Results 1 to 4 of 4
Thread: Audi A7 None start - J393 convenience module help needed
    Dec 2018
    Hi all, I have an audi A7, that is dead. No start or authorisation is being given to the steering lock, I have found no power on row of the fuses, which is controlled by 15 terminal relay, the earth request is not being sent from the convenience module. I have bypassed to get dash lights back and the gearbox lever surround lighting is now functioning, but the car still will not start on a push start button and the electric steering lock will not deactivate and electric windows will not shut.
    Can a second hand convenience module be programmed with VCDs or do i need a new unit?
    Anyone got any other ideas?
    Please see attached log.
    Monday,04,February,2019,18:27:59:63423
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ4G5CN069926   License Plate: A7SKU
    Mileage: 143042km-88882mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 15 16 17 19 30 3B 42 44 46 52 53 55 5F 62
              6D 72
    VIN: WAUZZZ4G5CN069926   Mileage: 143042km-88882miles
    03-ABS Brakes -- Status: Cannot be reached 0100
    04-Steering Angle -- Status: Cannot be reached 0100
    15-Airbags -- Status: Cannot be reached 0100
    55-Headlight Range -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 311 G    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0003
       Revision: 53H37---
       Coding: 1A034012040401020800
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907311G 001003
       ROD: EV_ECM30TDI0114G0907311G.rod
       VCID: 271E27AD5E1AAB72BC-8072
    5618 - Engine Off Timer Performance
              P150A 00 [096] - -
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 4G1 927 155 F    HW: 0AW 927 156 K
       Component: 0AW 30TDI RdW H04 0002
       Revision: --H04---    Serial number: 0000000248
       Coding: 000001
       ASAM Dataset: EV_TCMVL381 A02428
       ROD: EV_TCMVL381.rod
       VCID: 2F2ECF8D76EAF33274-807A
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 07A18703E085E1C0DB00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 3424C0E19FCCD0EA09-8060
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Coding: 01BA3000000000000000
       VCID: 76A03AE9C13082FAF7-8022
                        Fault Status: 00101101
                        Reset counter: 23
                        Mileage: 143042 km
                        Date: 2019.02.03
                        Time: 07:55:09
    02811 - Control Module for Electronic Steering Column Lock (J764)
                        Reset counter: 239
                        Mileage: 143042 km
                        Date: 2019.02.03
                        Time: 07:55:09
    01128 - Immobilizer Pickup Coil (D2)
                        Reset counter: 239
                        Mileage: 143042 km
                        Date: 2019.02.03
                        Time: 00:03:17
       Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
       Component: KLIMA 2 ZONEN H10 0062
       Serial number: 19101100040289
       Coding: 3623000820
       ASAM Dataset: EV_AirCondiBasisUDS 002037
       VCID: 230633BD2A224752E0-8076
       Part No SW: 4H0 907 063 BE    HW: 4H0 907 063 E
       Component: BCM1 2.0      H12 0100
       Revision: 19012002    Serial number: 00000001251426
       Coding: 2600201040349FE00181008000001D0C0F9DC30A27090101000004602100
       VCID: 6C9418818F7C482A11-8038
       Component: WWS57X 110909  H35 0051
       Serial number:         110922024832
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11721414
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 12 10 2011  00000172
    Address 15: Airbags
       Part No SW: 4H0 953 568 E    HW: 4H0 953 568 E
       Revision: --------    Serial number: 90372KJ7001VD
       Coding: 000030
       VCID: 3522FDE59CB6C9E23E-8060
       Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
       Component: E221 - MFL  H09 0009
       Serial number: 29 08 2011  33123505
       Part No SW: 4G8 920 950 G    HW: 4G8 920 950 G
       Component: MDieGb        H34 0119
       Revision: 25450105    Serial number: 658131011593013
       Coding: 338600020B032600010100
       ASAM Dataset: EV_RBC7KMID 004040
       ROD: EV_RBC7KMID.rod
       VCID: 3326C3FD9AC2D7D210-8066
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000275800
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 3228C6F965D8DEDA1B-8066
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650731333
       Voltage stabilizer:
       Serial number: 11292003077021200181
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000019853
       Coding: 01010101000000000001000203
       VCID: 648470A167AC006A59-8030
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA3200NK760
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6B961B9D82724F1218-803E
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0022174833
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0161122863
       Coding: 013B062220B9BC0083200A04000100000000000000000000000000000000
       Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA103392000000593175
    Address 52: Door Elect, Pass.
       Revision: --------    Serial number: 00000000155673
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A18DE994D08961AA3-807E
    Address 55: Headlight Range
       Part No SW: 4G0 035 193 C    HW: 4G0 035 193 C
       Component: RMC Cnct Nav  H51 0717
       Coding: 0101040001415947002B040301010000010001
       VCID: 230633BD22224752E0-8076
       Subsystem 1 - Part No: 8X0 919 884 C
       Component: P11-50-10.06  1006
       Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464HY0B0061757
       Subsystem 3 - Part No SW: 4G2 919 610     HW: 4G2 919 610
       Component: E380 BDT C7  H08 0203
       Serial number: 90349KJC000G9
    03405 - Bass Loudspeaker
                        Fault Status: 00101011
                        Reset counter: 24
                        Mileage: 143042 km
                        Date: 2019.01.31
                        Time: 13:18:07
                        Voltage: 11.80 V
    Address 62: Door, Rear Left
       Part No SW: 4G8 959 107 N    HW: 4G8 959 107 F
       Component: HDSG-Modul    H13 0039
       Revision: 11013001    Serial number: 271100362
       Coding: 0A3305C002
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       VCID: 40CC9C31DB747C4A9D-8014
    Address 72: Door, Rear Right
    End----(Elapsed Time: 01:20, VBatt start/end: 11.7V/11.7V. VIgn 0.1V)------
    Since it has the Kessy module integrated in it, I would have to say: No, the only way to replace that module is on-line.
  3. Likes Dana liked this post
    I could do a data transfer by mail of used or new modules but you are far away.
    Take kessy apart and post pictures.
    Overlay test the D2 for coil & transponder to kessy directly.
  5. Likes Dana liked this post
  6. #4
    United States
    I'm posting here in response to the email. I absolutely agree with the above advice and a new (unused) BCM2 module (AW 05 and 46) would need to matched online dealer style if faulty but rebooting it and inspecting for internal problems can't hurt.
  7. Likes Uwe, Jack@European_Parts liked this post
