Results 1 to 6 of 6
Thread: Audi a7 acc Cannot be reached
    Nov 2018
    Norway
    Hello.
    I have been in an accident with my audi.
    after the accident I have changed the dashboard and new airbags. but i can't find out of acc.
    I have changed both sensors in the front.
    I have checked that the wires are whole from the acc sensor to the gateway.
    Thought the gateway was broken since I have power to the sensors and have a signal to the gateway.
    changed the gateway but still not wise on what the problem might be ..
    the only thing i haven't changed is the lever on the steering wheel.
    Anybody have any tips?
    attaches to auto-scan.
    both night vision, headup and speedometer are changed and not coded yet.
    Friday,08,February,2019,19:08:42:19813
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WAUZZZ4G4BN017170   License Plate:
    Mileage: 167345km-103983mi   Repair Order: 08-2/19
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 22 28 34 36 3B 3C
              42 44 46 47 52 53 55 56 5F 62 69 6C 6D 72 82 84 85 8B 8E 8F
              90
    VIN: WAUZZZ4G4BN017170   Mileage: 167345km-103983miles
    82-Heads Up Display -- Status: Malfunction 0010
    84-Night Vision -- Status: Malfunction 0010
    8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551     HW: 4H0 907 551
       Component: 3.0l V6 TFSI  H05 0007
       Revision: --H05---
       Coding: 1A25003C056E01020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551 002010
       ROD: EV_ECM30TFS0214G0907551_002.rod
       VCID: 6695B4BA88E31B67041-8032
    6058 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [037] - -
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:37
                        Coolant temperature: 21 C
                        Intake air temperature: 13 C
                        Ambient air pressure: 860 mbar
                        Voltage terminal 30: 11.374 V
                        Engine speed: actual: 0 /min
                        T_AST_ENVD: 0.00 s
                        Gear: 0
                        Engine: operating status: ES
                        Battery voltage: 11.984375 V
                        Vehicle speed: actual: 0 km/h
    Readiness: 0110 0001
       Part No SW: 4G0 927 156 M    HW: 0B5 927 156 F
       Component: 0B5 30TFSIRdW H10 0010
       Revision: --H10---    Serial number: 0000001377
       Coding: 000001
       ROD: EV_TCMDL501.rod
       VCID: 363524FA98C3ABE7741-8062
       Part No SW: 4G0 907 379 B    HW: 4G0 907 379 B
       Component: ESP PREMIUM   H09 0190
       Coding: 44B6C702226DE340CB00
       ASAM Dataset: EV_ESPPremiAU57X 003013
       ROD: EV_ESPPremiAU57X_003.rod
       VCID: 303912E27AA785D72ED-8064
    0040 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_ACC_05_Timeout]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: A8
                        Uz: 91
    0042 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_ACC_10_Timeout]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: AE
                        Uz: 91
       Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
       Component: BCM2 2.0      H24 0217
       Coding: 05AA2F00000000000000
       VCID: 77ABE9FEDFC992EFAF7-8022
       Serial number: 2311000039309003
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H11 0076
       Serial number: 17021100040008
       Coding: 661300B80C
       VCID: 270BF9BE4F69C26FFF7-8072
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 12.5 C
                        Temperature after evaporator: 10.68 C
                        Engine speed: 0 /min
       Part No SW: 4H0 907 063 G    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0092
       Revision: 11012002    Serial number: 00000000963042
       Coding: 0D07201009769FE0A981008300001800CF9CC3082E090101000308452F00
       VCID: 2C010692560FE137125-8078
       Component: WWS57X 110218  H32 0051
       Serial number:         110221160113
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11300879
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
       Component: E1 - LDS  H07 0044
       Serial number: 13 08 2010  00000071
       Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A31 LED Mod1L  H02 0001
       Serial number: 00000000001101043126
       Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A27 LED Mod1R  H02 0001
       Serial number: 00000000001101210629
       Serial number: 0F080495000000000001
       Subsystem 7 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A32 LED Mod2L  H02 0001
       Serial number: 00000000001101211408
       Subsystem 8 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A28 LED Mod2R  H02 0001
       Serial number: 00000000001101230023
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4H0 919 475 E    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0013
       Revision: --------    Serial number: 56231104902303
       Coding: 312B04
       ASAM Dataset: EV_EPHVA2CAU57X0000 001004
       ROD: EV_EPHVA2CAU57X0000_001.rod
       VCID: 34311EF28EBFB9F74A5-8060
    Address 13: Auto Dist. Reg
       Revision: --------    Serial number: 003JG00ANV1H
       Coding: 30323436313330303339554A304C34473053
       Serial number: 3575HRB404P0G68UCP4.
       Serial number: 3585HRB404R0G68UE1LZ
       Serial number: 3515JRB405309GGS7PO-
       Serial number: 3525JRB405709GGS9G7H
       Serial number: 3554VRB404T6P1I8I8TL
       Serial number: 3564VRB404V6P1I8J9GD
    9442587 - Igniter for battery interrupt
              B1015 1B [137] - Resistance Too High
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:41
    1050368 - Databus
              [CAN: 0x323 PCF_01 Timeout]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:36
    15360768 - Component Protection
              U1101 00 [137] - Active
              [ATP Inconsistency]
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:38
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H03 0003
       Revision: --------    Serial number: 90372KBQ0003C
       Coding: 0000FC
       VCID: 372B29FE9F4952EF6F7-8062
       Component: E221 - MFL  H07 0009
       Serial number: 29 01 2011  11102750
       Part No SW: 4G8 920 930 R    HW: 4G8 920 930 R
       Component: TBenRdwAcc    H34 0309
       Revision: 18100069    Serial number: 658260111593003
       Coding: 078F0102DF030008000100
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K.rod
       VCID: 3C2136D2A6EF71B7825-8068
    16776960 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_02_FR keine Kommunikation]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:10:01
    16776961 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_04_FR keine Kommunikation]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:10:01
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105     HW: 4H0 265 105
       Component: Standheizung  H22 0240
       Revision: 56005006    Serial number: 20110208172316
       Coding: 4D3100
       VCID: 5F9BA15E57394AAFC77-800A
       Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000105294
       Coding: 00CD073000
       ROD: EV_GatewUDS_AU57.rod
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650659245
       Voltage stabilizer:
       Serial number: 11048000088021200410
    4365 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Voltage terminal 30: 11.4 V
                        Voltage terminal 15: 11.4 V
                        Control Module temperature: 23 C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    6654 - Automatic distance regulation 2
              U1071 00 [009] - No communication
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
              U1101 00 [009] - Active
                        Reset counter: 71
                        Mileage: 167345 km
                        Date: 2018.12.15
                        Time: 00:15:46
                        Voltage terminal 30: 11.9 V
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 27 C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
              U140B 00 [008] - -
              [Powermanagement active]
                        Reset counter: 111
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 17
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 04018E64747464545425363E
       VCID: 33331DEE8B31BECF53F-8066
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H11 0013
       Serial number: 001802110001058
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
       Component: KLIMA FOND    H07 0076
       Serial number: 23021100040248
       Coding: 01
    0116 - Temperature Sensor for Rear Right Seat
              B1114 15 [009] - Open or Short to Plus
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
    0119 - Temperature Sensor for Rear Left Seat
              B1113 15 [009] - Open or Short to Plus
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
    0124 - Rear Right Seat Heater
              B1118 15 [009] - Open or Short to Plus
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
    0127 - Rear Left Seat Heater
              B1117 15 [009] - Open or Short to Plus
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
       Part No SW: 4G0 907 553 B    HW: 4G0 907 553
       Component: LUFE-DAEMPFER H17 0778
       Coding: 008003
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2A0D008A5C7BFF07E09-807E
    0002 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:36
              C10C8 00 [008] -  -
                        Reset counter: 111
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:13:33
       Revision: AA000000    Serial number: 00000081794898
       Shop #: WSC 02387 823 28888
       Part No SW: 4G0 907 637 C    HW: 4G0 907 637 C
       Component: SARA 6D red   H02 0004
       Revision: --------    Serial number: EJ1BPA3E0028L%0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2E050C9A609393273C1-807A
       Part No SW: 4G0 907 566 C    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0040
       Revision: 00H04000    Serial number: 6PZ 010 287-01
       Coding: 0010107
       Shop #: WSC 01357 210 01865
       VCID: 2F3B119E6B199A2F377-807A
       Subsystem 1 - Part No: 4G0 907 568 C
       Component: J770  SWA Slave H04 0040
       Subsystem 2 - Serial number: 6PZ 010 287-21
       Subsystem 3 - Serial number: 5F12.12.1400H04000AMS17944
       Subsystem 4 - Serial number: S17944
       Part No SW: 4G8 959 793 B    HW: 4G8 959 793
       Component: TSG FA        H04 0210
       Coding: 011F56035E00620002080402
       Shop #: WSC 02312 785 00200
       VCID: 3FDB41DEB7796AAFA77-806A
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 F
       Component: RCEPS         H32 0010
       Revision: 00001000    Serial number: 0025041460
       Coding: 101101010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D18EA74ABB7C7589-8066
              [Lenkungsendanschlge nicht angelernt]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Write only channel
       Revision: 00002001    Serial number: 0144579851
       Coding: 013E0E2020B9B48583300A000E0100000000000000000000000000000000
       Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO1142194$
       Coding: 001F00
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA100924000000185618
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:33
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000023820
       VCID: 1B63D54E03A1168F6BF-804E
       Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
       Component: TSG BF        H04 0210
       Coding: 011F56225000628002080002
       Revision: --------    Serial number: 00000000046161
       ROD: EV_ParkiBrake_VW51.rod
    327936 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [FC_ACC_05_MESSAGE_TIMEOUT]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Voltage terminal 30: 11.3 V
                        Internal Fault ID: 86
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
       Component: ....LWR12.... H02 0012
       Serial number: 110227-0004-077
       Coding: 11236F601002A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C010692568FE137125-8078
       Part No SW: 4G0 035 053 A    HW: 4G0 035 053
       Component: Radio U Basic H52 0050
       Revision: AB001007    Serial number: 050BW0B7544369
       Coding: 010003010000000001
       VCID: 1C61D65206AF11B7625-8048
       Part No SW: 4G0 035 666 B    HW: 4G0 035 666
       Component: H-BN-EU       H46 0239
       Revision: --------    Serial number: 426C30B7592769
       Coding: 0A0100040303DFEF7D348F3E00000003E001010000000000
       VCID: 270BF9BE4FE9C26FFF7-8072
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB1300DHEI
       Subsystem 3 - Part No SW: 4G1 919 612 L    HW: 4G1 919 612 L
       Component: E380 BDT C7  H08 0120
       Serial number: 90349KC1000AD
       Component: CD-Database  2712
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:47
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 10001000 00000000
                        Bin. Bits: 00000000 00000010
                        Bin. Bits: 00000000 00000000
       Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
       Component: TSG HL        H03 0210
       Coding: 010F14224000628002080002
       VCID: 42DD482AC48B0747C89-8016
    Address 69: Trailer (J345)       Labels:. 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: ConWys Trailer H07 0072
       Revision: 7B001002    Serial number: 00000133243642
       Coding: 0100000000000000
       Part No SW: 4G0 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0050
       Revision: --H04---    Serial number: 525 PA8J12F0JR
       Coding: 1020013
       VCID: 2517F3B639E5D07FCDB-8070
       Part No SW: 4G8 959 107 D    HW: 4G8 959 107
       Component: HDSG-Modul    H12 0036
       Revision: 11012001    Serial number: 045100453
       Coding: 0A3205C000
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       Component: TSG HR        H03 0210
       Part No SW: 4G8 919 604     HW: 4G8 919 604
       Component: HeadUpDisplay Y26 0042
       ASAM Dataset: EV_HUDContiC7 001020
       ROD: EV_HUDContiC7.rod
       VCID: 70B9D2E2BA27C5D76ED-8024
              U1014 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 F    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H10 0042
       Serial number: 0K84AE40096373
       Coding: 1100
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H24 0034
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 6597B3B675E5107F0DB-8030
    0724 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_timeout]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Outside air temperature: -44.0 C
                        Voltage terminal 15: 11.0 V
                        Control Module temperature: 21.0 C
    Address 8B: Adaptive Cruise 2
       Part No SW: 4G0 907 107 B    HW: 4H0 907 107
       Component: BV-SG         H28 0034
       Serial number: 000040182202117
       Coding: 03C0BA1E1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 2517F3B63565D07FCDB-8070
    0046 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ACC_timeout]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:36
                        Voltage terminal 15: 11.2 V
                        Control Module temperature: 16.0 C
    0049 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Airbag_Airbag_01_System_error]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:39
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F17E671AD8CDF213-8064
    12585984 - Control module not coded
              U1013 00 [009] - -
              [Electronic Control Unit Malfunction]
                        Mileage: 167345 km
                        Date: 2018.12.15
                        Time: 00:15:44
    13697024 - Component Protection
              U1100 00 [009] - No Basic Setting
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
    15360256 - Component Protection
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
    12589824 - Data Set Implausible
              B2012 00 [009] -  -
              [Implausible Datase]
                        Reset counter: 71
                        Mileage: 167345 km
                        Date: 2018.12.15
                        Time: 00:15:44
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
              U1013 00 [009] - -
                        Mileage: 167345 km
                        Date: 2018.12.15
                        Time: 00:15:44
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.15
                        Time: 00:05:35
              B2012 00 [009] -  -
                        Reset counter: 71
                        Mileage: 167345 km
                        Date: 2018.12.15
                        Time: 00:15:44
    End----(Elapsed Time: 02:55, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
    Got you Verified. Moving this to Car Repair Support.
    Since you said you've got power for both sensors, how about the grounds?
    Nov 2018
    Norway
    then I finally got tested a little more.
    I do not know what happened, but I tried a new wire that I connected with the gateway and the controller to acc. then it worked. strange i think when i have checked the cables several times. but must check if the contact is secure between contact and device.
    but in the worst case, if contact is worn / damaged. how about can-bus and soldering? can one cut the wires and, for example, splice them after the firewall in the engine compartment?
    is not really geared up and tear the chairs to the floor to replace the entire cable as it is only incorrectly in contact.
    also adds new auto scan.
    bMonday,11,February,2019,19:16:53:19813
    Mileage: 167344km-103982mi   Repair Order: 11-02/19
              90
    VIN: WAUZZZ4G4BN017170   Mileage: 167344km-103982miles
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
       Revision: --H05---
       Coding: 000001
       Coding: 661300B80C
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Outside air temperature: 13.0 C
                        Temperature after evaporator: 10.32 C
    0276 - Engine Off Timer Performance
              P150A 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Voltage terminal 30: 11.17 V
       Coding: 0045F7
       Coding: 02562B
       Coding: 312B04
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7601010101
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 290FFF86597DF41FE93-807C
    6 Faults Found:
    34560 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [FAULT_CIM_TIMEOUT_SCU_01]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:49
                        Control Module temperature: 18 C
                        Voltage terminal 15: 12.863 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s
    95232 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_QEPBACC_FAIL]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
              [FAULT_ATP_IKA_ACTIVE]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
    87552 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FAULT_CIS_CONFIG_AAG]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:49
    89600 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FAULT_CIS_CONFIG_STARTSTOPP]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
    150016 - invalid data record
              B2005 00 [009] -  -
              [FAULT_BPC_NVM_DATA]
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:54
              [ATP Inconsistency]
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:52
       Coding: 0000FC
       ROD: EV_RBD4K.rod
       Coding: 4D3100
       Coding: 00CD073000
       Voltage stabilizer:
              U140B 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Voltage terminal 30: 11.2 V
                        Voltage terminal 15: 11.3 V
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 18
       Revision: AA001002
       Coding: 01
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
       Coding: 008003
       Coding: 0010107
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Write only channel
       Coding: 001F00
    Address 56: Radio
       Coding: 1020013
       Coding: 0A3205C000
              U1014 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
       Coding: 1100
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
       Coding: EA060000
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7601010101
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
              U1111 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:49
                        Voltage terminal 15: 12.903 V
                        Velocity_vehicle_reference: -0.00 m/s
              U1113 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Voltage terminal 15: 12.897 V
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
              U1014 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:49
              U1014 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
       ROD: EV_BC7.rod
              U1113 00 [009] - -
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:52
                        Voltage terminal 15: 11.1 V
                        Control Module temperature: 17.0 C
       ROD: EV_RGS_L.rod
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
       ROD: EV_RGS_R.rod
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
                        Reset counter: 71
                        Mileage: 167344 km
                        Date: 2018.12.17
                        Time: 00:05:48
    End----(Elapsed Time: 02:39, VBatt start/end: 11.2V/11.3V. VIgn 11.2V)-----
    [IMG][/IMG]
    Quote Originally Posted by arne_saether View Post
    Is it possible? Yes.
    Will it work? I'm nearly 100% confident that it will.
    Is it the right way to fix wiring? No, almost certainly not.
    Apr 2018
    ITALY
    I did a sloppy job for sure with CanBus in all my retrofits, multiple splices, used a twisted pair which is not really following factory specs. I never had a single problem. CanBus is way more robust than how they sell it.
    I am a professional sound engineer for a living, I know something about cables. you could have problems if the line was 50 meters long but with the lenghts involved in a car you'll be good even if wiring is not top notch.
    of course make sure the splices are well-made, be careful about cold soldering and make sure to know how to crimp if you do. and don't use two wires that are not twisted. any pair from a CAT5 patch cable (stranded wires) will do.
  6. Likes Uwe liked this post
    I agree. We like to sit in our offices at a proper desktop computer when developing and testing the software. So we run diagnostic CAN (which operates at the same 500 kbps as powertrain CAN inside the car) though many tens of meters of CAT5 cable, usually with several Female-to-Female RJ45 connectors splicing things together. Never a problem, except when we tried to run it all the way to a patch-panel in our server room and from there back to an office. So there is a limit to the distance you can run it, but it's pretty far, probably over 100 meters.
  8. Likes darkchina811, MartinsX liked this post
