Results 1 to 10 of 14
Thread: Electrical issues (2004 A8)
    Feb 2019
    Canada
    Hi everyone!
    I am a newbie. Bought a 2004 Audi A8l with 4.2l last week and drove it back home 22 hours in 2 days. Everything worked fine (no electrical problems) for 3/4 of the way home and mechanically the car seems in really good condition (new air suspension, suspension bushings and alignment 40,000km ago, new timing belt 20k ago, New plugs and R8 ignition coil 20k ago as well as new intake manifold runners and intake carbon cleaning). Runs and drives great. About 3/4 of the way home air suspension green light came on, little while later yellow light. Would disappear when I stopped to fuel and turn car off and re-appear a while down the road.
    Once home left parked outside. Very cold that night - 30 degrees Celsius. Next morning started car and air bag sensor was on, front air suspension not working, radio wouldn't work, windshield wipers not working, and blower fan for heater would increase speed when I would pull lever back to try windshield washer fluid. Shortly thereafter "headlight range control defective". Air suspension working again but compressor cutting in and out a lot. When leave car in garage a couple of days without touching it the air in suspension holds (car doesn't lower and stays height I left it......assuming air shocks and lines are good).
    Just performed my first scan and will post below. Talked to a couple of people who know these cars well. First idea is that it could be a Central Electronic/BCM problem and needs to be replaced. Second idea, it has a new battery.....possibly new battery was not coded to car (but wouldn't I have noticed problems immediately not after 22 hours of driving?). Any input appreciated.....please be patient with me as I mentioned I am new to all of this but willing to learn.
    Sunday,10,February,2019,10:13:44:02559
    VIN: WAUML44E24N024067   License Plate:
    Mileage: 271010km-168397mi   Repair Order:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
              47 4F 52 53 55 56 61 62 65 72 75 76
    VIN: WAUML44E24N024067   Mileage: 271010km-168397miles
    00-Steering Angle Sensor -- Status: Sporadic communication error 1000
    05-Acc/Start Auth. -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 1010
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 1010
    25-Immobilizer -- Status: Malfunction 1010
    36-Seat Mem. Drvr -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Sporadic communication error 1000
    55-Headlight Range -- Status: Malfunction 1010
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    65-Tire Pressure -- Status: Malfunction 1010
    75-Telematics -- Status: Malfunction 1010
    76-Park Assist -- Status: Malfunction 1010
    Address 01: Engine        Labels: 077-910-560-BFM.clb
       Part No SW: 4E0 910 560 A    HW: 4E0 907 560
       Component: 4.2L V8/5V      G   0070
       Revision: 00000000    Serial number: AUX3Z0D2537958
       Coding: 0007773
       Shop #: WSC 02313 785 00200
       VCID: 1F1BE112CBBD430F877-804A
    14 Faults Found:
    17981 - Left Engine Mount Solenoid Valve (N144)
                P1573 - 004 - Open Circuit
    17985 - Right Engine Mount Solenoid Valve (N145)
                P1577 - 004 - Open Circuit
    18282 - Valve for Torque Support Mount
                P1874 - 001 - Short to Plus - Intermittent
    18010 - Power Supply Terminal 30
                P1570 - 008 -  - Intermittent
    18044 - Powertrain Data Bus
                P1636 - 008 - Missing Message from Airbag Controller - Intermittent
    18057 - Powertrain Data Bus
                P1649 - 008 - Missing Message from ABS Controller - Intermittent
    18107 - Powertrain Data Bus
                P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
    18347 - Powertrain Databus
                P1939 - 008 - Missing Message from Controller for Access & Start Auth. - Intermittent
    18036 - Powertrain Data Bus
                P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent
    18058 - Powertrain Data Bus
                P1650 - 008 - Missing Message from Instrument Cluster - Intermittent
    19468 - Relay for Fuel Pump 2 (J49)
                P3012 - 004 - Open or Short to Ground - Intermittent
       Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
       Component: AG6 09E 4,2L5V USA  0110
       Revision: 00000001    Serial number:        0033645
       VCID: 2411EEFEE2DB60D7DA5-8070
    18275 - Powertrain Data Bus
                P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                        RPM: 1056 /min
                        RPM: 1184 /min
                        (no units): 30.0
                        (no units): 26.0
                        Temperature: 29.0°C
                        T.B. Angle: 0.0°
                        Voltage: 10.80 V
    18271 - Powertrain Data Bus
                P1863 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                        RPM: 1056 /min
                        RPM: 1184 /min
                        (no units): 30.0
                        (no units): 26.0
                        Temperature: 29.0°C
                        T.B. Angle: 0.0°
                        Voltage: 10.80 V
    18259 - Powertrain Data Bus
                P1851 - 000 - Missing Message from ABS Controller - Intermittent
                        RPM: 1056 /min
                        RPM: 1184 /min
                        (no units): 30.0
                        (no units): 26.0
                        Temperature: 29.0°C
                        T.B. Angle: 0.0°
                        Voltage: 10.80 V
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
       Component: ESP 5.7 allrad  H44 0500
       Coding: 0007597
       Shop #: WSC 93201 000 00000
       VCID: 221DE8E6F8CF6EE7A89-8076
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 A
       Component:     FBS AUDID3  H03 0140
       Revision: 01403903    Serial number: AUX3Z0D2537958
       Coding: 0263168
       Shop #: WSC 02311 785 00200
       VCID: 58E98A0EEE13F43786D-800C
                        Fault Frequency: 0
                        Reset counter: 224
                        Mileage: 170304 km
                        Date: 2019.01.28
                        Time: 18:16:36
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H07  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3940576
       Shop #: WSC 00000 785 00200
       VCID: 2313EDE2E7D567EFA3F-8076
    Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
       Part No SW: 4E0 910 731 N    HW: 4E0 035 729
       Component: Interfacebox    H43 3360
       Revision: 00000000    Serial number: 346CD047511142
       Coding: 0000103
       Shop #: WSC 93201 999 83974
       VCID: 2C0106DE8A0BA897125-8078
       Subsystem 1 - Part No: 4E0 910 609 C
       Component: Bedienteil MMI  H42 0100
       Subsystem 2 - Serial number: 390FM057502814
       Subsystem 3 - Serial number: 7423.06.0500000000290B0039˙
       Subsystem 4 - Serial number: 0B0039˙
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:25:17
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:25:17
    01964 - Control Module for Seat & Steering Column Memory (J136)
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:25:17
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 226
                        Time Indication: 15
                000 -  -  - Intermittent
                        Reset counter: 40
                        Mileage: 269355 km
                        Date: 2019.01.17
                        Time: 19:12:19
                        Bin. Bits: 00000000
                        Bin. Bits:  0010000
                        Bin. Bits:      000
       Part No SW: 4E0 910 043 A    HW: 4E0 820 043 B
       Component: KLIMAAUTOMAT    016 0300
       Revision: 00000025    Serial number: 00000000041379
       Coding: 1085761
       VCID: 1B63D502DFA55F2F6BF-804E
       Subsystem 1 - Part No: 4E0 910 772 A
       Component: Sitzluefter  FS H02  010
       Subsystem 2 - Part No: 4E0 910 772 A
       Component: Sitzluefter BFS H02  010
       Subsystem 3 - Serial number: 898053000
       Subsystem 4 - Serial number: HO12032004065A000000000154˙†89
       Subsystem 5 - Serial number: 000154˙†898053000      000-SHO
       Subsystem 6 - Serial number:     000-SHO12032004065A00000000
       Subsystem 7 - Serial number: 65A000000000189˙
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:54
                        Voltage: 11.50 V
    00455 - Control Module for Access and Start Control; Comfort CAN (J518)
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Bin. Bits: 00011000
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Bin. Bits: 00011000
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Bin. Bits: 00011000
    Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
       Part No SW: 4E0 910 279 J    HW: 4E1 955 113 B
       Component: ILM Fahrer      H12 0190
       Coding: 0123124
       VCID: 2F3B11D2BB1DD38F377-807A
       Subsystem 1 - Part No: 4E1 910 113 B
       Component: Wischer WWS D3  H50 0400
       Coding: 00000036
       Shop #: WSC 02313
       Component: REGENLICHTSENSORH10 0030
       Coding: 00139548
       Shop #: WSC 02313
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111
       Component: CD-Changer      H43 0470
       Revision: 00000501    Serial number: AUZ5ZBD1034960
       VCID: 1C61D61EDAAB5817625-8048
    02446 - Disk Drive Mechanical Malfunction
                        Fault Status: 00101110
                        Reset counter: 39
                        Mileage: 263427 km
                        Date: 2018.10.26
                        Time: 19:42:15
    Address 15: Airbags        Labels: 4E0-910-655-84.lbl
       Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
       Component: Airbag 8.4E+    H10 0920
       Coding: 0530707
    01213 - Belt Tensioner Igniter; Rear Middle (N198)
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549 A
       Coding: 0012241
       VCID: 6597B3FAA96159DF0DB-8030
       Component: Lenkradmodul    H04 0080
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 900     HW: 4E0 920 900 E
       Component: KOMBIINSTR. VDO H44 0090
       Revision: D15         Serial number: AUDID3D3021547
       Coding: 0016303
       Shop #: WSC 37110 001 1048576
       VCID: 5CE1961E9A2B1817A25-8008
                        Reset counter: 227
                        Mileage: 270798 km
                        Date: 2003.10.08
                        Time: 00:00:41
    Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
       Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
       Component: Gateway         H07 0040
       Revision: 07          Serial number: 050050431718D0
       Coding: FCFE7BDD1B2304
       VCID: 2615F4F694E792C7C41-8072
    15 Faults Found:
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 226
                        Mileage: 269910 km
                        Date: 2019.02.02
                        Time: 09:21:04
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
    00456 - Control Module for Access and Start Control (J518)
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
    00465 - Control Module for Telephone/Telematic (J526)
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:36
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:38
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:38
    01771 - Control Module for Headlight Range (J431)
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:55
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0263168
       XXXXXXXXXXX ELV                 XXXX
                        Fault Frequency: 0
                        Reset counter: 224
                        Mileage: 170304 km
                        Date: 2019.01.28
                        Time: 18:16:36
    Address 34: Level Control        Labels: 4E0-910-553.clb
       Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
       Component: LUFTFDR.-CDC    H05 4290
       Coding: 0015510
       VCID: 2517F3FAE9E199DFCDB-8070
    8 Faults Found:
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:07:49
    01400 - Suspension Level Control
                        Fault Frequency: 25
                        Reset counter: 233
                        Mileage: 269464 km
                        Date: 2019.01.18
                        Time: 20:30:40
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:01:42
                        Fault Status: 11101000
                        Reset counter: 193
                        Mileage: 270798 km
                        Date: 2003.10.08
                        Time: 00:00:44
    00774 - Level Control System Sensor; Rear Left (G76)
                        Fault Status: 11101100
                        Fault Frequency: 85
                        Reset counter: 193
                        Mileage: 270916 km
                        Date: 2003.10.08
                        Time: 23:57:46
                        Fault Frequency: 85
                        Reset counter: 193
                        Mileage: 270916 km
                        Date: 2003.10.08
                        Time: 23:57:46
    01399 - Relay for Level-Control Compressor (J403)
                        Fault Status: 00101001
                        Reset counter: 233
                        Reset counter: 193
                        Mileage: 270798 km
                        Date: 2003.10.08
                        Time: 00:00:44
       Component: Sitzmemory FS  H07  0060
       Coding: 4071650
                        Reset counter: 233
                        Date: 2004.01.01
                        Time: 00:00:00
       Part No SW: 4E0 910 888 F    HW: 4E0 919 887 C
       Component: MNS US          H43 0990
       Revision: 00000000    Serial number: 355DM047520069
       Shop #: WSC 93201 999 01273
       VCID: 313F17AAAD29C57F213-8064
    02927 - DVD Read Error
                        Reset counter: 226
                        Mileage: 270401 km
                        Date: 2019.02.02
                        Time: 15:23:51
                        Hex Value: 0x5C55
                        Hex Value: 0xB607
                        Hex Value: 0x04FF
                        Hex Value: 0x0000
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H02 0090
       Serial number: 00000418200064
       Coding: 0003476
       VCID: 1D67DB1AC1B1511F95B-8048
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
                        Mileage: 262136 km
                        Date: 2003.10.08
                        Time: 00:00:00
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 801
       Component: Türsteuer.FS BRM007 0110
       Coding: 0028196
       VCID: 5EE59C168C370A07CC1-800A
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 A    HW: 4E0 907 289
       Component: Komfortgeraet   H04 0040
       Revision: 00400004    Serial number:  W040403310156
       Coding: 0065150
       VCID: 270BF9F293ED8BCFFF7-8072
       Component: Heckdeckel      H06 0060
       Component: Neigungssensor  H03 0020
    10 Faults Found:
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
    02107 - Trunk or Luggage Compartment Opening Motor (V254)
                        Reset counter: 215
                        Mileage: 169912 km
                        Date: 2019.01.22
                        Time: 21:58:10
    00985 - Right Tail Light (M2)
                        Fault Frequency: 30
                        Reset counter: 193
                        Mileage: 268700 km
                        Date: 2019.01.30
                        Time: 17:56:33
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:33
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:33
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:34
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:34
                        Fault Frequency: 11
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:36
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:59
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:59
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 M    HW: 4E0 035 223 B
       Component: DSP-High D3/AUX H13 0450
       Revision: Dev_D01     Serial number: 00000000000562
       Coding: 0000016
                        Fault Frequency: 7
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:39
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H09 0040
       Revision:             Serial number: 00000000036801
       Coding: 0010111
       VCID: 1E65DC16CCB74A078C1-804A
       Subsystem 1 - Serial number: VK4978T0D43E
                        Reset counter: 233
                        Date: 2023.06.06
                        Time: 00:00:00
                        Reset counter: 233
                        Mileage: 262136 km
                        Date: 2003.10.10
                        Time: 04:24:00
                        Reset counter: 233
                        Date: 2023.06.06
                        Time: 00:00:00
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 802
       Component: Türsteuer.BF BRM007 0110
       Coding: 0028196
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
       Component: EPB  A4EC0230   H03 0230
       Revision: --H03---
       Coding: 0000532
       Shop #: WSC 93201 999 50662
       VCID: 2019E2EEF6C37CF7BED-8074
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:39
                        Voltage: 10.77 V
                        Count: 247
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:39
                        Voltage: 10.14 V
                        Count: 242
    00576 - Terminal 15
                        Fault Status: 00101100
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:37
                        Voltage: 8.28 V
                        Count: 41
    Address 55: Headlight Range        Labels: 4E0-910-357.lbl
       Part No SW: 4E0 910 357     HW: 4E0 907 357
       Component: Pre-AFS         H01 0040
       VCID: 629DA8E6B84F2EE7E89-8036
                        Reset counter: 233
                        Mileage: 1048568 km
    01310 - Level Control System Control Module (J197)
                        Reset counter: 0
                        Mileage: 1048568 km
                        Reset counter: 233
                        Mileage: 1048568 km
                        Reset counter: 0
                        Mileage: 1048568 km
                        Reset counter: 0
                        Mileage: 1048568 km
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 B
       Component: TUNER EU/US/RDW H41 0620
       Revision: 00000000    Serial number: 304JP047603682
       VCID: 2E050CD6BC17DA873C1-807A
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H11 0510
       Revision: 00000000    Serial number: 00000000015232
       Subsystem 1 - Part No: 000 915 105 AK
       Component: von VA0  0607311071
       Coding: 303030393135313035414B56413030363037333131303731
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 801 A
       Component: Türsteuer.HL BRM007 0110
       Coding: 0028196
       VCID: 5DE79B1A8131111FD5B-8008
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273     HW: 4E0 907 273
       Component: Reifendruck 2   H01 0210
       Coding: 0212127
       VCID: 5F9BA1128B3D030FC77-800A
    01477 - System Switched Off
                        Fault Frequency: 42
                        Reset counter: 193
                        Mileage: 270795 km
                        Date: 2019.02.03
                        Time: 13:22:03
                        Speed: 47.0 km/h
                        Temperature: -16.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Fault Status: 11100100
                        Reset counter: 146
                        Mileage: 268696 km
                        Date: 2019.01.04
                        Time: 01:07:18
                        Speed: 7.0 km/h
                        Temperature: 2.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 802 A
       Component: Türsteuer.HR BRM007 0110
       Coding: 0028196
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
    Address 75: Telematics        Labels: None
       Part No SW: 4E0 910 616     HW: 4E0 035 616 B
       Component: Telematik USA1      0080
       Revision: 00000004    Serial number: 0000ATD3014278
       Coding: 0000005
       VCID: 6099A2EEB6533CF7FED-513C
    01531 - Emergency Battery
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Component: Parkhilfe 8-Kan H12 0020
       Revision: --.--.--    Serial number: 08730406901591
       Coding: 0001208
       VCID: 211FE7EAFDC975FFB13-8074
                        Reset counter: 40
                        Reset counter: 40
    End----(Elapsed Time: 02:41, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Sunday,10,February,2019,10:19:08:02559
       Coding: 0007773
    14 Faults Found:
                        RPM: 1056 /min
                        RPM: 1184 /min
                        (no units): 30.0
                        (no units): 26.0
                        Temperature: 29.0°C
                        T.B. Angle: 0.0°
                        Voltage: 10.80 V
                        RPM: 1056 /min
                        RPM: 1184 /min
                        (no units): 30.0
                        (no units): 26.0
                        Temperature: 29.0°C
                        T.B. Angle: 0.0°
                        Voltage: 10.80 V
                        RPM: 1056 /min
                        RPM: 1184 /min
                        (no units): 30.0
                        (no units): 26.0
                        Temperature: 29.0°C
                        T.B. Angle: 0.0°
                        Voltage: 10.80 V
       Coding: 0007597
       Coding: 0263168
                        Fault Frequency: 0
                        Reset counter: 224
                        Mileage: 170304 km
                        Date: 2019.01.28
                        Time: 18:16:36
       Coding: 3940576
       Coding: 0000103
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:25:17
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:25:17
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:25:17
                        Reset counter: 226
                        Time Indication: 15
                        Reset counter: 40
                        Mileage: 269355 km
                        Date: 2019.01.17
                        Time: 19:12:19
                        Bin. Bits: 00000000
                        Bin. Bits:  0010000
                        Bin. Bits:      000
       Coding: 1085761
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:54
                        Voltage: 11.50 V
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Bin. Bits: 00011000
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Bin. Bits: 00011000
                        Reset counter: 232
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:06:04
                        Bin. Bits: 00011000
       Part No SW: 4E0 910 279 J    HW: 4E0 907 279 J
       Coding: 0123124
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 39
                        Mileage: 263427 km
                        Date: 2018.10.26
                        Time: 19:42:15
       Coding: 0530707
       Coding: 0012241
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 233
                        Date: 2063.15.31
                        Time: 31:63:02
       Coding: 0016303
                        Reset counter: 227
                        Mileage: 270798 km
                        Date: 2003.10.08
                        Time: 00:00:41
    15 Faults Found:
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 226
                        Mileage: 269910 km
                        Date: 2019.02.02
                        Time: 09:21:04
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:36
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:38
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:38
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:55
       Coding: 0263168
                        Fault Frequency: 0
                        Reset counter: 224
                        Mileage: 170304 km
                        Date: 2019.01.28
                        Time: 18:16:36
       Coding: 0015510
    8 Faults Found:
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:07:49
                        Fault Frequency: 25
                        Reset counter: 233
                        Mileage: 269464 km
                        Date: 2019.01.18
                        Time: 20:30:40
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:01:42
                        Reset counter: 193
                        Mileage: 270798 km
                        Date: 2003.10.08
                        Time: 00:00:44
                        Fault Frequency: 85
                        Reset counter: 193
                        Mileage: 270916 km
                        Date: 2003.10.08
                        Time: 23:57:46
                        Fault Frequency: 85
                        Reset counter: 193
                        Mileage: 270916 km
                        Date: 2003.10.08
                        Time: 23:57:46
                        Reset counter: 233
                        Reset counter: 193
                        Mileage: 270798 km
                        Date: 2003.10.08
                        Time: 00:00:44
       Coding: 4071650
                        Reset counter: 233
                        Date: 2004.01.01
                        Time: 00:00:00
                        Reset counter: 226
                        Mileage: 270401 km
                        Date: 2019.02.02
                        Time: 15:23:51
                        Hex Value: 0x5C55
                        Hex Value: 0xB607
                        Hex Value: 0x04FF
                        Hex Value: 0x0000
       Coding: 0003476
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
                        Reset counter: 233
                        Mileage: 262136 km
                        Date: 2003.10.08
                        Time: 00:00:00
       Coding: 0028196
       Coding: 0065150
    10 Faults Found:
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:32
                        Reset counter: 215
                        Mileage: 169912 km
                        Date: 2019.01.22
                        Time: 21:58:10
                        Fault Frequency: 30
                        Reset counter: 193
                        Mileage: 268700 km
                        Date: 2019.01.30
                        Time: 17:56:33
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:33
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:33
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:34
                        Fault Frequency: 13
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:34
                        Fault Frequency: 11
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:36
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:59
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:05:59
       Coding: 0000016
                        Fault Frequency: 7
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:39
       Coding: 0010111
       Subsystem 1 - Part No: 4E0 910 511 A
       Component: UGDO HL US      H02 0030
       Subsystem 2 - Serial number: VK4978T0D43E
                        Reset counter: 233
                        Date: 2023.06.06
                        Time: 00:00:00
                        Reset counter: 233
                        Mileage: 262136 km
                        Date: 2003.10.10
                        Time: 04:24:00
                        Reset counter: 233
                        Date: 2023.06.06
                        Time: 00:00:00
       Coding: 0028196
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
       Revision: --H03---
       Coding: 0000532
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:39
                        Voltage: 10.77 V
                        Count: 247
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:39
                        Voltage: 10.14 V
                        Count: 242
    00576 - Terminal 15
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:00:37
                        Voltage: 8.28 V
                        Count: 41
                        Reset counter: 233
                        Mileage: 1048568 km
                        Reset counter: 0
                        Mileage: 1048568 km
                        Reset counter: 233
                        Mileage: 1048568 km
                        Reset counter: 0
                        Mileage: 1048568 km
                        Reset counter: 0
                        Mileage: 1048568 km
                        Reset counter: 233
                        Mileage: 271016 km
                        Date: 2003.10.10
                        Time: 04:24:28
       Coding: 0028196
       Coding: 0212127
                        Fault Frequency: 44
                        Reset counter: 193
                        Mileage: 270795 km
                        Date: 2019.02.03
                        Time: 13:22:03
                        Speed: 47.0 km/h
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Reset counter: 146
                        Mileage: 268696 km
                        Date: 2019.01.04
                        Time: 01:07:18
                        Speed: 7.0 km/h
                        Temperature: 2.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Coding: 0028196
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
                        Reset counter: 233
                        Mileage: 271008 km
                        Date: 2003.10.10
                        Time: 04:24:62
       Coding: 0000005
       Coding: 0001208
                        Reset counter: 40
                        Reset counter: 40
    End----(Elapsed Time: 02:29, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
    Welcome. Got you Verified.
    What we have here is a 14-15 year old car that's chock-a-block full of fault codes, many of the flagged "Intermittent", which means the fault condition that set the code didn't exist (or could not be detected) at the time the scan was performed.
    Please start by clearing all fault codes, then scan again to see what comes back immediately, then drive the car some, and scan again to see what comes back.
    Oh, and if the car was cold-soaked at -30°C, it doesn't surprise me that some things would get cranky the next morning.
    Feb 2019
    Canada
    Thanks Uwe,
    I will follow your instructions this week and post the results.
    OK. I'm going to move this to the Car Repair section and deep-six the other thread.
    Change battery, check charging system erase and reboot codes............
    rescan......
    10v is unacceptable!
    Feb 2019
    Canada
    Thanks for your input Jack! I will do that!
  7. #7
    Feb 2019
    Canada
    Cleared codes and re-scanned as suggested (see below). Also tested battery with multimeter and only getting 12.2V but voltage fine when car is running (I assume alternator is good but battery on its way out). Will change battery next.
    Friday,15,February,2019,08:23:54:02559
       Coding: 0007773
    Readiness: 0110 1101
       Coding: 0007597
       Coding: 0263168
       Subsystem 1 - Part No: 4E0 905 852 D
       Component: ELV                 1834
       Coding: 3940576
       Coding: 0000103
       Coding: 1085761
       Coding: 0123124
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
       Coding: 0530707
       Coding: 0012241
       Coding: 0016303
       Coding: 0263168
       Component: ELV                 1834
       4E0905852D  ELV                 1834
       Coding: 0015510
                        Reset counter: 193
                        Mileage: 271016 km
                        Date: 2003.10.16
                        Time: 10:10:30
                        Reset counter: 193
                        Mileage: 271016 km
                        Date: 2003.10.16
                        Time: 10:10:31
       Coding: 4071650
       Coding: 0003476
       Coding: 0028196
       Coding: 0065150
       Coding: 0000016
       Coding: 0010111
       Coding: 0028196
       Revision: --H03---
       Coding: 0000532
                        Fault Status: 11101101
                        Reset counter: 193
                        Mileage: 271016 km
                        Date: 2003.10.16
                        Time: 10:10:37
       Coding: 0028196
       Coding: 0212127
                        Reset counter: 193
                        Mileage: 271016 km
                        Date: 2003.10.16
                        Time: 10:08:29
                        Temperature: 15.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Coding: 0028196
       Coding: 0000005
       VCID: 6099A2EEB6533CF7FED-5160
       Coding: 0001208
    End----------(Elapsed Time: 02:17, VBatt start/end: 13.7V/13.9V)-----------
  8. Likes Uwe, Jack@European_Parts liked this post
  9. #8
    May 2016
    Tbone, always suspicious with temps of -30 is -22f, would get this car in above freezing before I trusted anything.
    Yeah, those temps would wreak havoc on a week battery.
    LARIMORE
  10. Likes tbone liked this post
  11. #9
    Feb 2019
    Canada
    Thanks Larry! A friend lended me his heated shop.
  12. #10
    Feb 2019
    Canada
    Changed Battery
    Had old battery tested at shop and confirmed it was weak and on its way out. I put in new battery and used vcds to code for battery energy management. Looks like electrical issues have mostly resolved. On dash only warning lights left are air suspension warning lights and headlight range sensor defective. Posting scan below. I am going to check the suspension leveling sensor and wiring on left rear per vcds scan.
    Friday,15,February,2019,16:39:42:02559
       Coding: 0007773
       Coding: 0007597
       Coding: 0263168
       Coding: 3940576
       Coding: 0000103
       Coding: 1085761
       Coding: 0123124
       Coding: 00000036
       Shop #: WSC 02313
       Coding: 00139548
       Shop #: WSC 02313
       Coding: 0530707
       Coding: 0012241
       Coding: 0016303
       Coding: 0263168
       Coding: 0015510
                        Reset counter: 193
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:34:00
                        Reset counter: 193
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:34:00
       Coding: 4071650
       Coding: 0003476
       Coding: 0028196
       Coding: 0065150
       Coding: 0000016
       Coding: 0010111
       Coding: 0028196
       Revision: --H03---
       Coding: 0000532
       Subsystem 1 - Part No: 000 915 105 DL
       Component: von VA0  080111B1ZP
       Coding: 303030393135313035444C56413030383031313142315A50
       Coding: 0028196
       Coding: 0212127
                        Reset counter: 193
                        Mileage: 271016 km
                        Date: 2003.10.08
                        Time: 00:35:10
                        Temperature: 20.0°C
                        Error Code: 0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Coding: 0028196
       Coding: 0000005
       Coding: 0001208
    End----(Elapsed Time: 02:16, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
  13. Likes Uwe, Jack@European_Parts liked this post
