Results 1 to 10 of 10
Thread: 2010 T5 Multivan Haldex issues etc.
    New User
    Jan 2019
    Hello everybody. I've been reading the forum every now and then and now it's time for my first post.
    So my problem is with my 2010 T5 Multivan a.k.a. the troublemaker.
    I've had it for about a year now and since the beginning had small and somewhat bigger faults. For example, the AC system needed 11 (eleven!) different repairs By mechanics at the official VW dealership and I'm still unsure whether it actually works.
    The main problem I have is the haldex. I got the dreaded ESP and tire pressure warning lights in april. I couldn't fix it before the winter, so the problem was there for quite a while. So, I took the car to a car electrics specialist who diagnosed the haldex controller to be faulty. We replaced the unit for a used one that was supposedly working. He couldn't get a reading from the controller, so he checked the wirings (I don't know which ones or how he checked them). He also made sure the pump was working.
    I have below the scan before and after the fault codes were deleted. As you can see, the AWD control unit couldn't be reached
    *FIRST SCAN* VCDS
    Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: Release 18.9.0(x64) Data version: 20180927 DS296.0
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Monday,07,January,2019,14:23:18:19563
    VIN: WV2ZZZ7HZAH236860 License Plate:
    Mileage: 244270km-151782mi Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 22 25 47 56 69 6E 78
    VIN: WV2ZZZ7HZAH236860 Mileage: 244270km-151782miles
    0D-Slide Door, Left -- Status: OK 0000
    22-AWD -- Status: Malfunction 1110
    6E-Ctrl Head Roof -- Status: Malfunction 0010
    78-Slide Door, Right -- Status: OK 0000
    Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
    Part No SW: 03L 906 022 JE HW: 03L 907 309 H
    Component: R4 2,0L EDC X25 9970
    Revision: 22X25--- Serial number: 00000000000000
    Coding: 0125401A233600080000
    Shop #: WSC 66565 257 00032
    ASAM Dataset: EV_ECM20BTD01103L906022JE 002009
    ROD: EV_ECM20BTD01103L906022JD_002.rod
    VCID: 71EF9945A0E571C22A-8024
    Readiness: 0 0 0 0 X
    Self-Diagnosis Log
    Page 2
    VIN: WV2ZZZ7HZAH236860 License Plate: RSB-452
    Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb
    Part No SW: 0BT 300 011 H HW: 0BH 927 711 B
    Component: DSG DQ500-7A H02 0713
    Revision: 00H02V01
    ROD: EV_TCMDQ500021.rod
    VCID: 3363534D9A7903D218-8066
    Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
    Part No SW: 7E0 907 379 E HW: 7E0 907 379 E
    Component: ESP MK25A XT H43 0103
    Revision: 00H43001
    Coding: 108764AD11A7089B26AA88777A5E16
    Shop #: WSC 02756 790 49152
    VCID: 34615051977704EA01-8060
    Reset counter: 11
    Mileage: 241586 km
    Date: 2013.04.27
    Time: 16:59:33
    Count: 529
    Count: 8202
    Count: 252
    Self-Diagnosis Log
    Page 3
    Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
    Part No SW: 7E5 907 040 E HW: 7E5 907 040 E
    Component: ClimatronicT5 H10 0101
    Coding: 0004000102
    Shop #: WSC 02757 790 50316
    ASAM Dataset: EV_ClimatronicT5 A01002
    ROD: EV_ClimaAutoT5Basis.rod
    VCID: 2A5D4E294DB3421AAB-807E
    Slave 1:
    Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
    Component: Heckbedienung H10 0202
    Serial number: BHB-0011209170015218
    U1111 00 [008] - -
    Fault Frequency: 151
    Reset counter: 87
    Mileage: 240949 km
    Date: 2018.11.28
    Time: 11:13:54
    9479185 - Signal Line for Air Quality Sensor
    B10A4 11 [008] - Short to Ground
    Fault Frequency: 54
    Reset counter: 75
    Mileage: 241765 km
    Date: 2018.12.08
    Time: 12:55:30
    9479189 - Signal Line for Air Quality Sensor
    B10A4 15 [008] - Open or Short to Plus
    Fault Frequency: 67
    Reset counter: 75
    Mileage: 241749 km
    Date: 2018.12.08
    Time: 12:28:01
    Self-Diagnosis Log
    Page 4
    Self-Diagnosis Log
    Page 5
    Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
    Part No SW: 7H0 937 089 F HW: 7H0 937 089
    Component: BCM T5GP Li4 H46 0254
    Revision: BS046001 Serial number: 0112 018100323
    Coding: A0A2A93A0E612403932886407FEB8FD48090608F60846841300000000000
    Shop #: WSC 00000 208 256067
    VCID: 397F6165B015F982D2-806C
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 200110 05 54 0402
    Coding: 03302E
    Subsystem 2 - Part No SW: 7E0 959 801 A HW: 7E0 959 801 A Labels: 7E0-959-80X-V1.CLB
    Component: J386__TSG_FT 003 3310
    Coding: 040000
    Subsystem 3 - Part No SW: 7E0 959 802 A HW: 7E0 959 802 A Labels: 7E0-959-80X-V1.CLB
    Component: J387__TSG_BT 003 3310
    Coding: 040000
    Subsystem 4 - Part No: 7E1 951 171
    Subsystem 5 - Part No: 1K0 951 605 C
    Subsystem 6 - Part No: 7E1 951 171
    Subsystem 7 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
    Component: E221__MFL-TK6 H06 0022
    Serial number: 40000000000000008597
    Coding: E20000
    Fault Status: 00101010
    Reset counter: 81
    Mileage: 241179 km
    Date: 2013.04.22
    Time: 07:34:04
    Self-Diagnosis Log
    Page 6
    Address 0D: Slide Door, Left Labels: Redir Fail!
    Part No: 7E0 959 243 C
    Component: Schiebetuer-SG 406 3251
    VCID: 2F6B5F3DBE5127327C-807A
    Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
    Part No SW: 7E0 919 475 A HW: 7E0 919 475 A
    Component: PARKHILFE 8K H10 0008
    Revision: -------- Serial number: 32731001308711
    Coding: 110101
    Shop #: WSC 02756 790 50316
    ASAM Dataset: EV_VW75XParkAssis8K A01003
    ROD: EV_VW75XParkAssis8K_A01.rod
    VCID: 30695C416B6F38CA65-8064
    1079345 - Center Rear Right Parking Aid Sensor
    B1078 31 [008] - No Signal
    Reset counter: 59
    Mileage: 241952 km
    Date: 2018.12.10
    Time: 08:32:31
    1079337 - Center Rear Right Parking Aid Sensor
    B1078 29 [008] - Signal Implausible
    Reset counter: 59
    Mileage: 241952 km
    Date: 2018.12.10
    Time: 08:31:55
    Self-Diagnosis Log
    Page 7
    Part No SW: 7E0 959 655 HW: 7E0 959 655
    Component: VW10Airbag01L H05 0011
    Revision: -------- Serial number: 003E40009KGN
    Coding: 00000000000000000000000000000000314C
    Shop #: WSC 02754 790 50316
    ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
    VCID: 73E3934DDAF943D2D8-8026
    Serial number: 3495ZRB40596094IA1E2
    Serial number: 3505ZRB405B6094IDHNO
    Part No SW: 7E0 920 880 A HW: 7E0 920 880 A
    Component: KOMBI H16 0044
    Coding: 160F00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
    VCID: 2859B42153BF700ABD-807C
    12653568 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Fault Frequency: 139
    Reset counter: 54
    Mileage: 240949 km
    Date: 2018.11.28
    Time: 11:12:22
    Self-Diagnosis Log
    Page 8
    Address 18: Aux. Heat Labels: None
    Part No: 7E0 819 008 F
    Component: J737__Standheizung 0605
    Revision: 00086000 Serial number: 09024901A00000
    Coding: 0001332
    Shop #: WSC 31609 001 1048576
    VCID: 2C5148318F475C2A59-8078
    Part No SW: 6N0 909 901 HW: 7H0 937 089
    Component: GW-K-CAN TP20 H46 0254
    Revision: BS046001
    Coding: 042200
    VCID: 70E99C41A3EF78CA25-8024
    Reset counter: 253
    Mileage: 240949 km
    Date: 2013.04.20
    Time: 11:12:24
    01304 - Radio
    Reset counter: 253
    Address 22: AWD
    Self-Diagnosis Log
    Page 9
    Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
    Component: IMMO H16 0044
    Address 47: Sound System Labels: None
    Part No SW: 7L0 035 466 B HW: 7L0 035 466 B
    Component: DSP 10 Kanal 0030
    Revision: 00H06001 Serial number: 75850000952302
    VCID: 2D574535B45D55224E-8078
    Address 56: Radio
    Self-Diagnosis Log
    Page 10
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H07 0070
    Revision: 3A001001 Serial number: 00000125914014
    Coding: 4100000100000000
    Shop #: WSC 02756 790 00000
    VCID: 30695C41636F38CA65-8064
    Reset counter: 81
    Mileage: 241586 km
    Date: 2013.04.27
    Time: 16:13:18
    Reset counter: 75
    Mileage: 241586 km
    Date: 2013.04.27
    Time: 16:20:17
    Self-Diagnosis Log
    Page 11
    Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W1.clb
    Part No SW: 7E5 919 037 E HW: 7E5 919 037 E
    Component: Dachdisplay H15 0165
    Revision: 10100008 Serial number: 149019
    Coding: 000003
    VCID: 3363534D927903D218-8066
    Fault Frequency: 12
    Reset counter: 81
    Mileage: 240949 km
    Date: 2018.11.28
    Time: 11:13:25
    Address 78: Slide Door, Right Labels: Redir Fail!
    End-------------------------(Elapsed Time: 04:45)--------------------------
    *MEMORY CLEARED OF FAULT CODES = 2Nd scan* VCDS
    Dealer/Shop Name:
    Self-Diagnosis Log
    Monday,07,January,2019,14:40:30:19563
    6E-Ctrl Head Roof -- Status: OK 0000
    Self-Diagnosis Log
    Page 2
    VIN: WV2ZZZ7HZAH236860 License Plate: VENNELÄ
    Revision: 00H02V01
    Revision: 00H43001
    Reset counter: 54
    Mileage: 244270 km
    Date: 2013.05.30
    Time: 14:27:21
    Count: 17
    Count: 8202
    Count: 254
    Self-Diagnosis Log
    Page 3
    Coding: 0004000102
    Slave 1:
    Self-Diagnosis Log
    Page 4
    Coding: 03302E
    Coding: 040000
    Coding: 040000
    Coding: E20000
    Self-Diagnosis Log
    Page 5
    Coding: 110101
    Self-Diagnosis Log
    Page 6
    Coding: 160F00
    U1111 00 [009] - -
    Reset counter: 54
    Mileage: 244270 km
    Date: 2019.01.07
    Time: 14:27:18
    Coding: 0001332
    Self-Diagnosis Log
    Page 7
    Revision: BS046001
    Coding: 042200
    Reset counter: 54
    Mileage: 244270 km
    Date: 2013.05.30
    Time: 14:27:20
    01304 - Radio
    Reset counter: 54
    Mileage: 244270 km
    Date: 2013.05.30
    Time: 14:27:25
    Address 22: AWD
    Self-Diagnosis Log
    Page 8
    Address 56: Radio
    Coding: 000003
    End-------------------------(Elapsed Time: 04:25)--------------------------
    I also have a small problem with the speedometer needle jumping form bumps on the road. Not really a problem though, but a small inconvenience.
    Not here is the crazy part. All of a sudden the AWD started working a week ago. Nothing was done with the car since the scans. I drove to work and ESP and tyre pressure light was lit. I left in the afternoon and presto – I got 4motion back. I actually noticed it after starting from a small incline and the hill hold had activated which it didn’t do when the esp light was on. I really don’t know what to do now with it. There must be something that’s connecting all of the sudden that wasn’t working for the last six months. So what should I check next? I don’t trust it to work for a long time, but I will have to take it to mot. now that the lights are off.
    Thank you for any suggestions and I’m sorry for my rusty English, it’s been awhile since I’ve really used it.
    Hi and welcome.
    A couple of administrative requests:
    • Please see: How to Get Verified. I think you are in category 2 of that post.
    • Please don't use the PRINT function in VCDS for posting data here. The formatting it produces is good for a sheet-fed printer, but is much harder to read here than the original native text that VCDS produces. Please have a look in your Scan sub-folder. The above scan will be there in the desired format.
    New User
    Jan 2019
    Thanks for the message. And here I was thinking that for once in my life I read the instructions and nailed the code input.
    Here's another try:
    Monday,07,January,2019,14:22:27:19563
    VCDS Version: 18.9.0.2 (x64)
       Revision: 00H02V01
       Revision: 00H43001
                        Reset counter: 11
                        Mileage: 241586 km
                        Date: 2013.04.27
                        Time: 16:59:33
                        Count: 529
                        Count: 8202
                        Count: 252
       Coding: 0004000102
       Slave 1:
              U1111 00 [008] - -
                        Reset counter: 87
                        Mileage: 240949 km
                        Date: 2018.11.28
                        Time: 11:13:54
                        Fault Frequency: 54
                        Reset counter: 75
                        Mileage: 241765 km
                        Date: 2018.12.08
                        Time: 12:55:30
                        Fault Frequency: 67
                        Reset counter: 75
                        Mileage: 241749 km
                        Date: 2018.12.08
                        Time: 12:28:01
       Coding: 03302E
       Coding: 040000
       Coding: 040000
       Coding: E20000
                        Reset counter: 81
                        Mileage: 241179 km
                        Date: 2013.04.22
                        Time: 07:34:04
       Coding: 110101
                        Reset counter: 59
                        Mileage: 241952 km
                        Date: 2018.12.10
                        Time: 08:32:31
                        Reset counter: 59
                        Mileage: 241952 km
                        Date: 2018.12.10
                        Time: 08:31:55
       Coding: 160F00
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 240949 km
                        Date: 2018.11.28
                        Time: 11:12:22
       Coding: 0001332
       Revision: BS046001
       Coding: 042200
                        Reset counter: 253
                        Mileage: 240949 km
                        Date: 2013.04.20
                        Time: 11:12:24
    01304 - Radio
                        Reset counter: 253
    Address 22: AWD
    Address 56: Radio
                        Reset counter: 81
                        Mileage: 241586 km
                        Date: 2013.04.27
                        Time: 16:13:18
                        Reset counter: 75
                        Mileage: 241586 km
                        Date: 2013.04.27
                        Time: 16:20:17
       Coding: 000003
                        Fault Frequency: 12
                        Reset counter: 81
                        Mileage: 240949 km
                        Date: 2018.11.28
                        Time: 11:13:25
    Monday,07,January,2019,14:39:27:19563
       Revision: 00H02V01
       Revision: 00H43001
                        Reset counter: 54
                        Mileage: 244270 km
                        Date: 2013.05.30
                        Time: 14:27:21
                        Count: 17
                        Count: 8202
                        Count: 254
       Coding: 0004000102
       Slave 1:
       Coding: 03302E
       Coding: 040000
       Coding: 040000
       Coding: E20000
       Coding: 110101
       Coding: 160F00
              U1111 00 [009] - -
                        Reset counter: 54
                        Mileage: 244270 km
                        Date: 2019.01.07
                        Time: 14:27:18
       Coding: 0001332
       Revision: BS046001
       Coding: 042200
                        Reset counter: 54
                        Mileage: 244270 km
                        Date: 2013.05.30
                        Time: 14:27:20
    01304 - Radio
                        Reset counter: 54
                        Mileage: 244270 km
                        Date: 2013.05.30
                        Time: 14:27:25
    Address 22: AWD
    Address 56: Radio
       Coding: 000003
    And I don't believe I should be verified, the VCDS-License isn't mine. I had my car scanned and the report was given to me. I was engouraged to get a unit of my own which I will now that i've seen how vital it is with this car...
  4. Likes Uwe liked this post
    I'm not quite sure what to make of that situation.
    The Gateway seems to be able to talk to it:
    But VCDS can't.
    That's rather strange.
  6. Likes Hra47 liked this post
    Sep 2016
    Riga, Latvia
    But VCDS can't.
    I'm not quite sure if the gateway really is talking to address 22...
    module without fault codes status is 0000
    module containing fault information status is 0010
    module registered in the gateway but not reachable status is 1100
    but what does status 1110 mean?
    BTW are these status bits documented somewhere?
  8. Likes Hra47 liked this post
  9. #6
    Quote Originally Posted by MartinsX View Post
    VCDS already decodes them for you.
  10. #7
    Sep 2016
    Riga, Latvia
    You know I always look for deeper explanations
    Actually I didn't pay attention to status bits in GW list till this thread.
    Each bit has some special meaning, not only "malfunction", "ok" and "can not be reached" what VCDS decodes.
    For example part of scan with intermittent comm errors:
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001059158163
       Coding: 3D3F0340070002
       Shop #: WSC 00028 028 00001
       VCID: 2A5B68978581931197-807E
                        Fault Frequency: 32
                        Reset counter: 74
                        Mileage: 103322 km
                        Time: 14:18:20
    01304 - Radio
                        Fault Frequency: 32
                        Reset counter: 74
                        Mileage: 103322 km
                        Time: 14:18:20
       Part No: 1K0 035 186 P
       Component: Radio GR0       015 0019
       Revision: 0001503S    Serial number: VWZ2Z2E2577524
       Coding: 0040402
       VCID: 336575F3524BD2D924-8066
    00857 - CD Changer Unit (R41)
  11. Likes Hra47 liked this post
  12. #8
    Võru, Estonia
    Easy..... Verify can-bus, verifiy power and if that checks out, rrplace haldex module because of water damage.
    The world is my oyster...
  13. Likes Uwe, Hra47 liked this post
  14. #9
    New User
    Jan 2019
    Thank you all for the replies. I was thinking of can-bus failures also after replacing the haldex module but that wouldn't explain why it started working all of a sudden 6-10 weeks after replacing it. Also a new problem occured roughly the same time the 4motion started to work. The parking aids aren't working anymore, once I engage reverse it gives a long beeb and flashes the parking sensor button on the dash and neither the front nor rear sensors are operating?!?!?
    I will ask my car electrician to look at the can-bus issue and to verify power, because I hope he knows what that means
  15. #10
    Sep 2016
    Riga, Latvia
    This is answer to Your question about parking system:
       Coding: 110101
                        Reset counter: 59
                        Mileage: 241952 km
                        Date: 2018.12.10
                        Time: 08:32:31
                        Reset counter: 59
                        Mileage: 241952 km
                        Date: 2018.12.10
                        Time: 08:31:55
    Fast way to check is to interchange the rear right center sensor with any of other sensors, clear fault codes, engage reverse and rescan. If the same code comes back, You have faulty wiring to rear right center sensor. If fault moves to another position together with sensor, then sensor is faulty, need replacement.
    P.S. "THE Mr. GREEN" is everyday guest in car electricians life All the time he makes intermittent conditions and circuits
  16. Likes Uwe, PetrolDave liked this post
