hi i have a seat Alhambra that the abs module soft code has been deleted here is log can any one help with correct coding please
Monday,04,February,2019,15:48:59:63423
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
VIN: VSSZZZ7NZDV508771 License Plate: NV62KFE
Mileage: 74120km-46056mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 4C 52 53 56 61 62
72 77
VIN: VSSZZZ7NZDV508771 Mileage: 74120km-46056miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HL HW: 03L 906 018 M
Component: R4 2.0l TDI H27 9981
Revision: 44H27--- Serial number:
Coding: 0019001A040501080000
Shop #: WSC 00000 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018HL 003014
ROD: EV_ECM20TDI01103L906018F.rod
VCID: 7BB62BDDF212DF9288-802E
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 R HW: 7N0 614 109 R
Component: J104 C3 450M VDED 0023
Revision: --H07--- Serial number: 00000006274869
Coding: 0000000
Shop #: WSC 00020 790 00000
VCID: 3C34E8C17F9C18AAC1-8068
Fault Frequency: 22
Reset counter: 237
Mileage: 74119 km
Date: 2013.06.27
Time: 11:33:40
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 14.75 V
Bin. Bits: 00011110
Count: 248
Hex Value: 0x0002
Reset counter: 22
Mileage: 74119 km
Date: 2013.06.27
Time: 11:33:49
Speed: 8.0 km/h
Hex Value: 0x0000
Voltage: 14.75 V
Bin. Bits: 00011110
Count: 191
Hex Value: 0x0000
Fault Frequency: 13
Reset counter: 237
Mileage: 74125 km
Date: 2013.06.27
Time: 15:27:20
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00011110
Count: 215
Hex Value: 0x0000
Part No SW: 7N0 907 044 E HW: 7N0 907 044 E
Component: Clima-Sharan H01 0202
Revision: 00001K03
Coding: 0210004549
Shop #: WSC 00020 999 00000
VCID: 3228C6F965D8DEDA1B-8066
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 B HW: 7N0 907 049 B
Component: KBT-H 004 0102
Serial number: 20120927000000093214
Part No SW: 5K0 937 084 H HW: 5K0 937 084 H
Component: BCM PQ35 B 021 0068
Revision: BA021001
Coding: 40180A3B8125F1C0408800C01000006443019288424D29626480872000C1
VCID: 373EF7ED86BA3BF22C-8062
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120522 31 0032
Serial number: 120612045919
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y12M10D05H17M25S35S4
Coding: DD0842
Subsystem 3 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Reset counter: 22
Mileage: 74125 km
Date: 2013.06.27
Time: 15:36:54
Term 15 Off
Voltage: 12.30 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 237
Mileage: 74119 km
Date: 2013.06.27
Time: 11:27:38
Voltage: 12.85 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: -------- Serial number: 28261227600294
Coding: 108002
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 393AF1D5B8AE2D82DA-806C
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00F H10 0014
Serial number: 003LGPLNR0DK
Coding: 003046
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3FCE9FCDA68A03B2E4-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS6059A4E5169D0
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS6097B9E1169D$
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60C72BE5169D/
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60B7E8E1169D2
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS6089648F16DDY
Part No SW: 5K0 953 521 BM HW: 5K0 953 569 D
Revision: FF010041 Serial number: 20120613302097
Coding: 108A040000
ROD: EV_SMLSNGVOLWS.rod
VCID: 78BC34D1C324F48AE5-802C
226827 - Turn Signal Switch
B1144 13 [009] - Open Circuit
Reset counter: 237
Time: 00:00:00
227339 - Windshield Wiper Switch
B1145 13 [009] - Open Circuit
Reset counter: 237
Time: 00:00:00
B1149 13 [009] - Open Circuit
Reset counter: 237
Time: 00:00:00
365080 - Controls in Steering Wheel
Reset counter: 237
Mileage: 74125 km
Date: 2019.02.04
Time: 15:36:56
Part No SW: 7N5 920 970 G HW: 7N5 920 970 G
Component: KOMBI H05 0705
Coding: 441F01
VCID: 3C34E8C1B79C18AAC1-8068
12718592 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Lenksäulenelektronik: keine Kommunikation]
Reset counter: 22
Mileage: 74125 km
Date: 2019.02.04
Time: 15:36:51
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 E
Component: Zuheizer 051 2940
Revision: 00051000 Serial number: 09024297000000
Coding: 0000041
VCID: 3620FAE941B0C2FA37-8062
Part No SW: 7N0 907 530 AC HW: 7N0 907 530 AC
Component: J533 Gateway H48 1633
Revision: H48 Serial number: 300912F1001589
Coding: 468203
VCID: 71AA09F5A85EA5C222-8024
Fault Status: 00110100
Reset counter: 21
Mileage: 74125 km
Date: 2013.06.27
Time: 15:36:53
03109 - Tire Pressure Monitoring Control Module 2 (J793)
Reset counter: 237
Mileage: 74125 km
Date: 2013.06.27
Time: 15:27:33
Component: IMMO H05 0705
VCID: 6A981E998D88561A63-803E
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 F HW: 7N0 959 793 F
Component: TSG FA H02 0553
Revision: Serial number: 0000040615577
Coding: 011006208001411011
VCID: 45C28D25CC565962AE-8010
Part No: 7N0 909 144 P
Component: EPS_ZFLS Kl. 272 3305
Revision: 00H21000
VCID: 40CC9C3113747C4A9D-8014
Reset counter: 22
Mileage: 74125 km
Date: 2013.06.27
Time: 11:45:07
Battery Volts: 14.9 V
DU
Temperature: 28.0°C
Count: 5
Steering Angle: -2.89°
Count: 1
SteerAng Init
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 F HW: 7N0 959 792 F
Component: TSG BF H02 0553
Revision: Serial number: 0000040679323
Coding: 011004208001411011
VCID: 44C49021C76C606AB9-8010
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000482257
Coding: 0024167
Part No SW: 7N5 035 186 B HW: 7N5 035 186 B
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: SEZ1Z2M4539502
Coding: 05000400040024
VCID: 3326C3FD92C2D7D210-8066
Part No SW: 7N0 907 534 HW: 7N0 907 530 AC
Component: Batt.regelung H48 1633
Coding: 030F1859
Component: J367-BDM H07 0180
Serial number: 00000000008900318226
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 G HW: 7N0 959 794 G
Component: TSG HL H03 0553
Revision: Serial number: 0000041374161
Coding: 010004200001411001
VCID: 47DE872DF65A4B725C-8012
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0553
Revision: Serial number: 0000041193446
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663519706
Coding: 0A00000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A38EED9BDA8269AD3-806E
End----------(Elapsed Time: 01:35, VBatt start/end: 12.2V/12.1V)-----------
