Results 1 to 10 of 10
Thread: 2009 VW Tiguan tire size change
    Mar 2014
    The customer complaint is the speedo is off (a common complaint it seems with these vehicles). This one has had a tire change, from the stock 235/50/R18 to 235/55/R18. I'm unsure how to change the impulse counter coding in the cluster. Any help would be appreciated. Regards, Randy
    Lansdale, PA
    Please post an Auto-Scan from the vehicle.
    Under the instrument cluster coding, The parameter is usually listed as the "distance impulse".
    Mar 2014
    OK, thanks for the help:
    Auto scan:
    VCDS Version: Release 12.12.2 (x64)
    Data version: 20140212
    Unique Training Solutions
    Monday,17,March,2014,12:00:06:36970
    Chassis Type: AX (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 36 42 44 46 47 4F 52 53 55
              56 62 65 69 72 77
    VIN: WVGAV7AX3AW001325
    Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 DN    HW: 06J 906 026 DA
       Component: MED17.5 TFSI 2,0    4668
       Revision: AAH10---    Serial number:
       Coding: 0423010A19070160
       Shop #: WSC 01324 020 00200
       VCID: 79F3738B304938D6DC9-802C
    7 Faults Found:
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 000 - Implausible Signal - Intermittent
                        Mileage: 105778 km
                        Date: 2050.14.04
                        Time: 16:32:19
                        RPM: 2398 /min
                        Load: 27.4 %
                        Speed: 103.0 km/h
                        Temperature: 95.0C
                        Temperature: 18.0C
                        Absolute Pres.: 960.0 mbar
    001378 - System Voltage
                   P0562 - 000 - Too Low - Intermittent
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:05:57
                        Temperature: 63.0C
                        Temperature: 39.0C
                        Absolute Pres.: 980.0 mbar
                   P0300 - 000 -  - Intermittent
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 11:08:23
                        RPM: 754 /min
                        Load: 27.0 %
                        Temperature: 49.0C
                        Temperature: 29.0C
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 11:08:32
                        RPM: 784 /min
                        Load: 25.5 %
                        Temperature: 51.0C
                        Temperature: 30.0C
    000771 - Cylinder 3
                   P0303 - 000 - Misfire Detected - Intermittent
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 11:08:32
                        RPM: 784 /min
                        Load: 25.5 %
                        Temperature: 51.0C
                        Temperature: 30.0C
    000772 - Cylinder 4
                   P0304 - 000 - Misfire Detected - Intermittent
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 11:08:32
                        RPM: 784 /min
                        Load: 25.5 %
                        Temperature: 51.0C
                        Temperature: 30.0C
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected - Intermittent
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 11:08:32
                        RPM: 784 /min
                        Load: 25.5 %
                        Temperature: 51.0C
                        Temperature: 30.0C
    Address 02: Auto Trans        Labels: 09G-927-750.lbl
       Part No SW: 09G 927 750 KN    HW: 09G 927 750 KN
       Component: AQ 250 6F           1590
       Revision: 00H76000    Serial number:
       Coding: 0000840
       VCID: 87178573F6BDDE265AD-80D2
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
       Component: J104    C2 450 V2   0008
       Revision: --H13---    Serial number: 00000002301350
       Coding: 0002329
       VCID: 3973B38B70C9F8D69C9-806C
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 133 1213
       Revision: 00133024    Serial number: 00000000000000
       VCID: 6DDB57DB74019476401-8038
       Part No SW: 5K0 937 087 C    HW: 5K0 937 087 C
       Component: BCM PQ35 H+   008 3019
       Revision: BL008001
       Coding: 6D580A1B98232EC48088008534000D0441555186536D8D605C8000000000
       VCID: 356BBFBB9CD11CB6781-8060
       Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 13100  012 0203
       Coding: 009795
       Component: RLS 081009 05  54  0402
       Coding: 03304D
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:03:48
                        Voltage: 9.10 V
    00532 - Supply Voltage B+
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:05:47
                        Voltage: 7.20 V
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 09:43:41
                        Voltage: 11.55 V
    00927 - Terminal 30 (Right)
                        Fault Status: 00101011
                        Reset counter: 4
                        Mileage: 105182 km
                        Date: 2049.14.30
                        Time: 08:20:03
                            Term 15 Off
                        Voltage: 12.70 V
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:04:41
                        Voltage: 8.65 V
       Part No SW: 5N0 959 655 K    HW: 5N0 959 655 K
       Component: J234__200 VW10 HI   1916
       Revision: 20013000    Serial number: 003E3PLVLGBG
       Coding: 0012336
       VCID: 458BCF7B0C318C36E81-8010
       Subsystem 1 - Part No: 5N0 959 339 A
       Component: BF-Gewichtsens. 001 0004
       Subsystem 2 - Serial number: 0000000000436L
       Subsystem 3 - Serial number: 0026.08.090000100000660019†63
       Subsystem 4 - Serial number: 660019†6332MTS625272719 †63
       Subsystem 5 - Serial number: 72719 †6342MTS605642719 †63
       Subsystem 6 - Serial number: 42719 †6351HTS6OM8N56KR †63
       Subsystem 7 - Serial number: N56KR †6361HTS6L8AN56KR †63
       Subsystem 8 - Serial number: N56KR †63727TS68FA709KR †63
       Subsystem 9 - Serial number: 709KR †63827TS6OMN609KJ
       Subsystem 10 - Serial number: 609KJ
                        Reset counter: 36
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:04:10
    03551 - Functional Restriction of Seat Occupied Recognition
                000 - - - Intermittent - MIL ON
                        Fault Status: 10100000
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:04:10
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Component: J0527           056 0111
       Coding: 0001332
       VCID: 7AF16C87354F33CED53-802F
       Component: E0221           002 0030
       Part No SW: 5N0 920 971 A    HW: 5N0 920 971 A
       Component: KOMBI         H05 0206
       Coding: 210F00
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 30658EAF6BB3399E2B7-8065
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
       Component: J533  Gateway   H06 0111
       Revision:   H06 01    Serial number: 300909F1001549
       Coding: FD81FF47101603006002
       Shop #: WSC 07343 444 100065
       VCID: 6AD15CC745EF834E253-803F
                        Reset counter: 36
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:04:49
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223T63ZC04
       VCID: FEF9E097A9679FEE69B-80AB
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:05:36
       Component: IMMO          H05 0206
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
       Component: MEM-FS        H04 0032
       Revision: AA000000    Serial number: 00001001356839
       Coding: 20581300000044440011
       VCID: 3875B68F8BC3E1DE637-806D
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:05:38
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
       Component: Tuer-SG         008 2005
       Coding: 0005567
       VCID: 356BBFBB5CD11CB6781-8060
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.163 0703
       Revision: 1AH03273    Serial number: 00092430239502
       Coding: 0000258
       VCID: 3A71AC8775CFF3CE953-806F
    Address 47: Sound System (R12)       Labels: None
       Part No HW: 5K0 035 456
       Component: KonzernAmp 8K H06 0340
       Revision: --------    Serial number: BP218198624897
       VCID: 55AB1F3B34913CB6981-8000
       Part No SW: 1K0 907 532     HW: 1K0 907 951
       Component: EZE_2         H06 0111
       Coding: 050B0500
       VCID: E6C9A8F711F7272E81B-80B3
       Component: J245EE20SKB13  H01 0220
       Component: J394EE20SKB13  H01 0220
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
       Coding: 0005566
       VCID: 3669B8B741D717AE71B-8063
       Part No SW: 5N0 907 801 E    HW: 5N0 907 801 E
       Component: J540 EPB3  VW-13948 0008
       Revision:   H10       Serial number: 00000000059863
       Coding: 0000057
       VCID: 31638BABA8B93096249-8064
                        Reset counter: 252
                        Mileage: 105981 km
                        Voltage: 7.30 V
                        Count: 50
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Reset counter: 252
                        Mileage: 105981 km
                        Voltage: 9.20 V
                        Count: 52
                        Hex Value: 0x1170
                        Hex Value: 0x0008
                        Hex Value: 0x0101
    Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
       Component: AFS-Steuergeraet    0142
       Coding: 1324230
       VCID: 346D82BF57AB05BE4FF-8061
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000020
       Subsystem 2 - Part No: 7L6 941 329 B
       Coding: 00000020
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0034
       Revision: -----19S    Serial number: VWZ4Z7J1120748
       Coding: 0501000001
       VCID: 61C33BEB78D9C016F49-8034
                        Reset counter: 133
                        Mileage: 102650 km
                        Date: 2049.14.01
                        Time: 17:55:21
                        Reset counter: 37
                        Date: 2050.14.07
                        Time: 10:04:31
       Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
       Component: Tuer-SG         007 2001
       Coding: 0001168
       Shop #: WSC 01324 020 1012552
       VCID: 3777B5B346DDEEA66AD-8062
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
       Component: RDK           008 0817
       Coding: 018705
    02801 - Hard Warning
                        Mileage: 101381 km
                        Date: 2048.14.14
                        Time: 11:06:25
                        Text: 3448343303
                        Pressure: 1.90 bar
                        Pressure: 2.40 bar
                        Temperature: -6.0C
                        Text: 00
                        Speed: 77.0 km/h
    02903 - Hard Warning 2
                        Mileage: 101387 km
                        Date: 2048.14.14
                        Time: 12:50:08
                        Text: 3448343309
                        Pressure: 0.10 bar
                        Pressure: 2.40 bar
                        Temperature: 0.0C
                        Text: A0
    Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
       Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
       Component: Anhaenger     H08 0080
       Revision: 3A002002    Serial number: 00000120161450
       Coding: 0200000100000000
       VCID: 2F678DD37E8D266632D-807A
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:05:50
       Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
       Coding: 0001168
       VCID: 3875B68F4BC3E1DE637-806D
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
       Component: FSE_2P8x        H35 0170
       Revision: 00000000    Serial number: 00000005096572
       Coding: 0011070
                        Reset counter: 37
                        Mileage: 105981 km
                        Date: 2050.14.07
                        Time: 10:04:49
    Yes the distance impulse is in the cluster coding. I will upload an image in a few
    Last edited by Uwe; 03-17-2014 at 11:44 AM. Reason: Wrapped CODE tags around Auto-Scan
    Mar 2014
    Here's a pic of the cluster coding:
    http://imgur.com/PLpR5D1
    Randy
    Lansdale, PA
    click the drop down for distance impulse and select a different option.
    The distance impulse values are defined within the control module. You cannot fine tune further than whats defined by the impulse numbers.
    This is a limitation of the control module firmware, not VCDS. Dealer scan-tools will have to work within the same parameters.
    Mar 2014
    OK, pick from one of these? How do you know which one?
    http://imgur.com/sxxWowm
    Randy
  7. #7
    Lansdale, PA
    Quote Originally Posted by RDillman View Post
    Randy
    You will need to select a different impulse, drive the car and compare to the previous readings.
  8. #8
    You don't. VW didn't put this stuff in there so people could install some random sized tires. Sometimes there will happen to be one that's close, other times there won't, so it's going to be trial-and-error.
    Mar 2014
    Thanks for the replys Uwe and Santos. I drove the vehicle at 60 mph with each option and the one it came in with matched the best. Go figure. Thanks again for the support!! Randy
  10. #10
    United States
    Thanks for the update Randy. I have a 2012 Tiguan and it came with ridiculous 19" factory wheels. We went with the 4-motion for a reason (not to look cool - but to get around in any amount of snow that mother nature wants to throw at us) so I kept the 19" wheels and bought a used set of 2010 M.Y. 16" take-offs from a guy on the VW Vortex and tossed a set of new grabbers on them.
    I will say this much, going from the proper 19" wheels to the tiny 16" has it advantages and disadvantages. I don't know if your customer wanted to save a few bucks on tires .. or if they were looking for a softer ride but if it was the ride I'd suggest telling them to ride out the incorrect speedometer until those tires are spent and keep an eye out for used 17" Tiggy wheels. (Obviously, with the proper 17" tire size to eliminate this entire VSS issue.)
