- Joined
- Aug 5, 2017
- Messages
- 12
- Reaction score
- 7
- Location
- Bosnia and Herzegovina
- VCDS Serial number
- C?ID=121441
hi i need help with audi q3 abs coding.
car is originaly without awd and now i fitted all parts from awd q3 audi. gearbox MKH and rear differential drive.
I need to change coding in abs, and also in rear differential.
rear differential is from q3 with automatic transmission.
and i have fault no communication with transmission.
abs have fault wrong coding when i connect rear differential.
full scan below.
full scan below.
Saturday,02,February,2019,22:25:45:48407
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8U7CR041487 License Plate: AUDIQ3
Mileage: 172670km-107292mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ8U7CR041487 Mileage: 172670km-107292miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CN HW: 03L 906 018 ES
Component: R4 2,0L EDC H25 1162
Revision: 41H25--- Serial number:
Coding: 00190012040401080000
Shop #: WSC 00049 770 00156
ASAM Dataset: EV_ECM20TDI01103L906018CN 003003
ROD: EV_ECM20TDI01103L906018CN.rod
VCID: 78F4F909C36E5C8AE5-802C
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AM HW: 5N0 614 109 AM
Component: J104 C6 450M V49C 0005
Revision: --H07--- Serial number: 00000005411909
Coding: 0050308
VCID: 76E8F731017A2AFAF7-8022
Reset counter: 156
Mileage: 172673 km
Date: 2019.02.02
Time: 00:28:40
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.25 V
Bin. Bits: 00011111
Count: 215
Hex Value: 0x0000
Reset counter: 156
Mileage: 172673 km
Date: 2019.02.02
Time: 00:28:40
Part No SW: 8U0 820 043 B HW: 8U0 820 043 B
Component: E87 Klimavoll 0050
Revision: 00H03000 Serial number: 8U0820043B
VCID: 30640129A39E44CA6D-8064
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 K HW: 8X0 907 063 K
Component: BCM PQ35 M 110 0667
Revision: AE110667
Coding: 06000A2CA805F3C0201841C02100894C53FF85AA216F912AE408878400C5
Shop #: WSC 00049 770 00009
VCID: 448C5DF9C726C86AB9-8010
Subsystem 1 - Part No SW: 8U1 955 119 HW: 8U1 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 120215 H35 0071
Serial number: 120229164159
Coding: 0047F7
Component: G397_RLFS H06 0002
Serial number: 20165783
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 F HW: 8X0 919 475
Component: PARKHILFE 4K H03 0032
Revision: 11001001 Serial number: 37001205601634
Coding: 0C0004
Shop #: WSC 00049 770 00118
ASAM Dataset: EV_EPHVA14AU21X0000 002004
ROD: EV_EPHVA14AU21X0000_002.rod
VCID: 49924CCDE80415024A-801C
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 HW: 8U0 959 655
Component: AirbagVW-AU10 H05 0410
Serial number: 003DUR016NDU
Coding: 30363132313030303030554A304C38553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 040C9DF98FA6086AF9-8050
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME70111E18ZZZT
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME29425817ZZZQ
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME1A181E18ZZZX
Serial number: 3526KSME12405817ZZZI
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME7C6C6018ZZZB
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 B HW: 5K0 953 569 H
Revision: FF010016 Serial number: 20120223300751
Coding: 1184004000
VCID: 39723C0DB8E48582DA-806C
Subsystem 1 - Part No SW: 8U0 951 528 E HW: 8U0 951 528 E
Component: E221 - MFL H09 0009
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 940 A HW: 8U0 920 940 A
Component: KOMBI_COLOUR H15 0030
Coding: 12CF00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04391
VCID: 3668373189FA6AFA37-8062
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 A HW: 8U0 907 468 A
Component: GAT 4CAN 1L M H10 0044
Revision: 1P040023 Serial number: 2341P1221481DE
Coding: FBCF0A5A000100610253
VCID: 408451E9D33ED44A9D-8014
Component: J367-BDM H07 0180
Serial number: 00000000008900987980
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 12027000187021200181
Part No SW: 0BS 907 554 D HW: 0BS 907 554 D
Component: Haldex 4Motion 4017
VCID: 47964AF53610E3725C-8012
02248 - Valve for Controlling Clutch Operating Angle (N373)
014 - Defective
Fault Status: 01101110
Reset counter: 168
Mileage: 172673 km
Date: 2019.02.02
Time: 00:27:46
Reset counter: 138
Mileage: 172673 km
Date: 2019.02.02
Time: 00:27:46
Component: IMMO H15 0030
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04108
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 D HW: 8X0 959 793 D
Component: TSG FA H09 0409
Coding: 011E02200100000000
VCID: 4E987FD1196A323A1F-801A
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.374 1002
Revision: 1AH03836 Serial number: 00120540209601
Coding: 0000258
VCID: 3C7C25197FD6B0AAC1-8068
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 D HW: 8X0 959 792 D
Component: TSG BF H09 0409
VCID: 4D9A78DD146C092266-8018
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000018606
Coding: 0025166
VCID: 3668373141FA6AFA37-8062
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 B HW: 8X0 907 357 A
Component: ****LWR12**** H02 0021
Serial number: 120223-0001-079
Coding: 1157961010022300
ROD: EV_HeadlRegulBasic.rod
VCID: 418254EDD034DD4292-8014
Part No SW: 8U0 035 183 B HW: 8U0 035 183 A
Component: RMC Cnct H52 0775
Coding: 01000600028153070023020103010000010000
VCID: 336E0E2592887FD210-8066
Subsystem 1 - Part No SW: 8U0 919 603 HW: 8U0 919 603
Component: DUBasic AU316 H41 0018
Serial number: AUZ8ZDC0600V08G
Part No SW: 8X0 959 795 A HW: 8X0 959 795 A
Component: TSG HL H06 0409
Coding: 010E02200000000000
Component: TSG HR H06 0409
End-------------------------(Elapsed Time: 02:53)--------------------------
