Results 1 to 3 of 3
Thread: 1KZ Golf ABS Coding Issue
    Feb 2019
    New Zealand
    Monday,11,February,2019,14:11:31:01672
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ1KZ9U002256   License Plate:
    Mileage: 98650km-61298mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ9U002256   Mileage: 98650km-61298miles
    42-Door Elect, Driver -- Status: Malfunction 1010
    72-Door, Rear Right -- Status: Sporadic communication error 1000
       Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0H43NE847
       Coding: 040300431C070160
       Shop #: WSC 00046 412 00000
       VCID: 34671891573DE7EA09-8060
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 002 - Signal too High
                        Fault Status: 01100010
                        Fault Frequency: 53
                        Mileage: 98626 km
                        Time: 12:39:12
                        RPM: 1708 /min
                        Load: 48.2 %
                        Speed: 45.0 km/h
                        Temperature: 47.0C
                        Temperature: 23.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.351 V
    Readiness: 0110 0000
       Part No SW: 02E 300 050 J    HW: 02E 927 770 AE
       Component: GSG DSG         082 1409
       Revision: 04708020    Serial number: 00000803060114
       Shop #: WSC 44551 111 44551
       VCID: 1939C925D09F3A823A-804C
       Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
       Component: ESP MK60EC1   H35 0120
       Revision: 00H35001
       Coding: 163B600D092200FC680D06E9901F0081B500
       Shop #: WSC 28673 002 1048576
       VCID: 77FDEF9DC6CBCCF2EC-8022
    01130 - ABS Operation
                        Reset counter: 167
                        Mileage: 98638 km
                        Count: 4608
                        Count: 125
                        Count: 50446
                        Count: 516
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: 6DD1CDF57497762206-8038
                000 -  -  - Intermittent
       Revision: 00H54000    Serial number: 00000008473650
       Coding: E58D8F2700041500471400001400000000097F075C000100000000000000
       VCID: 33651B8D5233E0D210-8066
       Component: Wischer 140708 020  0501
       Coding: 00049109
       Shop #: WSC 00046
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     170608 046  0204
       Coding: 00208933
       Shop #: WSC 00046
                        Reset counter: 207
                        Mileage: 98641 km
                        Voltage: 12.10 V
                        Reset counter: 207
                        Mileage: 98641 km
                        Voltage: 12.10 V
       Component: 3C AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD213D0P
       Coding: 0013123
       VCID: 3D713DB5647726A2F6-8068
       Subsystem 1 - Serial number: 6332MSME3A2114743
       Subsystem 2 - Serial number: 6342MSME3A242918B
       Subsystem 3 - Serial number: 6352QSME66391E39S
       Subsystem 4 - Serial number: 6362QSME62692E69W
       Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
       Component: J0527           752 0101
       Coding: 0012122
       VCID: 04078851471D976AF9-8050
       Part No SW: 1K6 920 874     HW: 1K6 920 874
       Component: KOMBIINSTRUMENT VDD 2216
       Revision: V0002000    Serial number: VWX7Z0H43NE847
       Coding: 0003103
       Shop #: WSC 00001 016 00032
       VCID: 70EFD48163A59BCA2D-8024
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 190508F1001584
       Coding: ED807F0E0002020003
       VCID: 356125955C47FEE23E-8060
                        Fault Status: 00110100
                        Reset counter: 207
                        Mileage: 98641 km
                        Time: 14:16:46
                        Reset counter: 207
                        Mileage: 98641 km
                        Time: 14:16:46
                        Fault Frequency: 93
                        Mileage: 98588 km
                        Time: 13:16:10
       Component: IMMO            VDD 2216
       Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
       Component: Tuer-SG         006 1210
       Coding: 0000694
       VCID: 397929A5705F1A82DA-806C
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A5B06E985F9A11AA3-807E
       Coding: 809002005103087F2D0484057008DFC690FC00
       Shop #: WSC 00500 824 83286
       VCID: 03058B4D42139052C0-8056
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
                        Reset counter: 207
                        Mileage: 98641 km
                        Time: 14:16:46
                        Reset counter: 207
                        Mileage: 98641 km
                        Time: 14:16:46
       Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
       Coding: 0000950
       VCID: 3A7B36A97559119AD3-806E
       Part No: 1K0 035 186 AF
       Component: Radio GR0       035 0034
       Revision: 0003505S    Serial number: VWZ2Z2H1115702
       Coding: 0040400
       VCID: 6ADBC6E94579611A63-803E
       Component: Tuer-SG         006 1301
       Coding: 0000144
       Shop #: WSC 00046 412 1012544
       VCID: 387F2CA14B55038A25-806C
    00098 - Rear Left Central Locking (Safe) Motor (V163)
       Coding: 0000144
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 12 Einparkhilfe     0101
       VCID: 2D510DF5B417B62246-8078
    End-------------------------(Elapsed Time: 01:52)--------------------------
    Initial Auto Scan
    Installed New ABS module and copy and pasted long coding, calibrated sensors on vehicle and still has fault code for control module basic settings/coding
    Auto Scan after new module fitted below:
    Tuesday,12,February,2019,10:35:24:01672
                        Mileage: 98626 km
                        Time: 12:39:12
                        Temperature: 23.0C
                        Temperature: 25.0C
                        Voltage: 12.446 V
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    Readiness: 0110 0101
       Revision: 00H45001
       VCID: 000F844193058B4ADD-8054
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 167
                        Mileage: 98655 km
                        Count: 3
                        Count: 14
                        Count: 12800
                        Count: 143
                        Count: 50688
       Coding: 00049109
       Shop #: WSC 00046
       Coding: 00208933
       Shop #: WSC 00046
       Coding: 0013123
       Coding: 0012122
       Coding: 0003103
       Coding: 0000694
       Revision: 00H15000
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 98655 km
                        Time: 00:08:19
                        Battery Volts: 13.9 V
                            DU
                        Temperature: 30.0C
                        Count: 9
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Coding: 0000950
       Coding: 0040400
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Any help much appreciated.
    Regards
  2. Likes Uwe liked this post
  3. #2
    Welcome. Nice first post; before and after Auto-Scans, wrapped in CODE tags.
    Have you been here?
    http://wiki.ross-tech.com/wiki/index.php/00003
    There is a specific reference to the MK60EC1 on that page.
    Have you done the whole Basic Setting for Hydraulic Valves process? It's a bit tedious, especially with the cool-down. Make sure you watch the video at the bottom of the page.
  5. #3
    Feb 2019
    New Zealand
    Thanks for the Welcome, I have been a long time Lurker and first time poster.
    That worked a treat, Sorry should of been able to figure out that my self must of missed that page for what ever reason.
    I did have a issue doing the settings for valves, which was if I had the vehicle running (2 mins) it would lose communication with the module.
    I had to do the process with the vehicle switch off, which was bloody hard (Good thing I never skip leg days)
