Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: MK100 ABS Coding
    Feb 2018
    SLC
    Per dnoremann, I have re-added the T6 Transporter and 2K Caddy
    MK100 ABS Coding
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
  2. Likes Dana liked this post
  3. #12
    Feb 2018
    SLC
    Quick Update: (and to help with forum searches)
    I have seen a few questions pop up around the wheel speed sensor coding in the MK100 ABS module (Byte 26)
    Specifically, should it be 50 or F0 for the bi-directional sensors.
    Well, from my research, the answer is:
    50 is for Multi-Link Rear Suspension
    F0 is for Torsion Beam Rear Suspension
  4. Likes Uwe, downtime, m87a liked this post
  5. #13
    Apr 2018
    ITALY
    I am writing with the hope that my info will make your spreadsheet more complete. if you look at my autoscan:
    https://forums.ross-tech.com/showthr...chback-3-doors
    I find your sheet to be "wrong" for bytes 01 02 06 08 12 24 25
    let me know what you think
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  6. Likes Somnus, Uwe, Robert-VW liked this post
  7. #14
    Feb 2018
    SLC
    You are indeed correct, the spreadsheet is far from a complete source, but I am grateful for the information that your scan has provided.
    I have updated the spreadsheet accordingly.
    If I may ask, which part of Bytes 20 & 24 & 25 are incorrect?
    EDIT: My Apologies, I misread byte 25 as 20.
  8. Likes Uwe, Robert-VW liked this post
  9. #15
    May 2017
    I beg to differ here with darkchina. Byte 24 bits are well known for a long time already. Byte 20 is inverse byte of byte 10.
    So I’m also interested in hearing what is wrong with those bytes?
  10. Likes Robert-VW liked this post
  11. #16
    Apr 2018
    ITALY
    BYTE 24 is ok for ACC, but I also have PLA 3.0. how come my bits 5 and 6 are both at 0...? I happen to remember that setting those bits enabled always resulted with errors in the PLA.
    BYTE 25 I have AUTO HOLD (it's a perk from the Electronic Parking Brake), maybe I am wrong in assuming it's the same as HILL HOLD...?
  12. #17
    Feb 2018
    SLC
    Byte 24: In regards to PLA3, I have marked Bit 6 as "PLA related" since we have incomplete information regarding that bit specifically. I have however seen some scans with factory equipped PLA3 that has Bit 5 selected
    Byte 25: I was under the impression that Auto-hold and HHC are different since auto-hold will hold the vehicle in place (Via the EPB) indefinitely, whereas HHC only holds line pressure for a short duration before releasing the pressure and letting the car roll back. which begs the question, are the two controlled via two separate byte locations, or is auto-hold an Adaptation.
    I definitely have some more digging to do...
    Last edited by Somnus; 12-14-2019 at 08:58 PM. Reason: Decluttering my mind (and post)
  13. #18
    May 2017
    They are different things. Hill hold and autohold.
  14. Likes Uwe liked this post
  15. #19
    +1
    My Octavia III with manual gearbox cannot have Auto Hold as the Octavia III doesn't have an EPB but it does have Hill Hold where the hydraulic pressure is maintained for a few seconds after you release the brake pedal.
  16. Likes downtime, darkchina811, Uwe liked this post
