Electrical issues (2004 A8)
tbone
Canada
C?ID=355740
Hi everyone!
I am a newbie. Bought a 2004 Audi A8l with 4.2l last week and drove it back home 22 hours in 2 days. Everything worked fine (no electrical problems) for 3/4 of the way home and mechanically the car seems in really good condition (new air suspension, suspension bushings and alignment 40,000km ago, new timing belt 20k ago, New plugs and R8 ignition coil 20k ago as well as new intake manifold runners and intake carbon cleaning). Runs and drives great. About 3/4 of the way home air suspension green light came on, little while later yellow light. Would disappear when I stopped to fuel and turn car off and re-appear a while down the road.
Once home left parked outside. Very cold that night - 30 degrees Celsius. Next morning started car and air bag sensor was on, front air suspension not working, radio wouldn't work, windshield wipers not working, and blower fan for heater would increase speed when I would pull lever back to try windshield washer fluid. Shortly thereafter "headlight range control defective". Air suspension working again but compressor cutting in and out a lot. When leave car in garage a couple of days without touching it the air in suspension holds (car doesn't lower and stays height I left it......assuming air shocks and lines are good).
Just performed my first scan and will post below. Talked to a couple of people who know these cars well. First idea is that it could be a Central Electronic/BCM problem and needs to be replaced. Second idea, it has a new battery.....possibly new battery was not coded to car (but wouldn't I have noticed problems immediately not after 22 hours of driving?). Any input appreciated.....please be patient with me as I mentioned I am new to all of this but willing to learn.
Sunday,10,February,2019,10:13:44:02559
VIN: WAUML44E24N024067   License Plate:
Mileage: 271010km-168397mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E24N024067   Mileage: 271010km-168397miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Sporadic communication error 1000
55-Headlight Range -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
65-Tire Pressure -- Status: Malfunction 1010
75-Telematics -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 1010
Address 01: Engine        Labels: 077-910-560-BFM.clb
   Part No SW: 4E0 910 560 A    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0070
   Revision: 00000000    Serial number: AUX3Z0D2537958
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 1F1BE112CBBD430F877-804A
14 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
            P1573 - 004 - Open Circuit
17985 - Right Engine Mount Solenoid Valve (N145)
            P1577 - 004 - Open Circuit
18282 - Valve for Torque Support Mount
            P1874 - 001 - Short to Plus - Intermittent
17978 - Engine Start Blocked by Immobilizer
            P1570 - 008 -  - Intermittent
18044 - Powertrain Data Bus
            P1636 - 008 - Missing Message from Airbag Controller - Intermittent
18057 - Powertrain Data Bus
            P1649 - 008 - Missing Message from ABS Controller - Intermittent
18107 - Powertrain Data Bus
            P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
18347 - Powertrain Databus
            P1939 - 008 - Missing Message from Controller for Access & Start Auth. - Intermittent
18036 - Powertrain Data Bus
            P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent
18058 - Powertrain Data Bus
            P1650 - 008 - Missing Message from Instrument Cluster - Intermittent
19468 - Relay for Fuel Pump 2 (J49)
            P3012 - 004 - Open or Short to Ground - Intermittent
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0033645
   VCID: 2411EEFEE2DB60D7DA5-8070
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    RPM: 1056 /min
                    RPM: 1184 /min
                    (no units): 30.0
                    (no units): 26.0
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.80 V
18271 - Powertrain Data Bus
            P1863 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                    RPM: 1056 /min
                    RPM: 1184 /min
                    (no units): 30.0
                    (no units): 26.0
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.80 V
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    RPM: 1056 /min
                    RPM: 1184 /min
                    (no units): 30.0
                    (no units): 26.0
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.80 V
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
   Component: ESP 5.7 allrad  H44 0500
   Coding: 0007597
   Shop #: WSC 93201 000 00000
   VCID: 221DE8E6F8CF6EE7A89-8076
            000 -  -
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0D2537958
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58E98A0EEE13F43786D-800C
                    Fault Frequency: 0
                    Reset counter: 224
                    Mileage: 170304 km
                    Date: 2019.01.28
                    Time: 18:16:36
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H07  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940576
   Shop #: WSC 00000 785 00200
   VCID: 2313EDE2E7D567EFA3F-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 731 N    HW: 4E0 035 729
   Component: Interfacebox    H43 3360
   Revision: 00000000    Serial number: 346CD047511142
   Coding: 0000103
   Shop #: WSC 93201 999 83974
   VCID: 2C0106DE8A0BA897125-8078
   Subsystem 1 - Part No: 4E0 910 609 C
   Component: Bedienteil MMI  H42 0100
   Subsystem 2 - Serial number: 390FM057502814
   Subsystem 3 - Serial number: 7423.06.0500000000290B0039ÿ
   Subsystem 4 - Serial number: 0B0039ÿ
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:25:17
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:25:17
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:25:17
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 226
                    Time Indication: 15
02244 - Button in Control Head is Stuck
            000 -  -  - Intermittent
                    Reset counter: 40
                    Mileage: 269355 km
                    Date: 2019.01.17
                    Time: 19:12:19
                    Bin. Bits: 00000000
                    Bin. Bits:  0010000
                    Bin. Bits:      000
   Part No SW: 4E0 910 043 A    HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0300
   Revision: 00000025    Serial number: 00000000041379
   Coding: 1085761
   VCID: 1B63D502DFA55F2F6BF-804E
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO12032004065A000000000154ÿ†89
   Subsystem 5 - Serial number: 000154ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO12032004065A00000000
   Subsystem 7 - Serial number: 65A000000000189ÿ
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:54
                    Voltage: 11.50 V
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Bin. Bits: 00011000
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Bin. Bits: 00011000
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Bin. Bits: 00011000
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 J    HW: 4E1 955 113 B
   Component: ILM Fahrer      H12 0190
   Coding: 0123124
   VCID: 2F3B11D2BB1DD38F377-807A
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H50 0400
   Coding: 00000036
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0030
   Coding: 00139548
   Shop #: WSC 02313
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111
   Component: CD-Changer      H43 0470
   Revision: 00000501    Serial number: AUZ5ZBD1034960
   VCID: 1C61D61EDAAB5817625-8048
02446 - Disk Drive Mechanical Malfunction
                    Fault Status: 00101110
                    Reset counter: 39
                    Mileage: 263427 km
                    Date: 2018.10.26
                    Time: 19:42:15
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
01213 - Belt Tensioner Igniter; Rear Middle (N198)
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H13 0040
   Coding: 0012241
   VCID: 6597B3FAA96159DF0DB-8030
   Component: Lenkradmodul    H04 0080
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
02072 - Control Module for Energy Management (J644)
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 900 E
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3D3021547
   Coding: 0016303
   Shop #: WSC 37110 001 1048576
   VCID: 5CE1961E9A2B1817A25-8008
                    Reset counter: 227
                    Mileage: 270798 km
                    Date: 2003.10.08
                    Time: 00:00:41
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0040
   Revision: 07          Serial number: 050050431718D0
   Coding: FCFE7BDD1B2304
   VCID: 2615F4F694E792C7C41-8072
15 Faults Found:
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 226
                    Mileage: 269910 km
                    Date: 2019.02.02
                    Time: 09:21:04
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
00465 - Control Module for Telephone/Telematic (J526)
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:36
01316 - ABS Control Module
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:38
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:38
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:55
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
                    Fault Frequency: 0
                    Reset counter: 224
                    Mileage: 170304 km
                    Date: 2019.01.28
                    Time: 18:16:36
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   VCID: 2517F3FAE9E199DFCDB-8070
8 Faults Found:
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:07:49
01400 - Suspension Level Control
                    Fault Frequency: 25
                    Reset counter: 233
                    Mileage: 269464 km
                    Date: 2019.01.18
                    Time: 20:30:40
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:01:42
            008 - Implausible Signal
                    Fault Status: 11101000
                    Fault Frequency: 6
                    Reset counter: 193
                    Mileage: 270798 km
                    Date: 2003.10.08
                    Time: 00:00:44
00774 - Level Control System Sensor; Rear Left (G76)
                    Fault Status: 11101100
                    Fault Frequency: 85
                    Reset counter: 193
                    Mileage: 270916 km
                    Date: 2003.10.08
                    Time: 23:57:46
                    Fault Frequency: 85
                    Reset counter: 193
                    Mileage: 270916 km
                    Date: 2003.10.08
                    Time: 23:57:46
01399 - Relay for Level-Control Compressor (J403)
                    Fault Status: 00101001
                    Reset counter: 233
                    Fault Frequency: 6
                    Reset counter: 193
                    Mileage: 270798 km
                    Date: 2003.10.08
                    Time: 00:00:44
   Component: Sitzmemory FS  H07  0060
   Coding: 4071650
                    Reset counter: 233
                    Date: 2004.01.01
                    Time: 00:00:00
   Part No SW: 4E0 910 888 F    HW: 4E0 919 887 C
   Component: MNS US          H43 0990
   Revision: 00000000    Serial number: 355DM047520069
   Shop #: WSC 93201 999 01273
   VCID: 313F17AAAD29C57F213-8064
02927 - DVD Read Error
                    Reset counter: 226
                    Mileage: 270401 km
                    Date: 2019.02.02
                    Time: 15:23:51
                    Hex Value: 0x5C55
                    Hex Value: 0xB607
                    Hex Value: 0x04FF
                    Hex Value: 0x0000
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H02 0090
   Serial number: 00000418200064
   Coding: 0003476
   VCID: 1D67DB1AC1B1511F95B-8048
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
                    Mileage: 262136 km
                    Date: 2003.10.08
                    Time: 00:00:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM007 0110
   Coding: 0028196
   VCID: 5EE59C168C370A07CC1-800A
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revision: 00400004    Serial number:  W040403310156
   Coding: 0065150
   VCID: 270BF9F293ED8BCFFF7-8072
   Component: Heckdeckel      H06 0060
   Component: Neigungssensor  H03 0020
10 Faults Found:
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
02107 - Trunk or Luggage Compartment Opening Motor (V254)
                    Reset counter: 215
                    Mileage: 169912 km
                    Date: 2019.01.22
                    Time: 21:58:10
00985 - Right Tail Light (M2)
                    Fault Frequency: 30
                    Reset counter: 193
                    Mileage: 268700 km
                    Date: 2019.01.30
                    Time: 17:56:33
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:33
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:33
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:34
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:34
                    Fault Frequency: 11
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:36
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:59
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:59
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 M    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0450
   Revision: Dev_D01     Serial number: 00000000000562
   Coding: 0000016
                    Fault Frequency: 7
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:39
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H09 0040
   Revision:             Serial number: 00000000036801
   Coding: 0010111
   VCID: 1E65DC16CCB74A078C1-804A
   Subsystem 1 - Serial number: VK4978T0D43E
                    Reset counter: 233
                    Date: 2023.06.06
                    Time: 00:00:00
                    Reset counter: 233
                    Mileage: 262136 km
                    Date: 2003.10.10
                    Time: 04:24:00
                    Reset counter: 233
                    Date: 2023.06.06
                    Time: 00:00:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM007 0110
   Coding: 0028196
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000532
   Shop #: WSC 93201 999 50662
   VCID: 2019E2EEF6C37CF7BED-8074
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:39
                    Voltage: 10.77 V
                    Count: 247
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:39
                    Voltage: 10.14 V
                    Count: 242
00576 - Terminal 15
                    Fault Status: 00101100
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:37
                    Voltage: 8.28 V
                    Count: 41
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   Coding: 0000001
   VCID: 629DA8E6B84F2EE7E89-8036
                    Reset counter: 233
                    Mileage: 1048568 km
01310 - Level Control System Control Module (J197)
                    Reset counter: 0
                    Mileage: 1048568 km
                    Reset counter: 233
                    Mileage: 1048568 km
                    Reset counter: 0
                    Mileage: 1048568 km
                    Reset counter: 0
                    Mileage: 1048568 km
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 B
   Component: TUNER EU/US/RDW H41 0620
   Revision: 00000000    Serial number: 304JP047603682
   VCID: 2E050CD6BC17DA873C1-807A
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H11 0510
   Revision: 00000000    Serial number: 00000000015232
   Subsystem 1 - Part No: 000 915 105 AK
   Component: von VA0  0607311071
   Coding: 303030393135313035414B56413030363037333131303731
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM007 0110
   Coding: 0028196
   VCID: 5DE79B1A8131111FD5B-8008
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   VCID: 5F9BA1128B3D030FC77-800A
01477 - System Switched Off
            000 -  -
                    Fault Frequency: 42
                    Reset counter: 193
                    Mileage: 270795 km
                    Date: 2019.02.03
                    Time: 13:22:03
                    Speed: 47.0 km/h
                    Temperature: -16.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 11100100
                    Reset counter: 146
                    Mileage: 268696 km
                    Date: 2019.01.04
                    Time: 01:07:18
                    Speed: 7.0 km/h
                    Temperature: 2.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM007 0110
   Coding: 0028196
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
Address 75: Telematics        Labels: None
   Part No SW: 4E0 910 616     HW: 4E0 035 616 B
   Component: Telematik USA1      0080
   Revision: 00000004    Serial number: 0000ATD3014278
   Coding: 0000005
   VCID: 6099A2EEB6533CF7FED-513C
01531 - Emergency Battery
            002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revision: --.--.--    Serial number: 08730406901591
   Coding: 0001208
   VCID: 211FE7EAFDC975FFB13-8074
                    Reset counter: 40
                    Reset counter: 40
End----(Elapsed Time: 02:41, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Sunday,10,February,2019,10:19:08:02559
   Coding: 0007773
14 Faults Found:
                    RPM: 1056 /min
                    RPM: 1184 /min
                    (no units): 30.0
                    (no units): 26.0
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.80 V
                    RPM: 1056 /min
                    RPM: 1184 /min
                    (no units): 30.0
                    (no units): 26.0
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.80 V
                    RPM: 1056 /min
                    RPM: 1184 /min
                    (no units): 30.0
                    (no units): 26.0
                    Temperature: 29.0°C
                    T.B. Angle: 0.0°
                    Voltage: 10.80 V
   Coding: 0007597
            000 -  -
   Coding: 0263168
                    Fault Frequency: 0
                    Reset counter: 224
                    Mileage: 170304 km
                    Date: 2019.01.28
                    Time: 18:16:36
   Coding: 3940576
   Coding: 0000103
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:25:17
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:25:17
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:25:17
                    Reset counter: 226
                    Time Indication: 15
                    Reset counter: 40
                    Mileage: 269355 km
                    Date: 2019.01.17
                    Time: 19:12:19
                    Bin. Bits: 00000000
                    Bin. Bits:  0010000
                    Bin. Bits:      000
   Coding: 1085761
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:54
                    Voltage: 11.50 V
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Bin. Bits: 00011000
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Bin. Bits: 00011000
                    Reset counter: 232
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:06:04
                    Bin. Bits: 00011000
   Part No SW: 4E0 910 279 J    HW: 4E0 907 279 J
   Coding: 0123124
   Coding: 00000036
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 39
                    Mileage: 263427 km
                    Date: 2018.10.26
                    Time: 19:42:15
   Coding: 0530707
   Coding: 0012241
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 233
                    Date: 2063.15.31
                    Time: 31:63:02
   Coding: 0016303
                    Reset counter: 227
                    Mileage: 270798 km
                    Date: 2003.10.08
                    Time: 00:00:41
15 Faults Found:
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 226
                    Mileage: 269910 km
                    Date: 2019.02.02
                    Time: 09:21:04
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:36
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:38
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:38
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:55
   Coding: 0263168
                    Fault Frequency: 0
                    Reset counter: 224
                    Mileage: 170304 km
                    Date: 2019.01.28
                    Time: 18:16:36
   Coding: 0015510
8 Faults Found:
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:07:49
                    Fault Frequency: 25
                    Reset counter: 233
                    Mileage: 269464 km
                    Date: 2019.01.18
                    Time: 20:30:40
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:01:42
                    Fault Frequency: 6
                    Reset counter: 193
                    Mileage: 270798 km
                    Date: 2003.10.08
                    Time: 00:00:44
                    Fault Frequency: 85
                    Reset counter: 193
                    Mileage: 270916 km
                    Date: 2003.10.08
                    Time: 23:57:46
                    Fault Frequency: 85
                    Reset counter: 193
                    Mileage: 270916 km
                    Date: 2003.10.08
                    Time: 23:57:46
                    Reset counter: 233
                    Fault Frequency: 6
                    Reset counter: 193
                    Mileage: 270798 km
                    Date: 2003.10.08
                    Time: 00:00:44
   Coding: 4071650
                    Reset counter: 233
                    Date: 2004.01.01
                    Time: 00:00:00
                    Reset counter: 226
                    Mileage: 270401 km
                    Date: 2019.02.02
                    Time: 15:23:51
                    Hex Value: 0x5C55
                    Hex Value: 0xB607
                    Hex Value: 0x04FF
                    Hex Value: 0x0000
   Coding: 0003476
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
                    Reset counter: 233
                    Mileage: 262136 km
                    Date: 2003.10.08
                    Time: 00:00:00
   Coding: 0028196
   Coding: 0065150
10 Faults Found:
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:32
                    Reset counter: 215
                    Mileage: 169912 km
                    Date: 2019.01.22
                    Time: 21:58:10
                    Fault Frequency: 30
                    Reset counter: 193
                    Mileage: 268700 km
                    Date: 2019.01.30
                    Time: 17:56:33
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:33
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:33
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:34
                    Fault Frequency: 13
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:34
                    Fault Frequency: 11
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:36
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:59
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:05:59
   Coding: 0000016
                    Fault Frequency: 7
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:39
   Coding: 0010111
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T0D43E
                    Reset counter: 233
                    Date: 2023.06.06
                    Time: 00:00:00
                    Reset counter: 233
                    Mileage: 262136 km
                    Date: 2003.10.10
                    Time: 04:24:00
                    Reset counter: 233
                    Date: 2023.06.06
                    Time: 00:00:00
   Coding: 0028196
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
   Revision: --H03---
   Coding: 0000532
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:39
                    Voltage: 10.77 V
                    Count: 247
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:39
                    Voltage: 10.14 V
                    Count: 242
00576 - Terminal 15
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:00:37
                    Voltage: 8.28 V
                    Count: 41
   Coding: 0000001
                    Reset counter: 233
                    Mileage: 1048568 km
                    Reset counter: 0
                    Mileage: 1048568 km
                    Reset counter: 233
                    Mileage: 1048568 km
                    Reset counter: 0
                    Mileage: 1048568 km
                    Reset counter: 0
                    Mileage: 1048568 km
                    Reset counter: 233
                    Mileage: 271016 km
                    Date: 2003.10.10
                    Time: 04:24:28
   Coding: 0028196
   Coding: 0212127
            000 -  -
                    Fault Frequency: 44
                    Reset counter: 193
                    Mileage: 270795 km
                    Date: 2019.02.03
                    Time: 13:22:03
                    Speed: 47.0 km/h
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 146
                    Mileage: 268696 km
                    Date: 2019.01.04
                    Time: 01:07:18
                    Speed: 7.0 km/h
                    Temperature: 2.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
                    Reset counter: 233
                    Mileage: 271008 km
                    Date: 2003.10.10
                    Time: 04:24:62
   Coding: 0000005
   Coding: 0001208
                    Reset counter: 40
                    Reset counter: 40
End----(Elapsed Time: 02:29, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
Welcome. Got you Verified.
What we have here is a 14-15 year old car that's chock-a-block full of fault codes, many of the flagged "Intermittent", which means the fault condition that set the code didn't exist (or could not be detected) at the time the scan was performed.
Please start by clearing all fault codes, then scan again to see what comes back immediately, then drive the car some, and scan again to see what comes back.
Oh, and if the car was cold-soaked at -30°C, it doesn't surprise me that some things would get cranky the next morning. ;)
tbone
Canada
C?ID=355740
Thanks Uwe,
I will follow your instructions this week and post the results.
OK. I'm going to move this to the Car Repair section and deep-six the other thread.
Change battery, check charging system erase and reboot codes............
rescan......
10v is unacceptable!
tbone
Canada
C?ID=355740
Thanks for your input Jack! I will do that!
tbone
Canada
C?ID=355740
Cleared codes and re-scanned as suggested (see below). Also tested battery with multimeter and only getting 12.2V but voltage fine when car is running (I assume alternator is good but battery on its way out). Will change battery next.
Friday,15,February,2019,08:23:54:02559
   Coding: 0007773
Readiness: 0110 1101
   Coding: 0007597
            000 -  -
   Coding: 0263168
   Subsystem 1 - Part No: 4E0 905 852 D
   Component: ELV                 1834
   Coding: 3940576
   Coding: 0000103
   Coding: 1085761
   Coding: 0123124
   Coding: 00000036
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
   Coding: 0530707
   Coding: 0012241
   Coding: 0016303
   Coding: 0263168
   Component: ELV                 1834
   4E0905852D  ELV                 1834
   Coding: 0015510
                    Reset counter: 193
                    Mileage: 271016 km
                    Date: 2003.10.16
                    Time: 10:10:30
                    Reset counter: 193
                    Mileage: 271016 km
                    Date: 2003.10.16
                    Time: 10:10:31
   Coding: 4071650
   Coding: 0003476
   Coding: 0028196
   Coding: 0065150
   Coding: 0000016
   Coding: 0010111
   Coding: 0028196
   Revision: --H03---
   Coding: 0000532
   Coding: 0000001
                    Fault Status: 11101101
                    Reset counter: 193
                    Mileage: 271016 km
                    Date: 2003.10.16
                    Time: 10:10:37
   Coding: 0028196
   Coding: 0212127
            000 -  -
                    Reset counter: 193
                    Mileage: 271016 km
                    Date: 2003.10.16
                    Time: 10:08:29
                    Temperature: 15.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0000005
   VCID: 6099A2EEB6533CF7FED-5160
   Coding: 0001208
End----------(Elapsed Time: 02:17, VBatt start/end: 13.7V/13.9V)-----------
Larry Manton
C?ID=112505
Tbone, always suspicious with temps of -30 is -22f, would get this car in above freezing before I trusted anything.
Yeah, those temps would wreak havoc on a week battery.
LARIMORE
tbone
Canada
C?ID=355740
Thanks Larry! A friend lended me his heated shop.
tbone
Canada
C?ID=355740
Changed Battery
Had old battery tested at shop and confirmed it was weak and on its way out. I put in new battery and used vcds to code for battery energy management. Looks like electrical issues have mostly resolved. On dash only warning lights left are air suspension warning lights and headlight range sensor defective. Posting scan below. I am going to check the suspension leveling sensor and wiring on left rear per vcds scan.
Friday,15,February,2019,16:39:42:02559
   Coding: 0007773
   Coding: 0007597
            000 -  -
   Coding: 0263168
   Coding: 3940576
   Coding: 0000103
   Coding: 1085761
   Coding: 0123124
   Coding: 00000036
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
   Coding: 0530707
   Coding: 0012241
   Coding: 0016303
   Coding: 0263168
   Coding: 0015510
                    Reset counter: 193
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:34:00
                    Reset counter: 193
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:34:00
   Coding: 4071650
   Coding: 0003476
   Coding: 0028196
   Coding: 0065150
   Coding: 0000016
   Coding: 0010111
   Coding: 0028196
   Revision: --H03---
   Coding: 0000532
   Coding: 0000001
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  080111B1ZP
   Coding: 303030393135313035444C56413030383031313142315A50
   Coding: 0028196
   Coding: 0212127
            000 -  -
                    Reset counter: 193
                    Mileage: 271016 km
                    Date: 2003.10.08
                    Time: 00:35:10
                    Temperature: 20.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0000005
   Coding: 0001208
End----(Elapsed Time: 02:16, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
tbone
Canada
C?ID=355740
Checked wiring to rear left suspension level sensor and no obvious wear going on so I switched out the suspension levelling sensor. Took for a drive and suspension working again.....I can raise and lower the vehicle suspension through MMI which I couldn't do before. However, headlight range control defective warning still coming up. Anybody know if I was supposed to recalibrate suspension with VCDS after I changed out that sensor?
Have you cleared that fault?
It certainly coudldn't hurt to calibrate the suspension.
tbone
Canada
C?ID=355740
Thanks Uwe, I did clear. I will calibrate suspension next...….clear, drive for a while and re-scan. Thanks again.
tbone
Canada
C?ID=355740
Thanks to all for your input. After changing out left rear suspension levelling sensor and then driving it around for some time everything is working properly and no more warning lights. Very happy!
