Results 1 to 10 of 13
Thread: Golf VII rear video camera - no video
    Verified VCDS User langyyyy's Avatar
    Jun 2014
    Slovakia
    Lightbulb Golf VII rear video camera - no video
    Hi members.
    I have Golf VII 2015 without RVC (5G6 827 469 F).
    I bought used RVC (5G0 827 469 F) with harness.
    First I install the RVC. Next connect all conectors. Then I connect two VIDEO wires to infotainment unit ( 5G0 035 819 A ) .....Black (pin1) - to unit PIN 12 and transparent wire (pin2) to unit PIN 6. Yellow wire to reverse light, red wire to 12V+.
    After this steps I used VAG to activate RVC .....5F channel - long coding - BYTE 19 BIT 4 (from 0 to 1).
    Turn ignition on , select reverse gear = RVC opened, display pop up camera view but without video. Just video option ....like brightness etc...
    So, everything is working well, just video is not working....
    Any ideas? thanks.
    Friday,25,October,2019,19:46:31:51262
    VCDS Version: 19.6.2.0
    VIN: WVWZZZAUZFP535298   License Plate: GOLFFF
    Mileage: 93143km-57876mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZFP535298   Mileage: 93143km-57876miles
    Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 AN    HW: 04L 907 309 E
       Component: R4 1,6L EDC   H22 7214
       Revision: 86H22---
       Coding: 01110012032415092000
       Shop #: WSC 00028 028 00208
       ASAM Dataset: EV_ECM16TDI01104L906021AN 002011
       ROD: EV_ECM16TDI01104L906021AN_VW37.rod
       VCID: 71EDE51FA06124C758-8024
       Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
       Component: ESC           H31 0471
       Revision: 00000000    Serial number: 62144000003545
       Coding: 04FA62A1242309710379060941CB2520462490C06082A4F300400078C002
       VCID: 458561CFC469D867D4-8010
       Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
       Component: Climatronic   H03 0907
       Revision: 00001K08
       Coding: 02020104202100011005000000101000
       VCID: 73E1EF17DA7D16D7AA-8026
       Air quality sensor:
    197377 - Temperature Sensor for Right Vent
              B1088 11 [009] - Short to Ground
                        Reset counter: 224
                        Mileage: 93143 km
                        Date: 2019.10.24
                        Time: 19:38:24
                        Voltage terminal 30: 11.4 V
                        Outside air temperature: 14.0 °C
              B10CD 00 [009] - -
                        Reset counter: 224
                        Mileage: 93143 km
                        Date: 2019.10.24
                        Time: 19:38:24
                        CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
                        CAN input signal(s) status-Back-up light: On
       Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
       Component: BCM PQ37BOSCH 028 0106
       Revision: --------    Serial number: 86580408140256
       Coding: 00000846C24100DB4BE44004001C07081000000000000000000000000000
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
       ROD: EV_BCMBOSCH_013.rod
       VCID: 79FDDD3FF8116C87E0-802C
       Component: WWS    140719  043 0551
       Serial number:         140726224229
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Component: G355_FeuchteS  H07 0002
       Serial number: 20821956
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0A0L40
       Shop #: WSC 00028 028 00062
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 418D75DFD041F447E8-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 708 14
       Serial number: 3576700000078AA0701S
       Subsystem 2 - Part No SW: -----------    HW: 480 000 708 14
       Serial number: 35867000000DFB11701Z
       Subsystem 3 - Part No SW: -----------    HW: 480 400 608 14
       Serial number: 3516502C516DB802B1EK
       Subsystem 4 - Part No SW: -----------    HW: 480 400 608 14
       Serial number: 3526502B116DB804A0CE
       Subsystem 5 - Part No SW: -----------    HW: 480 400 508 14
       Serial number: 3556502B916DB801418D
       Part No SW: 5Q0 953 521 EQ    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20140805400394
       Coding: 1604
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 0505A1CF84E9186794-8050
       Part No SW: 5G1 920 741     HW: 5G1 920 741
       Component: KOMBI         204 4270
       Coding: 07A4120023800008000828001400000000000000
       VCID: 64C39C4B6F93816F23-8030
       Part No SW: 5Q0 907 530 R    HW: 5Q0 907 530 K
       Component: GW MQB Low    210 2186
       Revision: --------    Serial number: 10081410801039
       Coding: 030000040B087300EF000248080F00010001050000000000000000000000
       ASAM Dataset: EV_GatewConti 011017
       ROD: EV_GatewConti_011.rod
       VCID: 408B70DBDB4BFD4FE7-8014
       Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 3104694103
       Part No SW: 5Q4 959 393 C    HW: 5Q4 959 393 B
       Component: TSG FS        009 0015
       Serial number: 0000112888350
       Coding: 003003208000020000001000
       Shop #: WSC 00028 028 00068
       VCID: 43817FD7CA5DE657FA-8016
       Serial number: 00000000000006268330
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 0103
       ROD: EV_SteerAssisMQB_010.rod
       Part No SW: 5Q4 959 392 C    HW: 5Q4 959 392 B
       Component: TSG BFS       009 0015
       Serial number: 0000113002689
       Coding: 003001208000020000801000
       VCID: 428F7AD3D547EF5FF1-8016
       Serial number: 00000000000006276538
       Coding: 090000
       Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
       Component: MU-S--ER      041 0421
       Serial number: V1C00708140444
       Coding: 02730200FF00000011110001000800001F0106940100010001
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 2759CB475E252A77C6-8072
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H60 0030
       Serial number: VWZ8Z9PS203E18
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 224
                        Mileage: 93143 km
                        Date: 2019.10.24
                        Time: 19:38:24
                        Voltage terminal 30: 11.9 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    End-------------------------(Elapsed Time: 03:26)--------------------------
    May 2014
    ^^^ hmm............a number of webpages that sell 5G0 827 469 F (i.e. HERE) indicate that it isn't compatible with Composition Media units with P/N 5G0 035 819 A- which unfortunately is the hex 5F module in your auto-scan!
    I guess you have confirmed the seller's advice - alas!
  3. Likes Uwe, langyyyy liked this post
    Jun 2014
    Slovakia
    Thank you for your answer... Do you know what OEM I need to use?
    Thank you
    Jan 2015
    Bosnia and Herzegovina
    5G0 035 819 A doesn't support lowline rvc, maybe high?
    5F that doesn't support rvc
    3Q0 035 819
    3Q0 035 819 A
    3Q0 035 819 B
    3Q0 035 820
    3Q0 035 820 A
    3Q0 035 820 B
    5G0 035 812
    5G0 035 819
    5G0 035 819 A
    5G0 035 819 B
  6. Likes langyyyy liked this post
    Jun 2014
    Slovakia
    What about change unit to the 5G0 035 824 A or 3Q0 035 824 C , 3Q0 035 824 A ? Its Composition Media too and its not in not compatibility list... what do you think? Or what unit will be for me the best?
    Jan 2015
    yes, that should work
    Jun 2014
    Slovakia
    After replace head unit i have on display not correct resolution and have some faults ....see autoscan
    Thursday,31,October,2019,12:24:17:51262
    Dealer/Shop Name: bekscrs
    Workshop Code: 135 31518 016521
    Mileage: 93263km-57950mi   Repair Order:
    VIN: WVWZZZAUZFP535298   Mileage: 93263km-57950miles
       Revision: 86H22---
       Revision: 00001K08
       Air quality sensor:
                        Reset counter: 228
                        Mileage: 93263 km
                        Date: 2019.10.30
                        Time: 12:20:02
                        Voltage terminal 30: 11.3 V
                        Outside air temperature: 12.0 °C
       Coding: 1604
              U1101 00 [009] - Active
                        Reset counter: 228
                        Mileage: 93263 km
                        Date: 2019.10.30
                        Time: 12:20:01
                        Supply voltage: Terminal 30: 11.7 V
                        Terminal 15: On
       Coding: 0103
       Coding: 090000
       Part No SW: 3Q0 035 824 A    HW: 3Q0 035 824 A
       Component: MU-S--ER      H24 0245
       Serial number: VWZAZ2S0123110
       Coding: 02730200FF00000011110001000800001F0106840100010001
       Shop #: WSC 31518 135 16521
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 2B51377742CD0E1722-807E
                        Reset counter: 228
                        Mileage: 93263 km
                        Date: 2019.10.30
                        Time: 12:20:01
                        Voltage terminal 30: 11.8 V
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 228
                        Mileage: 93263 km
                        Date: 2019.10.30
                        Time: 12:20:04
                        BAP-BAP_Function_ID: 02
    End-------------------------(Elapsed Time: 03:19)--------------------------
  10. #8
    Apr 2018
    ITALY
    Component Protection needs to be cleared by dealer.
    new headunit has different video resolution so you need a new display. I have two different for sale if you are interested.
  11. Likes Uwe, langyyyy liked this post
  12. #9
    Jun 2014
    Slovakia
    Thank you friend, It will work after display change and Cp remove? And what display OEM number is required ? Can use 3G0 919 605 B?
  13. #10
    Apr 2018
    ITALY
    my stock unit was 3Q0 035 824 B with display 3G0 919 605 B. I replaced the display with the facelift version, that's why I have it available for sale.
