Results 1 to 10 of 10
Thread: Permission on likes links
    Jun 2014
    Swansea, UK
    Really petty and unimportant I know, but if you get more than 5 likes on a post, it lists 5 of them by name and "x others":
    But if I click on the "others" link, rather than listing the likes it gives me this:
    Is that a known (and fixable) issue?
  2. Likes jyoung8607, Santos, _Val, Jef liked this post
  3. #2
    Lansdale, PA
    i need to find the permission setting. I've temporarily set the plugin to display all "likes" inline.
  4. Likes Mike@Gendan, Jef liked this post
  5. #3
    Don't take it personally Mike; even I can't see 'em all when there's more than five.
  6. Likes Mike@Gendan, Jef liked this post
  7. #4
    Jun 2014
    Swansea, UK
    Yeah, but it's a much rarer occurrence for me - the novelty hasn't worn off yet
  8. Likes Uwe, Zenerdiode, Eric, Jef liked this post
  9. #5
    Work around; go to your profile:
    e.g: https://forums.ross-tech.com/member....74-Mike-Gendan
    There, click on the right-most tab that's labelled "Post Thanks / Like" where you'll find a list.
  10. Likes Mike@Gendan, Andy, Jef liked this post
  11. #6
    Jun 2016
    Hello All and of course ( Sebastian, Uwe, jyoung8607,and Dana )
    Just a question about Post Thanks / Like.
    Mike@Gendan put a reaction at 05.51 AM
    See below
    Wait a minute.
    You have replaced the BCM on a Mk7 with one from a Mk7.5 (i.e. MY2017 or newer), and that's what you're having problems with?
    https://forums.ross-tech.com/showthr...diculous/page2
    I correct his wrong assumption at 05.59 AM
    No, I flashed my BCM to higher version, so the same BCM!
    What I do not really understand is that there are several people like the message writen by Mike@Gendan what is incorrect and corrected a few minutes later by me again.
    And that after a few hours by some people the still like!
    Sebastian 06.55 AM
    UWE 09.20 AM
    jyoung8607 11.15 AM
    Dana 12.45 AM
    In other words, a few minutes later I give a correction, and all these persons read the wrong assumption, but still like this message after varies from an hour to longer!
    I thought that liking would be meant if you had a good solution or gave a correct answer!
    Giving Like Post Thanks you can earn something with it ( money, extra appreciation, Moderator, senior )or is it a custom belongs to this site!! like on everthing what you want...
  12. #7
    Quote Originally Posted by barstanders View Post
    This will happen when people read a thread sequentially. They read a post and click Like before they have read anything further down the thread. When I got to reading that thread this morning, it already had 24 messages (half way into the third page). Moreover, the plug-in we are using does not allow a Like to be un-done.
  13. Likes Sebastian, Andy, Jef liked this post
  14. #8
    Jun 2016
    Uwe,
    Like Sabastian says You always have choices to ( like ore not to like )
    I would almost think they all work at ross tech or have an interest in it.
    No 1 of the 16 reactions from that thread from me me has been like!!!! ( This will happen when people read a thread sequentially ) of course..
    ( You can call out what you want as long as the ears are closed it has no effect!)
    Maybe that in the future you can adjust this bit of nonsense.
  15. #9
    Oct 2014
    Arandjelovac, Serbia
    Thread lock until further notice. Tnx for understanding.
  16. #10
    https://en.wikipedia.org/wiki/Law_of_holes
  17. Likes Andy, Jef, Dana, Mike@Gendan, Santos, Bruce, PetrolDave liked this post
