Results 1 to 10 of 14
Thread: Engine + ABS Warning Light
    Dec 2018
    Terrebonne, Quebec, Canada
    New issue in my 100 electrical issues. As per the title, I have the Engine + ABS Warning Light.
    Any thoughts?
    Saturday,09,February,2019,15:42:00:55476
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
    VCDS Version 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    Mileage: 200120km-124348mi   Repair Order:
    Chassis Type: 7L - VW Touareg (2003 > 11/2006)
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
       Mileage: 200120km-124348miles
    Address 01: Engine        Labels: 077-907-560-AXQ.lbl
       Part No SW: 4D0 907 560 DB    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0010
       Coding: 0007875
       Shop #: WSC 94713 999 52438
       VCID: 698FBF8C0564690F293-5161
    No Faults Found
       Part No: 09D 927 750 AQ
       Component: AL 750 6A           0903
       Coding: 0004153
       Shop #: WSC 94713 999 59229
       VCID: 7DA7FBDC61ECE5AFF5B-5161
                013 - Check DTC Memory
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0014594
       Shop #: WSC 31414 000 00000
       VCID: 3D273BDC216C25AFB5B-5161
       Part No SW: 3D0 909 135 R    HW: 5WK 470 26
       Component: 17 Kessy            6610
       Revision: 66105312    Serial number: VWZ3Z0D7284728
       Coding: 0131304
       VCID: 34311EF81226E4E74A5-5161
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77ABE9F443D0CFFFAF7-5161
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 M
       Component:                     3001
       Coding: 0105695
       VCID: 46D5543074BA6677E41-5161
                010 - Open or Short to Plus
    00060 - Foglight Lamps
       Part No: 3D0 909 601 E
       Component: 0C Airbag 8.4E+ H10 0952
       Coding: 0012355
       VCID: 2517F3BCA9FC8D6FCDB-5161
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 881 D
       Component: KOMBIINSTRUMENT RB8 3135
       Coding: 0005331
       VCID: 392F2FCC3544198F993-5161
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70B9D2E826BE98C76ED-5161
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F5B01D46BE0F7BFE77-5161
    Address 32: Differential Locks        Labels: None
       Part No: 0AC 927 771 C
       Component: SG-Quersperre       5020
       VCID: 38292AC80E4E008766D-5161
    02412 - Differential Lock Rear
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       Shop #: WSC 94706 999 999999
       VCID: 363524F0045AF6F7741-5161
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 C
       Component:      Navigation     0047
       Coding: 0000101
       Part No: 3D0 909 158
       Coding: 0000003
       VCID: 678BB9B413705F7F3F7-5161
       Part No: 7L0 959 933 E
       Component: H6 HSG              0201
       Coding: 0000085
       VCID: 3E253CD02C6A3EB7AC1-4B01
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    01134 - Alarm Horn (H12)
    00901 - Back-Up Lamps
    Address 56: Radio        Labels: 7L6-035-186-CD.lbl
       Part No: 7L6 035 186 A
       Component:        Radio        0047
       Coding: 0014062
       VCID: 313F17ECED34D1CF213-5161
    00857 - CD Changer Unit (R41)
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000855
       Shop #: WSC 31414 000 376832
       VCID: 3C2136D83A762CA7825-5161
       Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 005  0605
       Coding: 00217125
       Shop #: WSC 31414
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 K
       Component: DACHDISPLAY         0538
       Revision: 00700538    Serial number: 2009289.06
       VCID: 3FDB41D42B6037BFA77-5161
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
    No Faults Found
    End----(Elapsed Time: 13:26, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    -->2005 Volkswagen Touareg
    V8 4.2, Air Suspension,
    Lockable Center Differential + Rear Locking Differential
    19" Wheels, Factory Hitch and about 50 electronic issues
    Please try reading fault codes directly in the engine.
    " or DTCs not supported by controller
    or a communication error occurred"
    Given "sympathy code" in the ABS module, I'm fairly confident the ECU has at least one fault code, so I take the above to indicate that a communications error did occur.
    In addition to Uwe's request OP: please also read the OBD2 mode in main screen to and codes present there.
    Dec 2018
    I did it and got "17417 - Mass Air Flow Sensor 1/2
    P1009 - 004 - Implosible Signal from Load Calculation - MIL ON
    I cleared all codes and now I do not have it anymore. problem is gone. I did those before seeing Jack's post.
    I didnt know but it seems that when we call codes directly from 1 controller we get more information. Is it like this by design?
    Quote Originally Posted by TkNorris View Post
    Nope, should not be the case. An Auto-Scan should show all the fault codes and all related freeze-frame data, but in the case of your original Auto-Scan, something when awry when reading faults from the ECU.
    Dec 2018
    The ABS errors came back about a week later.
    I made again full scan including now the OBDII options;
    Saturday,09,March,2019,15:55:04:55476
    Mileage: 201550km-125237mi   Repair Order:
    Mode 07: Pending emission related fault codes
    Address 10 (Engine): 1 Fault Found:
    P1009 - Mass Air Flow Sensor 1/2: Implausible Signal from Load Calculation
    Address 1A (Auto Trans): No fault code found.
    Saturday,09,March,2019,15:55:46:55476
    Freeze Frame Data for address 10
        PID02 DTC that caused freeze frame data storage: P1009
        PID03 Fuel system 1/2 status: Closed loop, using O2 sensors
                  ... Closed loop, using O2 sensors
        PID04 Calculated load value: 12.2 %
        PID05 Engine coolant temperature: 93 C
        PID06 Short Term Trim - Bank 1: -1.6 %
        PID07 Long Term Trim - Bank 1: 3.9 %
        PID08 Short Term Trim - Bank 2: 0.8 %
        PID09 Long Term Trim - Bank 2: 1.6 %
        PID0C Engine RPM: 1468 /min
        PID0D Vehicle speed: 30 km/h
        PID0E Ignition timing advance for cyl #1: 12.5 Degrees
        PID0F Intake air temperature: 3 C
        PID10 Mass Air Flow: 1.83 g/s
        PID11 Throttle position sensor: 12.5 %
        PID12 Secondary Air Status: Atmosphere/off
    Saturday,09,March,2019,15:56:11:55476
    Mode 01 - PID 01 : Readiness  --  Address 10
    Number of DTCs stored: 1  --  MIL Status: MIL ON
    Misfire monitoring:  Passed
    Fuel System:  Passed
    Comprehensive Components:  Passed
    Catalyst monitoring:  Passed
    Heated catalyst monitoring: Not installed.
    Evaporative system monitoring:  Passed
    Secondary air system monitoring:  Passed
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring:  Passed
    Oxygen sensor heater monitoring:  Passed
    Exhaust Gas Recirculation: Not installed.
    Saturday,09,March,2019,15:56:29:55476
    Mode 01 - PID 01 : Readiness  --  Address 1A
    Number of DTCs stored: 0  --  MIL Status: MIL OFF
    Misfire monitoring: Not installed.
    Fuel System: Not installed.
    Catalyst monitoring: Not installed.
    Evaporative system monitoring: Not installed.
    Secondary air system monitoring: Not installed.
    Oxygen sensor monitoring: Not installed.
    Oxygen sensor heater monitoring: Not installed.
    Saturday,09,March,2019,15:49:12:55476
    VIN: WVGMM67L75D055257   License Plate:
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    VIN: WVGMM67L75D055257   Mileage: 201550km-125237miles
       Revision: 00000000    Serial number: VWZ3Z0D7284728
       Coding: 0007875
                P1009 - 004 - Implausible Signal from Load Calculation - MIL ON
    16487 - Mass Air Flow Sensor (G70)
                P0103 - 001 - Signal too High - Intermittent
    16485 - Mass Air Flow Sensor (G70)
                P0101 - 004 - Implausible Signal - Intermittent
       Coding: 0004153
       Coding: 0014594
    02054 - Control Module for Differential Locks (J647)
       Coding: 0131304
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 H
       Component: CLIMAtronic R/L   X 3716
       Coding: 0000030
       VCID: 353723FC195CFDEF7DB-5161
    02193 - Supply Voltage for Regulator for Fresh Air Blower
       Component:                     3001
       Coding: 0105695
       Coding: 0012355
       Coding: 0005331
       Coding: 0000006
    02062 - Differential Lock
       Coding: 0015521
       Coding: 0000101
       Coding: 0000003
       Coding: 0000085
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
       Coding: 0014062
       Coding: 0000855
       Coding: 00217125
       Shop #: WSC 31414
    No Faults Found
    End----------(Elapsed Time: 09:46, VBatt start/end: 14.1V/12.4V)-----------
    Saturday,09,March,2019,15:54:41:55476
    Mode 03: Emission related fault codes
    Any tips for me?
  8. Likes Dana liked this post
    Vacuum leak, wrong or faulty MAF or MAF's installed/obstructed air filter or pre-screen or loose or damaged air bellows.
  10. Likes TkNorris, Dana liked this post
  11. #8
    Dec 2018
    I checked air filters, cleaned MAF Sensors, conducts, Trottle Body, reset trottle body adjustement from vcds (engine, basic settings, 060) and cleared codes.
    If it comes back I supposed it should mean faulty MAF sensor.
    Damn Vacuum leaks... can't find any. pump seems running fine to me.
  12. #9
    Dec 2018
    Cleaning does not seems to fix it. It may take a few days, but MAF Sensor error is coming back.
    I did not find easy to follow procedure to test MAF Sensor. Is there any for my Touareg 2005?
  13. #10
    Same as any other pre-UDS gasoline engine, except you need to log both sensors and add the values together.
