Hi everyone!
I am a newbie. Bought a 2004 Audi A8l with 4.2l last week and drove it back home 22 hours in 2 days. Everything worked fine (no electrical problems) for 3/4 of the way home and mechanically the car seems in really good condition (new air suspension, suspension bushings and alignment 40,000km ago, new timing belt 20k ago, New plugs and R8 ignition coil 20k ago as well as new intake manifold runners and intake carbon cleaning). Runs and drives great. About 3/4 of the way home air suspension green light came on, little while later yellow light. Would disappear when I stopped to fuel and turn car off and re-appear a while down the road.
Once home left parked outside. Very cold that night - 30 degrees Celsius. Next morning started car and air bag sensor was on, front air suspension not working, radio wouldn't work, windshield wipers not working, and blower fan for heater would increase speed when I would pull lever back to try windshield washer fluid. Shortly thereafter "headlight range control defective". Air suspension working again but compressor cutting in and out a lot. When leave car in garage a couple of days without touching it the air in suspension holds (car doesn't lower and stays height I left it......assuming air shocks and lines are good).
Just performed my first scan and will post below. Talked to a couple of people who know these cars well. First idea is that it could be a Central Electronic/BCM problem and needs to be replaced. Second idea, it has a new battery.....possibly new battery was not coded to car (but wouldn't I have noticed problems immediately not after 22 hours of driving?). Any input appreciated.....please be patient with me as I mentioned I am new to all of this but willing to learn.
Sunday,10,February,2019,10:13:44:02559
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUML44E24N024067 License Plate:
Mileage: 271010km-168397mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E24N024067 Mileage: 271010km-168397miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Sporadic communication error 1000
55-Headlight Range -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
65-Tire Pressure -- Status: Malfunction 1010
75-Telematics -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 1010
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D2537958
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F1BE112CBBD430F877-804A
14 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
18282 - Valve for Torque Support Mount
P1874 - 001 - Short to Plus - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
18044 - Powertrain Data Bus
P1636 - 008 - Missing Message from Airbag Controller - Intermittent
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
18347 - Powertrain Databus
P1939 - 008 - Missing Message from Controller for Access & Start Auth. - Intermittent
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster - Intermittent
19468 - Relay for Fuel Pump 2 (J49)
P3012 - 004 - Open or Short to Ground - Intermittent
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0033645
VCID: 2411EEFEE2DB60D7DA5-8070
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
RPM: 1056 /min
RPM: 1184 /min
(no units): 30.0
(no units): 26.0
Temperature: 29.0°C
T.B. Angle: 0.0°
Voltage: 10.80 V
18271 - Powertrain Data Bus
P1863 - 000 - Missing Message from Steering Angle Sensor - Intermittent
RPM: 1056 /min
RPM: 1184 /min
(no units): 30.0
(no units): 26.0
Temperature: 29.0°C
T.B. Angle: 0.0°
Voltage: 10.80 V
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
RPM: 1056 /min
RPM: 1184 /min
(no units): 30.0
(no units): 26.0
Temperature: 29.0°C
T.B. Angle: 0.0°
Voltage: 10.80 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 93201 000 00000
VCID: 221DE8E6F8CF6EE7A89-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D2537958
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58E98A0EEE13F43786D-800C
Component: ELV XXXX
Fault Frequency: 0
Reset counter: 224
Mileage: 170304 km
Date: 2019.01.28
Time: 18:16:36
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Shop #: WSC 00000 785 00200
VCID: 2313EDE2E7D567EFA3F-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 731 N HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 346CD047511142
Coding: 0000103
Shop #: WSC 93201 999 83974
VCID: 2C0106DE8A0BA897125-8078
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 390FM057502814
Subsystem 3 - Serial number: 7423.06.0500000000290B0039ÿ
Subsystem 4 - Serial number: 0B0039ÿ
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:25:17
01327 - Control Module for Parking Aid (J446)
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:25:17
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:25:17
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 226
Time Indication: 15
02244 - Button in Control Head is Stuck
Reset counter: 40
Mileage: 269355 km
Date: 2019.01.17
Time: 19:12:19
Bin. Bits: 00000000
Bin. Bits: 0010000
Bin. Bits: 000
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0300
Revision: 00000025 Serial number: 00000000041379
Coding: 1085761
VCID: 1B63D502DFA55F2F6BF-804E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO12032004065A000000000154ÿ†89
Subsystem 5 - Serial number: 000154ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO12032004065A00000000
Subsystem 7 - Serial number: 65A000000000189ÿ
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:54
Voltage: 11.50 V
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Bin. Bits: 00011000
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Bin. Bits: 00011000
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Bin. Bits: 00011000
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 J HW: 4E1 955 113 B
Component: ILM Fahrer H12 0190
Coding: 0123124
VCID: 2F3B11D2BB1DD38F377-807A
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
Reset counter: 233
Reset counter: 233
Reset counter: 233
Reset counter: 233
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1034960
VCID: 1C61D61EDAAB5817625-8048
02446 - Disk Drive Mechanical Malfunction
Fault Status: 00101110
Reset counter: 39
Mileage: 263427 km
Date: 2018.10.26
Time: 19:42:15
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
01213 - Belt Tensioner Igniter; Rear Middle (N198)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: 6597B3FAA96159DF0DB-8030
Component: Lenkradmodul H04 0080
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
02072 - Control Module for Energy Management (J644)
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D3021547
Coding: 0016303
Shop #: WSC 37110 001 1048576
VCID: 5CE1961E9A2B1817A25-8008
Reset counter: 227
Mileage: 270798 km
Date: 2003.10.08
Time: 00:00:41
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 050050431718D0
Coding: FCFE7BDD1B2304
VCID: 2615F4F694E792C7C41-8072
15 Faults Found:
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 226
Mileage: 269910 km
Date: 2019.02.02
Time: 09:21:04
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
00456 - Control Module for Access and Start Control (J518)
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
00465 - Control Module for Telephone/Telematic (J526)
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:36
01316 - ABS Control Module
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:38
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:38
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:55
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Fault Frequency: 0
Reset counter: 224
Mileage: 170304 km
Date: 2019.01.28
Time: 18:16:36
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2517F3FAE9E199DFCDB-8070
8 Faults Found:
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:07:49
01400 - Suspension Level Control
Fault Frequency: 25
Reset counter: 233
Mileage: 269464 km
Date: 2019.01.18
Time: 20:30:40
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:01:42
008 - Implausible Signal
Fault Status: 11101000
Fault Frequency: 6
Reset counter: 193
Mileage: 270798 km
Date: 2003.10.08
Time: 00:00:44
00774 - Level Control System Sensor; Rear Left (G76)
Fault Status: 11101100
Fault Frequency: 85
Reset counter: 193
Mileage: 270916 km
Date: 2003.10.08
Time: 23:57:46
Fault Frequency: 85
Reset counter: 193
Mileage: 270916 km
Date: 2003.10.08
Time: 23:57:46
01399 - Relay for Level-Control Compressor (J403)
Fault Status: 00101001
Reset counter: 233
Fault Frequency: 6
Reset counter: 193
Mileage: 270798 km
Date: 2003.10.08
Time: 00:00:44
Component: Sitzmemory FS H07 0060
Coding: 4071650
Reset counter: 233
Date: 2004.01.01
Time: 00:00:00
Part No SW: 4E0 910 888 F HW: 4E0 919 887 C
Component: MNS US H43 0990
Revision: 00000000 Serial number: 355DM047520069
Shop #: WSC 93201 999 01273
VCID: 313F17AAAD29C57F213-8064
02927 - DVD Read Error
Reset counter: 226
Mileage: 270401 km
Date: 2019.02.02
Time: 15:23:51
Hex Value: 0x5C55
Hex Value: 0xB607
Hex Value: 0x04FF
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000418200064
Coding: 0003476
VCID: 1D67DB1AC1B1511F95B-8048
Reset counter: 233
Reset counter: 233
Reset counter: 233
Reset counter: 233
Mileage: 262136 km
Date: 2003.10.08
Time: 00:00:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM007 0110
Coding: 0028196
VCID: 5EE59C168C370A07CC1-800A
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040403310156
Coding: 0065150
VCID: 270BF9F293ED8BCFFF7-8072
Component: Heckdeckel H06 0060
Component: Neigungssensor H03 0020
10 Faults Found:
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Reset counter: 215
Mileage: 169912 km
Date: 2019.01.22
Time: 21:58:10
00985 - Right Tail Light (M2)
Fault Frequency: 30
Reset counter: 193
Mileage: 268700 km
Date: 2019.01.30
Time: 17:56:33
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:33
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:33
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:34
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:34
Fault Frequency: 11
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:36
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:59
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:59
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 M HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0450
Revision: Dev_D01 Serial number: 00000000000562
Coding: 0000016
Fault Frequency: 7
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:39
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000036801
Coding: 0010111
VCID: 1E65DC16CCB74A078C1-804A
Subsystem 1 - Serial number: VK4978T0D43E
Reset counter: 233
Date: 2023.06.06
Time: 00:00:00
Reset counter: 233
Mileage: 262136 km
Date: 2003.10.10
Time: 04:24:00
Reset counter: 233
Date: 2023.06.06
Time: 00:00:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 93201 999 50662
VCID: 2019E2EEF6C37CF7BED-8074
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:39
Voltage: 10.77 V
Count: 247
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:39
Voltage: 10.14 V
Count: 242
00576 - Terminal 15
Fault Status: 00101100
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:37
Voltage: 8.28 V
Count: 41
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 629DA8E6B84F2EE7E89-8036
Reset counter: 233
Mileage: 1048568 km
01310 - Level Control System Control Module (J197)
Reset counter: 0
Mileage: 1048568 km
Reset counter: 233
Mileage: 1048568 km
Reset counter: 0
Mileage: 1048568 km
Reset counter: 0
Mileage: 1048568 km
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0620
Revision: 00000000 Serial number: 304JP047603682
VCID: 2E050CD6BC17DA873C1-807A
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000015232
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 0607311071
Coding: 303030393135313035414B56413030363037333131303731
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: 5DE79B1A8131111FD5B-8008
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5F9BA1128B3D030FC77-800A
01477 - System Switched Off
Fault Frequency: 42
Reset counter: 193
Mileage: 270795 km
Date: 2019.02.03
Time: 13:22:03
Speed: 47.0 km/h
Temperature: -16.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Fault Status: 11100100
Reset counter: 146
Mileage: 268696 km
Date: 2019.01.04
Time: 01:07:18
Speed: 7.0 km/h
Temperature: 2.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 B
Component: Telematik USA1 0080
Revision: 00000004 Serial number: 0000ATD3014278
Coding: 0000005
VCID: 6099A2EEB6533CF7FED-513C
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730406901591
Coding: 0001208
VCID: 211FE7EAFDC975FFB13-8074
Reset counter: 40
Reset counter: 40
End----(Elapsed Time: 02:41, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Sunday,10,February,2019,10:19:08:02559
Coding: 0007773
14 Faults Found:
RPM: 1056 /min
RPM: 1184 /min
(no units): 30.0
(no units): 26.0
Temperature: 29.0°C
T.B. Angle: 0.0°
Voltage: 10.80 V
RPM: 1056 /min
RPM: 1184 /min
(no units): 30.0
(no units): 26.0
Temperature: 29.0°C
T.B. Angle: 0.0°
Voltage: 10.80 V
RPM: 1056 /min
RPM: 1184 /min
(no units): 30.0
(no units): 26.0
Temperature: 29.0°C
T.B. Angle: 0.0°
Voltage: 10.80 V
Coding: 0007597
Coding: 0263168
Component: ELV XXXX
Fault Frequency: 0
Reset counter: 224
Mileage: 170304 km
Date: 2019.01.28
Time: 18:16:36
Coding: 3940576
Coding: 0000103
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:25:17
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:25:17
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:25:17
Reset counter: 226
Time Indication: 15
Reset counter: 40
Mileage: 269355 km
Date: 2019.01.17
Time: 19:12:19
Bin. Bits: 00000000
Bin. Bits: 0010000
Bin. Bits: 000
Coding: 1085761
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:54
Voltage: 11.50 V
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Bin. Bits: 00011000
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Bin. Bits: 00011000
Reset counter: 232
Mileage: 271016 km
Date: 2003.10.08
Time: 00:06:04
Bin. Bits: 00011000
Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
Coding: 0123124
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Reset counter: 233
Reset counter: 233
Reset counter: 233
Reset counter: 233
Reset counter: 39
Mileage: 263427 km
Date: 2018.10.26
Time: 19:42:15
Coding: 0530707
Coding: 0012241
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Reset counter: 233
Date: 2063.15.31
Time: 31:63:02
Coding: 0016303
Reset counter: 227
Mileage: 270798 km
Date: 2003.10.08
Time: 00:00:41
15 Faults Found:
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 226
Mileage: 269910 km
Date: 2019.02.02
Time: 09:21:04
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:36
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:38
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:38
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:55
Coding: 0263168
Component: ELV XXXX
Fault Frequency: 0
Reset counter: 224
Mileage: 170304 km
Date: 2019.01.28
Time: 18:16:36
Coding: 0015510
8 Faults Found:
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:07:49
Fault Frequency: 25
Reset counter: 233
Mileage: 269464 km
Date: 2019.01.18
Time: 20:30:40
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:01:42
Fault Frequency: 6
Reset counter: 193
Mileage: 270798 km
Date: 2003.10.08
Time: 00:00:44
Fault Frequency: 85
Reset counter: 193
Mileage: 270916 km
Date: 2003.10.08
Time: 23:57:46
Fault Frequency: 85
Reset counter: 193
Mileage: 270916 km
Date: 2003.10.08
Time: 23:57:46
Reset counter: 233
Fault Frequency: 6
Reset counter: 193
Mileage: 270798 km
Date: 2003.10.08
Time: 00:00:44
Coding: 4071650
Reset counter: 233
Date: 2004.01.01
Time: 00:00:00
Reset counter: 226
Mileage: 270401 km
Date: 2019.02.02
Time: 15:23:51
Hex Value: 0x5C55
Hex Value: 0xB607
Hex Value: 0x04FF
Hex Value: 0x0000
Coding: 0003476
Reset counter: 233
Reset counter: 233
Reset counter: 233
Reset counter: 233
Mileage: 262136 km
Date: 2003.10.08
Time: 00:00:00
Coding: 0028196
Coding: 0065150
10 Faults Found:
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:32
Reset counter: 215
Mileage: 169912 km
Date: 2019.01.22
Time: 21:58:10
Fault Frequency: 30
Reset counter: 193
Mileage: 268700 km
Date: 2019.01.30
Time: 17:56:33
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:33
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:33
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:34
Fault Frequency: 13
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:34
Fault Frequency: 11
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:36
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:59
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:05:59
Coding: 0000016
Fault Frequency: 7
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:39
Coding: 0010111
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0D43E
Reset counter: 233
Date: 2023.06.06
Time: 00:00:00
Reset counter: 233
Mileage: 262136 km
Date: 2003.10.10
Time: 04:24:00
Reset counter: 233
Date: 2023.06.06
Time: 00:00:00
Coding: 0028196
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Revision: --H03---
Coding: 0000532
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:39
Voltage: 10.77 V
Count: 247
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:39
Voltage: 10.14 V
Count: 242
00576 - Terminal 15
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.08
Time: 00:00:37
Voltage: 8.28 V
Count: 41
Coding: 0000001
Reset counter: 233
Mileage: 1048568 km
Reset counter: 0
Mileage: 1048568 km
Reset counter: 233
Mileage: 1048568 km
Reset counter: 0
Mileage: 1048568 km
Reset counter: 0
Mileage: 1048568 km
Reset counter: 233
Mileage: 271016 km
Date: 2003.10.10
Time: 04:24:28
Coding: 0028196
Coding: 0212127
Fault Frequency: 44
Reset counter: 193
Mileage: 270795 km
Date: 2019.02.03
Time: 13:22:03
Speed: 47.0 km/h
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 146
Mileage: 268696 km
Date: 2019.01.04
Time: 01:07:18
Speed: 7.0 km/h
Temperature: 2.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028196
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Reset counter: 233
Mileage: 271008 km
Date: 2003.10.10
Time: 04:24:62
Coding: 0000005
Coding: 0001208
Reset counter: 40
Reset counter: 40
End----(Elapsed Time: 02:29, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
