #: WSC 06335 123 12345
       VCID: 3C77C6BDBFEB9DAAC1-8068
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 091002  H10 0041
       Serial number: 90243014090926123814
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 10638743
       Coding: 024D25
    01800 - Light Switch (E1)
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 01:16:00
    Address 10: Park/Steer Assist
    Address 15: Airbags
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90304IJF000MP
       Coding: 000017
       VCID: 3D71CBB9A4F194A2F6-8068
    01426 - Controls in Steering Wheel (E221)
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 01:17:46
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 980 K    HW: 8R0 920 980 K
       Component: KOMBIINSTR.   H10 0255
       Revision: 00000000    Serial number: CJK60LGA9
       Coding: 8B1622000300D705020000
       VCID: 4189B749D809F04292-8014
       Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0105
       Revision: EB800053    Serial number: 5300E09A0382C3
       Coding: 00C303
       VCID: 52AB88050D6F7BDA3B-8006
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140165745
       Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001010018451
       Coding: 00581300000044440000
       VCID: 408FB24DD303F94A9D-8014
       Revision: 00002001    Serial number: 0122868117
       Coding: 0126023A207A749404B0053200000000
       Component: J245EE20SKB13  H01 0220
       Component: J394EE20SKB13  H01 0220
       Part No SW: 8T0 035 223 H    HW: 8T0 035 223 H
       Component: DSP Prem      H04 0120
       Revision: 00004001    Serial number: 34880005830103
       VCID: 3365ED8192B552D210-8066
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                        Fault Status: 01101011
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 01:02:06
                        Voltage: 11.50 V
                        Temperature: 33.0°C
                        Temperature: 39.0°C
                        Bin. Bits: 00000100
    Address 52: Door Elect, Pass.
    Address 53: Parking Brake
    Address 55: Headlight Range
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335J+097534845
       Coding: 020000010000000001
       VCID: 1D312B390431F4A2D6-8048
       Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
       Component: H-BN-NA       H41 0042
       Revision: --------    Serial number: 490JY097521444
       Coding: 010200060005A1EF41000B0E000000030000
       VCID: 3663D49581C747FA37-8062
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356JV091091039
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000382265
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
                000 -  -
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:58:11
    Address 62: Door, Rear Left
    Address 6C: Back-up Cam.
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Component: J605  Master  H27 0300
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B75C5A1BAE59A92C8-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Component: J756  Slave  H27 0300
       Serial number: 8R0827852B
    Address 72: Door, Rear Right
    End-------------------------(Elapsed Time: 03:08)--------------------------
    Scratching head at the fact that you have no faults in 05 or 46 (same module).
    My WAG: Some relay not closing.
    I do not think entering a security code wrong just one time would do this.
    May 2016
    Notice rear door and back up can can't be reached.
    All new to me after a advance systems class, meaning how invasive does the system get stopping you from using it until you fix them.
    I.e. door open or thinking it is being stolen? Learning here with all.
    UWE, also how picky are these systems if not calibrating cameras and radar, ect to factory specs.
    LARIMORE
    Lithuania
    Quote Originally Posted by Larry Manton View Post
    LARIMORE
    These are separate modules, they cant be reached because ignition does not run on. They depend on Terminal 15. If i turn on the terminal 15 relay ( by grounding ws/sw or sw/ws wire), all the modules are reachable. By the way terminal 15 relay is controlled by BCM 2.
    Lithuania
    Follow up here:
    I disconnected the battery for the night, came in the morning connected the battery and got a message on dash that steering lock is defective, then it disparaged and did not came back. I tried to autoscan one more time, and got a bit different results.
    Now i get error in 46 that module is "defective ", i can clear the code it wont come back unless i disconnect the battery for few minutes. Sill no ignition.
    Could it be that BCM 2.0 just looses its "mind" when doing the adaptations?
    I think that module 46 does not like when someone is messing with the adaptations. I have done the at least 3 Q5 in the past coded with the same values, and everything was ok. This time it took me long time till i found the values to put in, and i was connected to module for a long time. I think its the reason why it happened.
    Anyway, Could a reflash at the dealer help, or is it a toasted.? What do you guys think?
    All the help here is appreciated. Thanks.
    Saturday,16,February,2019,13:10:39:32826
    VIN:    License Plate: AUDI Q5 2
    Chassis Type: 8T0
              62 6C 6D 72
    Address 01: Engine
       Coding: 041D18
       Coding: 090500
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:00:01
       Coding: 46112000
       Coding: 26001091063CAF010000080300001D0D0F1C460800010161000000
       Coding: 01DD13
       Coding: 024D25
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:04:00
    03280 - Switch Position of Light-Switch Knob
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:05:00
    Address 15: Airbags
       Coding: 000037
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:10:32
       Coding: 00C303
    00003 - Control Module
                014 - Defective - MIL ON
                        Fault Status: 11101110
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:00:01
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:04:58
                        Voltage: 12.00 V
                        Temperature: 28.0C
                        Temperature: 31.0C
                        Bin. Bits: 00000100
                000 -  -
                        Reset counter: 248
                        Mileage: 216266 km
                        Date: 2009.06.26
                        Time: 00:08:14
    End-------------------------(Elapsed Time: 03:16)--------------------------
  6. #6
    Lithuania
    Might be, but ignition is contolled by the BCM2.0, module does not send signal to engage Terminal 15... With a relay obviously
