Hello I am Jaap from the Netherlands.Code:VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4 Data version: 20190114 DS296.0 www.Ross-Tech.com VIN: WVWZZZ3CZHE021497 License Plate: B8 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C-VW48 (5Q0) Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 2B 42 44 52 5F 69 6C VIN: WVWZZZ3CZHE021497 Mileage: 71906km-44680miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 2B-Steer. Col. Lock -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 69-Trailer -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CZEA) Labels:. 04E-907-309-V1.clb Part No SW: 04E 906 027 BT HW: 04E 907 309 AB Component: R4 1.4l TFS H23 9177 Revision: R6H23--- Coding: 0125007224741D083000 Shop #: WSC 51389 001 1048576 ASAM Dataset: EV_ECM14TFS01104E906027BT 001011 ROD: EV_ECM14TFS01104E906027BT.rod VCID: 77AA1F522F48F69FAF7-8022 CAN Converter 01: No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb Part No SW: 0CW 300 049 Q HW: 0AM 927 769 E Component: GSG DQ200G2_M H05 0902 Revision: 00005006 Serial number: CU501606085035 Coding: 0014 Shop #: WSC 05311 115 00062 ASAM Dataset: EV_TCMDQ200021 001001 ROD: EV_TCMDQ200021_VW31.rod VCID: 4BC293A20340A27F3BF-801E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH Component: ESC H62 0736 Revision: 00000000 Serial number: 61566000000864 Coding: 0FEC6A8F3422136D477B060941CA49F0562CC8E2608292711822F078C20202 Shop #: WSC 00015 115 08193 ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019 ROD: EV_Brake1UDSContiMK100IPB_035_VW37.rod VCID: 7BA203621360D2FFCBF-802E No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D Component: VWKESSYMQB 026 0811 Revision: 00026000 Serial number: 0407107756 Coding: 002F0F0F0F Shop #: WSC 05311 115 00312 ASAM Dataset: EV_KessyHellaMQBAB 004039 ROD: EV_KessyHellaMQBAB_VW48.rod VCID: 3B22C36253E012FF8BF-806E Sensor Controlled Power Rear Lid: No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5G0 907 044 BP HW: 5G0 907 044 BP Component: Climatronic H04 1601 Revision: 00001K10 Coding: 12020004200100011015504E00101922 Shop #: WSC 00015 115 08193 ASAM Dataset: EV_ACClimaBHBVW37X 006142 ROD: EV_ACClimaBHBVW37X_006_VW48.rod VCID: 76B4125628428F97B41-8022 Fresh Air Blower Front: Refrigerant Pressure And Temperature Sender: Air quality sensor: Relative humidity sensor in fresh air intake duct: No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 086 BG HW: 5Q0 937 086 BG Component: BCM PQ37BOSCH 032 0222 Revision: -------- Serial number: 865807061600ZT Shop #: WSC 00015 115 08193 ASAM Dataset: EV_BodyContrModul1UDSBosc 017002 ROD: EV_BCMBOSCH_017.rod VCID: 0058748E7A86B1279ED-8054 Control Unit For Wiper Motor: Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB Component: WWS 160512 042 0607 Serial number: 160525193416 Coding: 0E4DDD Rain Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB Component: RLHS 042 0105 Serial number: S2Y16M06D15H13M41S38 Coding: 00A8DD Light switch: Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633 Component: E1 - LDS MQB H01 0032 Serial number: 29 03 2016 10000059 Relative Air Humidity Interior Sender: No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A Component: PARKHILFE 8K H03 0056 Revision: -------- Serial number: 39331616300001 Coding: 0071151911 Shop #: WSC 51389 001 1048576 ASAM Dataset: EV_EPHVA18AU3700000 002026 ROD: EV_EPHVA18AU3700000_002_VW48.rod VCID: 44D0B89E2E1E6D07FA5-8010 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B Component: ACC BOSCH MQB H04 0194 Coding: 3200670A51FFC428949C804D Shop #: WSC 51389 001 1048576 ASAM Dataset: EV_ACCBOSCHVW48X 001009 ROD: EV_ACCBOSCHVW48X.rod VCID: 3430E85E7EBEDD874A5-8060 1 Fault Found: 0836 - Databus U1123 00 [008] - Received Error Message [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 21 Reset counter: 176 Mileage: 71792 km Date: 2019.02.06 Time: 11:22:19 Control Module temperature: 5 °C Voltage terminal 15: 14.1 V Velocity_vehicle_reference: 0.00 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² Status_ACC_System: ACC_StandBy ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA Component: Airbag VW20 013 0195 Revision: -------- Serial number: 003SSPAWG4BS Coding: 88CCC000000000005C5400CC000800000065 Shop #: WSC 05314 000 00001 ASAM Dataset: EV_AirbaVW20TS6VW48X 001116 ROD: EV_AirbaVW20TS6VW48X.rod VCID: 7EA40A760072C7D7EC1-802A Belt Pretensioner left: Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A Component: BeltPretRevFL 106 1032 Serial number: 3G1857705G0161Q00316 Coding: 80000D Belt Pretensioner right: Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A Component: BeltPretRevFR 106 1032 Serial number: 3G1857706G0161Q01336 Coding: 80000D Side Sensor Driver Front: Subsystem 3 - Part No SW: ----------- HW: 454 002 405 16 Component: SideSensor_Df 008 0887 Serial number: 3576U000000742695B1A Coding: 2D2D2D Side Sensor Passenger Front: Subsystem 4 - Part No SW: ----------- HW: 454 002 305 16 Component: SideSensor_Pf 008 0887 Serial number: 3586U000000426695B1A Coding: 2D2D2D Side Sensor Driver Rear: Subsystem 5 - Part No SW: ----------- HW: 454 800 506 16 Component: SideSensor_Dr 301 0148 Serial number: 3516R1A71980B0000003 Coding: 2D2D2D Side Sensor Passenger Rear: Subsystem 6 - Part No SW: ----------- HW: 454 800 506 16 Component: SideSensor_Pr 301 0148 Serial number: 3526RBB63980B000000G Coding: 2D2D2D Front Sensor Driver: Subsystem 7 - Part No SW: ----------- HW: 454 801 605 16 Component: FrontSensor_D 304 0149 Serial number: 3556VDAFC900A000000X Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb Part No SW: 3Q0 953 521 EJ HW: 5Q0 953 569 B Component: Lenks.Modul 100 0225 Revision: FF034034 Serial number: 20160525501240 Coding: 0410 Shop #: WSC 00015 115 00001 ASAM Dataset: EV_SMLSVALEOMQBLRH 001009 ROD: EV_SMLSVALEOMQBLRH.rod VCID: 7CA0007E166ED5C7C25-8028 1 Fault Found: 291104 - Temperature Sensor for Heated Steering Wheel B1455 01 [008] - Electrical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 60 Reset counter: 176 Date: 2000.00.00 Time: 00:00:00 Ubat 30 Voltage: 11.80 V Internal error state: 0 LIN_Temp: 0 Isense: 0 Max.Leistung: 110 PWM: 0 Offset: 245 Slope: 134 kp: 13 OUT: 50 Temperatur Statisch: 30 p_t_soll_0: 39.00 °C p_t_soll_1: 43.00 °C p_t_soll_2: 47.00 °C ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 3G0 920 750 B HW: 3G0 920 750 B Component: KOMBI 303 8311 Coding: 07A50A182780000801886B011000000000000000 Shop #: WSC 00015 115 00001 ASAM Dataset: EV_DashBoardVDDMQBAB 009051 ROD: EV_DashBoardVDDMQBAB_VW48.rod VCID: 23121B02CB504A3FA3F-8076 1 Fault Found: 1048578 - No Basic Setting B2010 00 [009] - - [Steuergerät keine oder falsche Grundeinstellung] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 130 Mileage: 71789 km Date: 2019.02.04 Time: 15:43:12 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M Component: GW MQB High 212 2265 Revision: -------- Serial number: 06061610802962 Coding: 030300347F085700FB00025C1C0F00010001070000000000000000000000 Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_GatewConti 013020 ROD: EV_GatewConti_013_VW48.rod VCID: 7CA0007E166ED5C7C25-8028 Alternator: Multi Function Steering Wheel Control Module: Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB Component: E221__MFL-DC1 H17 0040 Serial number: 29160001128830046231 Coding: 2FFFFF Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J Component: J367-BDMConti H03 1050 Serial number: 75410803001605270410 Analog clock: Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C Component: Analoguhr 209 2002 No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb Part No SW: 3G0 857 511 AE HW: 3G0 857 511 AE Component: FLA H10 0003 Revision: AA001001 Coding: 0101000400000000000000 Shop #: WSC 00015 115 00001 ASAM Dataset: EV_HighBeamAssisAU33X 001017 ROD: EV_HighBeamAssisAU33X_VW37.rod VCID: 6B8233226300427F5BF-803E No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb Part No SW: 3Q0 905 861 HW: 3Q0 905 861 Component: ELV-MQBB H05 0032 Serial number: 16000120720004 Coding: 0800000000000000 Shop #: WSC 05311 115 00062 ASAM Dataset: EV_ELVMarquMQBB 001007 ROD: EV_ELVMarquMQBB.rod VCID: 71BE214A412CA8AF613-8024 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B Component: TSG FS 020 0041 Serial number: 020616EEV13584 Coding: 00350B20D000028000001000 Shop #: WSC 00015 115 08193 ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003 ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 43D2BB822B106A3FC3F-8016 Drivers Door Rear Control Module: Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG DRV 007 0002 Serial number: 00000000000003870046 Coding: 010000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E Component: MQB_PP_APA 204 2041 Revision: 00000000 Serial number: 0000853784 Coding: 01000010005000 Shop #: WSC 00015 115 00312 ASAM Dataset: EV_SteerAssisVWBSMQBA 008028 ROD: EV_SteerAssisVWBSMQBA_008.rod VCID: 3D26CD7A4DF41CCFB5B-8068 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B Component: TSG BFS 020 0041 Serial number: 040616EF329398 Coding: 00350120DE00028000001000 Shop #: WSC 00015 115 08193 ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003 ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: 42DCBE86340A6337C89-8016 Passengers Rear Door Control Module: Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB Component: Fond FHSG PSG 007 0002 Serial number: 00000000000003866024 Coding: 090000 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb Part No SW: 3Q0 035 846 A HW: 3Q0 035 846 A Component: MU-S-N-ER H30 0356 Serial number: VWZAZ2S0314618 Coding: 02840201FF0000005111000100080A001F01008401200100CF Shop #: WSC 05311 115 00062 ASAM Dataset: EV_MUStd4CTSAT 001022 ROD: EV_MUStd4CTSAT_VW36.rod VCID: 2F3AE7329798FE5F377-807A Operating And Display Unit 1: Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B Component: ABT_Std-2_Nav H34 8074 Serial number: VWZ6ZDS2240005 Data medium: Subsystem 2 - Part No SW: 5NA 919 866 HW: ----------- Component: ECE1 2018/19 --- 1030 Serial number: -------------------- 1 Fault Found: 1555 - Check Software Version Management B201A 00 [009] - - [Check software version management] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 130 Mileage: 71789 km Date: 2019.02.04 Time: 15:42:39 Voltage terminal 30: 11.5 V Status_Software_Version_Management-module_name: D ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb Part No SW: 5Q0 907 383 J HW: 5Q0 907 383 B Component: Anhaenger H21 0203 Revision: 8C001003 Serial number: 0392593978 Coding: 0100000202000000 Shop #: WSC 51389 001 1048576 ASAM Dataset: EV_TrailFunctGener2Hella 001008 ROD: EV_TrailFunctGener2Hella_VW26.rod VCID: 3E24CA7640F207D7AC1-806A 1 Fault Found: 136203 - Supply Voltage P1757 00 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 23 Reset counter: 176 Mileage: 71789 km Date: 2019.02.04 Time: 16:16:37 ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb Part No SW: 5Q0 980 556 HW: 5Q0 980 556 Component: RVC Compact H09 0170 Coding: 0184020163002017000040 Shop #: WSC 51389 001 1048576 ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007 ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod VCID: 77AA1F522F48F69FAF7-8022 No fault code found. End----(Elapsed Time: 02:10, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)----- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 17: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 5F: DTCs cleared
I had a HEX-USB+CAN interface for years.
But with my passat B8 i had a lot off faults with the autoscan.
So i got a new HEX-V2 interface and the faults are gone.
But now i have a other problem.
In central electrics i want to make a few changes but after 3 changes it is giving me security access required.
I have put the security code 31347 in for the first changes and that was accepted.
So i gave the code in again and it is telling it is accepted but when i make a change it wants the code again.
Can anyone help me with this problem?
The interface is registerd with Ross-Tech.
