Results 1 to 5 of 5
Thread: Audi a7 fault codes
    Feb 2019
    Audi a7 fault codes
    Hi Guys,
    Received my hex-v2 cable today and carried out an auto scan which threw up a small handful of codes all off which I cleared after saving the data, I then took the car for a drive and re scanned which showed that 2 of the codes previously seen had re appeared. I'm hoping someone can let me know what they are exactly as I cant find anything either on here or online that directly relates to the 2 codes, please see below, your help would be greatly appreciated.
    0035 - Motor for Recirculation Flap
    B1092 07 [009] - Mechanical Failure
    Reset counter: 230
    Mileage: 89274 km
    Date: 2019.02.08
    Time: 17:43:06
    Voltage terminal 30: 13.37 V
    Outside air temperature: 8.5 °C
    Interior temperature: 13.66 °C
    Recirculation flap motor-Act.val.: 10210
    Recirculation flap motor-Specified value: 10748
    Recirculation flap motor-Stop open: 11427
    Recirculation flap motor-Stop closed: 10000
    013 - Check DTC Memory
    Fault Status: 01101101
    Reset counter: 230
    Mileage: 89278 km
    Date: 2019.02.08
    Time: 18:00:0
    We'll need to see a full Auto-Scan please.
  3. Likes Uwe liked this post
    Feb 2019
    Hi sorry didn't realise i had to post the whole lot please see below,
    Friday,08,February,2019,18:06:57:00592
    VIN: WAUZZZ4G7EN040625   License Plate: WEEEEE
    Mileage: 89278km-55474mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 30 36 3B 42 44 46 47 52 53
              55 56 5F 62 6D 72 82
    VIN: WAUZZZ4G7EN040625   Mileage: 89278km-55474miles
    Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
       Component: 3.0TDI EDC17  X41 0002
       Revision: 53X41---
       Coding: 1A254012042601020800
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
       ROD: EV_ECM30TDI0114G0907401Q.rod
       VCID: 313F1780E1A97F8F213-8064
       Part No SW: 4G2 927 156 P    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H01 0002
       Revision: --H01---
       Coding: 000001
       ROD: EV_TCMDL501021.rod
       VCID: 3B2335A833E585DF8BF-806E
       Coding: 27A69F03E465F9C0DB00
       VCID: 3A2D30AC3CDFBCD7909-806E
       Part No SW: 4H0 907 064 DN    HW: 4H0 907 064 DN
       Component: BCM2 2.0      H35 0510
       Coding: 01BA3046000000000000
       VCID: 78A9EAA442D36EC7A6D-802C
       Serial number: 2313000009281006
       Part No SW: 4G0 820 043 AC    HW: 4G0 820 043 AC
       Component: KLIMA 2 ZONEN H11 0087
       Serial number: 18071300112321
       Coding: 3623000831
       ASAM Dataset: EV_AirCondiBasisUDS 002045
       VCID: 6099A2C4FAC38607FED-8034
                        Reset counter: 230
                        Mileage: 89274 km
                        Date: 2019.02.08
                        Time: 17:43:06
                        Outside air temperature: 8.5 C
                        Interior temperature: 13.66 C
       Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
       Revision: 20012002    Serial number: 00000001754258
       Coding: 2600201040349FE00181008380001D0CCF9DC30A27090201000004606100
       VCID: 6E85CCFC309720777C1-803A
       Component: WWS57X 130713  H36 0080
       Serial number:         130715221204
       Coding: 0045F7
       Serial number: 21559327
       Coding: 02006E
       Subsystem 3 - Part No SW: 4G0 941 531 AA    HW: 4G0 941 531 AA
       Component: E1 - LDS  H07 0044
       Serial number: 15 07 2013  00001399
       Serial number: FC690BB6000000000001
                        Reset counter: 230
                        Mileage: 89278 km
                        Date: 2019.02.08
                        Time: 18:00:00
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4H0 919 475 AB    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0060
       Revision: --------    Serial number: 56231319003915
       Coding: 981304
       ASAM Dataset: EV_EPHVA2CAU57X0000 002012
       ROD: EV_EPHVA2CAU57X0000.rod
       VCID: 72BDD88C242F0497989-8026
       Revision: --------    Serial number: 003JG00E8Y9H
       Coding: 3031453032314E303133554A305234473853
       VCID: 3635249C08C758B7741-8062
       Serial number: 3575HRB400250IPEHP3G
       Serial number: 3585HRB400250GS660O
       Serial number: 3515JRB400K50KB8N10Y
       Serial number: 3525JRB400A50KB8HORQ
       Serial number: 3554VRB400E50KRCA24C
       Serial number: 3564VRB400E50KRCMOVV
       Revision: 00000000    Serial number: 20130724001381
       Coding: 000034
       VCID: 30391284EA2376872ED-8064
       Part No SW: 4G8 920 984 H    HW: 4G8 920 984 H
       Component: TDieGb        H80 0618
       Revision: 30460230    Serial number: 658250713596017
       Coding: 33A700020B432600010100
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K.rod
       Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000001038959
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001018
       VCID: 71BFD78021293F8F613-8024
       Serial number: 6672031003
       Voltage stabilizer:
       Serial number: 130527000000000004DC
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000045878
       Coding: 01010101000000000001000202
       VCID: 6491AED4EE5B9A271A5-8030
       Revision: AA000000    Serial number: 00000068542863
       VCID: 77ABE9984FCD61BFAF7-8022
       Component: SARA 3D       H02 0056
       Revision: --------    Serial number: EJ1BPA7205JSGS
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 33331D881BB54D9F53F-8066
       Coding: 011F56024E21620002080402
       VCID: 47CB59587FADD13F1F7-8012
       Component: RCEPS         H38 0010
       Revision: 00001000    Serial number: 0021696459
       Coding: 101100010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D188CE4AF4497589-8066
       Revision: 00002001    Serial number: 0312209594
       Coding: 013B0622A0B9B80083200A0400010D470000000000000000000000000000
       Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA106239000004186091
       Revision: CJ007001    Serial number: 00000000014831
       VCID: 1D67DB308DB1EBEF95B-8048
       VCID: 46D5545C78A7C837E41-8012
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000778740
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C0106F4C68B1267125-8078
       Serial number: 130724-0002-141
       Coding: 1123A6101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D070BF0FD911B6F05B-8078
       Part No SW: 4G0 035 061 L    HW: 4G0 035 061
       Component: Radio U DAB   H60 0133
       Revision: AB001007    Serial number: 109G/0D7701658
       Coding: 010103010000000001
       VCID: 2615F4DCD8E72837C41-8072
       Part No SW: 4G0 035 666 K    HW: 4G0 035 666 H
       Component: H-BN-EU       H51 0732
       Revision: --------    Serial number: 189GB0D7548088
       Coding: 090101040003E5ED45808B3E00000003E00101020000000000
       Subsystem 1 - Part No: 8R0 060 884 BC
       Component: EUR 2013/2014  1603
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD002354%
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Serial number: 90349MGP000GY
       Component: CD-Database  5298
       Coding: 010F14024021620002080002
       VCID: 49CF5F6069B9274F093-801C
       Part No SW: 4G8 959 107 Q    HW: 4G8 959 107 F
       Component: HDSG-Modul    H13 0043
       Revision: 11013001    Serial number: 190300969
       Coding: 0A3305C002
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571.rod
       VCID: 43D34D484B15FD1FC3F-8016
       Part No SW: 4G8 919 604 L    HW: 4G8 919 604 L
       Component: HeadUpDisplay 004 0201
       Coding: A20000
       ASAM Dataset: EV_HUDContiC7 001023
       ROD: EV_HUDContiC7.rod
       VCID: 3C2136B436EB82E7825-8068
    End----(Elapsed Time: 02:12, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
    Feb 2019
    Also guys are workshop manuals for the relevant vehicles the place to look to identify what exactly the codes are after scanning and how to fix if required? If so where are the best locations to download these for VAG cars?
    Thanks again
    Clear the fault in the HVAC module and then run the Basic Setting IDE01546 -- Adapt flap end stops in the HVAC controller. If that doesn't fix it, then physical investigation of the flap motor is indicated.
    The fault in the 09-BCM module is just a "Sympathy" fault.
