kawagatto
New Member
Good evening. I have a problem with a VW polo 6r 1200 TDI CFWA. The DPF indicator with MIL indicator light and pre-heating indicator lights up and the fault is present in ECU: " 15513-duration of regeneration of diesel particulate filter "P2458 00 (191). There are no further failures in memory, and the temperature sensors function correctly as both hot and cold indicate all three of the same temperatures. I've already replaced the differential pressure sensor for safety. Analyzing the exhaust gas temperatures I realized that never fail to sweat the 400 degrees and even the engine temperature is struggling to get to 90 degrees. My diagnosis is a broken or permeable EGR valve that lets the exhaust gas pass into the suction by compromising the temperature rise of the exhaust gases. What do you think? Sorry the bad inglese....se there are errors is the fault of Google translate!!! Hello everyone thanks
