- Joined
- Aug 3, 2014
- Messages
- 16
- Reaction score
- 5
- VCDS Serial number
- C?ID=221961
Hi everyone,
I'm seeing a few fault codes on my car 2008 VW Golf R32. I'll give a bit of background first.
About two months ago I had the steering rack replaced with a new one by a VW dealer.
Then about 3 weeks ago, I installed the MK6 reverse camera and installed a new Bluetooth unit and the MDI kit and disconnected the battery to do the installation & wiring/fuse. Upon reconnecting the battery, all the warning lights were lit up and did not go out. I freaked out, did a scan and saw all these error codes. I started doing research and apparently its normal for this to happen when disconnecting the battery and a simple drive would eliminate them. The steering felt quite heavy but then went back to normal as soon as the lights went out. I haven't had any issues while driving it.
Today I thought I'd give it a scan while I was activating voice control for the bluetooth unit. I'm getting the below:
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0004744
Shop #: WSC 01279 785 00200
VCID: 72EBC7C56DC094B169F-8027
Would this be because of the new steering rack, or have I fried the power steering module while reconnecting the battery? The steering feels fine.
Any ideas would be much appreciated.
Thanks.
Revision: 00H13001
Coding: 0004744
Thanks.
