Results 1 to 10 of 10
Thread: Greetings from South Africa (B7 RS4 question)
    Feb 2019
    South Africa
    I just received my Hex-V2 cable. Best thing that has ever happened to me and my car.
    Now for the core of my first post. I did a scan on an '07 B7 RS4 and this is what I got. History: I had carbon clean done, changed fuel filter, replaced spark plugs 1 year ago (after injector cleaner burnt them) after misfires. Also noticed that my N276 valves were leaking on both hpfp and installed new pumps. First scan today picked up low pressure error from time the fuel was leaking from hpfp, and few other errors from the past. Cleared DTCs. Drove a bit and got the below results.
    Why would N276 error come up with brand new pumps? Electrical fault?
    Self-Diagnosis Log
    Monday,11,February,2019,12:58:06:17755
    Page 2
    VIN: WUAZZZ8E47NXXXXXX License Plate:
    Address 01: Engine Labels:. 079-910-560-BNS1.lbl
    Part No SW: 8E1 910 560 B HW: 8E1 907 560
    Component: 4.2L V8/4V FSI 짧0040
    Revision: --H13--- Serial number:
    Coding: 01040000180F0160
    Shop #: WSC 03163 996 87872
    VCID: 2516040569E5539FCDD-8070
    8 Faults Found:
    001112 - Evap System Purge Control Valve (N80)
    P0458 - 002 - Short to Ground
    Fault Status: 01100010
    Mileage: 134367 km
    RPM: 779 /min
    Load: 26.7 %
    Temperature: 101.0째C
    Temperature: 59.0째C
    Absolute Pres.: 830.0 mbar
    Voltage: 13.589 V
    008201 - Intake Manifold Flap; Bank 1
    P2009 - 002 - Short to Ground
    Mileage: 134367 km
    RPM: 779 /min
    Load: 26.7 %
    Temperature: 59.0째C
    Voltage: 13.589 V
    004199 - Intake Air Switch-Over Valve (N335)
    P1067 - 002 - Short to Ground
    Self-Diagnosis Log
    Page 3
    Mileage: 134367 km
    RPM: 779 /min
    Load: 26.7 %
    Temperature: 59.0째C
    Voltage: 13.716 V
    005173 - Secondary Air Pump Relay (J299)
    P1435 - 002 - Short to Ground
    Mileage: 134367 km
    RPM: 779 /min
    Load: 26.7 %
    Temperature: 59.0째C
    Voltage: 13.716 V
    005153 - Secondary Air Injection Solenoid Valve (N112)
    P1421 - 002 - Short to Ground
    Mileage: 134367 km
    RPM: 779 /min
    Load: 26.7 %
    Temperature: 59.0째C
    Voltage: 13.716 V
    Self-Diagnosis Log
    Page 4
    008853 - Fuel Pressure Regulator Valve (N276)
    P2295 - 002 - Short to Ground
    Mileage: 134367 km
    RPM: 779 /min
    Load: 26.3 %
    Temperature: 59.0째C
    Voltage: 13.589 V
    000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
    P0037 - 002 - Short to Ground
    Mileage: 134367 km
    RPM: 780 /min
    Load: 26.3 %
    Temperature: 59.0째C
    Voltage: 13.589 V
    000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
    P0031 - 002 - Short to Ground
    Mileage: 134367 km
    RPM: 780 /min
    Load: 26.3 %
    Self-Diagnosis Log
    Page 5
    Temperature: 59.0째C
    Voltage: 13.589 V
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
    Component: ESP8 quattro H06 0150
    Coding: 0004533
    Shop #: WSC 06335 000 00000
    VCID: 2B02F23D0F0165EF1B9-807E
    Part No: 8E0 820 043 BQ
    Component: A4 Klimaautomat 2833
    Coding: 00000
    VCID: 71BE2055E8BD4F3F615-5160
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 N
    Component: int. Lastmodul ECE 0907
    Coding: 01041
    Shop #: WSC 06335
    VCID: 3D26CC65E465FB5FB5D-4B00
    Self-Diagnosis Log
    Page 6
    Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
    Revision: --H13--- Serial number: XXXXXXXXXXXXXX
    005491 - Left Engine Mount Solenoid Valve (N144)
    P1573 - 004 - Open Circuit
    Mileage: 134360 km
    RPM: 202 /min
    Load: 98.4 %
    Temperature: 21.0째C
    Temperature: 24.0째C
    Voltage: 10.668 V
    004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)
    P129C - 002 - Short to Ground
    Mileage: 134360 km
    RPM: 195 /min
    Load: 99.2 %
    Temperature: 21.0째C
    Temperature: 24.0째C
    Voltage: 10.668 V
    000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
    P0051 - 002 - Short to Ground
    Self-Diagnosis Log
    Page 7
    VIN: WUAZZZ8E47N903060 License Plate: BZ75KZGP
    Mileage: 134360 km
    RPM: 1249 /min
    Load: 48.2 %
    Temperature: 28.0째C
    Temperature: 25.0째C
    Voltage: 13.589 V
    000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
    P0057 - 002 - Short to Ground
    Mileage: 134360 km
    RPM: 1190 /min
    Load: 49.0 %
    Temperature: 36.0째C
    Temperature: 25.0째C
    Voltage: 13.589 V
    Self-Diagnosis Log
    Page 8
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H12 3730
    Revision: 91H12373 Serial number: 0036M0G3HAVM
    Coding: 0430712
    VCID: 3B22C27DFF61F56F8B9-806E
    Subsystem 1 - Serial number: 6332DRB403E2CE25Z
    Subsystem 2 - Serial number: 6342DRB403D51224E
    Subsystem 3 - Serial number: 6352ARB4018BBE3C%
    Subsystem 4 - Serial number: 6362ARB4018BD57F0
    Subsystem 5 - Serial number: 63729RB401A3FFF0%
    Subsystem 6 - Serial number: 63829RB401A3F6A1U
    Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
    Part No: 8E0 953 549 T
    Component: Lenks찼ulenmodul 0301
    Coding: 06021
    Shop #: WSC 06335
    VCID: 44D0B981878F8A97FA3-4B00
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
    Component: KOMBI+WFS 4 H14 0040
    Revision: 0040 Serial number: 00000000000000
    Coding: 0023111
    Shop #: WSC 03163 996 13764
    VCID: 2C00F1210A1F62D7123-5184
    Self-Diagnosis Log
    Page 9
    Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
    Coding: 0023111
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760 A
    Component: Sitzverstellung H01 0020
    Coding: 00001
    Shop #: WSC 06335
    VCID: 323CEF592D0B342758F-4B1E
    Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
    Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
    Component: RNS-E HIGH EU H72 0500
    Revision: 01S Serial number: AUZBZ7F1182915
    Coding: 0301114
    Shop #: WSC 02195 785 00200
    VCID: 2C00F1210A2F62D7123-5160
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    VCID: 6B82323DCA91A5EF5B9-50F4
    Self-Diagnosis Log
    Page 10
    Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
    Part No: 8E0 959 433 CH
    Component: Komfortger찼t T3B 4135
    Coding: 07918
    Shop #: WSC 03163
    VCID: 79AE1875B0CD077FD95-4B00
    Subsystem 1 - Part No: 8E2959802E
    Component: T천rsteuer.FS BRM 0706
    Subsystem 2 - Part No: 8E2959801E
    Component: T천rsteuer.BF BRM 0706
    Component: T천rsteuer.HL BRM 0606
    Component: T천rsteuer.HR BRM 0606
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Coding: 0000019
    VCID: 290E083505FD77FFE95-807C
    Subsystem 1 - Part No: 8E0 941 329 A
    Component: AFS-Modul links H03 0010
    Subsystem 2 - Part No: 8E0 941 329 A
    Component: AFS-Modul rechtsH03 0010
    Address 56: Radio Labels: 8E0-035-192-RNSE.clb
    Coding: 0301114
    Self-Diagnosis Log
    Page 11
    VIN: WUAZZZ8E47NXXXXXXX License Plate:
    Address 57: TV Tuner Labels: 4D0-919-146.clb
    Part No SW: 4D0 919 146 D HW: 4D0 919 146 D
    Component: TV Tuner H04혮0580
    Revision: 01H04001 Serial number: 00000000015330
    Coding: 0007130
    VCID: 2A0CF73900DB7CE7E0F-513C
    No Faults Found
    Address 65: Tire Pressure Labels: 8E0-907-273.lbl
    Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
    Component: Reifendruck 3 H04 0130
    Coding: 0022523
    Shop #: WSC 02197 785 00200
    VCID: 2A0CF73900DB7CE7E0F-5160
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
    Component: Parkhilfe 8-Kan H06 0010
    Revision: 00H06000 Serial number: 00067802120624
    Coding: 0000104
    VCID: 323CEF59280B342758F-5160
    End----------(Elapsed Time: 04:23, VBatt start/end: 13.4V/13.6V)-----------
    Hi and welcome!
    Administrative request: Please don't use the PRINT function in VCDS for posting data here. The formatting it produces is good for a sheet-fed printer, but is much harder to read here than the original native text that VCDS produces. Please have a look in your Scan sub-folder. The above scan will be there in the desired format.
    Next, I'm going to enhance the title of this post a bit, which will hopefully bring it to the attention of our resident B7 RS4 expert (he's in the UK). Personally, I still lust after that car, but have never owned one, and am not terribly familiar with their quirks.
  3. Likes Dana, RS4v8 liked this post
    United States
    All of those components likely share the same power supply relay. I would clear the codes to see if they return and verify power to the easiest components you can access to see if power happens to be missing entirely.
  5. Likes Uwe, RS4v8 liked this post
  6. #4
    Feb 2019
    South Africa
    Thanks @Uwe. How is this (code paste)? Hopefully RS4 expert is on look out.
    @Dana: Thanks. I suspected so as it seems to be a common question but not always answered. I need to purchase my basic EE tools in that case to do the debug as you suggest.
    Monday,11,February,2019,12:56:55:17755
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
              67 69 75 76 77
    VIN: WUAZZZ8E47NXXXXXX   Mileage: 134360km-83487miles
       Component: 4.2L V8/4V FSI     0040
    8 Faults Found:
                        Mileage: 134367 km
                        RPM: 779 /min
                        Load: 26.7 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.589 V
                        Mileage: 134367 km
                        RPM: 779 /min
                        Load: 26.7 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.589 V
                        Mileage: 134367 km
                        RPM: 779 /min
                        Load: 26.7 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.716 V
                        Mileage: 134367 km
                        RPM: 779 /min
                        Load: 26.7 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.716 V
                        Mileage: 134367 km
                        RPM: 779 /min
                        Load: 26.7 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.716 V
                        Mileage: 134367 km
                        RPM: 779 /min
                        Load: 26.3 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.589 V
                        Mileage: 134367 km
                        RPM: 780 /min
                        Load: 26.3 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.589 V
                        Mileage: 134367 km
                        RPM: 780 /min
                        Load: 26.3 %
                        Temperature: 101.0캜
                        Temperature: 59.0캜
                        Voltage: 13.589 V
       Coding: 0004533
       Coding: 00000
       Coding: 01041
       Shop #: WSC 06335
                        Mileage: 134360 km
                        RPM: 202 /min
                        Load: 98.4 %
                        Temperature: 21.0캜
                        Temperature: 24.0캜
                        Voltage: 10.668 V
                        Mileage: 134360 km
                        RPM: 195 /min
                        Load: 99.2 %
                        Temperature: 21.0캜
                        Temperature: 24.0캜
                        Voltage: 10.668 V
                        Mileage: 134360 km
                        RPM: 1249 /min
                        Load: 48.2 %
                        Temperature: 28.0캜
                        Temperature: 25.0캜
                        Voltage: 13.589 V
                        Mileage: 134360 km
                        RPM: 1190 /min
                        Load: 49.0 %
                        Temperature: 36.0캜
                        Temperature: 25.0캜
                        Voltage: 13.589 V
       Coding: 0430712
       Component: Lenksulenmodul     0301
       Coding: 06021
       Shop #: WSC 06335
       Coding: 0023111
       Coding: 0023111
       Coding: 00001
       Shop #: WSC 06335
       Coding: 0301114
       Coding: 00001
       Component: Komfortgert T3B    4135
       Coding: 07918
       Shop #: WSC 03163
       Component: Trsteuer.FS BRM 0706
       Component: Trsteuer.BF BRM 0706
       Component: Trsteuer.HL BRM 0606
       Component: Trsteuer.HR BRM 0606
       Coding: 0000019
       Coding: 0301114
       Component: TV Tuner        H040580
       Coding: 0007130
    No Faults Found
       Coding: 0022523
       Coding: 0000104
  7. Likes Dana, Uwe liked this post
  8. #5
    I wonder how many connectors were opened up when the carbon clean was done?
    And how many vacuum lines were opened up too?
    I'd check both of those and the connectors to the ECUs themselves as the common theme seems to be lack of power (short to ground) to many engine ancillary parts...
    I suspect someone may comment on the engine ECUs SW versions being 0040, is that the latest version available in South Africa? (my RS4 was UK spec so the SW versions are different and mine was running 0090 when I sold it 2 years ago).
    Side note - is the TV tuner still usable in South Africa as it's analogue only?
  9. Likes Dana, Uwe liked this post
  10. #6
    Feb 2019
    South Africa
    Good point @PetrolDave. Answering in order:
    I am not sure as to what was opened (walnut blasting method was used) except that intake manifold would have to be opened.....
    But a bit more history....the car had a tendency to have some difficulty to start once every three months or so until about 2016. When I say difficulty to start I mean the crank needs something like 3-6 seconds before engine fires up. With this difficulty starting up, the car would start and EPC light goes on and Sport button would not work. I would be able to drive although the engine didnt feel as sharp. Usually if I stopped and switched off the car and then start again, the car would be OK. EPC light gone and sharp(ish) engine feel returns. In 2017, the carbon became an issue. Not only would the starting be an issue but it would also be misfires from time to time. That is when I booked in for a carbon clean.
    After carbon clean, the car felt NEW. I thought this would get rid of the difficult start lottery. Instead the difficult start became frequent. Before I got the Hex V2, I thought priming the fuel line by turning ignition would help the car start first time. But it doesnt help. In fact now, it is more difficult start than easy starts so something has degraded over time.
    On the side note - things are moving rather slowly in South Africa. For the state-owned broadcaster, they are happy to be on analogue. So the media unit still works for radio (I've never used the TV tuner though). Personally I use my fibre Internet line to view content instead of the digital satellite signal. But let me not get carried away.
  11. Likes Uwe liked this post
  12. #7
    I still reckon the place to start is checking any electrical and vacuum connections that may have been disturbed when the inlet manifold was off, and the connectors to the ECUs themselves as the common theme seems to be lack of power (short to ground) to many engine ancillary parts...
    What condition are the spark plugs, and are they the correct ones?
    This engine is quite "fussy" about it's fairly complex vacuum system, so it's worth doing a Mark 1 eyeball check on ALL the vacuum connections - not forgetting that the exhaust valves are also vacuum operated (and if you've removed them check that the vacuum lines to them are plugged and not leaking).
    Next time you experience a difficult start and the EPC light is on, do an Auto-Scan straight away and check which fault codes have the current date/time - that will give some clues what is causing the difficult starting.
  13. Likes Uwe liked this post
  14. #8
    Feb 2019
    South Africa
    Aaah. I did the auto scan and a few checks before and after hard start. I cleared the DTCs in between the 2 tests as @Dana suggested. I went for a drive and did a scan afterwards. A much clearer picture formed including a confirmation of fuel trims when engine coolant temperature was over 85 centigrade.
    - the electrical fault symptoms remain(short to ground),
    -fuel rail pressure was around 6 bar before cold start when it should be at 23 bar. So hard start somewhat doesn't surprise me now.
    -when car has been driven for some time the fuel rail pressure sits at 18 bar before switching car off.
    -once switched off the rail pressure leaks down to 6 bar again.
    -scanning after drive shows intermittent low fuel pressure and I also saw the left engine mount short to ground. No surprise I guess.
    -fuel trim values were not not oscillating between -1% and +1% but were sitting at -1% when scanning after drive.
    Is this a more familiar problem in this case? I've not tried your recommendation of checking cables and connectors. Will do a bit later. I will also try to see if it's a faulty part or not.
    Oh the spark plugs are new but I need to inspect them as well just for control.
  15. #9
    Feb 2019
    South Africa
    The N276 that has shorted to ground is brand new. So is it reasonable to suspect the electrical fault?
    Also is it reasonable to suspect that rail pressure is leaking down to 6 bar (This seems to be in tank pump pressure) due to N276 that has shorted to ground?
  16. #10
    Feb 2019
    South Africa
    Additional information:
    Over and above the listed tests I did some physical checking of some connections that were available to me.
    I opened the N276 connector/power supply that was labeled as short to ground. I then ran a auto-scan. This scan showed that this N276 had Open Circuit and all the other errors were GONE!
    Upon looking at this connector, I noticed that it is a bit loose compared to the connector to Bank1's N276 connector. Could this be the culprit?
