Results 1 to 6 of 6
Thread: Seat Alhambra problem resetting steering angle sensor
    Dec 2018
    Trying to reset the Steering Angle Sensor (G85) on a Seat Alhambra, im entering code 41068 and its saying its not ok (incorrect) Anyone came across this problem before any advice on how to resolve much appreciated!
    HQ
    Aaron,
    You need to post a FULL Auto-Scan so we can see what we are dealing with.
    https://forums.ross-tech.com/showthr...t-an-Auto-Scan
    Once you post the Auto-Scan, then we can start providing assistance.
    Regards.
    Jef
  3. Likes Uwe, Dana liked this post
    United States
    The scan in this thread matches the email we have so it should be the same vehicle as the Lost ABS coding:
    Quote Originally Posted by aaron carter View Post
    hi i have a seat Alhambra that the abs module soft code has been deleted here is log can any one help with correct coding please
    Monday,04,February,2019,15:48:59:63423
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: VSSZZZ7NZDV508771   License Plate: NV62KFE
    Mileage: 74120km-46056mi   Repair Order:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 4C 52 53 56 61 62
              72 77
    VIN: VSSZZZ7NZDV508771   Mileage: 74120km-46056miles
    4C-Tire Pressure II -- Status: Cannot be reached 1100
       Part No SW: 03L 906 018 HL    HW: 03L 906 018 M
       Component: R4 2.0l TDI   H27 9981
       Revision: 44H27---    Serial number:
       Coding: 0019001A040501080000
       Shop #: WSC 00000 210 00000
       ASAM Dataset: EV_ECM20TDI01103L906018HL 003014
       ROD: EV_ECM20TDI01103L906018F.rod
       VCID: 7BB62BDDF212DF9288-802E
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 R    HW: 7N0 614 109 R
       Component: J104   C3 450M VDED 0023
       Revision: --H07---    Serial number: 00000006274869
       Coding: 0000000
       Shop #: WSC 00020 790 00000
       VCID: 3C34E8C17F9C18AAC1-8068
                        Fault Frequency: 22
                        Reset counter: 237
                        Mileage: 74119 km
                        Date: 2013.06.27
                        Time: 11:33:40
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.75 V
                        Bin. Bits: 00011110
                        Count: 248
                        Hex Value: 0x0002
                        Reset counter: 22
                        Mileage: 74119 km
                        Date: 2013.06.27
                        Time: 11:33:49
                        Speed: 8.0 km/h
                        Hex Value: 0x0000
                        Voltage: 14.75 V
                        Bin. Bits: 00011110
                        Count: 191
                        Hex Value: 0x0000
                        Fault Frequency: 13
                        Reset counter: 237
                        Mileage: 74125 km
                        Date: 2013.06.27
                        Time: 15:27:20
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011110
                        Count: 215
                        Hex Value: 0x0000
       Part No SW: 7N0 907 044 E    HW: 7N0 907 044 E
       Component: Clima-Sharan  H01 0202
       Revision: 00001K03
       Coding: 0210004549
       Shop #: WSC 00020 999 00000
       VCID: 3228C6F965D8DEDA1B-8066
       Slave 1:
       Subsystem 1 - Part No SW: 7N0 907 049 B    HW: 7N0 907 049 B
       Component: KBT-H  004 0102
       Serial number: 20120927000000093214
       Part No SW: 5K0 937 084 H    HW: 5K0 937 084 H
       Component: BCM PQ35 B    021 0068
       Revision: BA021001
       Coding: 40180A3B8125F1C0408800C01000006443019288424D29626480872000C1
       VCID: 373EF7ED86BA3BF22C-8062
       Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    120522  31  0032
       Serial number:         120612045919
       Coding: 004DBD
       Component: RLFS  024 0042
       Serial number: Y12M10D05H17M25S35S4
       Coding: DD0842
       Subsystem 3 - Part No: 7N0 951 171 A
       Component: DWA-Sensor 00  002 0206
                        Reset counter: 22
                        Mileage: 74125 km
                        Date: 2013.06.27
                        Time: 15:36:54
                            Term 15 Off
                        Voltage: 12.30 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 237
                        Mileage: 74119 km
                        Date: 2013.06.27
                        Time: 11:27:38
                        Voltage: 12.85 V
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 7N0 919 475 A    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0012
       Revision: --------    Serial number: 28261227600294
       Coding: 108002
       ASAM Dataset: EV_EPHVA18VW4280000 001005
       ROD: EV_EPHVA18VW4280000.rod
       VCID: 393AF1D5B8AE2D82DA-806C
       Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
       Component: VW10Airbag00F H10 0014
       Serial number: 003LGPLNR0DK
       Coding: 003046
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3FCE9FCDA68A03B2E4-806A
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS6059A4E5169D0
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS6097B9E1169D$
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS60C72BE5169D/
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60B7E8E1169D2
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS6089648F16DDY
       Part No SW: 5K0 953 521 BM    HW: 5K0 953 569 D
       Revision: FF010041    Serial number: 20120613302097
       Coding: 108A040000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 78BC34D1C324F48AE5-802C
    226827 - Turn Signal Switch
              B1144 13 [009] - Open Circuit
                        Reset counter: 237
                        Time: 00:00:00
    227339 - Windshield Wiper Switch
              B1145 13 [009] - Open Circuit
                        Reset counter: 237
                        Time: 00:00:00
              B1149 13 [009] - Open Circuit
                        Reset counter: 237
                        Time: 00:00:00
    365080 - Controls in Steering Wheel
                        Reset counter: 237
                        Mileage: 74125 km
                        Date: 2019.02.04
                        Time: 15:36:56
       Part No SW: 7N5 920 970 G    HW: 7N5 920 970 G
       Coding: 441F01
       VCID: 3C34E8C1B79C18AAC1-8068
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                        Reset counter: 22
                        Mileage: 74125 km
                        Date: 2019.02.04
                        Time: 15:36:51
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 E
       Component: Zuheizer        051 2940
       Revision: 00051000    Serial number: 09024297000000
       Coding: 0000041
       VCID: 3620FAE941B0C2FA37-8062
       Part No SW: 7N0 907 530 AC    HW: 7N0 907 530 AC
       Component: J533  Gateway H48 1633
       Revision:   H48       Serial number: 300912F1001589
       Coding: 468203
       VCID: 71AA09F5A85EA5C222-8024
                        Fault Status: 00110100
                        Reset counter: 21
                        Mileage: 74125 km
                        Date: 2013.06.27
                        Time: 15:36:53
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 237
                        Mileage: 74125 km
                        Date: 2013.06.27
                        Time: 15:27:33
       VCID: 6A981E998D88561A63-803E
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 F    HW: 7N0 959 793 F
       Component: TSG FA        H02 0553
       Revision:             Serial number: 0000040615577
       Coding: 011006208001411011
       VCID: 45C28D25CC565962AE-8010
       Part No: 7N0 909 144 P
       Component: EPS_ZFLS Kl. 272    3305
       Revision: 00H21000
       VCID: 40CC9C3113747C4A9D-8014
                        Reset counter: 22
                        Mileage: 74125 km
                        Date: 2013.06.27
                        Time: 11:45:07
                        Battery Volts: 14.9 V
                            DU
                        Temperature: 28.0°C
                        Count: 5
                        Steering Angle: -2.89°
                        Count: 1
                            SteerAng Init
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 F    HW: 7N0 959 792 F
       Component: TSG BF        H02 0553
       Revision:             Serial number: 0000040679323
       Coding: 011004208001411011
       VCID: 44C49021C76C606AB9-8010
       Revision:   H19       Serial number: 00000000482257
       Coding: 0024167
       Part No SW: 7N5 035 186 B    HW: 7N5 035 186 B
       Component: Radio RCD310  042 0082
       Revision: 01000001    Serial number: SEZ1Z2M4539502
       Coding: 05000400040024
       VCID: 3326C3FD92C2D7D210-8066
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AC
       Component: Batt.regelung H48 1633
       Coding: 030F1859
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900318226
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 G    HW: 7N0 959 794 G
       Component: TSG HL        H03 0553
       Revision:             Serial number: 0000041374161
       Coding: 010004200001411001
       VCID: 47DE872DF65A4B725C-8012
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H03 0553
       Revision:             Serial number: 0000041193446
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663519706
       Coding: 0A00000000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A38EED9BDA8269AD3-806E
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.2V/12.1V)-----------
    The repair history may shed light on both issues but do try the 03 coding and Basic settings suggested by NEtech if you haven't already.
    I believe someone either replaced the 16-Steering wheel module or completed repairs in that area. Although you may want to change the 16 coding to 1082040000 if it doesn't have the PPT telephone button I don't believe the problem is coding specific. Instead, I would check the connections to the stalks with electrical faults in addition to the MFSW slave module inside the steering wheel.
  6. #4
    Dec 2018
    Thanks for reply
    steering wheel module has been replaced and we have now re coded abs module but cant get steering angle to calibrate.We will have a look again at terminals tomorrow as another garage fitted steering wheel module but is there no instructions for latter vehicles
  7. Likes Dana, Jack@European_Parts liked this post
  8. #5
    United States
    Thanks for the additional info. Based on 00778 - Steering Angle Sensor (G85) - "Implausible Signal" do make sure G85 isn't reading 360° when straight per the MVBs in 03 before you remove the steering wheel. If it happens to be one full turn out that may explain the Implausible Signal and would be far easier to correct when the wheel is removed the first time (so you don't have to take it apart twice).
    G85 is adapted in address 03 instead of 16: http://wiki.ross-tech.com/wiki/index...ke_Electronics
  9. Likes Jack@European_Parts, Uwe liked this post
  10. #6
    Dec 2018
    Hi steering angle is straight and showing 0 degrees and calibrated fine in 3 abs but think coding issue in 16 steering module how do you code the long codeas I'm sure the coding boxes was greyed out .
    Can't clear steering wheel light which is showing 44 steering assist not calibrated and 4 codes in 16 steering module for not seeing indicators ,cruise, wipers.
