Results 1 to 4 of 4
Thread: Tiguan Airbag Index Code
    New User
    Nov 2018
    Guatemala
    I have the following code for my airbag system 01042 - Control Module; Not Coded
    I have located the airbag module installed in the car, after reading http://wiki.ross-tech.com/wiki/index.php/Airbag_Coding I can´t locate my index number can someone help me identify it or none of this are the index code.
    AIRBAG VW10
    5N0 959 655S
    221098-116 27 H20 S2118
    *017701083R*
    In the lower part of the module has this numbers.
    *003L 6P1B180X* 16 0317200P
    I can´t upload the photo but the module is exactly like this
    https://www.ebay.com/itm/09-17-VW-CC...cAAOSwFoNcRYc4
    Monday,11,February,2019,07:23:34:49958
    VCDS Version: 18.9.0.2 (x64)
    VIN: WVGAV7AX9CW586706
    Mileage: 65040km-40413mi   Repair Order:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4C 52 53 56 62 72
              77
    VIN: WVGAV7AX9CW586706   Mileage: 65040km-40413miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
       Part No SW: 5N0 959 655 S    HW: 5N0 959 655 S
       Component: J234__    VW10 HI   2118
       Revision: 27020000    Serial number: 003L6P1B180X
       Coding: 0000000
       VCID: 4DBF8C14D41238226E-8018
       Subsystem 1 - Part No: 5N0 959 339 B
       Subsystem 2 - Serial number: 00000000004GNA
       Subsystem 3 - Serial number: 0013.01.120000300000660098˙†63
       Subsystem 4 - Serial number: 660098˙†6332MTS641910602 ˙†63
       Subsystem 5 - Serial number: 10602 ˙†6342MTS623670592 ˙†63
       Subsystem 6 - Serial number: 70592 ˙†6351HTS6R36L0AKJ ˙†63
       Subsystem 7 - Serial number: L0AKJ ˙†6361HTS6EMOHMAKJ ˙†63
       Subsystem 8 - Serial number: HMAKJ ˙†63727TS6KQUL0AKR ˙†63
       Subsystem 9 - Serial number: L0AKR ˙†63827TS6G0EK0AKR ˙
       Subsystem 10 - Serial number: K0AKR ˙
    How did it get that way? Did you replace the airbag module? If so, do you still have the old one? Does it talk? A scan of the old module should show its index.
    Then the next question becomes: Is this one the same or compatible? Where did you get it?
  3. Likes Dana liked this post
    New User
    Nov 2018
    Guatemala
    I bought the car some months ago and it came that way with that module, I haven´t replaced any airbag or sensors for the airbag system. Is there any other way to get the index?
    Thanks.
    Give a dealer (or Partslink24) the VIN of the car and find out what the full part number for a replacement airbag module would be.
    The full part number will include the index for the module that should be in the car.
    Of course, that doesn't mean that's what's actually in the car.
