Results 1 to 6 of 6
Thread: New Guy trying to figure out how to remove Dynamic Steering Recommendation
    Feb 2019
    i, everyone, long time Audi fan since 98 and currently have 3 in the stable. A TTRS which sees a bunch of track days, a Q5 for the Mrs. and this 2015 A4 manual I just recently bought and had shipped in from Milwaukee. It's pretty much my DD. Anyway, I noticed the car would drift in the lane when I am on a highway. What I mean is that a slight adjustment of steering at center line nudges the steering over quite a bit. There never seems to be a center steering position and you are constantly course correcting. It can be described as wavy or loose (and driving me crazy) Of course, I searched the forums and someone had success unchecking the Dynamic Steering Recommendation in Module 44 steering assist.
    So I made a few of the common VAG COM adjustments including removing Seat belt chime, needle sweep and closing windows with Key Fob, so my software and cable does work!
    However, when I went to uncheck Dynamic Steering Recommendation, it wouldn't "save it" and I kept getting "Error 22 Coding rejected, Conditions not correct or request sequence error".
    Now in this module there was a prelim prompt that there might be experimental code in this section. I tried saving it with both the experimental code and the regular code, to no avail. Anyway, that is where I am at and was hoping someone might have had a similar experience they fixed or someone had any suggestions. Any and all a are welcome. Thanks in advance and a scan from when I last toyed around with it this past Sunday is below. I am hoping the picture links work as well!
    Sunday,03,February,2019,09:47:00:24144
    VIN: WAUHFAFL4FN018650   License Plate:
    Mileage: 64160km-39867mi   Repair Order:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F 62
              6C 72
    VIN: WAUHFAFL4FN018650   Mileage: 64160km-39867miles
    Address 01: Engine (0-MA-CAED)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 M    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0003
       Revision: ECH09---
       Coding: 4A190013242600062000
       Shop #: WSC 13918 002 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115M 001004
       ROD: EV_ECM20TFS0118K5907115M.rod
       VCID: 3C21365FE6EE42E7825-8068
    18062 - Coolant Pump 2
              P261A 00 [047] - Open circuit
                        Mileage: 61665 km
                        Date: 2018.11.01
                        Time: 08:49:26
                        Coolant temperature: 71 °C
                        Intake air temperature: 37 °C
                        Voltage terminal 30: 11.756 V
                        Engine status: COENG_READY
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Component: ESP8 quattro  H09 0020
       Coding: 071D1801
       VCID: 094F9F8BF93CA74FC93-805C
       Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
       Component: BCM2 2.0      H15 0711
       Coding: 0F814040000000000000
       VCID: 055793BBD524C32FADB-8050
       Serial number: 3214000112234015
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 204
                        Mileage: 61880 km
                        Date: 2018.12.29
                        Time: 14:46:52
       Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
       Component: KLIMA 3 ZONEN H04 0122
       Revision: C1000000    Serial number: 01071020140825
       Coding: 6400208000
       VCID: 77ABE9739FC8A1BFAF7-8022
       Revision: 08016001    Serial number: 00000915186401
       Coding: 26000091863CAFE00400488300003D0D0F9C9308A2090221000008004000030100000030000000
       VCID: 78A9EA4F92D6AEC7A6D-802C
       Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: MITSUBA160914  H18 0461
       Serial number: 1409130601123
       Coding: 004577
       Serial number: 23285293
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002609140459
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z009CE421
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 46198D47000000000001
       Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
       Component: AirbagVW-AU10 H51 0812
       Serial number: 003NDD12GH9B
       Coding: 303844354730383131304A55304C384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003114
       VCID: 4BC36583B340F55F3BF-801E
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R140000LK5U
       Serial number: 6334MSME48592F09P
       Serial number: 6344MSME4849061BH
       Serial number: 6352QSME1D462644H
       Serial number: 6362QSME58461270B
       Serial number: 63732SME65463B4C7
       Serial number: 63832SME45490D6EC
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NJ7001Q8
       Coding: 000016
       VCID: 48C95A8FA2B61E4716D-801C
       Part No SW: 8K0 920 983 F    HW: 8K0 920 983 F
       Component: KOMBIINSTR.   H35 0564
       Revision: 00200000    Serial number: ZAA75Z5AF
       Coding: 8BB409000301D705020000
       VCID: 38292A4FD2566EC766D-806C
       Component: GW-BEM 5CAN-M H11 0060
       Revision: 1Z120030    Serial number: 3041Z149290654
       Coding: 80C303FF00
       VCID: 4CC1669FB6CEF267325-8018
       Serial number: 2198474603
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0077
       Revision: AA000000    Serial number: 00000120092247
       Coding: 00581B00000000000000
       VCID: 3B233543E36045DF8BF-806E
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0348758461
       Coding: 010211
       VCID: 3FDB4153F7F859FFA77-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0348937179
       Coding: 010211
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H10 0305
       Coding: 011C13204E00410001
       VCID: 56F584F77802B8B7941-8002
       Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
       Component: RCEPS         H41 0509
       Revision: 00001000    Serial number: 0013981395
       Coding: 100000010001
       ASAM Dataset: EV_RCEPSAU48X 008016
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 38292A4FD2D66EC766D-806C
       Revision: 00002001    Serial number: 0349262287
       Coding: 0106023A00FA404580B0013200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000890940
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
       Revision: 00005001    Serial number: 94813035231306
       VCID: 2D070B1B2D14DB6F05B-8078
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H10 0305
       VCID: 55F783FB6504B3AF9DB-8000
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 00000001554290
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A2D3047ECDA7CD7909-806E
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156J50E8076159
       Coding: 020007010000000001
       VCID: 2411EE3F7EDE1A27DA5-8070
       Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
       Component: H-BNT-NA      H41 0812
       Revision: --------    Serial number: 204J%0E7684380
       Coding: 0F0200000006A1EF55028B5E00000403140000000000000000
       VCID: 3A2D3047EC5A7CD7909-806E
       Subsystem 1 - Part No: 8R0 060 884 CA
       Component: NAR 2014  1002
       Component: DU7 High  H42 0104
       Serial number: A130JR0E3154109
       Serial number: 00000002001161
       Component: CD-Database  5950
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H08 0305
       Coding: 010C13204000210001
       VCID: 59EF8FCB091C97CFB93-800C
       Revision: --H09---    Serial number: 525PA8-J4992OB
       Coding: 1000006
       VCID: 38292A4FDE566EC766D-806C
       Component: TSG HR        H08 0305
    End----------(Elapsed Time: 01:59, VBatt start/end: 14.6V/14.5V)-----------
    Address 44,8K0 909 144 J,recoded (Long Coding-exp),from,100000010001,to,000000010001,(02391/785/00200),
    Address 44,8K0 909 144 J,recoded (Long Coding),from,100000010001,to,000000010001,(02391/785/00200),
    Address 44,8K0 909 144 J,recoded (Long Coding),from,100000010001,to,010000010001,(02391/785/00200),
    Address 17,8K0 920 983 F,recoded (Long Coding),from,8BB409000301D705020000,to,8394090003010705020000,(02391/785/00200),
    Address 46,8K0 907 064 KM,recoded (Long Coding),from,0106023A00FA404580B0013200000000,to,0106063A00FA404580B0013200000000,(02391/785/00200),
    Address 17,8K0 920 983 F,recoded (Long Coding),from,8394090003010705020000,to,8397090023010705020000,(02391/785/00200),
    Address 44,8K0 909 144 J,recoded (Long Coding-exp),from,100000010001,to,000000000001,(02391/785/00200),
  2. Likes Uwe liked this post
  3. #2
    Feb 2019
    https://imgur.com/a/60cLJoK
    This link should bring you to the pics
    Feb 2019
    "Error 22 coding Rejected" - trying to remove Dynamic Steering recommendation
    Hi, I recently bought a 2015 A4 manual and it is my DD. Anyway, I noticed the car would drift in the lane when I am on a highway. What I mean is that a slight adjustment of steering at center line nudges the steering over quite a bit. There never seems to be a center steering position and you are constantly course correcting. It can be described as wavy or loose (and driving me crazy) Of course, I searched the forums and someone had success unchecking the Dynamic Steering Recommendation in Module 44 steering assist.
    Now in this module there was a prelim prompt that there might be experimental code in this section. I tried saving it with both the experimental code and the regular code, to no avail. Anyway, that is where I am at and was hoping someone might have had a similar experience they fixed or someone had any suggestions. Any and all are welcome. Thanks in advance and a scan from when I last toyed around with it this past Sunday is below. I am hoping the picture links work as well!
              6C 72
       Revision: ECH09---
                        Mileage: 61665 km
                        Date: 2018.11.01
                        Time: 08:49:26
       Coding: 071D1801
    00955 - Key 1
                        Reset counter: 204
                        Mileage: 61880 km
                        Date: 2018.12.29
                        Time: 14:46:52
       Coding: 6400208000
       Coding: 004577
       Coding: 02005D
       Coding: 000016
       Coding: 80C303FF00
       Coding: 010211
       Coding: 010211
       Coding: 1000006
    Moving from Car Repair Support to Tweaks, and merged with your previous thread.
    Are you by chance trying to do this with the engine running? If so, please try it with only the ignition on, but the engine not running.
    Feb 2019
    Ahhh, that did it. When I made all the other tweaks that WERE accepted the engine was running. This was accepted with just the ignition on. Thanks Uwe, it was driving me crazy. You're the best!
  8. Likes jyoung8607, Uwe, PetrolDave liked this post
