I have a very strange issue with my Superb coding. I can`t find any (even similair) issue like this in the internet.
Situation:
I coded in 09 long coding: autolock/unlock, mirror dip on revers and in adaptations 5-blinker.
Coding accepted. Start car and drive. All above is working. Stop engine.
Come again. Start engine. None of above is working. Check bits in long codding - all as before, means marked to activate functions. Check adaptation and there is autolock/unlcok OFF (was ON before), blinkers still 5.
I go to long coding and change any bit, even not corresponding with mentioned function or change bit from 0 to 1 and then back 1 to 0.
Then I start the car and autolock/unlock, mirror dip on reverse and 5-blinker are working. Stop car. Start car and again not working despite coding is still fine.
Every time this 3 function are working or not together. If I deactivate lock/unclok in long coding, mirror dip and 5 blink works also until second engine start.
Comming/Leaving home function stays activated all the time. However I changed leaving time from 10 to 30seconds and it is working only until next engine restart. After restart it is working with default 10 second (despite I still see 30 in adaptations)
Coding in other modules are maintained (i.e HHC)
There is no fault codes.
I had idea that maybe I have coded maxidot which I don`t have and computer is reading maxidot commands which don`t exits, but I didn`t find anything about that.
Could you please give me any advice? Any idea will be very helpful.
Address 01: Engine
Coding: 0200071
Address 03: ABS Brakes
coding: 843D401609230000210D02ED901C00412900
Address 08: Auto HVAC
Coding:0000000000
Address 09: Cent. Elect.
Coding: 46990AB8B82508C0401000841100812407781BA8432081605C4040000000
Wischer 02090
Coding: 00D7B7
RLS 100909 05
Coding: 0314ED
Address 10: Park
Coding: 100004
Address 15: Airbags
Coding: 0016965
Address 16: Steering wheel
Coding: 0000003
Address 17: Instruments
Coding: 110B00
Address 19: CAN Gateway
Coding: E9A07F06000202003302
Address 42: Driver door
Coding: 011C02208000121002
Address 52: Passenger door
Coding: 011F0220DC00121002
Address 56: Radio
Coding: 0D0004000004
Address 62: Door rear left
Coding: 010C00200000221002
Address 72: Door rear right
Situation:
Address 01: Engine
Coding: 0200071
Coding:0000000000
Wischer 02090
Coding: 00D7B7
RLS 100909 05
Coding: 0314ED
Address 10: Park
Coding: 100004
Address 15: Airbags
Coding: 0016965
Coding: 0000003
Coding: 110B00
Address 56: Radio
