Results 1 to 10 of 10
Thread: 3.0 TDI engine code CDYA
    Feb 2019
    Sweden
    Hi!
    2010 Audi A6 Quattro 3.0 TDI engine code CDYA (240hp)
    What options do I have with VCDS to “command” a DPF regeneration?
    Vcds activated emergency regeneration when driving and/or when standing/idle?
    And how to perform / activate it?
    Engine ECU/ECM uses the “CAN” protocol, but VCDS gives no hint “bubbles” or security code “bubbles ”
    And no “drop down” list with choices in basic settings.
    In [8] measuring blocks there’s not much info on what it’s showing, so a “nob” like me is left in the dark..
    MIL was on for some time due to a faulty temp sensor “3B” according to VCDS, at vag (etos/etka/elsa) the same sensor is called “4”
    So now I also would like to know how to see the measured ach volume/weight on the DPF as the faulty sensor did not allow any “by normal driving” regeneration.
    and if volume/weight is on the high side force a regeneration before I get “blinking glow spiral” and “limp home” mode.
    Lars in sweden
    Hi and welcome to our forum.
    Please post an Auto-Scan for context, so people can see the exact ECU ID info.
  3. Likes snowmad liked this post
    Feb 2019
    Sweden
    I just realized I used the Swedish translated version, does it work for you or shall I do it again?
    måndag,11,Februari,2019,14:01:43:17293
    VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 7 x64
    VCDS version: AER 18.9.0.2  HEX-V2 CB: 0.4437.4
    Dataversion: 20181218 DS296.0
    www.vcds.se
    VIN: WAUZZZ4F1ANxxxxxx   Reg.nr:
    Mätarställning: 160230km   Rep.order:
    Chassityp: 4F-AU56 (4F0)
    Skanna: 01 02 03 05 08 09 15 16 17 18 19 42 46 4F 52 53 55 56 5F 62
              69 72 76
    VIN: WAUZZZ4F1AN048589   Mätarställning: 160230km
    01-Motor -- Status: OK 0000
    02-Automatväxel -- Status: Felfunktion 0010
    03-Bromselektronik -- Status: OK 0000
    04-Styrposition -- Status: OK 0000
    05-Behör.kontroll -- Status: OK 0000
    08-Klimatanläggning -- Status: OK 0000
    09-Elektron. elcentral -- Status: Felfunktion 0010
    15-Krockkuddar -- Status: OK 0000
    16-Rattelektronik -- Status: OK 0000
    17-Instrument -- Status: OK 0000
    18-Extra/p-värmare -- Status: Felfunktion 0010
    19-CAN Gateway -- Status: Felfunktion 0010
    42-Dörrel. förare -- Status: OK 0000
    46-Komfortcentral -- Status: OK 0000
    4F-Elektr. centralenh. II -- Status: OK 0000
    52-Dörrelektr. pass. -- Status: OK 0000
    53-Parkeringsbroms -- Status: OK 0000
    55-Helljusområde -- Status: OK 0000
    5F-Information Elektr. -- Status: OK 0000
    62-Dörr, Vä Bak -- Status: OK 0000
    69-Släpvagn -- Status: Felfunktion 0010
    72-Dörr hö bak -- Status: OK 0000
    76-Parkeringshjälp -- Status: Felfunktion 0010
    Adress 01: Motor (CDY)       Labels: Textfil saknas
       Artikelnr SW: 4F9 910 402 A    HW: 4F0 907 401 E
       Komponent: 3.0TDI EDC17G004AG  0080
       Revision: 16H03---    Serienummer:
       Kodning: 0105002C191F0928
       Verkstad #: WSC 80093 222 69422
       VCID: 241110D8E2DFC7F7DAD-8070
    Ingen felkod funnen.
    Adress 02: Automatväxel        Labels: AER\09L-927-760.lbl
       Artikelnr SW: 4F2 910 156 Q    HW: 09L 927 156 C
       Komponent: AG6 09L 3,0 TDI RdW 0040
       Revision: --H05---    Serienummer:        4546441
       Kodning: 0000001
       Verkstad #: WSC 02325 785 00200
       VCID: 3333E3845731504F537-8066
    1 fel funnet:
    005913 - Nedsatt funktion p.g.a. motorstyrdonet
                   P1719 - 002 -  - Intermittent fel
                 frysta data:
                        Felstatus: 00100010
                        Felprioritet: 0
                        Felfrekvens: 24
                        Reset-räknare: 255
                        Mätarställning: 159444 km
                        Tidsindikering: 0
                        Datum: 2019.01.09
                        Tid: 18:22:17
    Adress 03: Bromselektronik        Labels: AER\4F0-910-517.lbl
       Artikelnr SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
       Komponent: ESP8 quattro    H03 0060
       Revision: 00000000    Serienummer: 00000000000000
       Kodning: 0004492
       VCID: 6E8532F07C933DA77C9-803A
    Adress 05: Behör.kontroll        Labels:. AER\4F0-910-852.clb
       Artikelnr SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Komponent: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serienummer: 10602601459789
       Kodning: 0000003
       Verkstad #: WSC 02323 785 00200
       VCID: 25170DDCE9E53EFFCD3-8070
       Subsystem 1 - Artikelnr: 4F0 910 132 E
       Komponent: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Artikelnr: 4F0 910 220 D
       Komponent: FBSAUDIC6 IDG   H01 0054
    Adress 08: Klimatanläggning        Labels: AER\4F0-910-043.lbl
       Artikelnr SW: 4F0 910 043     HW: 4F1 820 043 AA
       Komponent: KLIMABETAETIGUNGH20 0170
       Revision: 00000033    Serienummer: 00000000692588
       Kodning: 0002070
       VCID: 5BE36B249F21B80FAB7-800E
    Adress 09: Elektron. elcentral        Labels: AER\4F0-910-279.lbl
       Artikelnr SW: 4F0 910 279 N    HW: 4F0 907 279
       Komponent: ILM Fahrer      H22 0320
       Revision: 00000000    Serienummer: 4F0907279
       Kodning: 0003122
       Verkstad #: WSC 02335 785 00200
       VCID: 3431E098523F57774AD-8060
       Subsystem 1 - Artikelnr: 4F1 910 113 D  Labels: AER\1KX-955-119.CLB
       Komponent: Wischer AudiC6  H10 0040
       Kodning: 00056595
       Subsystem 2 - Artikelnr: 8K0 910 557   Labels: AER\8K0-955-559.CLB
       Komponent: REGENLICHTSENSORH04 0003
       Kodning: 00146221
    1 fel funnet:
    00156 - Styrning för spolarvätskepump
                007 - kortsl. till jord - Intermittent fel
                 frysta data:
                        Felstatus: 00110111
                        Felprioritet: 2
                        Felfrekvens: 1
                        Reset-räknare: 61
                        Mätarställning: 158976 km
                        Tidsindikering: 0
                        Datum: 2018.11.23
                        Tid: 17:33:00
    Adress 15: Krockkuddar (J234)       Labels:* AER\4F0-910-655-10.clb
       Artikelnr SW: 4F0 910 655 Q    HW: 4F0 959 655 G
       Komponent: Airbag AU1042 H06 0160
       Revision: --------    Serienummer: 003F9001ZXW%
       Kodning: 30314236303630303031554A304C34463053
       ROD: EV_Airba10AURB4.rod
       VCID: 3537DD9C55C54E7F7D3-8060
       krocksensor för sidoairbag på förarsidan:
       Serienummer: 3574SRB40000A488D8CN
       krocksensor för sidoairbag på passagerarsidan:
       Serienummer: 3584SRB40000A4C51913
       krocksensor för sidoairbag bak på förarsidan:
       Serienummer: 3516HRB402B9MGGL5CR0
       Krocksensor för sidoairbag bak: passagerarsidan:
       Serienummer: 3526HRB401TCD7SOVKM4
       krocksensor för airbag fram på förarsidan:
       Serienummer: 3554NRB4000052B088A/
       krocksensor för airbag fram på passagerarsidan:
       Serienummer: 3564NRB4000052AFE6DJ
    Adress 16: Rattelektronik        Labels: AER\4F0-910-549.lbl
       Artikelnr SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Komponent: J0527               0530
       Revision: 00H05000    Serienummer: 90055093310200
       Kodning: 0002041
       VCID: 270B07D493E92CEFFFF-8072
       Subsystem 1 - Artikelnr: XXXXXXXXXXX
       Komponent: E0221           H02 0030
    Adress 17: Instrument (J285)       Labels:. AER\4F0-920-xxx-17.clb
       Artikelnr SW: 4F0 920 933 Q    HW: 4F0 920 933 Q
       Komponent: KOMBIINSTR.   H08 0144
       Revision: 00100000    Serienummer: CN102KVC9
       Kodning: 0F560A0502000008010100
       Verkstad #: WSC 02391 823 56573
       VCID: 3537DD9C55454E7F7D3-8060
    Adress 18: Extra/p-värmare        Labels: saknas
       Artikelnr SW: 4F0 910 105 A    HW: 4F0 265 081 AA
       Komponent: Heizgeraet      H08 0100
       Revision:        B    Serienummer: 09018641
       Kodning: 0000111
       Verkstad #: WSC 02145 785 00200
       VCID: 1B632B24DFA1F80F6B7-804E
    2 Funna fel:
    00664 - Bränslemätare
                002 - Undre gräns överskriden - Intermittent fel
                 frysta data:
                        Felstatus: 00100010
                        Felprioritet: 0
                        Felfrekvens: 1
                        Reset-räknare: 68
                        Mätarställning: 159518 km
                        Tidsindikering: 0
                        Datum: 2019.01.12
                        Tid: 16:55:46
    01407 - Flamavbrott
                000 - - - Intermittent fel
                 frysta data:
                        Felstatus: 00100000
                        Felprioritet: 0
                        Felfrekvens: 1
                        Reset-räknare: 77
                        Mätarställning: 160019 km
                        Tidsindikering: 0
                        Datum: 2019.02.04
                        Tid: 02:15:41
                 frysta data:
                            Start
                        Temperatur: 21.0°C
                        Temperatur: -48.0°C
    Adress 19: CAN Gateway (J533)       Labels:. AER\4F0-907-468.clb
       Artikelnr SW: 4F0 907 468 M    HW: 4F0 907 468 F
       Komponent: GW-BEM 4CAN-M H06 0035
       Revision: LB100029    Serienummer: 2900L09B288028
       Kodning: 000303
       VCID: 392FD1AC795DAA1F99B-806C
       Subsystem 1 - Artikelnr SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Komponent: J367-BDM  H07 0125
       Serienummer: 00000000002790838416
    1 fel funnet:
    03041 - Energimanagement aktiv
                 frysta data:
                        Felstatus: 00100000
                        Felprioritet: 7
                        Felfrekvens: 16
                        Reset-räknare: 68
                        Mätarställning: 158972 km
                        Tidsindikering: 0
                        Datum: 2018.10.23
                        Tid: 06:06:00
                 frysta data:
                        Binära Bitar:    00000
                        Spänning: 11.90 V
                        Räkna: 18
    Adress 42: Dörrel. förare (J386)       Labels:. AER\4F0-959-793.clb
       Artikelnr SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Komponent: TSG FA        H11 0250
       Revision:             Serienummer: 0000102440014
       Kodning: 011C06204040410001
       VCID: 46D5AA5038A3D5E7E49-8012
    Adress 46: Komfortcentral        Labels:. AER\4F0-910-289.lbl
       Artikelnr SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Komponent: Komfortgeraet   H29 0250
       Revision: 02500029    Serienummer: 01247056780000
       Kodning: 0196849
       VCID: 3537DD9C59454E7F7D3-8060
       Subsystem 1 - Artikelnr: 1K0 951 605 C
       Komponent: LIN BACKUP HORN H05 1501
       Subsystem 2 - Artikelnr: 4F0 910 177
       Komponent: Innenraumueberw.H01 0020
    Adress 4F: Elektr. centralenh. II        Labels: AER\4F0-910-280.lbl
       Artikelnr SW: 4F0 910 280     HW: 4F0 907 280 A
       Komponent: ILM Beifahrer   H13 0100
       Revision:             Serienummer: 00000000676359
       Kodning: 0001103
       VCID: 5EE562308C33AD27CC9-800A
    Adress 52: Dörrelektr. pass. (J387)       Labels:. AER\4F0-959-792.clb
       Artikelnr SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Komponent: TSG BF        H11 0250
       Revision:             Serienummer: 0000102452401
       VCID: 45D7AD5C05A5DEFFED3-8010
    Adress 53: Parkeringsbroms        Labels: AER\4F0-910-801.clb
       Artikelnr SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Komponent: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Kodning: 0000321
       VCID: 211F19CCFDCDD2DFB1B-8074
    Adress 55: Helljusområde        Labels: AER\8P0-907-357.lbl
       Artikelnr: 8P0 907 357 H
       Komponent: Dynamische LWR  H02 0010
       Revision: 00000001    Serienummer:
       Kodning: 0000003
       VCID: 3FDBBFB46B79842FA7F-806A
    Adress 56: Radio (R)       Labels: Textfil saknas
       Artikelnr SW: 4F0 035 056 B    HW: 4F0 035 056
       Komponent: Radio U STD   H45 0020
       Revision: AB001007    Serienummer: 342L0097733657
       Kodning: 010003020100000000
       VCID: 1F1B1F34C7B9E42F87F-804A
    Adress 5F: Information Elektr. (J794)       Labels:. AER\4E0-035-6xx-5F.clb
       Artikelnr SW: 4E0 035 652 A    HW: 4E0 035 652
       Komponent: B-BN-EU       H56 0048
       Revision: --------    Serienummer: 349L9097528576
       Kodning: 01010000010282ED01002305EF6300030000
       Subsystem 1 - Artikelnr SW: 4L0 919 604     HW: 4L0 919 604
       Komponent: DU6 Basic  H43 0306
       Serienummer: 9355L 091054964
       Subsystem 2 - Artikelnr SW: 4F0 910 609 E    HW: 4F1 919 611 M
       Komponent: Bedienteil MM  H01 0060
       Serienummer: 00000001469119
    Adress 62: Dörr, Vä Bak (J388)       Labels:. AER\4F0-959-795.clb
       Artikelnr SW: 4F0 959 795 M    HW: 8K0 959 795 B
       Komponent: TSG HL        H10 0251
       Revision:             Serienummer: 0000102446957
       Kodning: 010804204040220001
       VCID: 43D3B3440B91E0CFC37-8016
    Adress 69: Släpvagn (J345)       Labels:. AER\4F0-907-383.clb
       Artikelnr SW: 4F0 907 383 D    HW: 4F0 907 383 D
       Komponent: Anhaenger     H08 0080
       Revision: 2B002002    Serienummer: 00000124441180
       Kodning: 0103030000000000
       VCID: 2C01F8F8860F0FB712D-8078
    1 fel funnet:
    00532 - Spänning
                011 - avbrott - Fellampa(MIL) tänd
                 frysta data:
                        Felstatus: 11101011
                        Felprioritet: 3
                        Felfrekvens: 11
                        Reset-räknare: 157
                        Mätarställning: 151975 km
                        Tidsindikering: 0
                        Datum: 2017.09.24
                        Tid: 17:19:00
    Adress 72: Dörr hö bak (J389)       Labels:. AER\4F0-959-795.clb
       Komponent: TSG HR        H10 0251
       Revision:             Serienummer: 0000102446971
    Adress 76: Parkeringshjälp        Labels: AER\4Fx-910-283.lbl
       Artikelnr SW: 4L0 910 283 C    HW: 4L0 919 283 C
       Komponent: Parkhilfe 8-Kan H02 0500
       Revision: 00H02000    Serienummer: 12630933604038
       Kodning: 0211006
       VCID: 2A0DFEE080FB1187E01-807E
    3 Funna fel:
    01545 - Givare för parkeringshjälp: vänster bak (G203)
                004 - Ingen signal/förbindelse - Intermittent fel
                 frysta data:
                        Felstatus: 00100100
                        Felprioritet: 3
                        Felfrekvens: 1
                        Reset-räknare: 58
                        Mätarställning: 159177 km
                        Tidsindikering: 0
                        Datum: 2018.11.26
                        Tid: 17:47:40
    01547 - Givare för parkeringshjälp: höger bak: mitten (G205)
                 frysta data:
                        Felstatus: 00100100
                        Felprioritet: 3
                        Felfrekvens: 1
                        Reset-räknare: 58
                        Tidsindikering: 0
                        Datum: 2018.11.26
                        Tid: 17:46:00
    02069 - Givare för parkeringshjälp fram
                011 - avbrott - Intermittent fel
                 frysta data:
                        Felstatus: 00101011
                        Felprioritet: 3
                        Felfrekvens: 1
                        Reset-räknare: 66
                        Mätarställning: 159400 km
                        Tidsindikering: 0
                        Datum: 2019.01.05
                        Tid: 21:59:37
    Slut--------(Förfluten tid: 01:38, Vbatt start/stopp: 13.2V/14.2V)---------
    I got the English version of VCDS installed as well, just to be up to date..
    The translation to Swedish isn’t that fast and English isn’t so hard for me to understand…. I think 😊
    I always have versions on both languages installed.
    //Lars
    It's always best to post here using the English version of VCDS.
  6. Likes Uwe liked this post
    Hmm, VCDS is aware that 4F9-910-402-A exists as an ECU part number and wants to re-direct it to 059-907-401-CDY, but I do see such a file in either English or German. I wonder if the Danish distributor has one?
    Yes I have one
    I find wiki procedure later (out of time now).
  9. Likes Uwe liked this post
  10. #7
    Here is some procedure.
    Oil and cooling water Min 73°C
    Cooling water Max 117°C
    Fuel temp. Max 68°C
    Probably this is used instead of [Coding II]:
    Security Access code 27971
    Basic Setting Enabling (e.g. Regeneration while Standing) is used in conjunction with Basic Setting MWB 226
    Read showed information in MWB, what to do.
  11. Likes Eric, Uwe, snowmad liked this post
  12. #8
    Feb 2019
    Sweden
    thank you.
    If I understand the link right MVB 104.3 is showing measured sot? "## Particle Filter Load below 68g (see MVB 104.3)" ?
    "Read showed information in MWB, what to do." as I wrote in the beginning of the tread, no info is shown to me..
    I ben “all over” with the curser/pointer but no yellow “bubbles” appears!
    I try to make some screen dumps and a “English auto scan” later today (if my son shows up with the car)
  13. #9
    No as Uwe wrote there is currently no label file.
    On the wiki link you could see a few explained.
  14. Likes snowmad, Uwe liked this post
  15. #10
    Feb 2019
    Sweden
    ok!
    still same car:
    how to "register" a new DPF and a new DPF difference pressure sensor?
    this question is just out off curiosity as the car runs like a bat out of he.. right now
