Results 1 to 10 of 13
Thread: Sharan 7N lights coding.
    Feb 2019
    Hello.
    Is there any coding to code 5 Brake lights?
    I hawe checked 09 coding and adaptions but have't find it. Second question is that is there possible to code us style park lights/Blinkers? To golf I found both of these options but sharan is mystery.
    Btw, I have halogen lights.
    Thanks!
    Please post an Auto-Scan so people can see how the vehicle is equipped and configured.
    Feb 2019
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#fi
    Feb 2019
    What!? Sorry I did not know. Tomorrow I Will go back to the Shop!
    Feb 2019
    First of all, I´m sorry that I insult you with the pirate/cloned VCDS. I called the seller and I have now his VCDS and laptop in use. Can you tell me is that ´new´VCDS original? He said that he ordered 5 of those from germany. They shoud be original. He quaranteed that this is original. I post here auto-scan:
    Removed.  Still from a clone.
  7. #7
    Oh, and the carpet doesn't match the drapes.
  8. Likes PetrolDave, pbsbogdan liked this post
  9. #8
    Feb 2019
    Hello.
    Thanks!
    Monday,15,July,2019,20:25:04:19148
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4505.4
    VIN: WVWZZZ7NZBV023218   License Plate: JHR-126
    Mileage: 205830km-127896mi   Repair Order:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 18 19 25 2E 37 42 44 46 4F 52 53 56
              61 62 72
    VIN: WVWZZZ7NZBV023218   Mileage: 205830km-127896miles
    18-Aux. Heat -- Status: Sporadic communication error 1000
       Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
       Component: R4 2.0l TDI   H24 9979
       Revision: 44H24---    Serial number:
       Coding: 001D001A042401080000
       Shop #: WSC 32500 205 00000
       ASAM Dataset: EV_ECM20TDI01103L906018HJ 003014
       ROD: EV_ECM20TDI01103L906018F_VW36.rod
       VCID: 79AFEDF3195DFE0F8D7-802C
       Part No SW: 02E 300 054 Q    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2602
       Revision: 05351112    Serial number: 00001011130416
       Shop #: WSC 00020 000 90108
       VCID: 2411EC87C2DF53E78E1-8070
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 L    HW: 7N0 614 109 L
       Component: J104   C3 450M VD66 0008
       Revision: --H07---    Serial number: 00000003523186
       Coding: 0027162
       Shop #: WSC 00020 790 00000
       VCID: 363526CF6443D177205-8062
       Part No SW: 5K0 907 044 G    HW: 5K0 907 044 G
       Component: Clima-Sharan  H11 0104
       Coding: 0000000009
       Shop #: WSC 00020 999 00000
       VCID: 2F3B13AB9799E0BF633-807A
    9601321 - Humidity sensor
              B1281 29 [008] - Signal Implausible
                        Reset counter: 140
                        Mileage: 205693 km
                        Date: 2019.07.14
                        Time: 12:54:23
       Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
       Component: BCM PQ35 B    011 0046
       Revision: BA011001
       Coding: 40190A3B89251AC0400800C4540000EC43511322422D25629980874000C1
       Shop #: WSC 00020 790 12345
       VCID: 353721C37545DA6F29F-8060
       Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    110911  31  0032
       Serial number:         110922114355
       Coding: 000D9D
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0022
       Serial number: Y10M12D12h07m45s42S1
       Coding: 1780BB
    03384 - Windshield Washer Jet Heating
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 88
                        Reset counter: 102
                        Mileage: 202581 km
                        Date: 2013.11.03
                        Time: 19:45:27
                        Voltage: 11.85 V
       Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
       Component: VW10Airbag012 H07 0013
       Serial number: 003GFPR4W1QK
       Coding: 003132
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3E253EEF40F31937F85-806A
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60CF192813DD1
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS60701528139D8
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS60DBE127139DY
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS6006102813DD8
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS60807039139D4
       Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101218301045
       Coding: 1992240000
       VCID: 6A8DC2BF6CFB459774D-803E
       Coding: E30000
       Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
       Component: KOMBI         H20 0420
       Coding: 170D00
       Shop #: WSC 52001 205 09977
       VCID: 303910D78AA7FF477A9-8064
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 A
       Component: Zuheizer        051 2630
       Revision: 00051000    Serial number: 09022126000000
       Coding: 0000041
       VCID: 323D1ADF882BCD570CD-8066
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 171210F2001989
       Coding: 468002
       VCID: 313F15D3812DF64F757-8064
    01207 - Control Module for Auxiliary Heater (J364)
                        Fault Status: 00110100
                        Fault Frequency: 41
                        Reset counter: 140
                        Mileage: 202622 km
                        Date: 2013.11.04
                        Time: 07:01:27
       Component: IMMO          H20 0420
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669038278
       Coding: 020000
       VCID: 2809F8B7B2F7B787A29-807C
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2K8357962
       Coding: 040004310400000000021000
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: 6099A0979AC70FC7AA9-8034
    1048582 - GPS Antenna
              B1054 13 [009] - Open Circuit
              [GPS antenna open load]
                        Fault Frequency: 54
                        Reset counter: 142
                        Mileage: 202719 km
                        Date: 2019.06.17
                        Time: 06:09:49
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 D    HW: 7N0 959 793
       Component: TSG FA        H04 0400
       Revision:             Serial number: 0000110543452
       Coding: 011006208000411011
       VCID: 43D34F1B2B9174DF97B-8016
    01705 - Selection Switch for Mirror-Adjust (E48)
                        Reset counter: 109
                        Mileage: 201508 km
                        Date: 2013.10.17
                        Time: 20:39:47
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.324 1401
       Revision: 1BH04739    Serial number: 00133360268701
       Coding: 0000258
       Shop #: WSC 52001 205 88154
       VCID: 41DF45133D8D66CF857-8014
       Component: EZE_2         H35 0614
       Coding: 050B0500
       VCID: 6FBBD3AB5799A0BF233-803A
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 D    HW: 7N0 959 792
       Component: TSG BF        H04 0400
       Revision:             Serial number: 0000109940236
       Coding: 011006208C00411011
       VCID: 42DD4A1F348B7DD79CD-8016
       Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
       Component: J540 EPB4  VW-53083 0006
       Revision:   H18       Serial number: 00000000132453
       Coding: 0024067
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71BFD5D341ADB64F357-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370245291
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
       Component: TSG HL        H03 0400
       Revision:             Serial number: 0000110849005
       Coding: 010004200000411001
       VCID: 45D7510325A54AEFB9F-8010
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H03 0400
       Revision:             Serial number: 0000110846452
    End----------(Elapsed Time: 01:53, VBatt start/end: 12.4V/12.3V)-----------
  10. Likes Uwe liked this post
  11. #9
    OP has redeemed himself and gone straight.
    Moved to Tweaks.
  12. #10
    Dec 2016
    DE
    I don’t see how this would be possible with coding. However it should be feasible with another tool that allows changing of EEPROM contents of the BCM.
