Results 1 to 7 of 7
Thread: Skoda Superb 3T5 camera retrofit
    Nov 2014
    Hi all,
    This is my first post, so please be gentle with me
    I've recently embarked upon a little project on my Superb Combi, namely a highline reversing camera.
    I've 'modified' the tailgate to accommodate the new parking camera/boot release unit with great success, installed the camera controller in a suitable void behind the boot trim near the offside wheel arch as well as run the cable from the boot to the RNS-510 (Columbus) unit. I've connected up the 12v, ground and CAN Hi & Lo connections as you'd expect.
    Now, I have registered the controller in the CAN gateway (6C - backup cam), and I can see its 'vitals' through the measuring blocks, the controller recognises the steering angle data, the reversing signal etc but that is where my luck runs out.
    There's very little info online about retrofitting a camera to this particular car so I have had to play it all by ear, as it were.
    These are the parts I have fitted so far:
    Camera unit: 5N0 627 566
    Camera control module: 5N0 907 441A
    The main problem I am having is not being able to change the coding on the camera controller AT ALL. It point blank refuses to accept ANY coding changes, I've tried altering the WSC/Importer figures to eliminates the 'zero number' issue but I still get error 31: out of range.
    I am wondering if I need to get a 3C Passat camera controller to replace the 5N Tiguan unit if it won't play nice with my car, or even change the CAN gateway.
    I have attached a full scan of my car as it currently stands, I'm not too concerned with the calibration error at the moment as I will look into that another day, All I want to go is get the damned thing working to start with!
    I've always overcome any issues with my 'tinkering' in the past, but I've hit a real brick wall on this one. Any help would be greatly appreciated
    Chassis Type: 3T (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 61 62
              6C 72 77
    VIN: TMBKF73T8E9015256   Mileage: 49360km-30670miles
    Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 RR    HW: 03L 906 018 MH
       Component: R4 2,0L EDC   H28 5266
       Revision: 41H28---    Serial number:
       Coding: 00190012042501080000
       Shop #: WSC 33361 790 00999
       ASAM Dataset: EV_ECM20TDI01103L906018RR 003003
       ROD: EV_ECM20TDI01103L906018RR.rod
       VCID: 0B1E10E3A2DF58790A9-805E
       Revision: 00H31001
       Coding: 863D6016092300FF610D06E9901F0092340000
       VCID: 7DFA4E3BE46B66C904D-8028
       Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
       Component: Climatronic   H19 0607
       Revision: 00001008
       Coding: 0018000003
       ROD: EV_ClimaAutoBasis_SK12.rod
       VCID: 7CFC433FF7716FC1333-8029
       Part No SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
       Component: BCM PQ35  H+  112 0771
       Revision: AF112771
       Coding: 48010AB8E86BF1C0400800C0310089EC4BF800E0732187208089E7040041
       Subsystem 1 - Part No: 3T2 955 119 B
       Component: Wischer 30061  26  0700
       Coding: 00D7B7
       Component: RLS 080713 05  54  0403
       Coding: 062BED
       Subsystem 3 - Part No: 7N0 951 171 A
       Component: DWA-Sensor 00  002 0206
    Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
       Part No SW: 5J0 919 475 B    HW: 5J0 919 475 A
       Component: PARKHILFE 4K  H11 0010
       Revision: --H11---    Serial number: 32961318501575
       Coding: 108002
       Shop #: WSC 33361 790 00085
       ASAM Dataset: EV_EPHVA14SKxxx0000 002001
       ROD: EV_EPHVA14SKxxx0000_SK46.rod
       VCID: 346CAB1F9FA16781BB3-8061
       Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
       Component: J234__LDM VW10 HI   2118
       Revision: 24019000    Serial number: 003LEPCYXU66
       Coding: 0017485
       VCID: 4280FDC71D15D93139F-8017
       Subsystem 1 - Serial number: 6332MTS680791713
       Subsystem 2 - Serial number: 6342MTS669541713
       Subsystem 3 - Serial number: 6351HTS6QIDB4CKR
       Subsystem 4 - Serial number: 6361HTS603KF2CKJ
       Subsystem 5 - Serial number: 63727TS685V95CKR
       Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
       Revision: FF010042    Serial number: 20130708300033
       Coding: 1082140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 79F25A2BF8435AE9285-802C
       Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
       Component: E221__MFL-PR6  H04 0120
       Coding: 820000
       Part No SW: 3T2 920 941 M    HW: 3T2 920 941 M
       Component: KOMBI         H06 0811
       Coding: 711E01
       ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
       VCID: 3F86F433A6E7B4D9561-806A
       Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1642
       Revision:   H58       Serial number: 200613F1002149
       Coding: 352303
       Shop #: WSC 03246 166 13427
       VCID: 7AF04527F54551F121F-802F
                000 -  -  - Intermittent
                        Mileage: 49364 km
                        Date: 2014.11.19
                        Time: 11:46:30
       Component: IMMO          H06 0811
       VCID: 6AD075678DE5E171D1F-803F
       Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
       Component: Sitzmemory    H05 3001
       Revision: 00H05000
       Coding: 00003B
       Shop #: WSC 12336 024 394758
       VCID: 37769C1386D78C999E1-8062
       Part No SW: 3T0 035 686 C    HW: 3T0 035 686 C
       Component: RNS-MID       H10 5269
       Revision: AB001001    Serial number: SKZ6Z7N5210009
       Coding: 04000402000400A11000
       VCID: 3668911781DD7591857-8063
       Subsystem 1 - Part No: 3T0 051 859 Q
       Component: EU West V10  8048
                        Reset counter: 55
                        Mileage: 49360 km
    Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H10 0415
       Coding: 011D0220DE01001000
       VCID: 52A0CD870D7549B189F-8007
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 195    3501
       Revision: 00H22000
       VCID: 39729A2B70C39AE9685-806C
    Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H10 0415
       VCID: 51A2C28B087332A9B05-8004
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Coding: 01C600003F000000
       ROD: EV_HeadlRegulVWAFSPt.rod
       VCID: 37769C138ED78C999E1-8062
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo links  H01 0003
       Coding: 8E0000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo rechts  H01 0003
       Coding: 8E0000
                        Reset counter: 55
                        Mileage: 49360 km
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1642
       Coding: 030F185A
       VCID: 71E2620BA83312A9905-8024
       Component: J367-BDM  H07 0180
       Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
       Component: TSG HL        H07 0415
       Coding: 010C00200001001000
       VCID: 50A4C78F03793BA1BFB-8005
       Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
       Component: J772__Rearview      0030
       Revision: 00H13000    Serial number: 525PA8-J399331
       Coding: 8388607
       Shop #: WSC 98765 666 38384
       VCID: 2D5ABE7BB48B3649F4D-8078
                000 -  -
                        Reset counter: 15
                000 -  -
                        Reset counter: 15
       Component: TSG HR        H07 0415
    Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
       Component: Telefon       022 0946
       Revision: --------    Serial number: 35502105026606
       Coding: 020000000100010000000001
       ASAM Dataset: EV_UHVPremi 002708
       ROD: EV_UHVPremi_SE36.rod
       VCID: 244C5B5F2F41F7012B3-8071
    End-------------------------(Elapsed Time: 03:42)--------------------------
    Nov 2014
    Bucharest Romania
    Hello, try 0000011, it is the coding from same hw from Superb after accept the coding use the VCDS help coding.
    Good luck
  3. Likes Uwe liked this post
    Nov 2014
    Hi and thanks for the reply. The controller won't accept any coding changes whatsoever. I've tried lots of different coding combinations and it always comes back with error 31: out of range. Is there a way to force the controller to take a coding change?
    Nov 2014
    Hm. I got hold of a 7n0 camera controller today and tried it. Same problem. Can't code it. always get error 31 appear. I can change adaptations and it accepts them but won't allow coding changes.
    Could it be the gateway if 5N0 and 7N0 controllers are doing the same thing? I have an AL gateway which is quite late but would there be a problem going with an even later model? Like a 7N0907530AS?
    The lead instructions stated to connect CAN Hi and Lo to the wiring loom behind the RNS-510 unit. I am guessing this is correct also?
    Please post up a screen shot of the coding screen when you get the Request out of Range. Move the message box a bit so we can see all the values please.
    Dec 2019
    Hi the issue that I encountered was solved by popping up the hood in my case it bypasses the firewall, when I did it it solved mine problem to let the car access the code programming
  8. Likes Uwe liked this post
    Quote Originally Posted by Ray67! View Post
    Yes, but I don't think this car is new enough to have that "feature"..?
