Today I did some coding on a Golf MK7.5 and tried to figure out how to code the tail lights to enable 5-brake lights mod, without success. I'm starting to think that maybe there is no chance to use the inner tail lights as brake lights, but maybe you can give me some advise.
The outer tails are Leuchte23SL HLC10 (left outer) and Leuchte24SL HRA65 (right outer), but don't know how to code the inner lights to work as both parking and brake lights.
The following images describes the factory settings
Lights Switch: AUTO/POSITION/LOW-BEAM/HIGH-BEAM
Lights Switch: 0 // Brake Pedal: ON
Lights Switch: AUTO/POSITION/LOW-BEAM/HIGH-BEAM // Brake Pedal: ON
AUTO-SCAN
MODULE 09 ADAPTATION MAP (FACTORY SETTINGS)
--- EDIT ---
1. Understanding that the parking lights (the ones turned on in the first picture) Dimmwert is 127, may be there is an option to lower Dimmwert value to 86 for position/parking and adding the brake function with Dimmwert 127. Does that make sense?
AUTO-SCAN
Saturday,09,February,2019,11:10:40:43330
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
Dealer/Shop Name: TopHost Soluciones
VIN: 3VWVB6AU7JM272755 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: 3VWVB6AU7JM272755 Mileage: 7404km-4600miles
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HD HW: 04E 907 309 BH
Component: R4 1.4l TFS H26 3742
Revision: R7H26---
Coding: 01250032232419080000
Shop #: WSC 00066 790 00235
ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: 6D92122DBC38BC220E-8038
CAN Converter 01:
Readiness: 1110 0001
Part No SW: 0CW 300 041 Q HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1601
Revision: 00005008 Serial number: CU501712025526
ROD: EV_TCMDQ200021_VW31.rod
VCID: 43C69495CA3C9A5288-8016
Address 03: ABS Brakes (J104) Labels:* None
Part No SW: 5Q0 614 517 CS HW: 5Q0 614 517 AF
Component: ESC H62 0973
Revision: 00000000 Serial number: 53347000000162
Coding: 01FA6AA12427216E407E060560C82980562484026006947220215030C002430B00000012121212B835351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
VCID: 044457898FB25D6AF1-8050
Part No SW: 5GM 907 044 F HW: 5GM 907 044 F
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 00020004200108011004004000101402
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: 47DE8085FE04B67254-8012
Part No SW: 5Q0 937 086 BK HW: 5Q0 937 086 BF
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: C864080118028M
Shop #: WSC 00066 790 00147
ROD: EV_BCMBOSCH_018.rod
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 171119 043 0551
Serial number: 97022066171125115204
Coding: 1F4DFD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 047 0105
Serial number: S6Y17M12D13H12M26S26
Coding: 06A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1725228HT
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099971616
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000116643R17322
Coding: 0471151011
VCID: 4BD6BCB5E26C521270-801E
Part No SW: 5Q0 959 655 BH HW: 5Q0 959 655 BH
Component: AirbagVW21 005 0336
Serial number: 003VVM05JMAE
Coding: 98CCC000000000005C0000CF000800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 075E4085BE84767294-8052
Subsystem 1 - Part No SW: ----------- HW: 480 000 112 17
Serial number: 3570000000099A91092L
Subsystem 2 - Part No SW: ----------- HW: 480 000 112 17
Serial number: 3580000000079A91092K
Subsystem 3 - Part No SW: ----------- HW: 480 400 512 17
Serial number: 3510001C3269FF9616CK
Subsystem 4 - Part No SW: ----------- HW: 480 400 512 17
Serial number: 3520001B52796E0113A.
Subsystem 5 - Part No SW: ----------- HW: 480 400 311 17
Serial number: 3550002A725629A0A2C4
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 10121708490279
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 0248519195A6535AC3-8056
Part No SW: 5G1 920 740 C HW: 5G1 920 740 C
Component: KOMBI 242 0310
Coding: 07A51908A180000801083A001001000000000000
VCID: 26002D01594E4F7A8F-8072
Part No SW: 3Q0 907 530 K HW: 3Q0 907 530 B
Component: GW MQB Mid 517 5323
Serial number: 22121700840686
Coding: 030100047F085708FA0002481C0F00010001070000000000000000000000
Shop #: WSC 00066 790 07025
ROD: EV_GatewNF_VW37.rod
VCID: 373EF0458EE4C6F224-8062
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 28170002966240121439
Coding: 30FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 8568765300
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038734401831
Coding: 003A02208000020000001000
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000084750
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50ECABD90B4A71CA05-8004
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038734201058
Coding: 003A02208E00020000001000
VCID: 46C08D81F90EAF7AAF-8012
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000094118
Coding: 090000
Part No SW: 3Q0 035 824 C HW: 3Q0 035 824 C
Component: MU-S--ER 722 0867
Coding: 02731000FF00000051220001001828001F0500D40120010003
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2D12D22D7CB87C224E-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJV0040276
0517 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Reset counter: 108
Mileage: 7404 km
Date: 2019.02.09
Time: 09:16:49
Voltage terminal 30: 12.4 V
B1064 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
Reset counter: 108
Mileage: 7404 km
Date: 2019.02.09
Time: 09:16:49
Voltage terminal 30: 12.3 V
0522 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Reset counter: 108
Mileage: 7404 km
Date: 2019.02.09
Time: 09:16:49
B1061 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
Reset counter: 108
Mileage: 7404 km
Date: 2019.02.09
Time: 09:16:49
End----------(Elapsed Time: 01:31, VBatt start/end: 12.4V/12.3V)-----------
;SW:5Q0-937-086-BK HW:5Q0-937-086-BF --- Cent. Elect.
;Component:BCM PQ37BOSCH 034 0245, Coding:
;EV_BodyContrModul1UDSBosc,018001,EV_BCMBOSCH_018.rod
;Saturday,09,February,2019,09:33:03:43330
;VCDS Version: Release 18.9.0 (x64) Data version: 20180927 DS296.0
;VCID: 044457898FB25D6AF1-8050
IDE01550-Service position,170.494336 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,Yes ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 12 9C 08 09 1C 00 00 00 04 4C 00 4C 14 00 64 07 13 9C 08 0A 1C 00 00 00 01 3A 00 49 14 00 7F 08 09 7F 00 00 00 00 00 00 01 44 00 4B 14 00 7F 08 0A 7F 00 00 00 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 ,172
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not_installed ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,16.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,16.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,26.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,24.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,26.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,24.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,31.494474 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,255 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,7.494498 °,2
IDE10299-Alternating park position 2,29.494476 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000 ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
MAS05055-lower turn position,31.494474 °,2
MAS05056-upper turn position,170.494336 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,not installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,58.5 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,58.5 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,58.5 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,58.5 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,54.5 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,49.5 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,46.5 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,35.5 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,31.5 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Unknown (76),16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,36 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,35 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,25 - allgemeine Glühlampe Innen- oder Außenlicht ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,minimize ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,28 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,28 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Blinken links aktiv (beide Phasen) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Nebellicht links ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,minimize ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,28 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,28 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Nebellicht rechts ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Parking light right ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 19 28 00 30 08 00 64 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 00 00 36 08 0A FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 09 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,HIM ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG122979-ENG141969-Networking-UGDO,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,not active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
ENG124714-OCU-,not installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,5.0 min,10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,not active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,not active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,not active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,not active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,not active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,not active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
Elapsed Time: 01:43
--- EDIT ---
1. Understanding that the parking lights (the ones turned on in the first picture) Dimmwert is 127, may be there is an option to lower Dimmwert value to 86 for position/parking and adding the brake function with Dimmwert 127. Does that make sense?
